Kevin Allen
    2,315
Reputation
1,067 Spectacular
Personal Information
  • Occupation
    Experiential, Scenic and Lighting Designer
  • Homepage
    klad.com
  • Hobbies
    figurative drawing
  • Location
    United States
Recent Profile Visitors
9,492 profile views
  1. you would have to build the lights as spotlight lighting devices, but then I would think it would be a great assistance.
  2. well, per instrument might account for different fog machines. I also miss the low fog option.
  3. I thought I recalled the PDF including links, might be wishful thinking on my part as well.
  4. There is a stock report called something like index of drawings
  5. IIRC, the standard ToC that ships with the app does this?
  6. Kevin Allen
    Renders fuzzy
    It would help to see the file, but are you using Loy fog or depth of field?
  7. a plan might help, but a sweep and solid subtractions
  8. not seeing your images, I usually start with a sweep.
  9. IIRC I messed with standard naming years ago, it didn't work and I moved on.
  10. Many of us have 'systems' in place, that have to be changed or forced to work around choices made by software engineers. Not sure that standard naming does the trick. The solution needs to work for all users. It gets more difficult with collaboration, but I want VWX to understand that I just don't use or care about the Lighting-LED class, even if I might be collaborating with someone who really needs that information. I want my own autoclassing and I want to override the internal autoclassing.
