Stair Tool - Pain Points
Uh, that is a quite comprehensive collection of all we could wish for .... 🤔
I could sign that.
I'm just a bit concerned if that all (beside the Railings) would go together
in one Tool. And so far I am quite happy with a strict parametrical approach
where you can "hard code" your inputs, opposed to a Archicad like AI Stair Tool
that looks like deciding most for you.
But that are just concerns and possibly diminish when you finally see and get
used to such options.
Maybe an addition to above said would be a Stair awareness by Slabs so that
cuts are done dynamic and automated/linked.
And of course things like Fire Stairs or Industrial Stairs on Oil Platforms that span
more than one Story, as a single controlled Object would be nice.
Edited by zoomer
  • Like 3
There are some points in where vw need to add interaction between objects. Like a windows in a wall, the same behavior should have the stairs with slabs and walls. That means: if i add a stair, the hole on slabs must be generated automatically, so like if i modify a stair, the hole follow it.
If i decide to model a specified stair in detail, the software should allowed to modify, i should be able to choose wich stair's part are connected with a specified slab compoent, even with a temporary 2D interface to detail managment.
And yes: it would be really important that users can change in 2d every single step, even if they want to draw a non sense stair (we are architects..).
Every part (construction parts, railing or external railing) must be visibile in 2D and 3D and completely edited. But not like now. Actually is too much complicated to manage the stair aspect in every form with the attribute dialog. The good way is allow to manage it like the 2d or 3d symbol parts.
I think it is essential to think of a whole new tool, please don't try to fix little parts of actually stair logic tool.
Totally agree with other points on this thread.
Edited by Zeno
On 9/15/2018 at 1:20 AM, line-weight said:
The tool needs to be flexible enough that we could model *any* of the staircases below, without having to resort to bodges and directly-modelled add-on bits that VW doesn't know are part of the stairs. I think that means full control of geometry on an individual tread and riser basis if necessary.
I'm not that bothered if the tool can't work out everything automatically for me; it would be too much to expect it to know what to do with the end of the handrail in the spiral-ended one for example; what we want is maximum flexibility in what we can model and still have understood as a staircase element.
Conceptually I don't think that a choice between concrete, timber, etc should be a starting point, and neither should 'U type' or 'L type'. That's how the current tool feels, you start off down one of these predefined paths and then try and bash it into something vaguely similar to what you want. Instead these should be nothing more than 'useful presets' or styles. The starting point should be basic geometry - top and bottom, rise and going, then you fiddle around with flights/landing combinations, something like that.
895031762_ScreenShot2018-09-15at00_05_18.thumb.jpg.1ca1d1a02d5547a256b2fe9f582669f7.jpg1097581526_ScreenShot2018-09-15at00_10_40.thumb.jpg.988d04077ff4149d1d9e7c0c002a8d22.jpg1328444812_ScreenShot2018-09-15at00_11_50.thumb.jpg.3330b55bdb05795a5ccee29725e137d8.jpg
Your first image would be awesome to do parametrically. The second and third I do manually. They are too specific/custom to have in a tool, I guess.
If we were free to model each tread, riser, balustrade segment, etc directly with whatever solid form we liked, I don't see why either couldn't be 'parametric' even if all that the tool really supplied us with was a definition of heights at top and bottom, going length, and number of risers. So, taking the second one you'd model each tread individually but they would be attached to that basic geometry. This would allow VW to understand the object as a 'stair' but also, it would mean that if, say, the difference between floor levels was adjusted slightly, then a situation where each riser needed to be extended by 20mm could be achieved instantly without any redrawing. For a non-parametric object that kind of thing can be very tedious and time-consuming to adjust (and inevitably it then gets reverted back to the original at some point later in the design process!)
  • Like 4
Wow, if that could be achieved! I now hold my students from using the tool, since it seems counter productive the way it collects all parameters, but your suggestions would help explaining it to them in a clearer way!
Thanks for this initiative VW( @Jim Wilson). Agree with everything already said.
I'd add +100 to the LOD comment. That would be awesome to able to start with a basic stair and the ability to built upon that later(parametrically) if needed.
On 9/15/2018 at 9:57 AM, zoomer said:
So something like the Basic Editing Mode that German Windows have.
You can set them up quickly and increase LOD and Features at any
point later.
We need more detailed stair to landing connections. Best as with editable solids an adjustable 2D basic form. At the moment I don't use the stair tool at all. It has very strange mesh geometry, it is very complicated to adjust everything, you are limited with textures, there is no possibility to apply a levelling layer (plaster) to the bottom view. Basically, it is easier to build a staircase out of editable solids. Because I need them more detailed later than is possible with the current tool, I build them from solids already in the pre-project phase.
Here is an example of the stair to landing connections of our 1:50 plans:
staircase bearing.pdf
All of the above.
It would be great if somehow a 'follow me' type tool could be implemented for stairs. This would be especially great with any curved spaces. I'm imagining a polygon as the object the stair follows, with straight segments and curved segments wherever the user wants them.
The tool would guide the staircase to essentially follow the drawn object, ensuring a minimum tread depth occurs, and widening treads where curves occur. Once its got the geometry of the curve/stepped wall/whatever correct in 2D plan, you can then worry about adjusting heights of treads and numbers of stairs etc. Once this is dealt with, some way to customise treads either as a group, or individually (with a 'reset' button incase we screw things up..).
I've not loaded 2019 yet, but I'm totally from Missouri on this tool. I check out each iteration but gave up on it years ago & only model stairs as a 3D symbol. If the stair needs to change I basically scrap the symbol & start from scratch. I see the need for the tool but there are just some things that are too complex for a tool. My feeling on the start tool can be summed up with this  Jack Handy quote: "If you ever drop your keys into a river of molten lava, let 'em go, because man, they're gone".
Stairs that transition from open treads to closed treads such as the very simple residential stair in the attached image are nearly impossible within a single stair object.  The Custom Stair tool allowed me to get close by configuring a landing at the transition point but that didn't work very well.
-  What we need to achieve this is the ability to have two independent straight runs of stairs with the ability to 'offset' the centerline of one run in order to get the desired alignment on one side despite the different tread widths.
- We would also need to control the side tread extensions per run depending on the open vs closed condition on each run.  Independent left and right side controls.
- Give us the option to wrap the nosing controls to the side of the treads in open tread conditions.  Independent controls for left and right sides and by stair run.
- We should be able to align the stringers that are created as part of each of the two runs of stairs...which should be possible with independent control of the tread extensions.
- There should be a distinction between the rough frame stringer object and the exposed open stringer trim you see in this photo.  The PIO should be able to make both with each located at the desired offset.
If a tread extension was desired just at the first tread or two...this could be achieved with a series of short stair runs in direct succession.
We don't often create finished interior stair images so we use the Custom Tool to get what we need for plans and building sections.  Anything beyond that is custom built 3D.
Edited by Joe-SA
Here are my ten cents:
This applies to small and midsize public buildings, where the stairs are mostly simple in geometry.
1.       Stability and predictability. Currently the stair object sometimes generates ghost stair shapes to another layer and is, in general, very buggy.
2.       Clarity. It is currently difficult to exactly decipher which settings affect which geometry and how, until one exits the dialog window.
3.       The lock settings should work more reliably, currently it’s a bit difficult to predict what happens after a particular lock. The other tabs don’t always update as they should.
4.       There are error messages with no apparent solution offered.
5.       Stair run/rise is the usual starting point. The rise cannot change within a stair flight, also the run should remain constant unless the stair is winding around a curved landing. Usually the architect knows beforehand what the elevation difference between the stories is, what kind of rise/run is possible for a stair of that particular usage situation (normal/egress etc.) use, and this with the available space determines the resulting size and configuration of the rest of the stair.
6.       Ability to lock top and bottom z, as suggested in this thread. For an architect, it is very important to remain confident that all kinds of elevation values stay put. Currently this can be affected too easily.
7.       Ability to lock bottom step vertical edge and (2nd) top vertical edge location. Most often we know beforehand, how much space there is for a stair available.
8.       Ability to separately input and lock landing dimensions. The landings usually must be of certain size to allow for stretcher use. There are also other regulations regarding landing sizes.
9.       Ability to adjust multiple line types/thicknesses at once. Now they have to be picked one by one, AFAIK.
10.   Stair step/landing elevation display would be nice option, easy to check landing heights etc.
11.   Railings: Currently these are almost unusable. Railings are laborious to draw by hand, therefore a proper geometry would allow for generation sections/elevation views of the railings. Currently the railings jump vertically at a landing, a condition never seen in real life. Also the abovementioned issues with geometry.
12.   Railings: The architect is interested in the top/bottom heights of the railings, and in the spaces left between the posts and possibly between the stair and the railing. There are regulations for the maximum space between the posts, vertical distance between open steps, “holes” between the railing construction and the step. All these should be lockable and editable. The regulations vary by country. Eg. horizontal divisions that allow climbing are not allowed in some countries.
13.   Perhaps a possibility to use custom geometry for the railing profile as in extrude along path.
14.   Ability to easily control what is shown above and below the break line, the current method is almost there but I’ve had difficulties with railing visibility setting regarding the break line.
15.   Ability to add “friction” strips on steps, or visual cues for the visually challenged. Perhaps by a custom symbol or geometry.
16.   Circular stairs: Currently the structure options are way too limiting, as are the 2D graphics. The circular stairs are mighty difficult to control as it is. There are regulations as to the minimum run at a certain distance from the inner edge, also for another distance at the inner edge, eg. 900mm. The stair minimum width is calculated from this inner minimum run, not from the inner edge. Additionally, the inner edge must not be zero. These regulations vary by country. Therefore; to be able to set minimum runs at least two different distances from the inner edge and display these for building permit approval.
17.   Separate central column controls and outer structure (eg. cage) controls. Ability to get rid of structure beneath the steps if the stair is supported from the centre and the outer ring.
18.   Ability to stretch individual steps in plan, if desired. Perhaps also solid operations as suggested.
19.   Ability to produce all necessary drawings for the stair by using current elevation/projection/plan views.
20.   Ability to get rid of the top/bottom structural joinings if necessary; Often the architect draws a solid stair solidly connecting to the top/bottom floor, then the construction bid winner selects a prefabricated stair fitting to the particular dimensions and the engineer makes a detail drawing of the connection suitable for that particular manufacturer’s stair.
21.   Stairs spanning multiple stories. This really is a must.
  • Like 4
No need to add any more... seems everyone has all my wishes covered.
However, one point from the last entry... the custom geometry for the railing profile as in extrude along path.  This needs to be an option in multiple tools.  Most significantly, the door and window trim options.  As of now, we can add trim to the doors/windows, but it is a simple rectangle with no options to add a backband or other profile.  While we can always add it as an extrude along path, can it not be included in the door/window trim options?  Seems like a simple path can already be defined in the door/window, and give us the option to extrude a profile of our choice.
Jim, maybe another thread for these tools is appropriate.  Your original thread mentioned Chief Architect's stair tool.  Check out their door/window tool also, as this option to add a profile is available also.
  • Like 3
As well as being stable and providing good presentation control the biggest thing for me is that the tool has to be a DESIGN tool. It has to be quick and easy to edit/customise the stair. Keeping the tool interface simple and intuitive is important. The current stair tool is so overwhelmingly complicated that you need to take a deep breath before delving into it.
I like the suggestion of being able to choose between different complexity level modes in the tool so that it can be used as a basic "sketch" design mode so that general layout and headroom etc can be quickly checked/modified, then a "developed" design level mode of complexity so that the styling and look of the stair can be customised, then a "detail" design level of complexity so that all the finer details can be incorporated.
This process of sketch through to detail design would reflect how an architect actually works. Many concepts are quick and sketchy and only need the first two modes.
  • 1 month later...
I have stopped relying on this tool and use a website (uk based) for designing the stairs and is so easy that even offers a good 3D visualiser. The simplicity of this website is in giving values when we set the floor height that then will generate accordingly the design that we will see in Plan and then in 3D, we can then add accessories and so on.
I would suggest on trying to contact these people and see how they've built this tool and use similar features.
Also i would suggest a better "rules" management on the stair, as i've setup the UK Building regulations in the stair tool and i never know if it's actually using it or not.
The possibility to actually change the drawing shape of the geometry offered by the tool, the existing one is just impossible to work with.
I hope this helps and let's improve the stair tool!
I've attached the stair tool vs the website i've mentioned and it's the exact same values and the geometry created is nothing alike. (the stair values in vectorworks are rounded up, but are the same)
Edited by FBernardo
adding the stair details on the website
  • Like 3
I pretty much agree with everything else on this long list.
Sadly, I wish we could turn off the construction tab entirely for the stairs.  That way I could use the tool for general building layout purposes only tread thickness and floor to floor.  As currently implemented, the handrails and construction settings are so inflexible and architecturally incorrect as to be completely not useful.
On my wishlist:
  • Stringers that can use architectural and structural metal shapes/profiles or at least a custom profiles, as it was in the legacy custom stair tool.  Why did the channel stringer option go away in the "improved" stair tool?
  • Pickets, balusters, and handrails should have an option to link to metal profiles as well.  Steel tube sizes.  Aluminum extrusion profiles.  Make sure to include aluminum profiles with have square edges.  Not to mention decorative extrusions. Or custom turned wood profiles.
  • Tread material customization.  The other day I was searching for grating or checker plate treads, to no avail in the texture library.  Many times treads are made out of a different material such as wood, or precast.  Each with their own attachment requirements.
  • Ability to customize the risers with angles, mesh, infill materials.
  • Newell posts.
  • Panels that incorporate mesh.  Sure this could be a texture.  But meshes require exterior supporting structure.
  • Railings that can be made out of cable or rod rigging.
  • Custom nosing profiles, again this was in the custom stair tool and it was never put back into the revised stair tool.
Or if we can't build this any of this into the program, we need to attach 2d view options to each of the 3d elevation and section components so that it can be accurately represented in 2d.
  • Like 4
