12,624 -
Everything posted by Pat Stanford
Yep. Remember that all items with the same criteria type are OR'd together. So your screen shot says give me all of the windows whose OnSchedule OR IDPrefix is 'W1-' If you really need to be this complicated, you can manually edit the criteria in the data bar, but you will lose the ability to edit using the criteria builder. After you edit the criteria and click OK to the criteria builder dialog box, take a look at the data bar. When I do that with a slightly simpler set of criteria (only one layer), I get Notice the vertical bar character between the IDPrefix and OnSchedule sections of the criteria. That specifies the logical OR function. That means the criteria will return every window on Design Layer-1 which has the OnSchedule checked OR has a prefix of 'W1-'. Click in the data bar and edit the formula to replace the vertical bar with a '&' ampersand and you will now only get windows that are BOTH On Schedule AND have a prefix of 'W1-'. It used to be that if you tried to edit a criteria that had been manually edited you would get a warning that you could not use the criteria builder. In VW2019, it appears that the criteria builder will open an just overwrite any manual changes you have made, so be careful.
If it is showing more than you expect, then you did not get the criteria correct. When you say set the criteria you mean you are right clicking on the database header row and choosing Edit Criteria? What are the criteria you are setting? Layer is "your layer" Field Value "ID Prefix" is "W1-" Since the option is for the field value EQUAL to what you type in, make sure you include the dash. Can you screen shot your criteria and post it for us to take a look at?
Are your Layer Option and Class Options set to Show/Snap Other, Snap Others, or Grey/Snap others?
Most likely the Header Row is hidden. Check the Worksheet menu:View and make sure there is a check mark next to Database Headers. If not select it to turn on the header view.
Take a look at the threads I referenced in this post: Set up a Workgroup folder that everyone can access and store the files in the correct folder and everything should "just work"/
Take a read through these two threads and then come and ask again if something is not clear. The second thread includes links to this post: and this thread:
- 4 replies
- 1
- workgroups
- resource manager
(and 1 more)
Tagged with:
To get it to work properly within symbols (and other container objects, i.e. groups and PIOs), each of the contained objects also needs to have the attributes set to ByClass. And just for the sake of saying it again, in order for contained objects to be visible, the containing object must be visible also. So if you create a symbol and put the symbol instance into Class A and then make Class A invisible, every object inside the symbol will be invisible also, regardless of the visibility settings of their individual classes.
I don't think Viewport overrides will do what you want based on the way you have things set up. Viewport Overrides only work on attributes that are set ByClass. Since you say you have objects with different fills, that means that those objects can't have the fill set to ByClass. I can think of some complicated work arounds, but nothing simple to do what you want.
Click the disclosure triangle (black downward pointing triangle) on the column with the area and check the Sum Values check box. This will sum all the values of "summarized" subrows. Without this checked you get what you are seeing, when objects with different values are summarized, you get a --- to indicate that the values are not all the same.
Vectorworks to PDF file low quality
Pat Stanford replied to Jonathan Cludts's question in Troubleshooting
The patterns are a holdover from the original Macintosh days. They are fixed 72 dpi resolution. If you need something better you will need to move to hatches or tile fills instead of the built in patterns. -
Sheet Layers (presentation layers) have a separate setting for resolution that is set to 72 by default. Try changing that (Organization dialog box, Sheet Layers, Edit, Raster DPI Setting). -
Every PlugIn Object has its own list. And if you create Custom Record Formats to attach to objects you can create and infinite number of record.field combinations. Check this thread for a script that will give the PIO fields in a worksheet for a selected PIO in the drawing. You probably want to read through the entire thread as modifications happened after the original post.
I agree with Robert that it is not a currently available functionality in VW. But I think it might be able to be scripted as a tool that might do what you want. How are you envisioning creating the links between the objects and the photos?
manipulating large quantities of records/ Lighting Devices
Pat Stanford replied to t-bud's topic in General Discussion
Often this has to do with drawing & redrawing handles. Try Grouping the object, change the layer of the group and then switch layers and Ungroup. I would guess this will be much faster. -
Yes, Hans-Olav is correct. It is also pretty well described in the VW Help. Search for Advanced Section Viewport Properties an excerpt:
Worksheets to stack rows up
Pat Stanford replied to MTRobin's question in Wishlist - Feature and Content Requests
The fixed "insertion point" idea should not effect the actual image of the worksheet at all, only where it is placed on the page. If it does otherwise it is a bad design decision. -
@MTRobinCould a different way to describe this request be: Pick the "insertion point" of worksheet images on drawing. If the Top/Left corner is picked as the insertion point and the worksheet increases in size, it will expand to the bottom and right. Similarly, if the Bottom/Right corner is the fixed point and the size of the worksheet expands, it will grow to the top and left. This option will allow worksheet images to be places at the edges of drawings and automatically expand into the drawing area instead of always expanding down and requiring the image to be moved to be on the page. The 9 point selector in the OIP as is used to determine the fixed point of 2D object (polygons, rectangle, circles) could be used to locate the fixed point. -
I am not certain that you can store a Workspace in the Workgroup folder. I know it works in the Application folder and if you edit one of the standard workspaces it saves it in the User folder. OK, I just checked and yes you can store the Workspace in the Workgroup Folder. You need to have a folder at the top level of the workgroup named Workspaces and you store the workspace files (*.vww) in that folder. But be careful, I think that data like the current active tool and the tool preferences are stored in the workspace file. If you have multiple people using the same workspace out of the workgroup, the last one to quit at the end of the day will overwrite any previous saves. Your tools may have different settings when you open VW the next time.
@Gadzooks, Thanks for the kudos, but my reading of the question is that @DCarpenter wants to do the opposite. He has the objects in the worksheet and wants to list the Location names. I don't think there is an easy way to do this. The LOC is not a property of the object. When you use the LOC criteria is goes through and compares every object to the objected named in the LOC and only returns the ones that do. If you have a "reasonable" number of LOCs (say 10-20 max) that don't change very often I would probably just create a separate database for each LOC and use that as a work around. If you have a large number of LOCs or they change name frequently (like you need to do this for every project), then we have to go to much harder options. The best option I can think of right now, which will probably be deadly slow on a large drawing) would be to create a custom worksheet function that will take an object, compare it to every object in the drawing with a name and return the Name of the first object that has the object in that LOC. If you can accept the LOC object being in some what identified (always in the same class, having a custom record attached, being on a different layer) then that would greatly decrease the number of comparisons and speed up the operation. Also, the way your database is set up, it is not going to work as you expect. Since you have your upbeats SUMarized, if you end up with objects in different LOCs, it will return a cell with a dash ("-") (I think) because the data is not identical for every object. Let me know if you need more help.
Workgroup Library VS Favorite In Resource Browser?
Pat Stanford replied to HEengineering's topic in General Discussion
It does not matter what the file is named. The only thing that matters is that it is stored in the correct folder inside Defaults, Inside Libraries, Inside a folder that is defined as a Workgroup Folder. If you have a single file with multiple different object types, they won't show up unless that file (or hopefully an alias) is in the correct folder for each of the object types that you want to be Default Content. -
If you want it to show as Default Content (say Line Styles), then you have to have them in EXACTLY the right location. Go to your user folder and copy the Libraries/Defaults complete folder structure to your Workgroup Folder. Libraries needs to be at the top level of the Workgroup folder and the rest of the hierarchy in enclosed in that. Then put the file(s) with the line styles you want to be Default Content into the Attributes - LineTypes folder. If you don't want to have to break them out to separate files, I think you can just use an alias to the file so you can use the same file in multiple locations. I can never remember is you need to restart VW after you change the Workgroup folder structure or not. If you put the file there and the LineStyles don't show up, try restarting. -
Objects are on a different layer and the Layer Options are set to Grey Others or Grey/Snap Others?
- 1 reply
- 1
Have you met the Chance Brothers? Slim and No? Just kidding, but what you are asking is not easy in VW, but it is possible. The only place in VW where you can be guaranteed to have a unique value is in the NAME field in the OIP. You could store your GUID there, but that is also used by some users and in some objects for other uses. Also, it is use accessible, so there is no way to keep someone from changing the value and messing up your database. You best option is probably to create a hidden record format and use that to store a UUID. In Vectorscript, there is a CreateUUID function, so it is probably in the SDK also. Basically, your script would first check for an instance of the hidden record. If it is not there, it would attach the record, create the UUID, and store the UUID into the record. Then that UUID could be stored into your database. Come time to go backwards, you would have to look for an object with a record.field value equal to the UUID in the database. What you do when you don't find and object depends on your needs. You might want to reach out to @John McKernonand see if he can offer any advise. His LightWright lighting paperwork program handles back and forth between VW and Lightweight robustly. That seems similar to what you are talking about.
There is a "bug" in the MESSAGE() procedure (or a bad design choice) that causes the Message to only display at the end of script execution. Probably not really useful for what it sounds like you are doing, but for debugging purposes, I use AlrtDialog. You have to hit return after each occurrence, but at least with a CONCAT you can display a string for trouble shooting purposes.
