Alora Posted July 21, 2010 Share Posted July 21, 2010 My drawings are colour-coded and I would like them to be in black and white before I export them as as pdf's. Is there a simple way to do this or do I have to change all of the individual attributes? Quote Link to comment
Pat Stanford Posted July 21, 2010 Share Posted July 21, 2010 File:Document Settings:Document Preferences Display Tab- Black & white Only Quote Link to comment
StaticDOS Posted July 22, 2010 Share Posted July 22, 2010 Or right click the viewport->properties->advanced properties->black and white only. Quote Link to comment
gmm18 Posted July 22, 2010 Share Posted July 22, 2010 Or Print to PDF First, then convert the PDF to Gray Scale after. This is not exactly Black & White, but the results will look closer to how it looked on screen (Yellow is lighter than Brown). I wish the Viewport Advanced Properties would have "Gray Scale Only," in addition to B&W Only. But easy enough to do it in the PDF. Quote Link to comment
CipesDesign Posted July 22, 2010 Share Posted July 22, 2010 I use gmm18's method. Simply print the sheet(s) to PDF using Mac's built-in PDF capabilities, then use Save As and select the Quartz Filter called "Gray Tones". I do this all the time and it works well. One bit of caution: some colors might not print to gray scale as expected, but this can be easily seen and solved once you actually print the resultant gray scale PDF... Quote Link to comment
Alora Posted July 22, 2010 Author Share Posted July 22, 2010 Peter et al, Thanks for the suggestions. I would prefer to print in a gray scale as I show concrete as a solid gray object for example. However, I am getting stuck after 'Save As' as I can't find 'Gray Tones' in the dialog box, which only asks for the name of the file and where it should be located. Quartz Filter has been enabled under VW Preferences. Alora Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted July 22, 2010 Vectorworks, Inc Employee Share Posted July 22, 2010 What I do is select the viewport and edit it's class attribute overrides (assuming you're using class attributes). Typically, I select all classes and set the pen color to black. I leave everything else as is so they will print in grey (if they're color). Quote Link to comment
CipesDesign Posted July 22, 2010 Share Posted July 22, 2010 Alora, the Quartz Filters are available in Preview (the Mac's PDF image viewing software which comes built in). So first create your PDF, then open it in Preview and then Save As... Hope that helps. Quote Link to comment
Alora Posted July 22, 2010 Author Share Posted July 22, 2010 Peter, Opening a pdf always triggers Adobe, but opening from Preview works! My plan looks great in shades of grey! Thanks, Alora Quote Link to comment
CipesDesign Posted July 22, 2010 Share Posted July 22, 2010 Hi Again, You can set your computer to always use Preview, but Acrobat Reader will take over as the default pdf viewer if you let it. You can change the default pdf (and other image file) viewer by selecting a single document in the Finder and going to its "Get Info" window. In there you can choose which application to use to open that particular document, or all other similar documents. Glad you were able to find the gray tones filter. I have used it for years and have always been happy with it. P Quote Link to comment
Alora Posted July 26, 2010 Author Share Posted July 26, 2010 Peter, You are right - Adobe keeps trying to take over when I open a pdf. How can I make Preview the default Pdf viewer? Alora Quote Link to comment
michaelk Posted July 26, 2010 Share Posted July 26, 2010 In a finder window select a pdf document. Don't open it - just select it. File > Get Info Toward the bottom of the window will be "Open with:" (there is a collapse triangle next to it. If it is collapsed, click the triangle to expand it.) In the pull down choose Preview.app Click the "Change All..." button You will get a "are you sure" warning. You are sure. Until you change it back, double clicking on any pdf should cause Preview to launch and open the pdf. hth michaelk Quote Link to comment
Jonathan Pickup Posted July 26, 2010 Share Posted July 26, 2010 For those that have one of my PDF manuals: If you set preview to be the default PDF viewer, and you open my PDF manuals with a double click, the manuals will open in Preview and Preview will NOT display any of the movies, or movie icons. If you right click on the PDF manual, you can still choose open with... Acrobat Reader. Quote Link to comment
CipesDesign Posted July 26, 2010 Share Posted July 26, 2010 Alora, Michael is exactly correct. However there is one other way that might help. Simply drag the PDF you wish to open to the Preview Icon in your Dock. See attached screen shot... HTH's Quote Link to comment
Alora Posted July 28, 2010 Author Share Posted July 28, 2010 Michael/ Peter, I have tried and failed to make Preview my default PDF viewer. When I open the Preview app. I can't find the 'Change All' button. Where is it? Since I can only print PDF's from Preview (I get an error message with Adobe) I really would prefer to use Preview. Alora Quote Link to comment
Pat Stanford Posted July 28, 2010 Share Posted July 28, 2010 The option is not in Preview, the option is in the Finder. Go to the Finder and select a PDF file. Go to the FIle menu and choose Get Info. There is a box called Open with:. if it is just one line, click on the triangle to open it. Choose Preview in the drop down box. Click the Change All button and it will set all PDF files to use Preview as the default application. Quote Link to comment
Alora Posted July 28, 2010 Author Share Posted July 28, 2010 Thanks Pat, that did it. Quote Link to comment
fargo3 Posted August 24, 2010 Share Posted August 24, 2010 (edited) I have written an Automator workflow. It takes a pdf, or group of pdfs and changes them from color to the Quartz filter gray scale. Unfortunately it only works for Mac folks. GrayscaleMe Edited August 24, 2010 by fargo3 Quote Link to comment
Alora Posted August 24, 2010 Author Share Posted August 24, 2010 Shawn - I've downloaded GrayscaleMe and placed it in my Application folder but I'm not sure how to use it. I've tried dragging my colour coded VW pdf to the alias on my dock but nothing happens. Quote Link to comment
fargo3 Posted August 24, 2010 Share Posted August 24, 2010 (edited) Alora and All, Sorry about that. I really should do these things when I am awake. I put the wrong link. So you should redownload and then follow these instructions. GrayscaleMe GrayscaleMe can be placed on the Desktop, or in a folder with an alias on your Dock. In this example, GrayscaleMe is on the Desktop for ease of screenshots. 1) Export the view you want from VW as a pdf. Step One 2) I save it to a folder called "To Be Grayed". NOTE this workflow will change the original file! So if you want a colored copy of the pdf, make sure you duplicate it. Step Two 3) Drag and drop the files you want to convert onto GrayscaleMe. Step Three 4) GrayscaleMe will ask you to confirm that you want convert the files. There is no going back to the colored version if you click "OK". Step Four 5) After GrayscaleMe has run it will append the file with"_bw". Step Five 6) Now all your selected files are converted to grayscale. Step 6 Edited August 24, 2010 by fargo3 Quote Link to comment
Alora Posted August 24, 2010 Author Share Posted August 24, 2010 Shawn, It worked perfectly! Thanks, Alora Quote Link to comment
fargo3 Posted August 24, 2010 Share Posted August 24, 2010 Alora, Glad to hear it! Good luck. Quote Link to comment
Stephen Comber Posted March 10, 2011 Share Posted March 10, 2011 Hi Shawn, Tried accessing your file but the attached error message came up. Any chance you could repost. Quote Link to comment
davidwd Posted March 26, 2011 Share Posted March 26, 2011 Hi Shawn , sorry to bother you . Possible you could repost the "Grayscaleme " Link as the link directs me to "Dropbox" but I recieve a -404 page not found notice . Thanks david Quote Link to comment
