645 -
Calendar
Everything posted by MattG
I do not believe this to have always been the case but at some point I believe things changed where when a new lighting device is inserted in a design layer the default setting for the light in existing viewports is set to on. This is very frustrating for me personally but hoping there is a setting somewhere I'm not aware of and cannot find to change the default insert function someone can lead me to. I have prebuilt templates with viewports already created. Many are just to show lighting systems in 3D space and have separate non spotlight light lighting devices in them. I render most of them in Shaded/Open GL. For one speed and secondly for the light limit in that render mode I would greatly prefer any new lights are defaulted to off. When drawing a light plot every new light is defaulted to on.
I have no clue how this has not ever come up for me in the past. I have an odd 3D model I'm working on. There are a number of 3D Loci in there already at useful positions. If I look in Top/Plan view I can just draw lines connecting the loci and see the distance of the line. That is good except it is not accounting for changes in Z so I'm not getting an accurate distance. I go to another view in 3D I can draw 3D polygons with just two points and it is correct on the overall location including the Z height. The issue is I want to know that distance. Is there a good way to get that actual distance from just the 2 point I connected with a 3D Polyline? Thanks, Matt
We are considering hiring an additional person or two to help on our in house drafting needs. This would be starting out with basic Vectorworks based drafting, understanding of Spotlight and use of the rigging tools is definitely preferred. A familiarity with AutoCAD is also very helpful. There is a possibility of helping in some rendering work as well. We primarily work in large scale touring applications and corporate events. If interested shoot me a note with some info and we can talk and go from there. This would be an inhouse / in person position in Sycamore, IL (about 60 miles west of Chicago). Matt Gohring mgohring@upstaging.com
I have a panoramic image I'm using as a custom renderworks background. Overall it looks correct like it should in terms of the background. However I have a generic ground plane in my geometry. I cannot seem to align where the bottom of that image would be to where the ground plane is. Does anyone have any experience with this? Right now it basically looks like my geometry is floating in mid air, but since the image aligned so well I'm thinking there has to be a way to essentially scale it or place it in the right space. Thanks, Matt
Oh that might be it. Ironically running out the door to coach a game. I will look tomorrow.
So I did a manual version of what I am describing. See the attached screen shot. This is on a sheet layer. I semi redacted as I didn't want to show the kids names. But basically there is a worksheet with a order 1-9 in the far left column. There are "players" populated in there at different positions. This rotates each inning. This is easy if it was just one inning. Trying to figure out how to do this for 3 inning for 3 separate instances of the lineup. The arrows show where I would want those names to populate. Does that make sense?
Here is a really odd topic/silly thing but I'm curious to see if there is a good way to do this. Completely silly and unrelated to anything normal drawing wise. I started coaching youth baseball and am currently coaching a T-Ball team. They were having a hard time with the positions so I drew a small lineup card in VW. Off to the side I made a little worksheet that has the batting order/line up on it. I also drew in symbols at each position where the players should be playing in the field. We are only playing 3 innings in t-ball so at each position in the field I have a symbol with what looks like a little worksheet in it that has 3 rows below it listing who plays that position first, second, and third. Off to the side I have a batting order and position lineup. We change the order and positions every inning so right now there is essentially 3 worksheets smooshed together to show three different innings. My curiosity here is if I did this all once in either the batting order lineup or on the positions on the field would there be an easy way to link the information in one item to the information in the other so I don't have to manually move all of that around a second time?
This is basically what I'm looking for. I get it and can adjust this with your info but this is really a regression from the previous tool for most users.
I may be doing this incorrectly and let me know if I am so I can be corrected, but I want to use a data tag that shows the overall point at the top of the hook connecting to the structure in the ceiling. What field do I use? My understanding is I should use the "Hook Weight Equivalent" as described above. I want to be able to enter the known value hanging from the hoist info under "Hoist Weight Equivalent" and have the value in "Hook Weight Equivalent" update its total based on the weight entered and the weight of the hoist & chain. Right now in what I am doing this does not work. Is this correct?
I'm really surprised if that is the case and also somewhat surprised it has not come up before. I am making a bunch of very similar worksheets that are sorting info from different locations. I am hoping to have a cell at the bottom that just says what the worksheet name is for reference to be sure I got the right one.
This is probably a simple one and I cannot believe I have not thought to do that in the past. Is there a function I can put in a worksheet to display the worksheet name? I'm not finding that. Thanks, Matt
I'm sure this has probably been asked but I didn't find it and I'm sure others are wondering, especially as the event world is picking up. With the updated hoist tool in v2021 and up there are a lot of changes. If I am not using braceworks what is the proper field to use in the OIP to manually enter a weight that would be most appropriate to use? From my basic reading in the help section I think this is "Hoist Force"? Is that correct? The default value in there shows a value in "lbf". In short I'm wanting to be able to manually enter in weight values of the items hanging from a hoist calculated outside of VW. My hope/understanding is that when I enter these values I can have them populate and not really effect the overall functionality of the backside of the hoist tools. I'm also updating my worksheets and reports for these and want to use the correct fields. Additionally with the appropiate field what is the unit value that it is defaulted to? I am looking in some of the backend items and it looks like a lot are formatted in grams. I am fine with whatever I just want to know what my base unit is for the field to use it appropriately in a function in the worksheet. @JCodgell Any thought? Thanks, Matt
Simple hoist tool for Spotlight
MattG replied to AStein's question in Wishlist - Feature and Content Requests
Just saw this looking for something else and not totally sure there is a question in here. However I can tell you that the pre 2021 hoist tool is still available, it is "Hoist (Legacy)" and you can add it to your workspace and use it as is for now. For the other things, you could just literally make symbols with records and accomplish all of that on your own and avoid anything brace works related. It really may be the better option for some. -
Great thanks, that was a bit buried in there to find.
Does anyone know with the hoist tool in 2021 going forward is there a class that the show measurement label dimensions end up on? The previous hoist tool plopped those on a class. I want to be able to have the dimensions shown, but on/off in different viewports.
I have done this in the past. However I wish that the "Preference" change would apply to all subsequent worksheets. It seems somewhat tedious. I also find that in spotlight I use the spotlight - reports - create report option a lot because I may not always know what the database or field of something is. Sometimes I just go through and delete unwanted columns and call it good. But I do wish I knew where VW decides to take that font value from just to change it. Not a huge deal but more of an annoyance I guess.
So @Pat Stanford it is funny I randomly came across one of your "global font change" scripts kind of looking at this. I knew this existed but I always had it in the back of my head that it was editable and I was just being lazy and not hunting down the culprit. I am in the event industry and have a bit of time on my hands. It is funny some of these relatively glaring gaps in things I think I'm finding.
This is probably a insanely simple one but I cannot find it and I'm sure I'm not alone. What determines the default font for a worksheet and how is that controllable? We used a standard font for a while. I am using a different font for things now. I have noticed that the choosing the "standard" font from the text menu doesn't seem to carry over to worksheets. I never really noticed before because the previous font was so close to Arial. It appears for me it is defaulted to variations of Arial. Any thoughts?
Not sure how I just saw this but this is awesome. I know I posted a "wish list" for something like this integrated into VW a long way back but just this is great. Long story short for me it helps in consistency when getting files from other incorporating into yours and suddenly text from .dwgs or other items don't all match. Super nice.
@ScottLebsack Yep totally doable just more curious now to what that actually is because I'm sure that info is accessible somehow. Thanks @Pat Stanford Matt
Yes on a index, no on the title block for this particular thing. That is where I am stumbling. I have done the above before but without too much explanation I'm not doing that here. Hoping to just get the actual Sheet Layer fields out. Matt
I know I've seen this before and cannot find it for the life of me. I'm trying to make a report of all my sheet layer numbers and titles. What database record/fields would I use for that? This is not the drawing border option. Thanks, Matt
I tend to draw a portion of a system to start and then get all my viewports set up for things. I often will do say a 3D view of some type of a truss or something that is more just for visualization not really for "rendering". I tend to just do these in a variant of open GL. My understanding is open GL uses a max of 8 lighting devices and gives priority to the last 8 light objects. My question is if there is a way when I add a new lighting device to a drawing to have the default on/off set to off for all existing viewports. The reason being that if I already set up the look for a viewport and it is good but I add a light that may be on in a layer or class that already exists it appears to start factoring into the rendering of that viewport and depending on the quantity take priority over existing devices. I feel like there is a setting for this I am missing but maybe not. Anyone have a solution for this? Thanks, Matt
Side not CP's site has good .dwgs as well for this and most of their products. We are working on building some into some set pieces so I generally prefer the manufacturer's drawing to be sure clamps and spacing are a bit better and CP probably has the "cleanest" dwg that come into VW.
@JBenghiat thanks that is very helpful info and I would have never found that. I wish there was somewhere that documented those fields, I can see real use for it. Thanks, Matt
