mjm
1,409 -
consider making a template file containing only those layers, classes, resources you actively use.
Vectorworks on MacBook M4 is only usable in clamshell mode...
mjm replied to matteoluigi's question in Troubleshooting
my MBP M1 Max, 32gB unified ram | Tahoe latest |VWX 2026 often displays great lags between click and the apparent actual acquisition of the object -
Creating Staging Symbols for use with the Inventory and Equipment list
mjm replied to adamcarree's topic in Entertainment
ouchies. -
Thank you @JustinVanHassel
Awesome offer @Pat Stanford
Yep, this happened the other day, workin along and then boom this little window popped up and was the only window which was functional: no other app could be closed, sized, no menus worked. M1 Max, 32gB unified memory. Force-quitting apps one by one did not free up enough of anything for the remainder to be functional. Freaky.
- 1 reply
- 1
Telescoping Stirrup Hangers Symbols as Side Arms
mjm replied to JustinVanHassel's topic in Entertainment
Super cool, thanks @JustinVanHassel. -
yeah naw, no stop render button in design layer only in sheet layer, which is a fantastic reason to only render anything complex on sheet layers. sry
O thanks for this @Tom W.. I've been wondering why on occasion the 2026 selection tool seems to act differently than it did yesterday, for ex.
Nicely said indeed, thank you @thinkingpencil
Burned my uh nose several times w this issue and data tags
Welp, I notice the following as of today: • the Vee window hesitates several seconds now, before sliding into view (OTG, cause now I can click on what I want without disruption) • the Vee window also appears to occupy less vertical real estate, also a relief
You know @Kevin Allen I suppose it's an ai virtual assistant. So little interest in having that shoved in my face and down my gullet w out permission. I will immediately look to find out how to turn it off.
Gosh that first one has bitten me a few times…
