3,321 -
Reputation
1,587 SpectacularPersonal Information
Occupation
Architect
Homepage
www.rd-a.net
Location
United States
Recent Profile Visitors
17,243 profile views
I would expect that it should as well. I am shopping for a new M-series Mac with 64gb RAM and it is disheartening to read Vw2026 experiences like yours. Have you tried running Vw2025 on your MBP M4 Max to see how it runs -vs- Vw2026? Are you running multiple apps at the same time as Vw2026?
I usually click on a Midpoint to hide / show a segment, not an endpoint. Seems to be more predictable than clicking on an endpoint.
I don’t know that it is related to what you are seeing, but back in 2016 I posted about a similar issue with HL SLVPs being ‘cropped’. I haven’t seen it again recently - but it doesn’t seem like what you are seeing…
Flush valve on open side of accessible toilet
rDesign replied to Chad Hamilton HAArchs's question in Wishlist - Feature and Content Requests
If it is just a Symbol, can you not just mirror the symbol so that the flush valve is on the correct side? Mirroring it should work whether it is a 2D or 2D/3D hybrid symbol. -
A couple of years go they made VMware Fusion free for everyone including commercial users.
VM software allows you to install a 2nd OS alongside your current OS and you can switch between the two without rebooting. You have to install a virtualization app like Parallels Desktop or VMware Fusion and then use that to install the 2nd OS.
Wishlist - Paste on multiple layers
rDesign replied to Gregovitch's question in Wishlist - Feature and Content Requests
If you install that plug-in using the JNC Tools Free Manager as Jesse suggested per the following post does it still get caught by the new Vw 2026 Plug-in security? -
Other than the ideas posted here — have frequent automatic Vw file backups so that the amount of lost work is minimized.
Yes, you’ll have better control of the variables and the quality if you make a SLVP and do your rendering on a Sheet Layer.
You could try the Layer Import method outlined below. Note that it does not import Stories or Levels into the new file, so if you are using them you’ll have to recreated them in the new file — if it works.
To-do list when converting to Vectorworks 2026
rDesign replied to Christiaan's topic in General Discussion
In 2025 and earlier, I think you also need to have Architect to be able to see the Enable Cut Plane option on the DL settings. -
For further info on this new 'feature' included in Vw2026, take a look at this related thread:
Walls not displaying properly after 2026 update
rDesign replied to SGSF 42's question in Troubleshooting
Walls were changed significantly in Vw2026, there are several existing threads discussing this topic. Here’s a few relevant posts:
