jakez 11 Posted January 5, 2018 I'm looking for any help (tools, tips, suggested videos) in drawing this in its 3d form as accurately as possible: ... any advice would be greatly appreciated. Quote Share this post Link to post
Pat Stanford 1,632 Posted January 6, 2018 How much information do you have on the part? Looks like multi-direction curves. If you want to draw it accurately, you will need to know much of that information. Do you know how the part is made? If it is a casting it may be challenging. If it is a flat sheet punched and bent, then it should be doable. At first glance I would consider using the Subdivision tool to make this. It will let you move parts around as necessary. If you know the radius of the curves, you could also start with a big block and make "cutting" pieces to subtract from the big block to get the shape. Quote Share this post Link to post
Kevin McAllister 1,162 Posted January 6, 2018 If its a flat sheet punched, I would draw the flat shape, extrude it to the correct thickness and use the Deform tool to add the bend. Finally I would add the fillet/chamfer to the edges. If you have the physical object, you could make a It looks like the anchor point for a seat belt or a child safety seat. Kevin Quote Share this post Link to post
Benson Shaw 603 Posted January 6, 2018 I think draw it the way it was made. Start 2w flat as an extrude, then fillet the edges, then bend with the deform tool. -B Quote Share this post Link to post
Benson Shaw 603 Posted January 6, 2018 Doh Looks like Kevin and I saw same potential. But I thought it was a bottle cap opener. Also looks like there is an edge not consistent with fillet. so that would need some other process. Maybe split out that area and apply taper face. Then add it back. -B Quote Share this post Link to post
Kevin McAllister 1,162 Posted January 6, 2018 (edited) Here's an example file. 22 minutes ago, Benson Shaw said: But I thought it was a bottle cap opener. ^ Love this. It does look like one of those bench mounted ones, doesn't it. I wonder how much force it takes to open a bottle. My guess was based on it having a force rating stamped on it. I always notice the nerdy tech info.... Benson's right about the geometry. There is something else going on beyond my simplified version. KM Example.vwx Edited January 6, 2018 by Kevin McAllister 1 Quote Share this post Link to post
zoomer 1,130 Posted January 6, 2018 ^ I need the love button back for such nice illustrations. 1 Quote Share this post Link to post
nrkuhl 12 Posted January 8, 2018 @jakezyou designing some climbing walls? For the curious, that's a bolt hanger used in climbing to clip a quickdraw and rope into (or anchor to). Typically anchored into rock with an expansion bolt, or t-nutted to a plywood climbing wall. Quote Share this post Link to post
Phil hunt 76 Posted January 9, 2018 Need a monthly competition on how to model various items.....could be interesting on how different people approach the task.......great forum Quote Share this post Link to post
AlanW 547 Posted January 9, 2018 Can double as a beer bottle opener on the way up. Just hanging about having a cold beer. Quote Share this post Link to post
nikihoops 3 Posted January 9, 2018 22 hours ago, nrkuhl said: @jakezyou designing some climbing walls? For the curious, that's a bolt hanger used in climbing to clip a quickdraw and rope into (or anchor to). Typically anchored into rock with an expansion bolt, or t-nutted to a plywood climbing wall. Thought it looked familiar! Quote Share this post Link to post
Gadzooks 110 Posted January 9, 2018 6 hours ago, Alan Woodwell said: Can double as a beer bottle opener Thought that was more familiar (OK - says a lot about me - and possibly Alan) Quote Share this post Link to post
jakez 11 Posted January 19, 2018 On 1/8/2018 at 7:49 AM, nrkuhl said: @jakezyou designing some climbing walls? For the curious, that's a bolt hanger used in climbing to clip a quickdraw and rope into (or anchor to). Typically anchored into rock with an expansion bolt, or t-nutted to a plywood climbing wall. Wow, clearly I have to change my forum settings so I get emails when people respond to my questions. You guys are amazing! Thank you so much. Yes, I design climbing walls and am slowly adding to my library of itsy bitsy details so I can just plug them into any drawing I'm working on. (It isn't great for opening a beer bottle, better to use a H-frame carabiner :)) Quote Share this post Link to post
jakez 11 Posted January 19, 2018 On 1/5/2018 at 5:28 PM, Kevin McAllister said: Here's an example file. ^ Love this. It does look like one of those bench mounted ones, doesn't it. I wonder how much force it takes to open a bottle. My guess was based on it having a force rating stamped on it. I always notice the nerdy tech info.... Benson's right about the geometry. There is something else going on beyond my simplified version. KM Example.vwx Beauty, thanks Kevin. Quote Share this post Link to post
