Any luck with Win Door in 2022?
KrisM
I have been looking forward to the inclusion of Win Door in 2022. So... make a wall. Click on WinDoor. Get an outline of a door and place it into a wall. Great. Got a door. Do some other stuff. Click on Win Door again. Get the Win Door options displayed at the top of the screen. So Win Door should be operational. Do not get any door outline to inset the door. Win Door basically does nothing. Try this iin a new file. I can place a few doors and then nothing. Try the Win Door ID tag tool a door already inserted. Click on the door. Click on the ID location. Door disappears in 2D. If I look in 3D, there is a door opening but no door. Opening doesn't even show in 2D. WAY TOO BUGGY! Anyone else have a functioning Win Door?
17 answers to this question
Are all the WD- classes set to visible? Windoor uses a WD-2D class for most 2D geometry and a range of other WD- classes for 3D geometry, ID tags,  ceiling lines etc.
These should all typically be set to visible except the WD-ceiling lines class which is typically off but can be used in reflected ceiling plans.
Another possibility is the cut plane settings. Their are various options for how the 2d can be displayed depending on how high the windoor object is placed in relation a determined height.
I saw these Classes first in the WinDoor Class Settings - but not in my Navigation Palette !?
And all my Edits in the WinDoor Settings Window were ignored for my Wall Inserted WinDoor.
Changes only worked by OIP Edits.
There may be lots of user errors from my side but some things don't look issue free fror me though.
Will have take a look at the Video Tutorials before further testing 🙂
Nikolay,
VW file attached, screen recording link - https://youtu.be/Nwl2oS7d5bs
In 2022, Architect workspace -
Create generic wall
Place 3 Win Door doors, get door preview, successful
Place VW door, successful
Go to place another WinDoor door, get the door preview (don't actually place the door)
Click on WinDoor ID tool, click on door, click for ID location, door disappears. Look in 3D, opening is there but no door. No door in 2D
Try to place another Win Door door. Don't get any preview of the door object.
Win 10, current update.
AMD Ryzen 7, 32GB, NVidia 2070 Super
2022 Test File WinDoor.vwx
@KrisM Thanks for the video and test file. I was able to reproduce the issue that you are seeing. The problem comes when you click with the WinDoor tool once on the drawing and then cancel the tool by pressing ESC. The problem seems to get fixed if you restart VW. We will see what is causing this and work on fixing it. Sorry for the inconvenience!
On 9/17/2021 at 7:54 PM, KrisM said:
Nikolay,
Create generic wall
- After some more testing it seems like turning on "Run scripts in developer mode" in "Vectorworks preferences" fixes this issue. You can use this workaround for now.
@Julian Carr thanks very much for that video - I would not have managed to get anything working without it.
A critical point is that you have to turn on wall closure for the individual window instance, and you have to do it via "plug in object options".
As far as I can see, this is not explained in the most obviously relevant help page:
https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Walls/Wall_closure_settings.htm
Doesn't this need to be made clear in here?
I don't really understand why I change this setting in this separate dialogue box, rather than the OIP for the window instance, which would seem more intuitive.
Also, do I have to go round every single window and change this "use wall closure" setting? I can't choose it per window style, for example?
49 minutes ago, Julian Carr said:
You can select multiple WinDoor/Window/Door instances, then right click on one on the selected objects, choose Plug-in Object Options, turn on Use Wall Closure and it will be applied to all selected objects.
Ok, thanks.
I don't understand why this can't be set by style and/or in the OIP box, but in any case I think it needs to be made clearer on the VW help page, because it says this:
2006581443_Screenshot2021-09-23at13_06_30.thumb.jpg.80ab58aac945c006f0ff5510a8a70aea.jpg
You have to read the green text very carefully to understand that you need to go to the "plug-in options" dialogue, and not to the "Wall closure" button on the OIP to get things to work:
Because that's where most people will expect to find settings that apply to a particular object.
I bet that 90% of Vectorworks users who want to try this out will spend quite some time fiddling with wall closure settings in the Wall and Window object OIPs, find that they have no effect, and give up or assume something isn't working.
