Tom Klaber Posted September 19, 2018 Share Posted September 19, 2018 Selecting objects and then moving the objects and mouse to the edge of the screen used to result in auto panning the drawing in that direction - allowing you to drag objects to other parts of the drawing. This does not seem to be working in 2019 1 Link to comment
0 markdd Posted September 19, 2018 Share Posted September 19, 2018 Same here. Been trying to think of a good way to describe it. Auto-pan seems to do the trick! Link to comment
0 zoomer Posted September 19, 2018 Share Posted September 19, 2018 Oh my god ! It's true. I was never happier about any Bug before. Please don't fix it (*) Finally the upgrade is worth. I found that previous behavior SO distracting. (*) if ever fixing, please as an OPTION setting. (Or maybe that already is and off by default ?) 1 1 Link to comment
0 Tom Klaber Posted September 19, 2018 Author Share Posted September 19, 2018 @zoomer haha. BOOOOO - Zooomer booo. I drag stuff around all the time.... I am detailing now and it is driving me CRAZY. 1 Link to comment
0 zoomer Posted September 19, 2018 Share Posted September 19, 2018 (edited) My dreams ended quickly. 1st because that moved into the Known Issue Area and 2nd because it does not work reliably in that new fashion. Tested with Rectangle Tool fine first but Screen will jump when in Line creation anyway(*). Just not controllable. (*) So even an SP>0 embargo from my side would not really help .... Edited September 19, 2018 by zoomer Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted September 19, 2018 Vectorworks, Inc Employee Share Posted September 19, 2018 3 minutes ago, Tom Klaber said: @zoomer haha. BOOOOO - Zooomer booo. I drag stuff around all the time.... I am detailing now and it is driving me CRAZY. It's making me bonkers. It apparently popped up right in the release build, as I would have stumbled over this heavily creating videos. I'm all for an option to disable the scrolling, but I needs my scrolling edges back. 2 Link to comment
0 markdd Posted September 19, 2018 Share Posted September 19, 2018 If I drag hard to the left then the Auto-Pan will work, hard to the right, then it won't. However, if I hover about 3-4mm away from the edge, (where my OIP is located) then it works fine(-ish) Could this be an issue with the OIP. When I replace the OIP with the navigation Palette it all works as expected. 1 Link to comment
0 Tom Klaber Posted September 19, 2018 Author Share Posted September 19, 2018 @markdd Your right! It is still there - just the tolerances / hover zones are all messed up. Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted September 19, 2018 Vectorworks, Inc Employee Share Posted September 19, 2018 It is apparently related to a fix that allowed the dragging of objects between mutliview panes. I am able to alter it as well by changing which palettes are docked where. Engineering already acknowledged this one and is working on a fix currently. Link to comment
0 Kevin McAllister Posted September 19, 2018 Share Posted September 19, 2018 I noticed this the other day. At the time I wasn't sure if it was a bug or because I was drafting with my laptop trackpad for the first time in a while. Glad to hear it will be fixed. Kevin 1 Link to comment
0 Dan Hoffman Posted January 4, 2019 Share Posted January 4, 2019 And yet, it's still not fixed almost four months and two service packs later.... Link to comment
0 markdd Posted January 4, 2019 Share Posted January 4, 2019 I've just tried it here and it all works as it used to. You do need to "hover" ever so slightly on the area where the rulers are, but that seems like its intended and makes sense to me... 1 Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted January 4, 2019 Vectorworks, Inc Employee Share Posted January 4, 2019 Correct, this SHOULD already be fixed as of 2019 SP2. But as mentioned above the mouse has to stop near the edge it can't just go over a palette, this is to prevent accidental scrolling, prevent scrolling when you mouse out of the drawing area to enter an OIP value, to another monitor, or if you have multiview enabled. However, we have indeed decided that the auto scroll area is a bit too small and we will be changing the behavior again in the next SP to make it more comfortable like it used to be without still allowing for errors. Link to comment
0 Dan Hoffman Posted January 4, 2019 Share Posted January 4, 2019 Hmmm, I see what you mean - it *kinda* works, but definitely not the same way that it used to. If you hover in that few-pixels-wide border zone near the edge of the screen, after a delay, it auto-pans. But that's very different from the previous behavior, which was activated as soon as the cursor reached the edge of the screen. At the very minimum it would really be great if there was a toggle for something like this....trying to hover in that area with a trackpad or with a bunch of things snapping near the edge is rather tricky... Link to comment
0 RGyori Posted January 7, 2019 Share Posted January 7, 2019 On 1/4/2019 at 9:16 AM, Dan Hoffman said: Hmmm, I see what you mean - it *kinda* works, but definitely not the same way that it used to. If you hover in that few-pixels-wide border zone near the edge of the screen, after a delay, it auto-pans. But that's very different from the previous behavior, which was activated as soon as the cursor reached the edge of the screen. At the very minimum it would really be great if there was a toggle for something like this....trying to hover in that area with a trackpad or with a bunch of things snapping near the edge is rather tricky... Perhaps not only toggle but to allow adjustment in preferences of the time delay that initiates the auto scroll. This should help account for differences in mouse/trackball, etc. sensitivity settings. Link to comment
0 Bryden Scott Posted July 5, 2019 Share Posted July 5, 2019 Any updates on this one? Just ran into it using 2019 to get around another bug in 2018. Being able to turn auto-pan on or off would be great and to have it work like 2018 did would be awesome. It just takes too much time to auto-pan. Thanks, Bry Link to comment
0 thinkingpencil Posted December 13, 2019 Share Posted December 13, 2019 I have just upgraded to 2020 from 16. Auto pan works when I run 2020 in Windows 7 (yes, really, I spent the new lap top fund on the software upgrade!!). But auto pan won't work on 2020 on Windows 10. (Yes, I know, time to use a Mac!!) So it's a MS Windows issue? Any recent experience welcome.... Link to comment
0 thinkingpencil Posted December 19, 2019 Share Posted December 19, 2019 I followed advice earlier in this thread. Auto panning fine now. Link to comment
Tom Klaber
17 answers to this question
