1,331 -
Calendar
Everything posted by Kevin Allen
Possibly then taking GDTF from an interesting idea to something usable.
Ability to export PDF pages and images directly
Kevin Allen replied to karstenwolfGL's question in Wishlist - Feature and Content Requests
isn't this more of a function for Acrobat? -
So, this is another instance of a need for better Class Control. I have long wanted to be able to tell VWX that objects should be assigned to such and such a class.
I have not tried this, but if you can make the lens a lens object you can set the lens to pick up the color from the color filed in the OIP through the Document Spotlight preference. You need to have a class for the lens and a glow texture that uses the object attribute.
where is the card to improve the usability of the roadmap interface?
- 6 replies
- 4
- workspace editor
- designer
(and 1 more)
Tagged with:
Atomic Design in Lititz PA has a similar series of products and they offer VWX models.
terrific!
I have used them, I have to dig...
They have likely been provided by the manufacturer.
sadly no. If you built your own stand using marionette,that could be possible. You can also just add a vertical lighting position to get the unit at the right height.
standards vs template files, what is the difference?
Kevin Allen replied to grant_PD's topic in General Discussion
I'll look but pretty sure I do not have this ON. I do have lot's of classes, but I HATE it when I bring in an object or I am training and showing library content and I am bombarded with classes. I loping ago, edited and renamed 'none' and 'dimension' and they update always. Now if I could get rid of the classes that PRG and VER seem to think I need... -
My issue is always getting rid of the VWX created Classes and/or replacing them with my own. I keep my classes in my template. -
what do you consider a standards file? -
Find and Replace drawing labels inside annotations?
That would be very useful if it does not exist -
Import and edit .eps or .svg files?
Kevin Allen replied to CalebOtis's question in Wishlist - Feature and Content Requests
Once upon a time, there was an import Adobe Illustrator option. -
Is the 'Nomad' app still alive and does anyone use it?
Kevin Allen replied to line-weight's topic in General Discussion
I'd love to see Nomad Publish... with visibilities settings. Especially if the file is stored in the Cloud Folder or dropbox, although I see that adds a complexity. -
I've used something like this, not sure if it was this exactly. It can every useful
Rendering performance with referenced DLVP
Kevin Allen replied to livespace josha's topic in Rendering
the reference should be fine. -
I have often wished I was this organized. Frankly this kind of thing should be looped into the software help and linked in the dialogs. Noise bumps are another area where it takes a fair bit of hunting to understand.
In the top image. Change the texture to a backlit shader. Leave the glow as us and see what that does. Some fiddling will be required.
There might be chain ink enchain the libraries. All you need is a erecting image file. Ideally with an alpha channel, but you can often create that in VWX. The fence in from of a bunch of stuff will be a challenge, but against a clean black or white background should be good
I think I have this file, but I don't recall how/when these were made
IIRC, Adobe Illustrator lines have special corner definitions, that might be an excellent VE
