Gal
21 -
Reputation
4 NeutralPersonal Information
Location
Israel
Recent Profile Visitors
Thanks guys, I tried to open the file on a more capable system and it seems you are right. I guess I need an upgrade soon 🤭
Thanks! I’m working on an old intel iMac. It’s inlet a section viewport with openGL background and hidden line foreground. here is the file.. OMZ_Work.vwx
Strange, #IPZL# gives me no value. What is this function?
Hello, I'm getting this weird effect. It's like a miniature version of the surface colours that should appear. Can anyone help me undo it? I'm on VW 2019 with these OpenGL settings:
Hello everyone, Is there a way to create a data tag showing the height of an object (it’s z location) relative to the layer elevation where it’s placed? I’m working on VW2019 Thanks!
Hello everyone, Is there a way to insert a symbol such as a recessed light fixture into a slab while making a hole in it as with walls? Gal
Hello everyone, I'm trying to create a venetian shader plug-in object, that will get it's parameters from a window it will be associated to. It's Section should look like this: While X will be determined by the window's height, and the plan view should look like that: At the window's width. Can anyone help me? Where should I begin? Gal M
Hello! I'm wondering, is there a way yo number the stairs without starting at 1, in order to number each floor separately? Gal
Thank you Mat! I'm trying to achieve this without changing the structural logic of the building. I need the Section to look like this: I tried to uncheck "Draw Edges" from the Background Render Settings, and it resolves the wall-slab face issue, but then I lose the outlines 🤷♂️
Hello everyone, Can anybody help me get rid of the edges between the walls and the slab? How can I get a smooth wall in Open GL?
Hello, I'm trying to create an existing site with an existing retaining wall. When creating a retaining wall site modifier with a pad under the wall and a left side modifier, I'm able to get only some of the terrain to follow the side modifier. Am I doing anything wrong? Gal
Hello, this is the first time I try to work with Vectorworks in 3D. When creating a section viewport I see the wall with a VERY thick line in one floor and a very thin one in the other floor. Does anyone understand who's going on? I'm using the same wall style in both floors. Gal OMZ_Sections.pdf
