BG
    397
Reputation
108 Spectacular
Personal Information
  • Occupation
    Architectural technician
  • Location
    New Zealand
Recent Profile Visitors
  1. When using the spelling checker, being able to select specific layers and sheets would be super useful.
  2. I never tried fitting it to a roof face, only an extrude. Good to know.
  3. Re the same start & end position, I did consider that, VW however DOES draw a complete 360 degree circle, so it is possible. And you can move it by changing the coordinates, just not any other way. No big deal, an easy thing to work around. 2 half circles work well & can also be fitted to objects, unlike the full circle.
  4. When creating or editing saved views, it would be helpful to have a search box for selecting layers and classes. This seems to be standard for most other things.
  5. This may be a user problem, but if I have a round wall with a sweep of 360 degrees, when moving the wall, it disappears. If the sweep is changed to say 358 degrees it can be moved as expected. Is this a bug?
  6. Re the adjustment of section marker lines moving viewports, we have opted to use separate section lines and then link them to the sections. Having viewports move is a pain.
  7. We have just started using VW26 Update 2. When re-positioning dimension lines, the text turns a solid black rectangle. Is this a known issue? It doesn't seem to affect workflow, but is annoying. Thanks
  8. Not being able to lock the pitch (from either end of the member) is a real issue.
  9. It would be good if there was an option to make Graphic Legends Black & White only like viewports have.
  10. Hi. I still like using screen plane objects, yet when selecting 'Enable Legacy 2D features', every time I reopen the file, I have to enable this again. This is occuring only since upgrading to VW2025. Is it meant to be this way now? It's annoying if so. Thanks
  11. We have had this happen too. Roof faces randomly disappear. Then reappear usually after restarting VW. Haven't noticed it happening with update 2, so not sure if it has been fixed?
  12. We also have an issue showing hidden line textures (cladding lines) on curved walls, where the textures do not show up.
  13. Since posting this, update 6A became available & whatever the issue was, it seems to have been fixed. What a relief, very thankful 🙂
  14. I'm having issues with a graphic legend window schedule constantly crashing. It seems to have started since VW2024 Rev6. I can't update the schedule otherwise it crashes. I have tested this on a windows machine and it's fine, so seems to be a mac issue. Attached is a small sample file. When defining the legend image, and changing the dimension settings in the annotation settings, causes VW to crash. Is this a known issue? Thanks I'm using VW2024 Rev6 on an iMac Win Sched Test File.vwx
  15. Good to hear that highlighting objects that are behind visible objects is being worked on, as we frequently have this issue.
