sam@pcd
Content Count
15 -
Community Reputation
0 NeutralAbout sam@pcd
Rank
Greenhorn
Personal Information
Location
United Kingdom
Recent Profile Visitors
Hi, Can anyone help with the following?. I am trying to connect the 2D and 3D elements of a 2D/3D symbol so all I have to do is edit the 3D aspect of the object. I have manually drawn a 2D object in the 2D part of the symbol. Can anyone help?
Hi, Can anyone help with importing IFC files into vectorworks?...First I imported the IFC file and then converted it in to an Auto Hybrid, then to 2D/3D symbol to give the object the 2D Visual I want. However when doing this process the IFC (BIM) data is hidden?..or disappears from the object.. Is there a way to add the BIM data so it is seen on the 2D/3D symbol?. Thanks
Hi, Is there a way in which you can edit the 3D part of a symbol and it will automatically change the 2D part of the symbol? It just becomes a bit tedious when resizing a shelf, table etc... Thanks
@Matt Panzer Hi Matt, Please see attached. Thanks, Sam WR500ML3 REVIT.rfa
@hepburngc Hi Graham, This is how I import the file... And then the result is this... However, it only provides me with a 2D view of the Revit model and then I go inside of the symbol and I try and create an auto hybrid, but it buffers for a very long time. I can see the potenially for it to be a 3D object, but the model has no texture and the mesh lines make it very complex. Hope this makes sense. Cheers, Sam
Hi, I am having issues importing revit files into vectoroworks. When I import the files it imports as a 2D/3D object, however the object doesn't have a texture, so I try the convert the Revit entity into an auto hybrib and the process buffers for an extremely long time. Is there a simpler more manageable way to handle Revit files in Vectorworks? And reduce the file size? Thanks, Sam
@Hans-Olav Hi Hans, I am having a few problems trying to get the BIM information to show on the 3D symbol. I imported an IFC from a manufacturer and then created an auto hybrid and then a symbol. However the BIM information is on the IFC model within the 3d symbol and auto hybrid. How can I move that Information on to the symbol which i've created? Do you have any advise on this? Thanks, Sam
@Hans-Olav Okay thanks, I will give that a go 🙂 Cheers, Sam
Hi, I am looking to add BIM to the 3D symbols which I've created in Vectorworks. Could anyone point me in the right direction to accomplish this? Thanks
@Pat Stanford Hi Pat, Happy New Year! Thanks for this! I managed to get the files to appear in my favorites as I add them in to the workgroup folder However there is nothing appearing in the workgroup libraries drop down, the files are automatically added to the favorites. Is this correct? Thnakyou!
- 4 replies
- workgroups
- resource manager
(and 1 more)
Tagged with:
Hi, I am looking to create a work group folder for 3 people to use the same library in the office. Is there a way in which I can share the library's I have on my vectorworks with others and for those libary's to update as I change them? Thanks
- 4 replies
- workgroups
- resource manager
(and 1 more)
Tagged with:
Hi, I'm looking to convert the library I have alrady created from Vectorworks 2018 to 2019. Is there an easy way to do this? I opened 2019 and via the migration manager I was able to convert the title blocks etc, but it didn't give me the option for library's. Do I need to save each file individually?...It seems a bit tedious if this is the case. Can anyone help? Thanks
There is only the natural light I think ( I am very new to Vectorworks..) Could you have a quick look at the file?.. White_Lion_Vectorworks_Rev_B_20_11.18.vwx
Hi Robert, I have checked the ambient light slider under set lighting options and it is turned off..
I am having a problem with the rendering using a renderworks camera. I have created my own renderworks style, however while on some projects it works like a treat, others it tends to become very bright and blotchy in areas. Can anyone help? Cheers
