rudybeuc@gmail.com
    237
Reputation
95 Excellent
Personal Information
  • Occupation
    Architect
  • Hobbies
    Distilling
  • Location
    United States
Recent Profile Visitors
5,922 profile views
  1. I'm at wit's end again, going to lunch.... I'm trying to create a custom window assembly with an arched lintel. I've managed to get the symbol inserted into the window assembly, but cannot manipulate it, or make it show up after exiting the window assembly edit mode. What's going wrong now??? Thanks, Rudy Beuc Window Assemblies Feb 2026.vwx 2026-02-05 11-26-21.mkv
  2. Ok that did the trick. It hadn't even occurred to me that I had to look out for that when updating the wall style. I spent hours last night trying to find a "manual override rvalue" (or something similar) to stick in my worksheet function. I know I'm going to be iterating designs in ResCheck, so in order to not have to manually recorrect each individual wall, I wanted the wall style to drive that value. Thanks, Rudy Beuc
  3. So, I'm trying to figure out a workflow to integrate ResCheck into my projects. I need to schedule my exterior walls with their desired R-Values. Please see the attached project. It's a stripped down version of what I'm working on. The problem I'm currently having is I can't seem to get the manually overridden r-values to appear in my worksheets. Only the calculated ones will appear. How do I correct this? Currently in the example, the manually entered R-Values are facetious. Once I get this problem solved, I'll correct them. Thanks, Rudy Beuc Wall R Factor.vwx
  4. <<"plugin object style options",>> Aggghh!!!! I spent hours last night searching for where it was buried. Went through looking at all the settings for the style several times. Yeah that was it. To answer the issue brought up in another message, maybe if you could right click over a locked down parameter and get info on what's doing that/where it's controlled. Kinda like the "Locate Plug-In in Resource Manager" function. Thanks, Rudy Beuc
  5. Why is the Class setting in the OIP locked down for window and door assemblies? Thanks, Rudy Beuc 2026-01-25 21-27-02.mkv
  6. Ok, way past beer-30 today, so I apologize in advance. I was on a preliminary interview with a couple today for a renovation of their house. Brought along my Ipad, tried to get some primary measurements and maybe a point cloud of a retaining wall outside. Had connectivity through 5g connection with my android phone acting as a hot spot. After saving to photos, 3d Nomad became a brick. Nomad needs to Cache jobs to upload and allow the user to work while sync is going on in the background regardless of connectivity or it is useless. Thanks, Rudy Beuc
  7. Honestly, all I what I want is to not have my tools die because of someone else's precarious business plan. Attached is my Grandfather's work, which I still have access to in its' original format. Thanks, Rudy Beuc
  8. I just had to go back and look at this thread to solve the problem again. Had to dig for that setting in my new saved elevation viewport style... Thanks, Rudy Beuc
  9. Please see the attached files. A window with the top shape set to half segment from left and a muntin is not resolving correctly. What's up? Thanks, Rudy Beuc Window Problem.vwx 2025-10-06 19-38-37.mkv
  10. But with Service Select, they do get money every year.....
  11. I'm sticking with Service Select until it is no longer an option. Then I'll keep my perpetual license and figure something else out. Subscription Only licensing is not an option for me. thanks, Rudy Beuc
  12. It has since cleared up. If I remember correctly, switched off the clip cube and that seemed to help.
  13. Well, this iteration of the family business has been around since 1961. I've had my license since 1996. We've made it so far. No lawsuits, no complaints to any licensure board. I get alot of my work from contractor recommendations. They are the type that like a complete and detailed set of documents. They roll it out and get to work. Something from my grandfather.... Thanks, Rudy Beuc
