Popular Post bcd Posted September 25, 2023 Popular Post Share Posted September 25, 2023 (edited) Please allow Rectangles to be reshaped via the Reshape Tool. I don't see that it should be necessary to first convert them to Polygons. Edited September 25, 2023 by bcd 9 Quote Link to comment
0 Kevin Allen Posted September 25, 2023 Share Posted September 25, 2023 In theory that has been true for several versions, not in top/plan. 1 Quote Link to comment
0 Jesse Cogswell Posted September 25, 2023 Share Posted September 25, 2023 I played around with this a little bit, but I don't know what this would really gain. The rectangle already has reshape handles built in for general resizing, and any of the other reshape options (adding/removing vertices, hiding edges, etc) would make the rectangle not a rectangle anymore. What is interesting, is that if you use the Reshape tool and drag a marquee around part of the rectangle and resize from there, the rectangle will be automatically be converted into a polygon without a prompt. This goes back to at least VW2019. Initial Rectangle: Reshape tool w/ Marquee around corner: Result: 3 Quote Link to comment
0 bcd Posted September 25, 2023 Author Share Posted September 25, 2023 11 minutes ago, Jesse Cogswell said: What is interesting, is that if you use the Reshape tool and drag a marquee around part of the rectangle and resize from there, the rectangle will be automatically be converted into a polygon without a prompt. Yes, this is exactly what I'm envisioning - without the need to drag the marquee. For example I want to Hide/Show one edge of the rectangle. Many steps could just be one. 2 Quote Link to comment
0 Tom W. Posted September 26, 2023 Share Posted September 26, 2023 You don't even need to drag a marquee, you can just reshape a corner vertex directly. But I agree with @bcd there are frequent occasions I want to hide an edge of a rectangular shape + it's a pain having to either draw it as a Polygon initially or convert a Rectangle to a Polygon after the fact in order to do it. Perhaps another approach would be for the Polygon Tool to have a constrained rectangular mode in the same way that there's a triangle mode. It's almost there with a 4-sided Regular Polygon... Then we're not compromising the integrity of the Rectangle Tool 🙂 2 Quote Link to comment
0 bcd Posted September 26, 2023 Author Share Posted September 26, 2023 7 hours ago, Tom W. said: You don't even need to drag a marquee, you can just reshape a corner vertex directly. Bah! - I had selected the wrong mode - yes, it's behaving exactly as I expected as all of you indicated thanks @Tom W. , @Jesse Cogswell @Kevin Allen And in Top/Plan too. However, Change Vertex, Add/Delete Vertex, Hide/Show edge don't yet work yet on rectangles. And here's one I overlooked from prior versions - very interesting. I'm interested to see when that may become useful, maybe during schematic design. 2 Quote Link to comment
0 Pat Stanford Posted September 26, 2023 Share Posted September 26, 2023 I also would like Reshape to work on Rectangles. I think maybe the reason it doesn't is because it is changing the type of the object. If that is the "only" reason then a warning message "This action will convert a rectangle into a polygon. Do you want to proceed?" Yes/No with a Don't Ask again check box would be the best solution. 2 Quote Link to comment
0 Tom W. Posted September 26, 2023 Share Posted September 26, 2023 3 minutes ago, Pat Stanford said: I also would like Reshape to work on Rectangles. you mean modes 4-7 presumably Quote Link to comment
0 Pat Stanford Posted September 26, 2023 Share Posted September 26, 2023 In addition to modes 1 that already converts to Polygon and Modes 2/3 that resize while leaving the object a rectangle. Quote Link to comment
0 Tom Klaber Posted October 9, 2023 Share Posted October 9, 2023 Is the simplest would be to retire the rectangle object entirely. The rectangle tool should remain - but simply draw a 4 sided polygon. 3 Quote Link to comment
0 E|FA Posted October 9, 2023 Share Posted October 9, 2023 2 hours ago, Tom Klaber said: Is the simplest would be to retire the rectangle object entirely. The rectangle tool should remain - but simply draw a 4 sided polygon. Agree completely. Should be easy to implement (easy for me to say, at least). Does anyone have a workflow that this suggestion would break? Quote Link to comment
0 zoomer Posted October 9, 2023 Share Posted October 9, 2023 For me the Rectangle Object is one of the greatest VW features. I think it is great that it tries to stay a Rectangle. For me it is reasonable to need to convert it first to be able to destroy it. (I think I have "Convert to Polygon" in my RMB "object mode" option menu) I always get crazy when in DWG Apps, a Rectangle is just a mere Polyline and so easily distorted accidentally. And a VW Rectangle has so many unique and cool features. (OIP Action Center radio buttons, length/width auto adjust, option to keep aspect ratio when scaling, ....) 3 Quote Link to comment
0 line-weight Posted October 10, 2023 Share Posted October 10, 2023 Agree with @zoomer - I'd not want the rectangle retired. Just make modes 2-7 (in addition to mode 1) of the reshape tool automatically create a polygon. No need for mode 2 to preserve as a rectangle because if I want to do that transformation and preserve the rectangle I can do it with the regular selection tool. Also have never noticed mode 3 before. But if this were to preserve as rectangle, wouldn't it be more consistent to include this in what the selection tool can do, rather than the reshape tool. 3 Quote Link to comment
0 Giacomo Devoto Posted October 10, 2023 Share Posted October 10, 2023 Totally agree with Tom. Consolidating rectangles into polygons would simplify reports too. In many cases I need to quickly calculate the surface using rectangles and polygons. Also selecting with magic wand in some cases I forget to select either the poligons or the rectangles when I usually need to select both types... Quote Link to comment
0 zoomer Posted October 10, 2023 Share Posted October 10, 2023 6 hours ago, Giacomo Devoto said: Consolidating rectangles into polygons would simplify reports too. Lines vs open Polygons too ? (Just kidding) If it helps for reports and calculations, I would be OK with sorting VW Rectangles into a global (closed) Polyline scheme .... as long as all "Rectangle-features" are somehow mimicked be Edit Tools or similar. On the other hand, I often used and want, to keep the ability to magic-wand-select only (true) Rectangles vs other 2D geometry. So I do think that in the reports case, I would rather like to see that change/feature include into the features of Reports (?) For the initial Rectangle to Polygon Conversion task, I could live much easier with that, when Reshape Tool automatically destroys Rectangles, when you grab a Vertex (as long as there is no better solution). BTW, AFAIR, could even be that there is an old post somewhere in the Forum where I wished exactly for the same thing, that it would be more consistent if Reshape Tool does an Auto convert to Polyline. But only if needed as a Vertex is grabbed in Vertex Mode .... But that was surely before I learned to love VW Rectangles and their reliability .... Quote Link to comment
bcd
Edited by bcdLink to comment
14 answers to this question
