Gilbert Osmond Posted September 17, 2016 Share Posted September 17, 2016 (edited) I haven't yet updated to VW2017, waiting to hear how it's working for others. If you're using VW2017 already please share: Did the installation / upgrade go smoothly? How is it working w/ your v2016 and/or earlier files? Does VW2017 seem stable enough to trust your workflow to? I did already see the separate thread on Renderworks changes & related issues in VW2017. No need to recapitulate that here. Thanks! ---- EDIT: Whoops, I don't know how this was posted under "Buying & Selling LIcenses". I had meant this post to go in the General forum. Mods, if you see this please consider moving this entire thread to the main / general VW forum. Thanks. Edited September 17, 2016 by Gilbert Osmond Quote Link to comment
zoomer Posted September 17, 2016 Share Posted September 17, 2016 Installation was smooth. Workgroup Folder conversion went well, but I excluded Workspace conversion. Will do that manually from scratch as my 2016 custom Workspace was somehow ... strange. Project conversion, so far : - Renderings will look again different > changes in Specular Channel. - Slabs changed, > new features Stability : Quite strange, no crash at all so far Quote Link to comment
Kevin McAllister Posted September 17, 2016 Share Posted September 17, 2016 1 hour ago, Gilbert Osmond said: I haven't yet updated to VW2017, waiting to hear how it's working for others. If you're using VW2017 already please share: Did the installation / upgrade go smoothly? How is it working w/ your v2016 and/or earlier files? Does VW2017 seem stable enough to trust your workflow to? I did already see the separate thread on Renderworks changes & related issues in VW2017. No need to recapitulate that here. Thanks! Installation was easy. I didn't use the Migration Assistant and rebuilt my workspace from one that shipped with v2017 however. No trouble with v2016 files that I've seen. No crashes so far (in use since Tuesday evening). Its definitely more nimble... rotating into 3D from top/plan using the flyover tool doesn't have delays like it did in v2016. Two favourite unsung changes - all drawing numbers for SLVP can be edited via the OIP now / updated UI for Data Tab of the OIP. Kevin Quote Link to comment
Gilbert Osmond Posted September 17, 2016 Author Share Posted September 17, 2016 (edited) 42 minutes ago, Kevin McAllister said: Two favourite unsung changes - all drawing numbers for SLVP can be edited via the OIP now / updated UI for Data Tab of the OIP. Thanks for your all's replies so far. Is there a published *complete* list of all the little "Easter Egg" improvements that have been made? For example in another post someone mentioned that the Property Line tool underwent extensive renovation & improvements. It'd be great to see a complete list of every improvement in all the user-facing areas of Vectorworks. If JimW has access to such maybe he can post it somewhere? Such a list would help people find the little goodies that may help their personal workflow a lot, which they otherwise might not run into for weeks, months, or longer. ----- EDIT: Here's a complete list of new & improved features in VW2017 Edited September 17, 2016 by Gilbert Osmond 1 Quote Link to comment
zoomer Posted September 17, 2016 Share Posted September 17, 2016 Install 2017 in any case. Make project Copies to test first though. The complete what's new is in the online help. Very interesting. Jim linked it somwhere. Quote Link to comment
Gilbert Osmond Posted September 17, 2016 Author Share Posted September 17, 2016 17 minutes ago, zoomer said: Install 2017 in any case. The complete what's new is in the online help. Very interesting. Jim linked it somwhere. Thanks, here's a comprehensive list of new features & improvements, big & small, in VW 2017. (From the online help.) I used to be an early-adopter of everything but with age & a little patience I've seen there's really not much percentage in it for me. If a lot more people post positive experiences I may hop aboard but proably I'll just wait for SP1. Quote Link to comment
zoomer Posted September 17, 2016 Share Posted September 17, 2016 You could try the trial version to see if your project will work. For me V 2017 is the best release update ever. Quote Link to comment
Gilbert Osmond Posted September 17, 2016 Author Share Posted September 17, 2016 1 minute ago, zoomer said: You could try the trial version to see if your project will work. For me V 2017 is the best release update ever. I have VSS & access to VW2017 now, I just prefer to wait. Quote Link to comment
zoomer Posted September 17, 2016 Share Posted September 17, 2016 I wish I had your patience But is not bad to wait until SP 2 if you can. Quote Link to comment
J. Wallace Posted September 18, 2016 Share Posted September 18, 2016 I've just started playing with VW 2017 Landmark. My observations on a few files which I converted from VW 2016 files are, that they are more stable and run better. I was having some issues with two files, trouble selecting plant list worksheets in the design layer as well as some video issues (lossing color fill). So far these issues have disappeared. It should be noted that I had to upgrade my OS from OSX 10.9.5 to 10.11.6. Also what about that resource manager? What a feature. Really pleased so far, I think at this point this is the best upgrade I've witnessed. 1 Quote Link to comment
zoomer Posted September 18, 2016 Share Posted September 18, 2016 16 hours ago, Gilbert Osmond said: Does VW2017 seem stable enough to trust your workflow to? Hmmh, I see coming in first crash reports here on the forum, which seem to happen with normal usage like sending objects between layers. Had no time to test myself so far .... Quote Link to comment
rDesign Posted September 18, 2016 Share Posted September 18, 2016 23 hours ago, Gilbert Osmond said: EDIT: Whoops, I don't know how this was posted under "Buying & Selling LIcenses". I had meant this post to go in the General forum. Mods, if you see this please consider moving this entire thread to the main / general VW forum. Thanks. @JimW- can you move this thread to the 'General Discussions' forum? Thanks. Quote Link to comment
markdd Posted September 19, 2016 Share Posted September 19, 2016 My experience hasn't been quite as positive. Stability is much better and the programme seems to be "snappier", particularly the 3d wireframe and Open GL which is great. Sheet layers are still as cumbersome as ever though which is a big disappointment. The Spotlight Instrument Plug-in has seen some small and very welcome improvements in terms of reporting angles and ESP Vision compatibility , but there are bugs now where none existed regarding XY rotation of symbols and also how the Spotlight plug-in responds to classes. Some new tools have been added which are welcome additions. The big worry from the outset was that one triggered an instant crash when changing any object's layer. This was due to a plugin being corrupted for some users on installation and has been fixed for me by tech support - but all this has left me very wary. This is because (as with plug-in bugs/changes) that drawings created in 2016 and opened in 2017 now show geometry differently. In my case its the Spotlight Instrument. I have carefully looked through the list that JimW provided of the changes made to VW 2017, but I wonder if there is a more detailed list of changes that show all the more subtle tweaks? It would be good to see what has changed so that there are no surprises down the line, particularly when I start to create new projects with the software. Mark Quote Link to comment
EAlexander Posted September 19, 2016 Share Posted September 19, 2016 4 hours ago, markdd said: The big worry from the outset was that one triggered an instant crash when changing any object's layer. This was due to a plugin being corrupted for some users on installation and has been fixed for me by tech support - but all this has left me very wary. This is because (as with plug-in bugs/changes) that drawings created in 2016 and opened in 2017 now show geometry differently. In my case its the Spotlight Instrument. Mark, What was the fix for this? I submitted this bug and had correspondence with Tech support, but not fix was offered up. Thanks, e. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 19, 2016 Vectorworks, Inc Employee Share Posted September 19, 2016 6 minutes ago, EAlexander said: Mark, What was the fix for this? I submitted this bug and had correspondence with Tech support, but not fix was offered up. Thanks, e. Please contact them again referencing this thread. Quote Link to comment
markdd Posted September 19, 2016 Share Posted September 19, 2016 (edited) The fix has worked for me Edited September 19, 2016 by markdd Quote Link to comment
Jonathan RD Posted September 20, 2016 Share Posted September 20, 2016 Anyone with project sharing done the switch from 2016 to 2017 jet - Just overall experience, we're sticking to a dedicated fileserver for now.. We are very excited about the new improvements, but a bit cautious since we have experienced some bugs / problems with Project Sharing in the past.. Quote Link to comment
Kevin McAllister Posted September 21, 2016 Share Posted September 21, 2016 I might add a caveat to my initial comments - rendering seems much slower than VW2016 with the same SLVP. I'm not sure why, but the combination of Renderworks Style background and Hidden Line Foreground is substantially slower. With 26 sheets all with this type of viewport, the time I need to allow for rendering is much greater than it was. Kevin Quote Link to comment
Kevin McAllister Posted October 4, 2016 Share Posted October 4, 2016 (edited) Well, another first with VW2017. I used the uninstaller, which I've never done before. After a few weeks of working with it VW2017 developed all sorts of random quirks, the most annoying of which was hanging completely when quitting. I had to force quit after quitting every time. I'd already tried resetting my settings/preferences so I thought I would try an uninstall and re-install of a fresh copy. I don't remember ever doing a complete re-install of a VW version before. Things seem calmer again. Hopefully this time it will behave. Kevin Edited October 5, 2016 by Kevin McAllister Grammar Quote Link to comment
Dubman Posted October 4, 2016 Share Posted October 4, 2016 the install was easy, I did not migrate all file to 2017 & still have 2016 installed. I'm using 2017 on a 4 week job. So far only hassles was with the new Resource Browser. Now they want you to search for a resource instead of opening folders, but in some searches, I have locked up VW to where I had to force it to close. And when searching certain item, like Door Hardware, I get nothing, but I see the folder with the 3d hardware. Also in some searches, I get many different items that have nothing to do with my search. I find it quicker to have like items group in folders. I have been making my favorites folder with all of the line types, & objects I use a lot & just leave that folder open. Also, another small aggravating problem I'm having is being able to enter a number in feet in the Object Info Browser & floating Data Bar, I press the number key & then the foot key, the one to the left of ENTER on the key board, I get nothing, when I hit it a second time, I get what looks like an inch mark & then hit Delete/Backspace once to enter a foot dimension. It works correctly some of the time, but more often it does not. Now this works fine in VW2016 & other software. My graphics is working fine when set to Good Performance & Compatibility. Better than other settings Quote Link to comment
zoomer Posted October 4, 2016 Share Posted October 4, 2016 In real work here 3-5 crashes per day. And some problems with tools. Quote Link to comment
Taproot Posted October 5, 2016 Share Posted October 5, 2016 Migrating to 2017 was probably the easiest yet (the assistant worked and I've had a lot of practice). I still had to migrate some of my custom plugins manually to the Vectorworks plugins folder (not the User folder). They either didn't import on their own or their icons wouldn't display properly. In all but a few cases, moving the plugins solved the problem. The new features work pretty much as designed. Negatives: I'm experiencing about 3 crashes a day. I have my auto-backup set to a short interval and I habitually save before doing processor intensive operations. It's a nuisance but I haven't found it to be a real problem. There is considerable lag in opening files from 2016 or before. Perhaps a minute? That may be subjective, but it seems like a long time. The new resource browser makes common 'User Folders' workable for shared office standards and libraries. We have a fast network, but the response is sluggish. It's especially noticeable in the attributes pallet when waiting for the pop out 'resource browser' to surface. ±3 seconds (in 2016 it was instantaneous). This is undoubtedly the fault of the hardware, but it's still sub-optimal. Zooming in and out in plan view still looks blurry. It's better than it was, but from the demo - it sure looked like the 2d graphics were better than I'm experiencing. Like before, it takes a moment after zooming for the screen to pop back into focus. Positives: The docking pallets work great (mac). The resource browser is a huge leap forward. I had thought that the pop open feature would be annoying and that I would just leave it open on my second monitor. But actually, it's intuitive and works well. Older files brought forward seem to be intact without unexpected changes. I haven't found any glaring issues (like the window sills going goofy 2015>2016). The new features that I have tried are fairly mature (not half measures). Disclaimer - I have a highly customized workspace and templates that have been years in the making, so I'm loathe to start with a blank file and recreate these materials from scratch. So, crashes associated with 'legacy' items may be partly to blame. 1 Quote Link to comment
benboggs Posted October 5, 2016 Share Posted October 5, 2016 My personal experience has been pretty bad. I experience ~5 crashes per day. 2017 seems to have more difficulty handling imported files. It crashed every time I try to import a second CAD file into a drawing. The import Revit file is not a very useful tool yet. I hope this will get better as time goes on. Quote Link to comment
Tom Klaber Posted October 5, 2016 Share Posted October 5, 2016 I am have had a few crashes - but lots of weird ticks and wonkiness. Most recently with roof objects. 1 Quote Link to comment
Gilbert Osmond Posted October 5, 2016 Author Share Posted October 5, 2016 1 hour ago, benboggs said: My personal experience has been pretty bad. I experience ~5 crashes per day. 2017 seems to have more difficulty handling imported files. It crashed every time I try to import a second CAD file into a drawing. The import Revit file is not a very useful tool yet. I hope this will get better as time goes on. I also experience relatively slow imports from VW2016. ~1 minute to convert a file of moderate complexity. (Single-family home / small garden landscape.) These same files imported from VW2015 to VW2016 in probably 15 seconds or less. Once imported, however, the files are working fine, for which I am thankful. Quote Link to comment
