374 -
Reputation
53 ExcellentPersonal Information
Occupation
Architect
Hobbies
photography, motorcycling
Location
United States
Recent Profile Visitors
To date I have not used AI other than in the form of specific functions baked into some of my photo apps...(producing some interesting if not anticipated results). With this said there will be interesting Architectural uses developed in the (near?) future that will open up some useful and likely unexpected possibilities. An idle and perhaps naive thought regarding ChatGPT: What happens once human writers have been relegated to the fringes and ChatGTP is left to mine the works of earlier ChatGTP work that in turn was mined from earlier ChatGPT work... and so on down the rabbit hole? An iterative process in reverse producing nonsense or the great cosmic truth?
Perhaps a small ray of sunshine regarding bootable back-ups in Ventura... https://appleinsider.com/inside/macos-ventura/tips/how-to-make-an-external-bootable-working-drive-in-macos-ventura Haven't done it myself but the source is reliable.
I too use PDF Squeezer on my Mac (OS Mojave, soon to be Big Sur) for a variety of application produced or downloaded pdf's. Couldn't be simpler, just drag and drop.
Mac OS 10.13.6 and crashing new download of Vectorworks 2022
RGyori replied to Roslyn's question in Troubleshooting
For what it's worth: I run OS 10.14.6 Mojave which also doesn't appear on the list of required OS's for VW22... and it nonetheless runs fine... for now! -
I have command H programmed to a key on my Kensington Expert Trackball... use it to deal with several application that have a persistent screen presence.
Here you go... standard dwg conversion settings using VW2021: Gym Steam Shower Floor Plan 01.04.21.dwg Vereley House First Floor Lighting Plan 31.03.21.dwg Vereley House Ground Floor Lighting Plan 06.04.21.dwg
Hi @SFS Chris , if you do exactly as described above you are not reinstalling Vectorworks but repairing it. I've done this at times and the repair process has upon occasion found some problem and repaired it. Certainly worth the try.
Oooh, @jeff prince thanks for the lead. I agree that once accustomed to a track ball going back to a mouse is a pain... figuratively and at times literally. The one complaint I've had with my Kensington Expert Trackball is the coarse scrolling so I will give it a look.🧐
Out of curiosity us anyone tried a track ball such as the Kensington Expert Trackball? Over the years I have grown to appreciate the long session arm/hand comfort, 4 customizable buttons that work individually or in combination and programmable tracking/scrolling speeds that has proven ideal for my limited desk space. Works very well with my many photo editing apps as well. 🤔
PDF Squeezer https://www.witt-software.com 👍
She's doing just fine providing USA architects with a well rounded source for accessibility design and compliance. https://steppingthruaccessibility.com 👍
Unfortunately same "Illegal copy of VW" result here.
Similar results here using an array of lines in @Todd Muspratt's example . Even when using the connect/combine tool in the admittedly more laborious single object connect mode the resulting connected lines were not be properly connected. For instance after using the compose command I found that the resulting polygon was not closed at one corner. 😕
Is snap to grid in the snapping preference perhaps on?
docking the snapping palette?
RGyori replied to hollister design Studio's topic in General Discussion
You learn something every day... if you're paying attention. 😉 I just learned to first stretch the undocked Snapping pallet horizontally so it is a single row. Otherwise you'll end up with an extra blank space across the entire drawing width.
