Chris Morrison 0 Posted July 2, 2015 Hi, Is there an "isolate objects" command in vectorworks? I'm trying out the 3d side of vectorworks and am a form Z user - in Form Z you can right click on the mouse and this command appears in the menu-it's very useful for complicated 3d scenes to reduce visual clutter. Is there anything similar in vectorworks? mny thx, Quote Share this post Link to post
michaelk 466 Posted July 2, 2015 (edited) Have you tried the clip cube? Select an object or objects, invoke the clip cube from the tool bar. You will get an adjustable cube. Object inside the cube are visible, objects outside are not. And there's always the old school way. Select an object or objects. Group. Go inside the group (with show other objects while in edit modes turned off). When you're done, exit the group and ungroup. That's what we used to do before the clip cube. My fingers still remember the keyboard shortcuts: Command-G, Command-Left Bracket to isolate Command-Right Bracket, Command-U to return. hth mk Edited July 2, 2015 by michaelk Quote Share this post Link to post
michaelk 466 Posted July 2, 2015 Come to think of it, there is an even older way that might do exactly what you want. These scripts will run deprecated commands that sound like they do exactly what Form Z does. Select the object or objects you want to work on. Run the script, "Hide UN Selected" When you're done, make sure to run the script "Show All" I don't know where these scripts came from. Probably safe to credit Pat. Or Raymond. hth mk Quote Share this post Link to post
Chris Morrison 0 Posted July 2, 2015 awesome - thank you Michael - I'll try that. Quote Share this post Link to post
AlanW 521 Posted July 2, 2015 Hi, if you make a class active you can isolate all the class. Right click on screen and layer or class options. Ctr+alt+3 isolates the class and Ctr+alt+8 turns them all on again. HTH Quote Share this post Link to post
Pat Stanford 1,428 Posted July 2, 2015 Or you can make the objects you want to isolate a group and turn off the preference to Show Other Object in Edit Modes (or something like that). 1 Quote Share this post Link to post
C. Andrew Dunning 187 Posted July 3, 2015 I don't know where these scripts came from. Probably safe to credit Pat. Or Raymond. Sounds like things from the mind (and fingers) of Sam Jones. He's where I got the versions I use... Quote Share this post Link to post
Schanke 0 Posted February 21, 2019 @michaelk where do i find those scripts you, describe. sorry abslolute newbie with scripts in vw. but im missing these function so much in vw 3d environmet. thx simon Quote Share this post Link to post
Pat Stanford 1,428 Posted February 21, 2019 Simplest way is to make them yourself. Edit your workspace and add Custom Visibility to the menu from the Legacy set. It was originally in the Tools menu with Custom Selection etc. before being moved to Legacy. Run the tool and check the Create Script option. The first script you want to have it make is Show All so you can get things back after you hide them. Then you can make a tool for Hide Objects that are Not Selected. And as many other versions as you need to do what you are trying to do. Hide specific layers or classes. Or types of objects (text perhaps). Very powerful. Quote Share this post Link to post
Boh 436 Posted February 21, 2019 Wow I like that! One thing though. I notice that creating a "Show all" script shows all objects but doesn't change their classes to visible. I.e. even objects on invisible classes are visible - which could get confusing. I've noticed some right click menu items called "Hide Objects" & "Show All". "Hide objects" in the context menu hides all items which aren't selected, "Show Objects", available when nothing is selected shows everything except items that have their classes off. Quote Share this post Link to post
MattG 43 Posted February 22, 2019 This is funny this came up and is active as I am actively trying to figure out a way to do this. I am very much in need of an isolate selection mode at the moment. I think I am personally going to submit a wishlist item for this. Unfortunately things in the drawing are already classed and layered. The item is a curve and the clip cube does not give me the desired results. If I group I give up some of the layering already in place. There really should be a quick toggle to isolate items like in an edit mode, not sure how this is just coming to me now. Quote Share this post Link to post
Boh 436 Posted February 22, 2019 Hmmm Matt does the right click “Hide Objects” command as mentioned above not do what you want? Quote Share this post Link to post
MattG 43 Posted February 22, 2019 I do not have any right click options for "hid" objects as you do. Quote Share this post Link to post
Boh 436 Posted February 22, 2019 Have you tried adding it to your workspace? Quote Share this post Link to post
mgries 61 Posted February 22, 2019 I saw this thread, and didn't know about this command. I went to add it to my workspace, but I don't see it! Is the name of the command something other than "Hide Objects"? Quote Share this post Link to post
Boh 436 Posted February 22, 2019 (edited) I suspect it may be part of the Australasian version of VW Try bringing in that “Custom Visibility...” command instead that @Pat Stanford mentioned. I played around with it but couldn’t figure out how to get a “show “ command that didn’t show objects on classes set to invisible. Edited February 22, 2019 by Boh Quote Share this post Link to post
Pat Stanford 1,428 Posted February 22, 2019 For me the Custom Visibility tool does not effect objects with hidden Class or Layer visibilities. The scripts created are really simple. Show All: Show(INSYMBOL & INVIEWPORT & (ALL)); Hide Visible Selected Objects Hide(INSYMBOL & INVIEWPORT & (VSEL=TRUE)); If scripts are acceptable, copy and paste everything in the code block in to a new blank Vectorscript from the Resouce Browser. If you want to give them key shortcuts or add them to the contextual right click menu you will need to use the Plug-in Manager (Tools:Plug-ins) to make them into a command and then add that command into your workspace. 3 Quote Share this post Link to post
Sam Jones 162 Posted February 22, 2019 If you want to hide all but the selected objects you will need 2 commands, one to hide and one to unhide. you need to be sure that you do not include symbols and plug-ins because selected objects may hide there interior components leaving you with just control points, if that. The commands are To hide all unselected objects Hide(((SEL=FALSE))); To show what you just hid. Show(((VSEL=FALSE))); Let me know if this is not what you need. 4 Quote Share this post Link to post
Schanke 0 Posted February 25, 2019 @Pat Stanford @Sam Jones , this helped a lot !! thx is it possible to assign a shortcut to a script ? that would be just super cool. i do have three scripts now: for Isolate selected i used: Hide(((SEL=FALSE))); for Show All: Show(((VSEL=FALSE))); and Hide selected: Hide(INSYMBOL & INVIEWPORT & (VSEL=TRUE)); 😀😀😀 Quote Share this post Link to post
Schanke 0 Posted February 25, 2019 (edited) and indeed i do now have the problem of having groups and symbols not included. @Sam Jones I couldnt find out what to add to the script to include groups and symbols when i try this nothing happens anymore Hide(INSYMBOL & INOBJECT & SEL=FALSE); thx in advance Edited February 25, 2019 by Schanke Quote Share this post Link to post
Sam Jones 162 Posted February 25, 2019 To hide selected objects use Hide(((SEL=TRUE))); There is no such thing as a short cut, but you can turn the script into a menu command. To do this you need to turn it into a plug-in command. 1. go to the plug-in manager 2. In the resulting dialog click on the "New..." button 3. In the resulting dialog type in a name for the command you are making and click on the "Command" radio button click on the "OK" button. You will now have a command that does nothing. 4. In the Plug-In Manager dialog be sure the command you just created is highlighted, and click on the "Edit Script..." button. 5. In the resulting editor window type script, for example "Hide(((SEL=FALSE)));" and click on the "OK" button. Then, click on the "Close" button. You now have a command that you can put in your workspace. You will have to decide in what menu and where, but once that is done you will have a menu command always available, and you can give it a keyboard shortcut if you wish. Hope that helps (HTH) Sam 3 1 Quote Share this post Link to post
Schanke 0 Posted February 26, 2019 wow thank so much !!!!!!!!!!! this opens a whole new world in VW i guess. Quote Share this post Link to post
C.T 5 Posted October 23, 2020 (edited) @Sam Jones Can you please explain how to do add this Hide command I made according your instructions (posted February 25, 2019 ) into the Basic Tool Set : ''......You now have a command that you can put in your workspace. You will have to decide in what menu and where, but once that is done you will have a menu command always available, and you can give it a keyboard shortcut if you wish.'' Edited October 23, 2020 by C.T Quote Share this post Link to post
Boh 436 Posted October 23, 2020 At the bottom of the tools menu I think is the workspace editor. Quote Share this post Link to post
