AlanW
3,435 -
Reputation
734 SpectacularPersonal Information
Location
Australia
Recent Profile Visitors
I need to create a texture with seamless pattern from a download image
AlanW replied to shyamsundar's topic in Architecture
@shyamsundar Hi you need to use photohp to adjust the light and dark sides to be the same. I often use the Clone Stamp tool to copy one side to the other. HTH -
Dont worry found the problem. Was me:) Can you delete a post once its up???
Hi again, In the 2026 Fencing tool you used to be able to right click and allocate a class now you cant, I had to cut and paste the class name in. Am i missing anything again? 🙂
Hi Thanks, If i show in low mode which works you dont see the windows in detail. All workeds well in 2025.
Hi Second problem, my wall opening is solid red in 2d Wall Problem_02.vwx
Hi Me again, My wall is on Wall new calss and i have wall components withing the wall new. Before i could turn off the components anthe wall new calss would show. But not now. Any ideas again.Wall Problem.vwx Thanks from a real 2026 NOOB
Hi must be missing something again. When you put = in spreadsheed cell then right click you should be able to insert function then criteria. I cant seem to do this now by right clicking. Can you point me to the correct way to do this in 2026. Thanks in advance.
@michaelk Tell me???
@michaelk Well that was simple!! Thanks How Dumb am i, LOL Alan
Roof Framing not showing in hidden line viewport 2025 but does show in 2026? All design layers and classes showing. Shows with shaded viewport in 2025. Any ideas. Thanks in advance Roof Rafters.vwx
A person with a keen eye in our office has just pick up what appears to be a spelling mistake in the Title Block Border Settings under drawing stamp. Display Drawing Stamp, 'For Developement Application Only" Should it be Development ???? Over to you
@Tom W. Well that was easy!! thanks Alan
Hi Is there a way to change all the stair tread components at once rather than one at a time? Thanks
