517 -
I'm still using this script / menu item without any glitches, so for those of you experiencing problems - consider editing the script and replacing it with new text: Navigate to the following menu: Tools>Scripts>Plug-in Manager ... "TA_Activate L+C Tool" Then click on "Edit Script" Paste: PROCEDURE ActivateLayerAndClass; VAR pt : POINT; h : HANDLE; BEGIN GetPt(pt.x,pt.y); h:=PickObject(pt.x,pt.y); IF h<>NIL THEN BEGIN NameClass(GetClass(h)); Layer (GetLName (GetLayer(h))); END; END; RUN(ActivateLayerAndClass); If you want to access a few similar tools and/or review more on this topic refer to this post:
4 x Vectorworks Architect 2023 UK Licenses for sale
Taproot replied to KJ1's topic in Buying and Selling Vectorworks Licenses
I'm curious if a VW Employee could chime in on this topic. When I spoke with the sales department last year, they told me that perpetual licenses were non-transferable. The work around being that the software could be transferred to another party, but the original owner would still be the one in their records ... That would make on-going upgrade fees complicated. It also seemed counter-intuitive. Why I am I paying thousands of euros / dollars to buy an equity stake in the software if I can't then re-sell it to someone else? I think the logic is that a perpetual license holder pays a lower annual fee. Still - this seems like a point of confusion and it would be helpful to understand just what rights are attributed to 'perpetual license' holders. -
Hello Bob Sure - Here's a link to the Custom Class thread I shared awhile back:
I saw Danny H's recent query on the Drawing Label and while I didn't know enough to answer the question, it got me thinking about this tool. I realized that after years of struggling with this tool I've finally found a workable solution. For me, the issue has been that for virtually all of my drawing titles I want to include a scale bar. And for plans, I want to include a north arrow. Prior to "object styles", I found that grouping the label, north arrow and scale bar created weirdness. Often the label wouldn't update in the OIP when selecting the viewport. If the viewport was rescaled, then the 3 objects would move around irregularly. Sometimes the North arrow would be incorrect on a (seldom used) plan. It was a chore to keep up. Solution We have created an object style for each scale that we commonly use in the drawing set: 1:240 (site), 1:96 & 1:48 (Primary Drawings) 1:12 (Details), etc... We have one style with a north arrow (plans) and one without (elevations, sections). Here's a visual example. Within the style, we can rotate the north arrow and it will change it's orientation for all similarly styled Drawing Labels. For the scale bar, we found that embedding a 'graphic scale' wouldn't work, so we exploded (ungrouped) one and then joined its geometry into a continuous polygon by adding a thin rectangle horizontally aligned to the line of the Drawing Label. If you have multiple objects, they will misbehave. The zig-zag style was selected because it works with both even and odd increments - like 1' = 50' or 1" = 30'. Below the scale text, we've included a "note" field (not shown) in the style which allows us to list overall comments like: "All objects are existing UON" Attached is an example (v.2023) if you want to reverse engineer this solution. Like many things in VW - what looks simple and straightforward actually takes a fair bit of persistence to pull off, but then it is immensely satisfying to have it work correctly. Drawing Title.vwx
Yes, I asked for this feature back in 2017 and to date it doesn't work. I became so annoyed by the lack of this essential feature that I moved all of my product scheduling out of Vectorworks into Airtable and now just ID elements on the plan but use the online database to manage the content. One would think that for a Building Information Modeling software where nearly all of the "information" is on the web, there would be better means of linking to it.
And me. As I recall lines are organized by creation order or some such that prevents them from being clearly ordered by the user.
Right clicking on a worksheet and selecting "recalculate" causes the software to crash. Recalculating while within the worksheet works fine.
You just need to add the .vsm file to the "Plugins" folder located in either your Vectorworks app folder or your User folder (depending upon how you organize your custom plugins. You'll then need to restart VW. When it starts up again, the available plugins will be refreshed. Then go to menu: Tools>Workspaces>Edit Current Workspace Select "Menus" (not Tools or Keys) On the left sidebar, flip down "All Menus" and scroll the list to the new plugin name that you want to add to your workspace. Grab it and drag it into the menu location of your choice (at right). Once there, you can assign a hot key (short cut).
Fasteners library/plug-in for Fundamentals?
Taproot replied to S4DecorDesign's topic in General Discussion
I can't speak to the plug-ins issued in each version of the software package, but one possible work around would be to use the v.9 software and create a symbol library of "exploded" fasteners. that you can use in the current version. Obviously, they would be a little less convenient to use, but if you set them to import as "groups" then you could pretty easily adjust the length of the bolt shank, etc. to meet your needs. -
Thanks Michael, That's exactly the advice I needed. I'll pass it along.
This isn't a VW specific question, but rather a Theater Lighting Question. Giving the amount of theater lighting talent here, I'm hoping you can point me in the right direction. I've designed a small gathering space for a non-profit that wants to light a speaker podium / stage with (2) frontal lights and (2) side lights. I did some quick calculations on lighting levels and our client selected a 50w LED dimmable unit for the four locations. This one. They ordered one to try it out and learned that it's DMX and too sophisticated for our ultra simple direct wired system (which is already installed). They would like to just have each light on it's own dimmable switch. Can you give me a recommendation on: Is this possible? What would be a suitable unit / dimmer combination? Thank you.
@AdamRoxby For PDF markups, I prefer PDF Expert. I have come around to using Trace as well, but find it better for design sketching.
I finally solved my Logitech mouse driver problems by downloading a 3rd party app called "SteerMouse." Here's a link to their site. It cost $20, but totally solved my driver issues and has been trouble free.
@vassen Since migrating to 2021, the rendering problem that launched this thread hasn't been a problem. As to rendering style, here's some tips: We use two lights for each elevation - one that casts shadows and one that does not. The secondary light acts as a fill light (like in photography) so they are aimed at the facade at opposing angles (from above). The four pair of lights are rotated 90° from one another so that each one will optimally light one of the cardinal directions. Each pair of lights is classed so that they can be turned on or off per elevation. We then turn on the appropriate lighting pair in each viewport so that the shadow best illuminates that facade. For schematics, we set the elevation viewport display to Open GL with the foreground set to Hidden Line with the "Certain" sketch style applied. I hope you find resolution to your slowness issues.
For me, it's in my dimension tool set. If it's gone missing, you may need to check your workspace editor and add it. It's titled "Center Line Marker Tool" if you look for it alphabetically in the tool list of the workspace editor.
