Christian Fekete
498 -
Reputation
25 GreatPersonal Information
Occupation
Residential Architect
Homepage
www.rhinebeckgreen.com
Hobbies
Organic Architecture (would like to do more)
Location
Rhinebeck, NY
Contact Info
Skype
christianfekete
Recent Profile Visitors
4,747 profile views
OPEN GL OPTIONS GREYED OUT
Christian Fekete replied to Christian Fekete's topic in General Discussion
REINSTALLED VECTORWORKS, PROBLEM RESOLVED, THANK YOU -
I cannot see the edges in open GL and I can't change the option, is there an option asking for that anywhere that i can change that?
OPENGL Shadow option not available
Christian Fekete replied to Christian Fekete's question in Troubleshooting
Previous drawings are also not showing properly anymore. I know I used a malware software to clean up my hard drive and this happened right after. Should I reinstall vectorworks to make sure? -
The option to setup OPENGL with shadows is greyed out, any reason for that? I have lights on the lighting plan 250217 30 High Wood Rd SD4.vwx
openGL rendering transparent
How did it get there? I have no plans to build on the moon yet😃 -
ahhh thank you soooo much I could not sleep over it, you’re the best -
Is there a reason why my rendering in OpenGL suddenly show up as transparent. It looks like it is only in this file. If I copy just the rafters in another file it is solid with textures but if I copy and paste the whole drawings it shows as transparent. 240819 HELMREICH WD.vwx
thank you, here it is -3BR-2BATHS WD.vwx
I have again issues with hatch alignment. These are applied to wall components (sheathing). My setup is with the world origin but it does not line up on different layers. Arrrgh
this is a 2021 VW file and I run the latest Mac OS This issue is only with this file though, not other files, could this be a file setup issue?
This is the only file (not new files) where this happens. I reduced the file to this one line and saved it with the name below to keep the file setup of the original file for troubleshooting and the issue continues here. New files do not seem to show this problem. Note: this is a 2021 VW file END OF LINE NOT SHOWING.vwx
I have used walls and doors/windows for years and I am still baffled by how to control the classes inside these. I put my walls on walls-main and the components on their own classes. Doors have their own classes like windows but I seem unable to control what I actually can hide/show out of these. Am I the only one still struggling with these?
