Content Count
71 -
Community Reputation
10 GoodAbout Jeremiah Russell
Rank
Apprentice
Personal Information
Occupation
Principal Architect
Homepage
www.roguearch.com
Location
Little Rock, Arkansas
Recent Profile Visitors
Has anyone else had issues with the parking space object? The accessible space is all sorts of screwed up. The aisle is placed over top of the adjacent parking space instead of next to it and the width of the accessible space is 5' larger than what is specified in the OIP. HELP! Untitled-1 (dragged).tiff
This seemed to work. Not entirely sure why as the wall was highlighted when I originally inserted the clerestory window. All is good now though. I'll keep an eye out for this in the future. Thank you for your help!
I've tried that and it is not working. The work around is to have a separate wall above on another design layer, but this is not ideal in almost all situations. Any other thoughts?
Alright, this has only started happening recently. Anyone have an idea why this happens when I insert a clerestory window above a door? Instead of seeing the wall cut by the door it isn't cut by either the door or the window above. Help greatly appreciated!
OK, so I've created a bathroom as a symbol for a large multifamily development. But I need to have the door tags editable for each symbol instance. How do I do that? Thank you!
Thank you, everyone, for your replies and advice. This has been incredibly helpful and instructive. Moving from mostly single family and light commercial to large Multi-family has been an interesting transition. I appreciate all your advice! Cheers.
My most sincere thanks for the input you've all given so far. This particular project is a little complicated so I'm going to adopt a hybrid of just about all the suggestions above. Breaking out the units so that I can reference them (i.e. only draw/detail them once) is going to be a huge savings. Pulling out the elevations, section views and other details into separate referenced files is also going to be a huge savings of both time and CPU power. This will also allow me to bring in outside help without necessarily having to go the Project Sharing route. There have been too many bugs with that lately. Thanks again!
@herbieherb Thank you for your input. I hadn't thought of creating a layer for the units and then referencing them onto the individual stories. This particular project is a historic building, but the units stack vertically so that could save me a boat load of time and frustration. I'll give that a shot and hopefully it will help with the computing power. Currently I have 16mb of ram and a decent graphics card. I may be upgrading near the end of the year so we'll see. Thanks again!
I'm looking for advice on what the best workflow is for a large multifamily project. The project is 5 floors, 145k+sf. Currently my file is 500mb+ and is seriously killing my computer. It takes forever to do simple tasks. Should I break apart the floors into separate files, then reference them into a master file to pull all my sheets together? Or is there a better way? Thank you!
@Matt Panzer The entire wall comes unjoined. I don't know what custom component joins are. I use the join wall tool, not the join component tool. Is that what you meant?
@Matt Panzer It's generally noticed after I have have saved, committed and closed the file then come back to the working file. I do not notice it happening while I'm working in the file. However that's not to say it doesn't happen. One thing I can think of is that all my wall types are different. This particular project is an old historic masonry building and so I have about 15 different wall thicknesses all as their own wall style but with the same class and texture assignments. There are also a fair number of wall projection elements for pilasters at the perimeter of the exterior walls. That may or may not have something to do with it. Thanks!
@Matt Panzer I do not have any idea what might be causing the problem. I am using Project Sharing, though it isn't necessary right now. I am using Design Layer Referencing but not within the building model. The references are for 2D details on separate design layers not tied to stories. Any help would be appreciated. Thank you.
Lord give me strength. Can someone tell me why all my wall intersections are un-joining when I open the file? It's really getting annoying to spend hours every week re-joining my walls on a 145,000sf multifamily project.
