Kees W Posted November 4, 2022 Share Posted November 4, 2022 On 10/31/2022 at 5:25 PM, Dave Donley said: Hello @Kees W Redshift is included with Vectorworks and is used when rendering in Redshift or in Renderworks render modes, which is often. The first time this is done there is long pause (can be minutes). After that the application works normally. It happens again with every new Vectorworks session, it doesn't go away with new sessions. Ah, I understand thanks. Found it in the RenderWorks style settings. A little Off topic, but it doesn't work for me, it throws up an error "Redshift cannot operate with less than 128Mb of free VRAM. Aborting the render" I have an older 4GB Vega Pro card in an Intel MacBook Pro, so that message seems strange, but I'll assume it needs newer hardware (VW2023 SP1) Would that mean the issue would not occur for me in Ventura. (this is mostly out of curiosity, I'm not updating yet. The comment about pre-compiled shaders missing from the new OS also sparked my interest. If this is the issue, shouldn't the issue occur in VW2022 also? Again, out of curiosity. Quote Link to comment
zeno Posted November 4, 2022 Share Posted November 4, 2022 Are there some other issues out of renderings, actually? Quote Link to comment
Wesley Burrows Posted November 10, 2022 Share Posted November 10, 2022 (edited) FYI, Maxon released updates to Cinema 4 and Redshift that have solved the shaders compiling issue for me in Cinema 4D on Ventura 13.1 beta 2. I assume Vectorworks won't be too far behind with an update. Other than that 2023 SP1 on Ventura 13.1 beta 2 is running great for me. Edited November 10, 2022 by Wesley Burrows 4 Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted November 10, 2022 Vectorworks, Inc Employee Share Posted November 10, 2022 Thanks for the info @Wesley Burrows we will be updating the Redshift plugin included with Vectorworks ASAP. 3 Quote Link to comment
GatRed Posted November 22, 2022 Share Posted November 22, 2022 @Dave DonleyIs Vectorworks 2023 SP2 fully compatible with Ventura ? (including this Redshift plugin). Quote Link to comment
zoomer Posted November 22, 2022 Share Posted November 22, 2022 When I read the release notes, it reads like it is. 1 Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted November 22, 2022 Vectorworks, Inc Employee Share Posted November 22, 2022 4 hours ago, GatRed said: @Dave DonleyIs Vectorworks 2023 SP2 fully compatible with Ventura ? (including this Redshift plugin). We are adding something like the following to the Ventura compatibility page linked above: Vectorworks 2023 SP2 - Vectorworks is fully compatible with Ventura. Known issues: Redshift GPU rendering shows a long pause when used for the first time in each session, then proceeds normally thereafter. Redshift GPU is enabled on high-performance GPUs such as M-series and Intel AMD 5600/5800. This problem will be corrected in a future Service Pack. 2 Quote Link to comment
geo44rey Posted November 23, 2022 Share Posted November 23, 2022 Thanks for the update! My MBPro running 2023.1 hung on printing (elevation hidden line rendering I assume?) and various mystery stuff, and this 2023.2 patch has (for now!) cleared that up. 2019 MBPro 2.3 GHz 8-Core Intel Core i9 Radeon Pro Vega 20 4 GB Intel UHD Graphics 630 1536 MB 32 GB 2400 MHz DDR4 1 Quote Link to comment
zeno Posted December 12, 2022 Share Posted December 12, 2022 (edited) Good morning I would like to report an important BUG for CW windows. By copying and pasting the same window, they change the size. Trying the file on Big Sur DOES NOT HAPPEN. I'm about to try on windows. CW windws VENTURA.MP4 PS: Maybe it's a matter of SP2 and not the operating system. I’m testing PS2: it’s a regression from SP1. Tested on monterey, win11 and Ventura @Stephan Moenninghoff can we talk with someone? PS2: VB-192280 created Edited December 12, 2022 by zeno 1 Quote Link to comment
Mark Aceto Posted December 30, 2022 Share Posted December 30, 2022 Wast thinking about upgrading sooner than usual, and just read about an issue with a USB-C to DP external display connection. Is anyone here connecting their 4K monitor that way? Any issues with full screen native resolution or otherwise? Quote Link to comment
zeno Posted December 31, 2022 Share Posted December 31, 2022 13 hours ago, Mark Aceto said: Wast thinking about upgrading sooner than usual, and just read about an issue with a USB-C to DP external display connection. Is anyone here connecting their 4K monitor that way? Any issues with full screen native resolution or otherwise? Hello. What do you mean by DP? I have a 43 and I have no problems Quote Link to comment
Mark Aceto Posted December 31, 2022 Share Posted December 31, 2022 5 hours ago, zeno said: Hello. What do you mean by DP? I have a 43 and I have no problems USB-C to DisplayPort cable. Quote Link to comment
Edgar I Arana J Posted February 15 Share Posted February 15 Hi, I ask for your help, I have the following problem, I purchased a MacBook Pro computer with an M2 processor, OS Ventura and installed VectorWorks 2023. Copy several works files to a USB device that I have done in VectorWorks 2021, 2022 and 2023 in Windows 10 and 11 and when I connect the USB to the MacBook several of the files are not displayed so I cannot copy them to this computer. I do not understand why some files are displayed and can be copied and others are not displayed and cannot be copied, do you have any idea why this happens with the VectorWorks files? Quote Link to comment
Pat Stanford Posted February 15 Share Posted February 15 Are the files on the USB drive when you connect it back to the Windows machine? Or to a different Mac? If not, it is possible that the files did not get copied to the drive. If they do show on a different machine are the file sizes correct? Quote Link to comment
FBernardo Posted February 15 Share Posted February 15 9 hours ago, Edgar I Arana J said: Hi, I ask for your help, I have the following problem, I purchased a MacBook Pro computer with an M2 processor, OS Ventura and installed VectorWorks 2023. Copy several works files to a USB device that I have done in VectorWorks 2021, 2022 and 2023 in Windows 10 and 11 and when I connect the USB to the MacBook several of the files are not displayed so I cannot copy them to this computer. I do not understand why some files are displayed and can be copied and others are not displayed and cannot be copied, do you have any idea why this happens with the VectorWorks files? Hi Edgar, I would be careful on the way you use USBs between Windows and MacOS, Windows is moving from NTFS to another system and MacOS has usually the FAT32 system, if you ensure the USB is using only FAT32 you shouldn't have issues but this means that files bigger than 4gb will be problematic. Although in relation to your files, I can't say I would verify the USB stick on another laptop to check if everything is there as Pat said above, and when unplugging from the Mac ensure you use the "Exit" feature to disconnect the USB stick as this might create problems in the USB. Quote Link to comment
Edgar I Arana J Posted February 15 Share Posted February 15 hace 15 horas, Pat Stanford dijo: Are the files on the USB drive when you connect it back to the Windows machine? Or to a different Mac? If not, it is possible that the files did not get copied to the drive. If they do show on a different machine are the file sizes correct? The files I copy from the Windows computer to a USB I remove the device following the proper procedure and connect it to the Macbook computer, when the computer recognizes the device I proceed to view the contents of the device and this is when several of the files are not listed along with the other files that are listed. Quote Link to comment
Edgar I Arana J Posted February 15 Share Posted February 15 hace 9 horas, FBernardo dijo: Hi Edgar, I would be careful on the way you use USBs between Windows and MacOS, Windows is moving from NTFS to another system and MacOS has usually the FAT32 system, if you ensure the USB is using only FAT32 you shouldn't have issues but this means that files bigger than 4gb will be problematic. Although in relation to your files, I can't say I would verify the USB stick on another laptop to check if everything is there as Pat said above, and when unplugging from the Mac ensure you use the "Exit" feature to disconnect the USB stick as this might create problems in the USB. The USB stick is formatted FAT32 and the files I can't see on Macbook computer are less than 1 gb. The removal of the USB from the MacBook I do with the procedure indicated. 1 Quote Link to comment
FBernardo Posted February 15 Share Posted February 15 1 hour ago, Edgar I Arana J said: The USB stick is formatted FAT32 and the files I can't see on Macbook computer are less than 1 gb. The removal of the USB from the MacBook I do with the procedure indicated. Would it be possible to test out in a different machine with Windows before going to the macOS to see if the files are there ? Quote Link to comment
Edgar I Arana J Posted February 16 Share Posted February 16 hace 4 horas, FBernardo dijo: Would it be possible to test out in a different machine with Windows before going to the macOS to see if the files are there ? On another Windows computer all files contained in the usb if they can be viewed without any problem. On the MacBook is where only some files are displayed and others are not seen. Format a usb on xFat-formatted MacBook computer and move the usb to Windows computer and copy the files to and then plug the usb into the MacBook and the same does not display all files only a few. Quote Link to comment
Pat Stanford Posted February 16 Share Posted February 16 Sounds like an Apple problem, not a Vectorworks problem. Have you tried with any other types of files besides vwx? If you load the drive up with PDFs do they all show on the Mac? Quote Link to comment
Your Name Here Posted February 16 Share Posted February 16 14 minutes ago, Pat Stanford said: Sounds like an Apple problem, not a Vectorworks problem. Have you tried with any other types of files besides vwx? If you load the drive up with PDFs do they all show on the Mac? Agreed. It almost sounds like an old school hard drive indexing problem. Or the beginnings of a very bad day. unrelated… A firm I was working with last year actually had a high end RAID array fail due to incompatibility between the M1 processor and SoftRAID running in certain modes. Point being you never know why these problems happen until it is too late. 1 Quote Link to comment
Edgar I Arana J Posted February 21 Share Posted February 21 En 15/2/2023 a las 22:45, Pat Stanford dijo: Sounds like an Apple problem, not a Vectorworks problem. Have you tried with any other types of files besides vwx? If you load the drive up with PDFs do they all show on the Mac? Test on another Apple computer and the same thing happens, the files are not seen, so the problem is on the Vectorworks not on Apple. I have versions 2021, 2022 and 2023 Quote Link to comment
Pat Stanford Posted February 22 Share Posted February 22 So let's start from the top. 1. You put files onto a FAT32 formatted USB drive on a Windows 10 or 11 machine. Question - How did you do this? Windows Explorer or save from VW? 2. Have you tried to access the USB drive on a different Windows machine? Question - Are all the files seem on Windows? 3. You put the USB drive in a Mac and don't see all the files. Question - How are you doing this Finder? Or trying to open in VW? 4. You tried on a second Mac. Questions - Did you see the same result on the second Mac? Same files missing? Or is everything seen? Suggestions: 1. Try a different USB Drive. 2. Use Windows Explorer to store the files on the USB drive. 3. Use Finder to copy the files off the USB drive onto the local disk. 1 Quote Link to comment
Edgar I Arana J Posted February 26 Share Posted February 26 En 21/2/2023 a las 18:28, Pat Stanford dijo: 1. You put files onto a FAT32 formatted USB drive on a Windows 10 or 11 machine. Question - How did you do this? Windows Explorer or save from VW? 2. Have you tried to access the USB drive on a different Windows machine? Question - Are all the files seem on Windows? 3. You put the USB drive in a Mac and don't see all the files. Question - How are you doing this Finder? Or trying to open in VW? 4. You tried on a second Mac. Questions - Did you see the same result on the second Mac? Same files missing? Or is everything seen? 1. I have put the files in USB formatted with Fat32 and ExFat and formatted them with windows explorer. I use Windows 11. 2. I have put the USB on different computers with Windows 10 and 11 and in all you see the files. 3. When you put the USB on Mac not all files are seen. Out of 33, only 18 are seen. I visualize them with Finder and I have also tried with VW as they are not seen. On Mac I installed Windows 11 and I wanted to view them from Windows Explorer and you can not see them all either. 4. I put the USB on another Mac (IMac 2010) and the result is the same only some files are seen and others not. I appreciate your interest. The VW versions I have are licensed Quote Link to comment
Pat Stanford Posted February 26 Share Posted February 26 Since the files don't show in the finder on multiple Macs that tell me that it is an Apple (or Microsoft) problem, not a Vectorworks problem. If the Finder can't see them, there is no way that Vectorworks will be able to see them as Vectorworks uses the same function calls as the Finder to access files. Is there anything similar about the files that are not showing? Are they all big? or small? Actually it just occurred to me that it is probably a file naming problem. Try and rename the files with no special characters. Use ONLY A-Z, a-z, 0-9, dash (-) and underscore (_). Those characters are definitely compatible across both operating systems. If you have other characters with diacritical marks or slashes, colons, backslashes, $, %, ^, & #,@ those could all possibly be problems. Good luck. 1 Quote Link to comment
