3,173 -
Everything posted by Andy Broomell
Just wanted to put it out there that about 5% of the time when I go to Tools<Purge, Vectorworks crashes (when clicking OK after previewing items to purge). Haven't been able to figure out the rhyme or reason as to why, but it's been doing it for years across different files and computers. Always at that same point in the process. Just curious if anyone else has encountered the same issue.
Reference Marker Arrow Angle
Andy Broomell replied to Andy Broomell's question in Wishlist - Feature and Content Requests
Bump -
Awesome! Just wasn't sure if I was missing something on my browser
Just curious if this is this still the case? I just got a notification about someone "reacting" to a post, but I can't see what that reaction was, nor can I react to others' posts.
To make new textures - double click in a blank area of the RM (or click the "New Resource" button in lower left) then choose Renderworks Texture. Give it a name. Under the "Color" shader dropdown choose "Image" then import your custom image. Assign the texture a size in the lower lefthand area. The new texture you create will then live in your file. If you're wanting to make it available across numerous files via a custom user library, let us know.
Select the Wall and go to the Render tab of the OIP. Find the dropdown that says "Part" then select any portions of the wall that don't say "from Overall." For each of those, click the "Revert to Overall" button, which then makes those faces listen to the "overall" texture assigned to the Wall. Hope this helps
Not anymore. :-/ Hoping they re-implement the ability to do this.
🙌 🙌 🙌 I just want to reiterate that the current "always-do" implementation for title block borders is decidedly wrong and inconsistent with other VW tools. I've had three unrelated acquaintances call me in the last few weeks asking what's wrong with their title blocks' double-click function. (They had inadvertently chosen to always edit the Layout, but because the layouts are all By Style, every time they double click a title block they just get an error saying they can't edit the instance's layout.) @JimW @Nikolay Zhelyazkov Any way of confirming whether this is a bug or working "as designed"? Right-clicking and choosing "Edit" needs to bring the pop-up back, just like it does for Viewports.
Auto Hybrid Separate Cross Sections
Urgh. Today I found myself thinking "oh this is a perfect time to use an Auto Hybrid" ....until I was reminded they don't do what they should. Some simple flats with sliding doors: Looks like a fat mess. :-/ PLEASE allow an option for separate cross sections -
Sheet Title updating per character entry
Andy Broomell replied to Charlie Winter's topic in Wishes Granted / Issues Resolved
This happens to me occasionally on SP2 as well when typing in project values. -
I just came to this subforum to ask where the "Edge Split" mode went in 2018... But then as looked closer it seems as though it was rolled into "Face Split" mode which is now just the "Split" mode and functions as both
Is it possible to have white drape appear white
Andy Broomell replied to Tony_PSAV_PM's topic in Entertainment
Are you able to post a screenshot of what you currently have? Sometimes for things I want to appear whiter, I'll add Reflectivity<Glow to the texture, then put the Brightness around 40% (depends), turn off "Emit Light" and turn on "Add Matte Reflectivity". The Matte Reflectivity is important so that it still reacts to other lighting and shadows in the scene. -
@scottmoore THANK YOU for continually beating this drum. I don't use lit fog beams anymore because they look so unrealistic in Vectorworks. Thankfully I haven't had to render many rock concert-style shows recently, but if I were a lighting designer I would be livid at the current functionality. The funny thing is if you go to the Vectorworks home page http://www.vectorworks.net/ you're immediately greeted with an image that's completely unattainable in Vectorworks.
- 54 replies
- volumetric
- rendering
(and 2 more)
Tagged with:
Great chart! Are you already utilizing the "Text Scale" factor in the Advanced Viewport Properties? This should allow you to scale up and down text when the Viewport scale doesn't match the Design Layer scale. (So in your example you'd type in 0.5 to get the text to appear as 12 point again)
- 3 replies
- text style scale
- annotation
(and 1 more)
Tagged with:
Question: the video at 0:56 mentions needing to use a Render Mode with Indirect Lighting. Lit Fog seems to also work for me with Indirect Lighting off. Of course, turning it off results in the renderings looking very different than those in the video (since they all have Indirect Lighting on), but I just wanted to bring it up as it might be misleading to suggest Lit Fog requires Indirect Lighting. (It of course looks better with it on )
Awesome, thanks! Any chance we could play around in this stained glass file? Seems like a good learning set-up.
This (lack of) functionality baffles me.
- 3 replies
- publish
- navigation palette
(and 1 more)
Tagged with:
Basic Tool Pallet and Tool Set Bar always resizing
Andy Broomell replied to mlance's question in Known Issues
This used to happen for me consistently in 2016 and 2017, though 2018 has actually been better for me, thankfully. -
When I use indirect lighting, I tend to turn off Emit Indirect Lighting for textures that are applied to super complex geometry such as plants, grass, 3D figures, etc (as long as it's not detrimental to the rendering). Saves some time.
"Move along path" animation problems/suggestions
Andy Broomell replied to line-weight's question in Troubleshooting
All excellent points and questions! This command needs some love. -
Searching & Finding objects hidden in groups
Andy Broomell replied to Asemblance's topic in General Discussion
Another approach is to make a worksheet with the criteria set to find objects on your class. Then you can then right click subsequent row headers (there will be a row for each object on that class) and choose "Select Item" which will select the object even if it's inside a group or symbol. Let me know if you need more details on this process. -
Update all viewports on selected sheet
Andy Broomell replied to Bertf's question in Wishlist - Feature and Content Requests
I'd use this. In the meantime, I use the Select Similar tool (I have a preset for "Object Type") then click on a single Viewport on the sheet. This selects all the viewports, which I can then update by clicking the Update button in the OIP. -
My "M" is mapped to Mirror
