BG
    376
Everything posted by BG
  1. BG
    Graphic Legend
    Thanks Julian. What is the release date for update 2? Just want to check if I need to manually re-draw the schedule or wait? Regards.
  2. BG
    Graphic Legend
    Hi After installing VW2024 Update 1, the window schedule I had drawn using a Graphic Legend seems to have an issue. The design layer that the windows are drawn at is not at '0' and has an elevation of 293900. However the graphic legend is now drawing the floor level at '0' and is also dimensioning the windows from '0' and I can't see how to make it show the floor level at the correct elevation? Attached is a PDF of what the legend used to look like plus a VW file that has this issue. Is there anyone that could spare a minute to check if there is a setting I am missing? Note, the windows are 'Windoor' objects. Thanks Graphic Legend Issue.vwx Window Schedule 2023-10-12.pdf
  3. When dragging a structural member that is pitched, the pitch changes. Being able to lock the pitch (or other values too) would be much more user friendly. I will try the tab suggestion, as this sounds good. We gave up using the structural member and went back to the framing member as it is easier to manipulate. Having a 'direction' indicator would also be helpful. Thanks
  4. I agree, this seems like a very simple tool to upgrade.
  5. Hi Does this resolve the issue? test comments.vwx
  6. Hi See attached. Windoor Window Example.vwx
  7. Try setting the offset (3) to the same thickness as the window frame member thickness. This eliminates the offset for us.
  8. Thanks, that is helpful. It is frustrating that a tool is close to being useful, just needs a bit of further development! fingers crossed before retirement, although with the state of the worlds finances, that may not be for some time yet!
  9. Yes, I agree with everything you have said. I can't believe that you can't change the length of a sloping member without it changing the pitch? We had some issues with an IFC coordination with a structural draughting company where the framing members were 'shifting' in the file transfer & we had better results with using the structural member. These were however, horizontal members so were easier to reshape. It is a pain not being able to change the length of multiple structural members in one go.
  10. Hi Did you get an answer on this? I'm using it for roof framing members, but when I change the length of the structural member, the pitch changes & I can't see how to 'fix' the pitch? Thanks
  11. Could there just be a handle available outside the viewport? This would avoid having to enter the viewport to shift the label?
  12. BG
    Graphic Legend
    Hi Tim To add my view. Yes, the elevation and plan images should align - ignoring the dimensions. Thanks Brett
  13. BG
    Graphic Legend
    Thanks Tim, much appreciated. Brett
  14. BG
    Graphic Legend
    Hi Thanks for the file example. The dimensions seem to align okay with your doors & windows. We tried using the Windoor graphic legend so wonder if there might be an issue with that?
  15. BG
    Graphic Legend
    Hi Tim File attached. Thanks Brett Graphic Legend Example.vwx
  16. BG
    Graphic Legend
    Have installed VW2023 and was keen to try the new graphic legend. Immediately noticed that if the windows have a value specified in the 'Z Off:' field, then the automatic dimensions do not align with the windows by this amount. Is there a setting to select that allows for this?
  17. When using the Title Block Border, is there a way to add a revision to multiple sheets in one step? Likewise when adding or removing Drawing Stamps, is there a way to add or remove drawing stamps on multiple sheets in one step? Thanks
  18. When using the Publish command. Be good if there was an option to only list sheets that have an 'Active' title block.
  19. When publishing drawings, is there a way to only list sheets that have an 'Active' title block border? Thanks
  20. BG
    Plumbing Schematics
    Thanks Ron We have considered using EAP, that would work, but this isn't that user friendly either and I suspect would take just as long as our current method. Would be good if there was a tool for this. Cheers
  21. Hi No, we usually add insulation in the annotations, unless it's a layer of say PIR insulation which has a hatch.
  22. This is great and also how we approach roofs. We don't use a single roof face with components, but model the individual members eg rafters, purlins, roofing, flashings etc. This makes the model accurate and also the elevations and sections don't need too much tidying up in the annotation space, if any. Would love it if the roof tool could show actual materials like tiles, and include ridge and hip flashings etc. Also the wall tool needs to show cladding/siding materials.
  23. Just wondering how others are drawing 3D plumbing schematics? We have been using the HVAC tools, but they aren't overly user friendly. They don't automatically join, the vertical ducts can't be dragged to change their height, there are no falls on the straight ducts etc etc Any improvement on this would be welcomed. Thanks
