71 -
Reputation
0 NeutralPersonal Information
Occupation
Architect
Location
British Columbia
For years I have copied and pasted a group of symbols (plumbing and appliances) from one drawing to another and the scale changes automatically from 1/8" to 1/4" etc. This time when I copied from a plan at 1/4" scale and pasted to a new plan at 1/4" scale the symbols are at 1/8" scale! How can I change them? Alora
I don't have time to book a training session between now and Friday when 17 drawings are due. Why would importing the Title Block from Autocad (DWG/DXF)be so much more complicated than importing the plans, etc? Can someone else please help?
Jim. Can you please walk me through the steps to import the title plan because changing the scale to 1:96, which is the scale for all of the other sheets, isn't working. It's still miniscule and I'm running out of time and patience! Thanks, Alora
Hi Jim, How about if I just re-import the title block? It was sent as a DWG/DXF. Alora
I don't have time to go through tutorial right now as I've got a deadline. (Actually been using VW for about 15 years but obviously missed this lesson.) The problem is I am working with another architect and am using his title block. Which plane should I import the title block to? The plans have been imported to screen plane but I can't paste the title block into it.
I've got Active Sheet Layer and Screen Plane - which is Sheet Layer?
I've imported some drawings and the title block is at 1:1 scale while the rest of my layers are at 1/4" scale. When I try to past the title block into the other layers eg. the plan, it's miniscule. What scale should I use?
Hi Jim, I tried joining the walls with and without the Join Wall Tool, and received the same message. I also tried a sample, changing an unstyled wall to a styled wall and received the same message. Any other suggestions? Alora
I changed a styled wall from 4" to 6" wide wall and now I can't join the corners. I receive a message telling me "This editing operation cannot be performed because of constraints on one or more objects." When I try to edit constraints I receive another message telling me "This object does not have any parameter constraints." What do I try next?
Isn't the reshape tool for 2d objects? How do I reshape a wall in 3D(isometric)? I am not ready to roof it yet.
How do I create a peaked parapet that will show up in an isometric?
I use Object Info all of the time and the Windows are in Wall.
Glazing is set to clear but what is OIP?
The windows do show up in the isometric but I want to be able to see through them.
That's exactly what the video showed and it worked like a charm? Is the procedure similar for making windows transparent?
