No Stories, No Problem
Guest Wes Gardner
Hello All. Thank you for providing such a comprehensive guide for transitioning from 2D to 3D BIM workflows, especially for those of us who may not be as comfortable with the concept of stories in Vectorworks. Your hands-on approach of learning by "reverse engineering" is particularly effective for understanding the practical implications of wall styles, slab styles, and offsets.
Best Regards,
Edward.
  • 6 months later...
I have a similar but far less complicated basement situation
at a sloped site.
I divided Foundations over 2 Stories,
the lower Foundations with Walls on top in between,
the upper Foundations and all Walls starting from there.
Then there is an extra non standard Foundation, so it will get
its own (Wall)Style anyway and so it can also get its own Level.
Everything else that does not match gets local overwriting in OIP.
In your case it is a bit difficult.
Generally it looks more like custom modeling with Solids.
For IFC's sake you may want to put it on a Story and use VW Walls
or just tag it manually.
You can use a non level bound Wall Style for foundations and base
Walls. But you can also add 30+ of your Levels to assign them manually
to Walls in OIP, in case this can help organizing your modeling.
I did so in some cases where I had not enough data of existing and
had to correct some of the levels later over time when modeling.
This was quite handy as when you adapt such a Level, all related bound
Walls will update automatically.
On 1/2/2024 at 3:44 PM, line-weight said:
If not, just put everything in one storey. Then you don't need to worry about storey elevations. Just have a zero datum for the whole thing & relate all your levels to that.
If you're doing that why use Stories at all?  Take a look at the original post in this thread to see the No Story workflow.
A Story is mandatory to have access to  Story Levels.
And with Levels you can add some useful parametric control
to make later changes easier.
OK, VW's Story Level Settings Design is the worst of all option available
to make later changes in Levels any comfortable ...
But the more a project tends to go from completely chaotic to more
boring standardized and more changes/adaptions while design
expected, there comes a point where the unnecessary tedious
Story/Level setup starts to bring an advantage.
I basically like Story/Levels or parametric in Arch Modeling in general,
so I set them up wherever possible, even when renouncing of it would
likely be a bit faster at the end.
But it always depends on the special project and is a personal preference.
Like Zoomer says, it's mainly about accessing Levels.
The parametric possibilities are one reason, but also the ability to have reference levels that I can use to create elevation benchmarks on elevations/section viewports. Even if I never really change the levels, I find them very useful for making sure everything is in the right place. It's a visual check that things are at the correct height relative to things like finished floor levels, and is also useful when I have "existing" vs "proposed" and need to match a height somewhere. I like that the elevation benchmarks will always be correct automatically. Similar to grid lines in plan views.
  • Like 4
@zoomer I understand the use of Stories, but in the particular instance referred to in the suggestion:
it doesn't seem like there's any benefit to using them.  If you have a building with multiple floor levels + foundation, can you get any benefit from setting Story Levels, and if so is the benefit worth the added complications?
I think Assigning (multiple Stories is the easiest thing and applicable in 98% of buildings.
Just @digitalcarbon screenshot looked a bit like it may either not have further Stories
or if that these may look similar chaotic.
So in the 2% where Stories may not help, I think @line-weight  proposed to use
a single Story anyway to have access to Levels.
Sometimes it is, sometimes it may not.
E.g. if you just have a singly Story defined - you do not need "default" Levels.
You can assign Levels directly to Story and don't get the mess when changing
Level Zs afterwards.
I dont' use Stories or Levels. Can those of you who do please comment on if there is any benefit to using them if you are not using Walls and PIOs that can automatically associate with the levels?
If I am only using modeled solids that won't automatically adjust when I change levels is there any benefit for me?
So far only PIOs and Symbols can make use of Levels ....
For mainly custom Solids geometry, Story/Levels are indeed useless.
If you are doing BIM with mainly sophisticated stylized Level bound PIOs
on Component Level, maybe similar repeating projects,
VW Story/Levels, once pre set, can be a great help and time saver.
But working the old school, less abstract, pre-Story/Level way,
with Layer and Layer Wall Heights,
in many cases may not be much less effective.
It is more a preference of how you like to work.
Since manual height overwriting in OIP works reliably in VW and
is needed in both cases.
Similar to Stair Tool, some hate it in general for its abstraction, complexity
and on the other hand its limitations and prefer to model a Stair manually.
I like to set up a Stair Style parametrically and reuse it,
but get annoyed when it can't make it look the way I want.
Edited by zoomer
As l said above, the ability to use elevation benchmarks is benefit enough for me. Even if no objects are actually associated with them.
I no longer need to have the bit of paper stuck next to the screen with a project's significant levels written on it.
Part of the attraction for me is that I don't really like giving layers elevations, because I like to be able to paste-in-place between different building storeys. Having a single storey with a number of important/useful "levels" proves to be a good way of keeping Z values organised and recorded. For me and the kind of projects I do.
I find it quite satisfying/reassuring when I can make, say, a steelwork setting-out drawing and with a couple of clicks have things like finished floor levels, or top-of-steel levels, or whatever appear in the right locations in viewports.
  • Like 4
  • 3 months later...
I'm just getting started on 3d after a long time using only 2d.  Are the slab setting under organization/stories referring to the same slab as drawn with the slab tool?  For example, I'm starting from the template file which has stories set up with 1' slabs, but the actual slab assembly will be something like 10 3/4".  If not, should they not be referred to differently?  Also, when I got to top and bottom bounding, which slab definition is it referring to?  I'm getting a little confused.
Edited by homero
What template file are you looking at?
If it's one from the first page of this thread, note that the point of this thread is to explain a model set-up that does not need the use of stories.
If you are looking at organisation/stories and seeing the "default storey levels" then if there's one with slab in the name, no it is not necessarily connected to any slabs you've drawn. You can set a storey level to any elevation you like, and you can call it what you want. The name of the storey level is just that, a descriptive name. You can then choose to relate various objects to a storey level, including slab objects.
Another thing to consider is that you can return the story level names in Elevation Benchmarks so worth thinking about what you want to see in your section VPs when naming them.
I have only just started doing this + it is pretty impressive functionality (having things set up so Elev BMs automatically display in section VPs).
Yes I have been doing this for a while now and it's very useful. It's one of VW's best-implemented features. Just waiting for section-elevation lines to be updated to behave as nicely.
Relating elevation benchmarks to storey levels is one of the main reasons I use "storeys" even though I actually just use one storey and put all of my levels (for multiple floor levels) within it.
But this is all a bit off topic for this thread, which is supposed to be about getting by without using storeys at all.
I'd be interested in quizzing you over your set-up as I'm not sure I completely know what I'm doing (with Stories) yet, but like you say probably better in another thread...
It was actually after you clarified for me elsewhere that to get the full benefit of Elev BMs you needed to use Stories that I finally decided to do so on a current project. Although I added them halfway through which wasn't perhaps the most effective way of doing it 🙂
My setup is pretty simple in the end really.
This was the thread I made when first trying it:
  • 1 year later...
My wall style was set to original story levels for top and bottom boundaries. Then, later, I changed the boundary levels. When I edit the wall in the OIP it is set to boundary levels which "don't exist". (That's why I changed the levels in the wall style dialogue). So I am trying to reset the wall in the OIP to the later levels. But they are not accessible. I do see an option called "Stories...". Which takes me to the story preview. I expect that I should be able to select a story level by this route? If so how? I guess this is a simple blind-spot of mine....any help gratefully received, thank you!
