Tom Klaber Posted February 19, 2023 Share Posted February 19, 2023 How would one go about creating an elliptical stair in Vectorworks? Quote Link to comment
Jeff Prince Posted February 19, 2023 Share Posted February 19, 2023 I believe you would have to model it like you build one in real life. I’ve seen framing examples online before, they are very gorgeous. Quote Link to comment
Tom W. Posted February 19, 2023 Share Posted February 19, 2023 There is an elliptical stair configuration with the legacy Custom Stair tooL: 1 Quote Link to comment
markdd Posted February 19, 2023 Share Posted February 19, 2023 If you want to model it from scratch, then I would have thought that the Helix Spiral command is the place to start. Equal Top and Bottom Radius. Ungroup it so it is just a NURBS curve. then Place it inside a group. Stretch the Group to the Elipse that you need using the Group control points, then start modelling the treads..... I know nothing about how an eliptical staircase should be constructed, but this seems like a good place to start.... 3 Quote Link to comment
Tom Klaber Posted February 19, 2023 Author Share Posted February 19, 2023 Thanks! @vectorworks - hate to say this... but we need a BETTER STAIR TOOL! Quote Link to comment
Popular Post zoomer Posted February 19, 2023 Popular Post Share Posted February 19, 2023 Did this in 2001 in Microstation. At that time there were no Stair Tools. Kind of a nightmare. I felt with the carpenters too. But i think they somehow like such stuff and do it quite often. 5 Quote Link to comment
Tobias Kern Posted February 20, 2023 Share Posted February 20, 2023 Hi, in the Marionette library must be one from Dominique Corpartaux for such kind of stairs. Greetings Tobi Quote Link to comment
mac@stairworks Posted February 22, 2023 Share Posted February 22, 2023 Be careful using the stair tools. Curves and winders don't have a consistent run at the travel line. They're fine if code doesn't matter... Tom, if you have a plan you can P.M. me I might be able to help you. 3 Quote Link to comment
line-weight Posted May 13, 2024 Share Posted May 13, 2024 On 2/20/2023 at 12:24 PM, Tobias Kern said: Hi, in the Marionette library must be one from Dominique Corpartaux for such kind of stairs. Greetings Tobi Can anyone point me where to find this? Quote Link to comment
Benson Shaw Posted May 14, 2024 Share Posted May 14, 2024 Not marionette, but previous thread about modeling elliptical stair might also be helpful: -B Quote Link to comment
line-weight Posted May 14, 2024 Share Posted May 14, 2024 5 hours ago, Benson Shaw said: Not marionette, but previous thread about modeling elliptical stair might also be helpful: -B Thanks. Looking for something somewhat parametric at this stage though, so that I can fiddle with various options. I've ended up using the legacy "custom stair" tool which allows a sort of ellipse made up of several curved sections joined together. Rather painful to make adjustments to but better than nothing. Quote Link to comment
Gadzooks Posted May 14, 2024 Share Posted May 14, 2024 3 hours ago, line-weight said: I've ended up using the legacy "custom stair" tool Funny how the legacy stair tool is often the best way to tackle 'architectural' stairs with a bit more style. This is an older but still interesting stair being 'hand drawn' - Sorry nothing parametric about it, but once you have the 2D layout its not too much to adapt and develop to 3D https://youtu.be/aj7m40TAjco?si=NMFlsPJ1pft4W-IH Quote Link to comment
line-weight Posted May 14, 2024 Share Posted May 14, 2024 Yeah I nearly always end up modelling stairs from scratch for the detailed design ... but try to use a "close enough" parametric one at early stages. 1 Quote Link to comment
Popular Post Joe-SA Posted May 14, 2024 Popular Post Share Posted May 14, 2024 I made this one a couple of years ago using the Custom Stair tool and a series of 3 radial stair segments all in one object. There is actually a 4th straight segment making the top tread. Certainly not simple and had a major fuss factor with hard to predict results but we got very close to what we needed in the end. The structural stringers came later. Joe 5 Quote Link to comment
line-weight Posted May 14, 2024 Share Posted May 14, 2024 That's fairly much the method I've used. The limitation is that each segment has to be a whole number of treads which means that the radius can only change at points determined by whole tread-depths. This gets more problematic, the sharper the radius is. That aside though, it doesn't work too badly. Quote Link to comment
VIRTUALENVIRONS Posted May 15, 2024 Share Posted May 15, 2024 Not something that VW's does easily Quote Link to comment
