Bryden Scott
10 -
Reputation
0 NeutralPersonal Information
Location
Canada
Opening a floating view pane crashing VW every time.
Bryden Scott replied to Bryden Scott's question in Troubleshooting
Hi @JuanP, To add, I just tried opening a floating view pane with the VW main window on the Viewsonic and it seems to have worked. The floating pane has always been a bit glitchy but I can't imagine what you and the team go through with all the variations of setups. For now I'll use this workaround until it doesn't work or can be fixed. Thank you and @Josh Loy for the help. -
Hi @JuanP, Thanks for the reply as well! I disconnected two of the monitors and there was no crashing issue. I'm currently running 3 monitors, a Samsung 34" S34CG50 (primary), a Viewsonic 24" VA2456 (secondary, would like to use this a real estate for reviewing plans via floating pane), and a Bimawen 17.3 inch 2K Portable Monitor (3rd for layers, classes, tools, resource manager, etc.). I tried opening a floating pane with just the Samsung on and it was fine. I tried a pane with both the Samsung and the Bimawen and it was fine. It was only when plugging in the 3rd Viewsonic that it crashed. Could this be an M1 issue? Before this I had issues of violent screen flickering with a floating view pane while running two BenQ monitors. Thanks, Bry -
Hi @Josh Loy, Thanks for getting back so quick! Yes I just tried that and it crashed again. Every file, every time so far. Cheers, Bry -
Bryden Scott posted a question in Troubleshooting
Hi folks! Wondering if anyone has run into this issue lately? I go to open a floating view pane, and VW has been crashing every time. A few weeks ago it depended on which pane I selected but now it seems to affect all panes and just the action of trying to open a floating view pane crashes VW. Any help is much appreciated as I like the floating pane in my secondary monitor to keep an eye on the plans. Specs: VW Architect 2023, SP8 Mac Studio 2022, M1 Max Chip, 32GB Memory, Ventura 13.3.1 (a) Thank you! -
Resolution Changing with Floating View Pane on Second Monitor.
Hi VW Community, I've just upgraded to a new computer, an iMac (Retina 5K, 27-inch, 2019) and have just recently installed VW2022 as well. I'm still using an older second monitor (Benq GW2765). I'm currently experiencing this issue on both VW2020 SP6 and VW2022 SP 3.1. I've matched the resolutions of both screens to 2048x1152 When I drag a floating view pane over to the Benq monitor, the resolution of the view pane changes. Everything else stays the same when I drag between the two, Vectorworks main window, youtube, gmail, etc.. It only seems to be the floating view pane and I cannot figure out why. See the attached screenshots. iMac, looks normal, please note the selected rectangle. Benq Monitor, with entire VW window, looks normal, not as sharp as the retina 5K, but at least the same reso. iMac with floating view pane in front. Looks normal. Same viewport dragged over to the Benq. Note the selected rectangle. Why such a big resolution jump? Big nasty selection boxes. This has been happening with both VW2020 and 2022 (office in transition period). It was not happening with my 2015 iMac 4k retina display and this monitor. Why would only the view pane change resolution? Any help is much appreciated because I use a floating view pane quite a bit. Cheers! Bry -
Hi folks! I started a new project the other day, and noticed every line I hover over or select now shows these little direction arrows. How can I turn these off? They're annoying and make the lines look fuzzy/ unprofessional on zoom meeting share screens. All I can find on here is how to toggle on/off direction arrows in object preferences. I'm sure it's something simple I must be missing, any help on this is much appreciated! (Edit: Colleague found it! Smart Cursor Settings, Distance, Percent, 0) Cheers! Bry VW 2020, SP6. iMac (Retina 5k, 27inch, Mid 2015) 3.4 GHz Intel Core i5, 32 GB 1600 MHz DDR3, NVIDIA GeForce GTX 775M 2 GB
Just got rid of Mojave today. Back to default Yosemite 10.10.5. Got absolutely tired of beach balls on both VW2018 and VW2019. Hoping this works for the time being, may try High Sierra but for now the beach balls are gone and I'm back to happily drafting and selecting text, polygons, etc. Bryden
Vectorworks Freezing When Selecting Reference Marker Tool
Hi guys, Thanks for your responses, the issue went away with the drawing over some time and different people working on it. I've still been experiencing freezing issues similar to the previous but now they are a little less predictable and can last for the same duration of time (5-10mins usually). I apologize for the delay, and not having the specs up yet, here they are. Thanks, Bryden VW2018 SP6 -
Any updates on this one? Just ran into it using 2019 to get around another bug in 2018. Being able to turn auto-pan on or off would be great and to have it work like 2018 did would be awesome. It just takes too much time to auto-pan. Thanks, Bry
Hi there, First post! Have been searching on the google but it seems no one has posted about this issue. While trying to select a reference marker tool in one file, Vectorworks freezes. It's been consistent in this file since this afternoon, I've tried shutting Vectorworks down, restarting the computer. I can quickly box select the markers and delete them if I'm very fast (tried dragging one from another file that I worked on all morning with no issues) but the problem still persists. Other files seem to be intermittently freezing on selecting the reference markers, but this one file freezes consistently. Haven't had an issue like this persist for this long in my short 2 years on VW. A colleague of mine opened the file on his computer with a different OS and he experienced no issues. It leads me to believe this may be a VW 2018 / Mojave issue? Going to keep at drawing to see if the issue maybe fixes itself, but any recommendations are much appreciated. Thanks, Bryden
