DMcD Posted October 22, 2018 Share Posted October 22, 2018 Quote I have been using 2019 SP1 with success. Its not perfect, but its functional. I have been using 2019 on High Sierra OK but not on Mojave. I could not see if you stated your OS. That being said, there are some problems which were visible with 2018 which are still there but worse with 2019. The worst of these by far is the way that objects can disappear when you're trying to edit them. By this I mean that you can enter a group or symbol to edit it and either the object's control handles are not aligned with the entities in the object or the handles are visible or there's nothing visible at all and even doing a select all, shows nothing in the info pallet… yet when you exit the symbol or group, everything is back to normal. There are occasional work arounds… quitting and restarting, closing the drawing and reopening, selecting Unified View and deselecting, changing the view etc, but these work only occasionally. This is a huge time waster and the behaviour is worse with 2019 than 2018. I don't think this is a bug with the graphics card since it happens on laptops as well as desktops. So while I would not say that it's not worth upgrading to 2019 yet, I would avoid Mojave and 2019 like the plague for some time. Part of the reason for these problems is that Apple have deprecated OpenGL and it appears that VW relies fairly heavily on OpenGl and maybe have not done all the work necessary to make it fully compatible with the new OS. Yes, Apple have caused a lot of problems but not the problem of disappearing objects. D Quote Link to comment
BryanNaegele Posted October 22, 2018 Share Posted October 22, 2018 16 minutes ago, DMcD said: I have been using 2019 on High Sierra OK but not on Mojave. I could not see if you stated your OS. That being said, there are some problems which were visible with 2018 which are still there but worse with 2019. The worst of these by far is the way that objects can disappear when you're trying to edit them. By this I mean that you can enter a group or symbol to edit it and either the object's control handles are not aligned with the entities in the object or the handles are visible or there's nothing visible at all and even doing a select all, shows nothing in the info pallet… yet when you exit the symbol or group, everything is back to normal. There are occasional work arounds… quitting and restarting, closing the drawing and reopening, selecting Unified View and deselecting, changing the view etc, but these work only occasionally. This is a huge time waster and the behaviour is worse with 2019 than 2018. I don't think this is a bug with the graphics card since it happens on laptops as well as desktops. So while I would not say that it's not worth upgrading to 2019 yet, I would avoid Mojave and 2019 like the plague for some time. Part of the reason for these problems is that Apple have deprecated OpenGL and it appears that VW relies fairly heavily on OpenGl and maybe have not done all the work necessary to make it fully compatible with the new OS. Yes, Apple have caused a lot of problems but not the problem of disappearing objects. D I'm running 2019 SP1 on Mojave. I haven't noticed this issue, most of the problems I've had are minor glitches with the GUI like the black bar in the resource browser which is one of their known issues. Quote Link to comment
Christian Fekete Posted October 23, 2018 Share Posted October 23, 2018 I get that vector need to create updates regularly to sustain sales but it seems that all release now come with so much frustration and bugs that it may be wise to release less improvements but with better finished features and complete troubleshooting. It’s not fair to any of us who stand behind VW and have to spend countless hours frustrated and not able to respond to deadlines ! 2 Quote Link to comment
Sam R Posted October 23, 2018 Share Posted October 23, 2018 Are there plans to update VW 2017 to work with Mojave? Quote Link to comment
rgcn Posted October 24, 2018 Share Posted October 24, 2018 2 hours ago, Sam R said: Are there plans to update VW 2017 to work with Mojave? No. Vectorworks will only provide service packs for 2018 and 2019 to work with Mojave. Rob Quote Link to comment
Sam R Posted October 24, 2018 Share Posted October 24, 2018 Okay, thanks. Is it typical that VW drops product support after two yearly releases? Quote Link to comment
Chicago Otto Posted October 24, 2018 Share Posted October 24, 2018 Like many of us we hold off upgrading till we'er not so busy, Unfortunately I had to upgrade my Mac to Mojave to make other apps work and has slowed down VW2018 to where its almost unusable. Every Click of the mouse is a pinwheel of slowness. Please let me know if there are any solutions out there either than upgrading to 2019 or wiping the computer and installing High Sierra. Thanks Quote Link to comment
Axel Posted October 24, 2018 Share Posted October 24, 2018 Good morning, What about the users of the non-english version (f.e. German)? I have read this morning that Vectorworks was planning to release a 2018 SP5 on the 11th of December. Any chance to get a hold of Vectorworks 2019, that seems to be more or less working with Mojave, earlier? Thanks! Quote Link to comment
Nicolas Goutte Posted October 24, 2018 Share Posted October 24, 2018 (edited) 3 hours ago, Sam R said: Okay, thanks. Is it typical that VW drops product support after two yearly releases? You can check the "Vectorworks Operating System Compatibility List" for what could be considered "typical" support of operation systems. (Windows is far more stable, therefore supported back to Windows 7). Edited October 24, 2018 by Nicolas Goutte Quote Link to comment
Nicolas Goutte Posted October 24, 2018 Share Posted October 24, 2018 56 minutes ago, Axel said: Good morning, What about the users of the non-english version (f.e. German)? You should probably ask ComputerWorks. Quote Link to comment
zoomer Posted October 24, 2018 Share Posted October 24, 2018 VW 2018 Mojave patch will come "later this Fall". VW 2019 also is still not Mojave ready + there seem to be some issues which Apple has to fix too and so no timeframe given. Quote Link to comment
zoomer Posted October 24, 2018 Share Posted October 24, 2018 (edited) 7 hours ago, Sam R said: Okay, thanks. Is it typical that VW drops product support after two yearly releases? Yes. It is always the current Release, that will be released a few days before macOS update, that will get a SP1 later for current macOS compatibility (Seems SP2 in VW 2019 case) + the previous VW Version, which gets a SP for compatibility (usually SP5) (One time there wasn't an SP5 at all, but SP6 !?) All older Versions will not get any patch. Edited October 24, 2018 by zoomer Quote Link to comment
SergeB Posted October 24, 2018 Share Posted October 24, 2018 (edited) Well I am screwed! I was using VW 2016 and updated to Mojave a couple of weeks ago. I didn't work well so i tried to revert to the High Sierra and couldn't because after I upgraded to Mojave Mac told me that they had to perform a new backup, thus I lost all of my previous backup. I am stuck with Mojave. My Vectorworks was working but with some bugs. I had to be careful. Since VW told me that they will not upgrade version 2016, I just bought 2019 thinking that I might work a bit better than my version 2016. And now it is even worst. I can't see my basic tools, the only palettes i see are the attributes and snapping. All the other palettes are blank and unusable. It can't work at all now. And it is the version with SP1 included. Should I erase everything, as well as my vectorworks 2016, and restart the installation process? Thanks, *** I restarted everything and it seems to work fine **** Edited October 24, 2018 by SergeB Quote Link to comment
homework Posted October 24, 2018 Share Posted October 24, 2018 Just installed OS 10.14. Vectorworks 2016 crashes. Anyone else experiencing this issue? Quote Link to comment
zoomer Posted October 24, 2018 Share Posted October 24, 2018 Just now, homework said: Anyone else experiencing this issue? I fear everyone will experience the same, as unfortunately VW 2016 is not Mojave compatible and never will be. Mojave support will come soon but only for VW 2019, its predecessor VW 2018 and future VW Versions Quote Link to comment
DMcD Posted October 24, 2018 Share Posted October 24, 2018 Quote *** I restarted everything and it seems to work fine **** I wonder if this has something to do with your computer. We have Mojave on two Touch Bar type MacBook Pros with SP1 and Mojave. It totally fails. I also tried a downgrade to High Sierra which also fails as many have pointed out on Mac OS sites. If you actually work in VW for a living, I'd really suggest waiting to upgrade to Mojave. On the other hand, VW 2019 appears to work OK on a Mac Pro (2013). I say OK… I have had only one crash in 3 weeks but have all sorts of graphics problems which mean restarts and closing and reopening files. JC Quote Link to comment
Nikke Posted October 25, 2018 Share Posted October 25, 2018 On 10/21/2018 at 1:24 AM, Ian Graham said: Don't hold your breath. I turfed Mojave , re installed High Sierra , cost me time and money , but had to be done until this is resolved . VW was unusable and I was going mental Also re-installed High Sierra, didn't cost any real money, only my time (whole weekend) :) Quote Link to comment
zoomer Posted October 25, 2018 Share Posted October 25, 2018 WTH : Started VW 2019 SP today ... VW 2019 SP1 went back to 32 bit ? 😉 😂 Quote Link to comment
Tim Norman-Prahm Posted October 25, 2018 Share Posted October 25, 2018 So far my experience on Mojave with 2019 & SP1 is that it works in principle fine with minor graphics issues. Comp is Mac Book pro 2016 Touch Bar Would love to see last bits improved but working okay at the minute. Will update if this changes Tim 2 Quote Link to comment
creynolds2 Posted October 30, 2018 Share Posted October 30, 2018 Waiting with bated breath here! I always treat Mac OS updates with suspicion, as I think anyone with much experience of them should. As a matter of course I wait and check with forums and colleagues who are also experienced before doing anything this major to my equipment. Luckily I asked my tech manager about Mojave and he advised waiting until VW issues were solved. Expecting VW to send us all emails about potential issues is unrealistic, altho desirable! I never see any NEED to update any OS before it is truly reamed, steamed and dry cleaned... many are finding out the same thing now. Quote Link to comment
TKA Posted October 30, 2018 Share Posted October 30, 2018 so the new Mac Mini has been released, I have been waiting for this quite a while, obviously it will come with Mojave. Is there a timeline for VW to be compatible with the new OS. Alternatively, has anyone (I know nobody has an answer to that today) successfully downgraded new Mac mini to High Sierra? Quote Link to comment
mar schrammeyer Posted October 30, 2018 Share Posted October 30, 2018 (edited) Clone your existing HD to an external drive and work from that till The Day I Work on a 2017 4K imac from a Thunderbolt external drive while mI have upgraded the imac to Mojave Edited October 30, 2018 by mar schrammeyer Quote Link to comment
Jeff Cooper Posted October 31, 2018 Share Posted October 31, 2018 2 hours ago, TKA said: so the new Mac Mini has been released, I have been waiting for this quite a while, obviously it will come with Mojave. Is there a timeline for VW to be compatible with the new OS. Alternatively, has anyone (I know nobody has an answer to that today) successfully downgraded new Mac mini to High Sierra? Not likely. I posted the same question to MacRumors in hopes of a miracle, but it seems the 2018 Mini is stuck at 10.14.1 or higher. I know there has been hardware in the past I could downgrade, but I think only if it was released very soon after the OS. But a month likely gave them plenty of time to write measures into the firmware to prevent it. Thanks, Jeff Quote Link to comment
Andrew Davies Posted October 31, 2018 Share Posted October 31, 2018 Does anyone know if the updated version of Mojave (10.14.1) released yesterday has any effect on VWX 2019? still holding off upgrading. Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted October 31, 2018 Author Vectorworks, Inc Employee Share Posted October 31, 2018 14 hours ago, TKA said: so the new Mac Mini has been released, I have been waiting for this quite a while, obviously it will come with Mojave. Is there a timeline for VW to be compatible with the new OS. Alternatively, has anyone (I know nobody has an answer to that today) successfully downgraded new Mac mini to High Sierra? No date so far, however since the new Mac Mini has integrated graphics and no dedicated VRAM, it sadly still falls below the minimum system requirements. They gave it a great CPU and no decent GPU unfortunately. Quote Link to comment
