Ride Posted August 26, 2011 Share Posted August 26, 2011 I need to make a window and door arrangement like the attached PDF. I can't seem to find enough flexibility in the door dialogue boxes to make this work. I can get close, but how do you define a half-height sidelight? I haven't invested a lot of time in the window and door dialogue boxes, but what little I have has been frustrating..... Quote Link to comment
taoist Posted August 26, 2011 Share Posted August 26, 2011 Sounds like you need Windoor. http://www.ozcad.com.au/products/windoor.php You can of course create what you need manually. taoist Quote Link to comment
Christiaan Posted August 26, 2011 Share Posted August 26, 2011 Been told you need to spend $220 US to form a half-height sidelight is probably just as frustrating as not being able to do it. Quote Link to comment
Ride Posted August 26, 2011 Author Share Posted August 26, 2011 Is this true. VW can't do it? I assumed it was my own ignorance of the tools, although I did spend time trying - just thought I missed something small that would allow me to do this. I'm sure this topic has been discussed at length, but this is just basic functionality needed here. Quote Link to comment
taoist Posted August 26, 2011 Share Posted August 26, 2011 Maybe others who know better than I will chime in. taoist Quote Link to comment
Christiaan Posted August 26, 2011 Share Posted August 26, 2011 I didn't mean it can't be done Ride, just that you couldn't do it. I'd let you know if it was possible but I'm too many versions behind these days. Quote Link to comment
Jonathan Pickup Posted August 26, 2011 Share Posted August 26, 2011 (edited) I recommend you get windoor. the cost will easily be worth the time you would spend to create these doors and windows manually. windoor believes that windows and doors can be built into the same frame, thus you can make the window and door combinations that you want. Vectorworks believes that windows and doors are never built into the same frame, thus we have a window object and a door object. you can make a window, and a door, then push them together. I know the two side frames will overlap. Edited August 26, 2011 by Jonathan Pickup Quote Link to comment
taoist Posted August 26, 2011 Share Posted August 26, 2011 Good Point Jonathan. The issue has to do with the Software Engineers or maybe the Architects at VW or both. Do not miss understand me. I love VW but it again appears that those in the know do not spend enough time in the drivers seat as an end user or do not have to do what others do all the time. This is one reason why we have a wish list. I for one when I upgrade my VW will get Windoor. taoist Quote Link to comment
mike m oz Posted August 27, 2011 Share Posted August 27, 2011 Unfortunately ganging Door and Window units together works in 3D but not in 2D (see attached image and file). If Door and Window objects could be ganged together with the correct wall breaks in Plan view the problem would be solved. I made a wish for this some time back but it has never come about. Quote Link to comment
Jershaun Posted August 27, 2011 Share Posted August 27, 2011 It is issues like these (among others like plan infill colours) that I don't use vw's windows and doors hence vw fails as a BIM program. There's lots of modelling and manual work involved in vw. Quote Link to comment
CipesDesign Posted August 27, 2011 Share Posted August 27, 2011 Okay, honestly guys... This might not be exact, but it's just a door and a window, right out of the (VW's) box. This took 2 minutes, max. If you spend a bit of time experimenting I'm pretty sure you can get something that's workable. Not saying anything bad about WinDooor. It's awesome and has capabilities that VW's alone does not. Just showing what's possible... Quote Link to comment
Christiaan Posted August 28, 2011 Share Posted August 28, 2011 Peter, that's not workable unless you're willing to accept the way it looks in plan view, which any professional shouldn't be. Quote Link to comment
CipesDesign Posted August 28, 2011 Share Posted August 28, 2011 You're no doubt correct. I have sometimes simply annotated over the plan VP to get the graphics right. I know this isn't ideal, but sometimes you just gotta get something done. Ultimately, yes, VW's needs to correct this (and other) flaws. Keep filing bugs and wishes and hopefully the team will find time to tackle them all. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted August 29, 2011 Vectorworks, Inc Employee Share Posted August 29, 2011 Peter's solution can work in plan if you place both the PIOs in a symbol. Quote Link to comment
