Wes Gardner 328 Posted January 2, 2020 Hi All, There's been alot of discussion regarding the Data Tag Tool since its introduction in 2019. Several folks have built some pretty cool data tags to solve their particular issue. In this thread, please post your custom tag and a brief description of how it works or any additional information that'll make it easy to use. It would be cool if we could keep this thread to JUST new/cool tags and keep any requests for "how to" or other issues in a separate thread...thanks for understanding. All industries are invited to participate. 9 Quote Share this post Link to post
Wes Gardner 328 Posted January 2, 2020 Door Dimensions on Leaf This tag gives you the ability to show the dimensions of the door leaf on/near/beside the leaf. I've updated this to include three versions. 4 Quote Share this post Link to post
Wes Gardner 328 Posted January 2, 2020 Spot Elevation for Slab This tag gives you the ability to show a spot elevation for the top of slab. It ONLY really works in plan as the actual tag is placed at "0" of the design layer that it's on. Spot Elevation for Slab.vwx 2 Quote Share this post Link to post
Wes Gardner 328 Posted January 2, 2020 @Josh Schulman, here's a simple tag that you can attach to a symbol and then give it a name and color. You can add additional fields to the Record, etc. as needed. The tag is set up to look for the field in the record called "Name". Edit the tag to see...The worksheet is set up to show the two fields called "Color" and "Name" from the Record Symbol Name.vwx 1 Quote Share this post Link to post
mike m oz 373 Posted January 3, 2020 Two custom tags for: - 2D polygon length - 2D shape area Data Tags 2D Area and Length v2020.vwx 4 Quote Share this post Link to post
milezee 80 Posted January 3, 2020 Simple numbered Data Tags Add the BOQ record to your objects or symbols, add your names, sizes finishes, place BOQ Table on your drawing, add Data Tags with or without leader, simple but effective way to create a BOM/BOQ with everything named, quantities etc, and easily identified on your drawing, hth someone 👍 Data Tags BOM Worksheet.vwx 4 Quote Share this post Link to post
Wes Gardner 328 Posted January 30, 2020 Cabinet Size tag Here's a tag that will show the size of both base and upper cabinets (without the dimension "ticks"). There are several configurations and of course, you can easily change the font size, whether or not you want a box around the data, etc. Check out the file...you'll need both the tag and the Record. The record lets you change from "B" for base to maybe "SB" for sink base, etc. (you'll find that function in the "Edit Tag Data" button in the OIP) Works on both design and sheet layers (in viewports in Annotation space) Enjoy Cabinet Tags.vwx 3 Quote Share this post Link to post
Mike Nelson 19 Posted February 1, 2020 Placed on a sheet layer viewport annotation, this Data Tag can be modified to pull standard and custom data from the Window PIO for a particular type of window schedule. Window Schedule Data Tag.vwx 14 Quote Share this post Link to post
leecalisti 30 Posted April 10, 2020 These are useful tags and tools for architects like me who don't have the time to develop these things. Thank you @Wes Gardner and others. 2 Quote Share this post Link to post
leecalisti 30 Posted April 18, 2020 (edited) I don't have a unique tag to contribute (see below), but I was thrilled to figure out how to edit them to include the data I want. I use a door key that uses the Prefix / ID Label / Suffix (probably incorrectly) I was able to edit a tag to suit my preferences. What is great about Data Tags, is they work at all scales of the VP. For instance, I like to have enlarged plans, but I have never found a way to have the ID label scale with the floor plan. Therefore, I have turned the class off with the ID Label. This also works in Sections, which is much easier than fumbling with an ID tag in 3D. That often appears backwards for me. Thankfully, this is no longer an issue! door key.vwx Edited April 18, 2020 by leecalisti 3 Quote Share this post Link to post
rDesign 473 Posted August 12, 2020 (edited) [I moved my question about Data Tags usage to THIS separate thread.] Edited August 12, 2020 by rDesign Quote Share this post Link to post
techdef 34 Posted February 23 Here's a Path of Egress tag - for your fire life safety plan(s). Use the Piping Run tool to draw the line from wherever to the Exit. Tag the pipe runs with this tool and it will label them and show the total length of the line. EgressDistance Tool.vwx 3 Quote Share this post Link to post
techdef 34 Posted February 23 Next up is a simple tag for Net Area of an object. I use this for net area calcs sheets for opening protection distance sheets. Trace all your windows on a simple elevation & then tag all. Net Opening & Area Tool.vwx 2 Quote Share this post Link to post
techdef 34 Posted February 23 Lastly, I made a few Slab Styles (included here) which are 0 thickness and only show as a border. I use these as floor slab Gridlines on their own Class. You can draw the "slab" around your building footprint and assign to the Story / Layer you want. Tag these and it will display the Story and the Elevation of the story. Very useful for keeping track of things like FF, Parapet, Ceiling Height etc... Story Grid Tool.vwx Quote Share this post Link to post
leecalisti 30 Posted February 24 @techdef I like this idea, but it concerns me to have another "thing" to keep track of in the model. I do these types of things for this reason, but if you move the actual slab or parapet, you have to remember to move this object as well. Otherwise, I like the idea. 15 hours ago, techdef said: Lastly, I made a few Slab Styles (included here) which are 0 thickness and only show as a border. I use these as floor slab Gridlines on their own Class. You can draw the "slab" around your building footprint and assign to the Story / Layer you want. Tag these and it will display the Story and the Elevation of the story. Very useful for keeping track of things like FF, Parapet, Ceiling Height etc... Story Grid Tool.vwx 478.64 kB · 0 downloads Quote Share this post Link to post
techdef 34 Posted February 24 @leecalisti, Glad you got the idea - the whole point to me is that you DONT have to move it. I usually start with these the size of my property lines, or perhaps the setback envelope. Since they're SLABS that are assigned to a level on a story, they move automatically if you change the story heights. With the tag applied to that object, it will move and auto-update too. Best of all, you can duplicate and rotate the tag so you can see them in ELEVATIONS and SECTIONS! Finally, the gridlines in 3d that auto-update! 1 Quote Share this post Link to post
