Site Model: Proposed + Existing Contours
Message added by Vectorworks - Admin
VB-152588 - Fix has been identified, but the issue is extensive. Expected fix version 2019 SP2. This message will be updated if this changes.
Hi All,
Tell me if I'm going crazy. I believe that in 2017 and previous versions, when I would set the 2D Display of the site model to be: "Proposed + Existing," VW would display existing contours with proposed contours overlaid. Importantly,  proposed contours would only show where the contours were actually changed by site modifiers. In other words, all existing contours that were not changing would be fully visible with the graphic style for existing contours.  See the 2017 example. Proposed Contours are in solid heavy black lines. Existing contours in dashed gray lines. This is what I want the software to do.
This feature was buggy in 2017 and before. But usually with fiddling, switching back and forth with the 2D and 3D display settings I could usually get it to display correctly.
In 2018, the site model shows all contours in the proposed graphic style underlain below all contours with the existing graphic style. In other words, you can't tell exactly where the site transitions from existing contours to proposed contours. See the screenshot. (Note: also in Proposed+Existing display mode the contours start making very odd connections (contours crossing contours) that do not show in Proposed display mode. That's another issue).
I've made a test file that displays this behavior.
Is this how VW is "supposed" to work? Did anyone else notice the change from previous versions to 2018?
Thanks,
Dillon
test contours exst prop.vwx
  • Sad 1
  • 3 weeks later...
Thanks for responding, gbland. I spoke to Dylan at tech support about this before I posted. He saw the same thing and said he would ask around but hasn't responded yet.
I have to say I'm surprised no one else has responded to this post. This seems like such a basic feature to go buggy that I would think others would be upset. Maybe other people have a different way of showing existing and proposed contours that I don't use... I wish they would share...
Dillon
  • 3 weeks later...
This is a big deal! It makes our grading plans extremely hard to read... definitely not the way civil or landscape architecture industries show the change of grade documentation... Waiting on the edge of my seat for the service pack to fix this and go back to the way it used to work correctly in previous versions.
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
Alright... still no fix. So here is my pain-in-the-butt work around. Once grades have been worked out, I copy the dtm. One dtm I set to just show existing topo. the other I set to show proposed contours but make the dtm outline the same as the limits of grading so the "proposed" changed contours stop where they are supposed to and always did before Vectorworks messed up this freakin' tool.
So when this gets fixed, I would like to request an added feature for the DTM. Please give us a pull down that we can set the units and decimal settings for the dtm just like the staking tool has. That would be awesome! That way we would not have to change the drawing units any time we wish to update the dtm labels. I like my spot elevations to have two decimal points, my dtm to not have any decimal points, but all my drawing dimensions to be in feet and inches. Just FYI.  Anybody else out there do this?
  • 1 month later...
  • 2 weeks later...
Unfortunate... old system worked well until it was "improved"... now to get drawings to look right,  I am either stuck tracing individual changed topo lines or creating a second DTM and cropping it down to the limits of grading as a current work around.  That's pretty intensive and expensive too.  Just Sayin'
  • 2 months later...
  • 2 years later...
  • 1 year later...
On 8/26/2021 at 10:13 AM, Itchy said:
Running into this now, 3 years later...
Hey Itchy,
Seperate to the comment further up, I've had it confirmed that this bug was fixed in Vectorworks 2019 Service Pack 2. If you're using VW2019SP2 or later, the symptoms you are experiencing might be different, or will (probably) be caused by something else. It's been a year since your comment about this. Is this still an issue you encounter?
Just tried this in 2023 and issue is still there. If something has been fixed maybe my issue is slightly different to the original. But when the site model is set to proposed, you would think that any existing contours should be classed as such, and only the new contours coloured as proposed?
On the existing+proposed you can see where the changes are, but graphically the existing and the existing lines that are changed are the same so not much use there. On the proposed everything is blue, so graphically on a site plan this is a waste of time, and I have to have multiple site plans set up and adjusts crops to get it to look right.
image.thumb.png.a2f9ad38c229600bb8163d34c005aba7.pngimage.thumb.png.b5b72633137a490fe910537fb182f4f0.pngimage.thumb.png.bffbe16da2051d5fb6c99219d36755e1.png
  • 1 month later...
The Post mentioned here has been deleted and the poster (not rDesign) has been marked as a Spammer. - Moderators.
@JuanP spammer in post above.
Didn’t there used to be a way on the user forum to report a post to site admin? It seems to have been removed, or I can’t find it.
Edited by Pat Stanford
Post referenced hidden as spam
I would have flagged this as Links SPAM hours ago.
But that feature went away.
On the other hand,
timeframe for editing Posts went to down to 30 minutes or so.
Which quadruples my need for additional new postings.
