Photogrammetry - who's doing it?
Tried feeding the same set of photos into the demo version of Metashape. This was just following the default workflow and accepting all the default settings (of which, there are many more to fiddle with than in Photocatch).
The demo version doesn't allow export of models so wasn't able to bring it into VW for direct capture, however this is what it gave me.
Interestingly, like the first attempt with Photocatch it seems to have made a decision to focus only on one portion of the site. I did get some kind of error message at some point in the process asking me to do something about unmatched photos, but I dismissed it and carried on. Probably with greater understanding of the software, much better results could be obtained. But at first sight, the "default" output it's given me is not obviously better than what I got out of photocatch. It seems to have more gaps and contains one very obviously completely wrong section, where a wall has become entirely detached from the building and is floating in fresh air.
1111638431_Screenshot2022-09-23at14_25_40.thumb.jpg.cf12fdad1f3c45515f125d830225a39c.jpg600467166_Screenshot2022-09-23at14_26_55.thumb.jpg.bbf2b6c87d002b2d05c3c19ca3764268.jpg
  • 1 month later...
  • 5 months later...
On 9/4/2022 at 11:59 AM, Claes Lundstrom said:
The biggest limitations when scanning objects with an iPhone, such as the Eames chair, comes on the skinny parts, for example the foot and armrests. Bigger more solid chunky objects typically works fairly ok I would say. In my example, a 250 year old chair, the seat works fine, whereas the skinny and more intricate parts fail. The problem with it is of course the combination of being skinny and having a very intricate and detailed shape.
Another disadvantage with scans in general for a symbol is that the model becomes much bigger. A good symbol should always have as few elements a possible, especially when you insert many on a bigger model. Keep it as simple as possible while maintaining a recognizable shape.
I finally had a go at this myself this afternoon. I tried the chair below with Scaniverse several times + I could tell from the preview it was useless so didn't bother taking any further. Using the Photos to 3D model feature on Nomad however was much better:
814909614_Screenshot2023-04-30at20_37_09.thumb.png.4c5da06d91f50443b21dc7c811c675c6.png
I need to try some other things with the iPad/Scaniverse + see if the results are better...
8 hours ago, jeff prince said:
Did you try the photogrammetry option in Scanniverse instead of lidar?  I have found it creates a better result than Nomad.
Thanks for the tip but I can't see a photogrammetry option within Scaniverse...?
  • 4 months later...
Hi! Thought I might as well jump one of the old threads on this topic. I recently visited a site and did 2 captures to evaluate different methods. I did a Lidar scan with Scaniverse and also did a "photos to 3D model" in Nomad, both via an iPhone. Ended up with ≈200 photos for the latter method. The nomad scan is way better in most ways but seems to drift considerably while scanning which becomes obvious when walking around an object (a house in this case). Guess this is due to the linear nature of the capture. The Photos to 3D doesn't suffer from this but rather has a molten metal kind of style to all surfaces, so they are considerably less accurate than the Lidar scan.
Has anyone got any recommendations for how to achieve better results for a project like this without calling the surveyor? A far fetched idea that came to mind would be to get an Apple Watch Ultra and hope that the higher accuracy multiband GPS would sync to connected devices and improve upon things but I guess it's unlikely? I've also got a little drone, a DJI mini 3 pro, but haven't really been able to utilize as I hoped for in these cases.
Scaniverse Lidar scan:
Nomad "molten metal", Photos to 3D:
  • Like 3
I think the idea is to conduct a number of separate scan then stitch them together in VW. Did you see this video?
I have tried a few point clouds on Scaniverse + Nomad + thought Nomad gave the better results. I was doing architectural interiors + in the end gave up. There was tons of drift if I attempted to scan several rooms at a time. I suppose I should try again doing one room at a time then stitching them all together but frankly the amount of work involved + the hit + miss nature of the exercise puts me off: what am I gaining over doing it the traditional method with pen, paper + laser measure? It's a lot easier to model from your own drawn dims. Where I need an accurate laser scan l'd prefer to get the surveyor in.
But be interested to hear from others getting better results as I'm willing to persevere. @michaelk you've been doing good stuff right?
Thanks for the input, watched the video a while back but forgot about it. I might try the stitching next time. It's valuable to get data on surrounding ground and I believe the Lidar does a good enough job there for simple jobs as long as drifting isn't becoming to much of an issue. Traditional measuring with yardstick etc. is a pain outdoors as nothing is flat/vertical/parallel asf. so some kind model is a big win there.
A few suggestions regarding Ladar scanning:
Stitching definitely helps.
Practice scanning. It's a craft and you soon learn that slow gentle movements helps.
Plan your scans so that you move the camera as little as possible.
Avoid thin object like for example shrubs and bicycles, which seldom works well.
Avoid shiny objects such as glass and cars, as reflections never works well (spray it with something dull if you have to).
Dump scans where you get weird offsets. Better to try again.
At best, you can expect an accuracy of about 1%, so don't expect miracles.
You can use it with DTM with decent results, but I suggest that you clean away obvious errors and excessive measurements. Each point may be less accurate than traditional measuring, but on the other hand you don't get thousands of measurements from traditional measuring. I have found that using a combination of traditional measuring and scans to be quite useful.
  • Like 4
Good advice thank you. I think you're right to say that you shouldn't expect to be able to rely on the results 100% like you can with a professionally scanned point cloud. It's beneficial to have some baseline dimensions to match the scans to.
It would be nice if this could be automated to some extent. For example, I imagine having some kind of reference point objects that I can place around whatever I am surveying. I take manual, accurate measurements of their relative positions, tell the photogrammetry software what these are, and it recognises them in the images and uses them to calibrate what it outputs.
That exists already in most drone photo processing softwares and pretty much every professional LiDAR processing package.  You place targets at known locations and the software adjusts accordingly.  Trick is, you need those reference targets placed precisely, otherwise you are back to square 1.
10 hours ago, Matt Overton said:
Hi All,
We have local geolocated 1m cloud files we can get from government lands agency alright for broad context of the sites we work on but they need embellishment to get visible neighbours context.
Wondering if and one has seen a system that can argument one cloud with photos or scan.
You can do that pretty easily with Metashape or contracting someone to do the combination for you if you don’t use such software frequently.
Alternatively, you could generate point clouds from your photos and then manually line them up in Vectorworks if you have some easy to identify common points.
either way, it’s going to take a bit of effort since the data you were given may not be the quality needed and could be challenging to find common alignment points.
