bob cleaver
239 -
Everything posted by bob cleaver
Gerard- in VW preferences, select good performance and compatibility and see if that solves the issue Thank you VW Tech Support for the help with this
Could you create a 3D polygon (profile) with a sloped base and horizontal top and sides and extrude it across the lower slab ? If the base changes you would adjust the profile as needed
Eric has a great list You can consider an 'initial' class so you can add a letter to to the center of a plant outline and help delineate plants
I played with the plant massing and am now trying to develop a workflow with them- This is a great resource and would like to hear how others are suing them in practice Thank you Tony for the recommendation Observations: The preset configuration allows for more than 100% plant coverage in a landscape area The file size gets big quickly If you ungroup the landscape area, you get the 2D graphics of each plant in the area, but the redraw tales time, and the plan results can be chaotic
We did not quickly upgrade to VW 2019 because the software is too young and the timing of the MacOS update- Anyone who does is clearly taking a risk - It is totally understandable that everyone wants to newest and best thinking VW has to offer - If a significant group of faithful users do not take the bait of a shiny new VW release and wait for at least SP2 release, I would assume VW would change their ways- they will see the metrics - We are enjoying VW 2019 for 2 months now and have yet to upgrade to Mojave- We upgraded to VW2019 because of many new features - data tags are the best thing ever-
Is there a way to make the massing model and then make it a symbol and when editing one they all edit ?
Thank you so much for following up I am glad there appears to be a reasonable solution and terrific support through the forum Great work ! and All the best
- 21 replies
- site design
- site model
(and 3 more)
Tagged with:
A few screen shots of before and after would be appreciated
- 21 replies
- site design
- site model
(and 3 more)
Tagged with:
File management - XL Landscape Architecture Project
bob cleaver replied to D-VECT's topic in Site Design
VW 2019 has design layer and class folders/filters that makes navigation easier Simple and efficient file management has been the holy grail and there are many in the forum who can point you in the best direction- 1 reply
- 2
Vlado- This is a great explanation - even better than the help manual
So is the 2018 Mac Mini a viable VW machine?
bob cleaver replied to hobick's topic in General Discussion
The link below shows a mac mini with 2 eGPUs on DaVinci software The software allows to activate 2 GPUs and the results are dramatic I am not sure if this will ever be a VW option -
you will need to find where the comment exists - on the OIP, in a data selection on the OIP, I will check it out if time allows
you will need a note or comment column added to the worksheet- begin by reviewing the database options in the worksheet and add the comment, annotation, or note field to the database row and it will be added to the worksheet or it is possible to add a blank column and then add a pre-formatted comment, annotation, or note field (starting with = ) in the database row for additional info, Jonathan Pickup has free short you tube videos that show how to develop a custom worksheet with custom database functions Good Luck
Hi Eric Can you place your new resource in the VW library folders ? If you use a distinctive label for the resource, then your team will know the resource is yours and can access them We also have a few resources we have developed in irrigation and your question sparked my response
- 1 reply
- irrigation
- workgroup
(and 3 more)
Tagged with:
Benson thank you for the video, it was a terrific solution to this issue Sketchup has a similar issue i had not seen the video before and I appreciate your dedication to the forum
- 21 replies
- site design
- site model
(and 3 more)
Tagged with:
EdwinE - It is our pleasure to meet you We use Hunter Products exclusively on irrigation and Hunter has been busy with new products (HC series controllers and flow sensors) We look forward to more irrigation product development We also use butterfly valves to isolate remote control valve manifolds Febco back flow preventers are typical Hose bibb options are important We always add fountain autofill valves and swimming pool autofill Hopefully other uses will add info they need- Please review and comment- Thank you
I am waiting to upgrade to 2019 but want to know if the irrigation products/catalogs include Hunter's new controllers and flow sensor and MP spray heads and drip irrigation lines- Are there any details ? I look forward to the upgrade to stabilize the 2019 release and make it Mojave compatible I appreciate everyone working hard at Vectorworks to get the 2019 version stable and functional I am especially in awe of the many users working to get the release stable
1. in a new column place '=image' in the database row 2. size the cell for the symbol and use the symbol for display (not attributes) 3. be sure when you place the worksheet on the sheet, the classes you want for the graphics are on 4. more good advice will follow by other users 5. good luck
- 1 reply
- 1
Site Model Roadway Nurbs Vs Road way Poly Stations
bob cleaver replied to HEengineering's topic in General Discussion
Jonathan Pickup has a terrific series of road tool movies and how he adapts the tools to create complicated roads. I agree that the tools are good in certain applications and do not adapt well to complicated-real-life situations. -
go to 3D warehouse from sketchup and search also many manufacturers provide models on their web sites good luck Jonathan Pickup is the source for all things New Zealand
I learned Minicad then VW using the tablet only I also used sketchup for awhile, but now 100% VW the tablet does not take long to adapt to because you do not look at the tablet for cursor movement just like a mouse I have no experience with Cintiq line and I like using the computer screen for cursor control
I have been using a Wacom tablet for 20 years and I started with Minicad. I like the feel of holding a pencil and drafting It requires one handed keyboard use for right clicks, but I feel the tablet is a good input device and recommend it
you are welcome
check: in the OIP and make sure the plants are 'on the plant list' is selected- the classes of each plant group and whether the plants are 'on' and included in the worksheet-
Thank you Eric We had scaled the hatches using local mapping and this was part of the problem So... We scaled the hatches in the hatch edit dialog box and used world units and all is well-
