Bertf
87 -
Cloud services shared document .vcdoc is blank when opening in browser
Bertf replied to Bertf's question in Troubleshooting
Thanks for the hint Pavol, but it think it was just a general bug. My previous uploads work now. -
Bertf posted a question in Troubleshooting
I've shared a document with the cloud services. So it upladed a .vcdoc file to my cloud. When I try to open it, it briefly shows the toolbar but then everything goes white. I just end with a blank page no. No content, no tools, nothing. Is .vcdoc bugged? Or what am I doing wrong? Thanks, -
Toggle between wireframe and shaded render mode with shortcut
Bertf replied to Bertf's topic in Python Scripting
Thanks Jesse for your input. Thanks Pat for the script and link. I went for Pat's script so I don't have to do the panning. I can confirm this work flawless. Thanks! I just want to let you know that the pdf "SST-Add a Command to a Workspace..." on your linked post isn't downloading for me though. Might be broken? But I've been able to add it as a menu item and add a shortcut to it with the workspace editor. Thanks again. -
Busted. 😁 Thanks for the quick responds! I'll try them out now. -
Hi, I want to be able to toggle between wireframe and shaded view on my design layer with a simple shortcut key combination. I'm trying to do it with a script. Can anyone point me in the right direction for the commands? I do find the wiki and git a bit uncomplete to find these commands. I also tried to use DoMenuTextByName but that didn't seem to work for setting the render mode. A bit of the (not working) script logic: (doesn't matter if it's in python or vs for me) import vs # Get the current render mode current_mode = vs.GetRenderMode() # Check and toggle if current_mode == 2: # Wireframe vs.SetRenderMode(6) # Set to Shaded else: vs.SetRenderMode(2) # Set to Wireframe I know, you can put a shortcut on "shaded" and another one on wireframe. But I'd rather have it the same button to toggle between the 2 states. Thanks, Bert
Hi, I made a custom tool a couple of years ago with it's own custom icon: This worked perfect in vectorworks 2023 and previous versions but since we're using 2024 and now when I'm setting 2025 up the icon is blank in my tool palette: I'm thinking it has something to do with the color scheme introduction in vectorworks? But I can't get the icon to work. The location of the plugin is in our workgroup library. Thanks for the help, Best regards, Bert
Isolating and Deleting Point Cloud with Clip Cube
Bertf replied to benelmo's topic in General Discussion
Also stumbled upon this bug in VW 2024. -
I just checked out your marionette. The "Create Custom Object" node seems great, any hint where I can find the naming of the objects? Like Drilling 3D is "XG CPDrilling"? CenterPunch is ..., ... Is there also a node to adjust the properties of the created drilling object? By propertyname for example? I can only find SetIFCProperty which has input object, name and value but not sure if these are the same as object properties. If that's possible, I think it's not such a big deal that I (or extragroup? @Stephan Moenninghoff🙂) create a library with these "Create Custom object"-networks wrapped into InteriorCad nodes? Kind regards, Bert
Wow thanks for going to such lengths to test this! The reason I asked about this is because I would like to create the Hawa Concepta pivot and sliding door drilling pattern with a marionette. https://products.hawa.com/shop/en/on-furniture/hawa-concepta/hawa-concepta-25.html MON_XX_Hawa_Concepta_25_30_30182 (1).pdf In the pdf in the attachment you can find the manual with the drilling pattern for this fitting. As you can see below, the positioning is parametric with parameters like EH, Q, ... At the moment I just place a NC-macro 3D on the part and fill in some parameters in the record. In NC-hops, I have programmed the drilling pattern according to this macro and the parameters. The big downside on this is that I don't see the fitting in 3D. So because I can't see the fitting and drilling in 3D I was looking into this direction to use a marionette so that I can place a 3D drilling with depth ="depth" and diameter="dia" on position x="EH/2" and Y= "26" for example. And accordingly place some extrudes parametrically that resemble this fitting. So you're not sure this is a stable way to go? Thank you for your help.
Do you mean that if for example I make a parametric marionette which contains Drilling 3D objects and I place this marionette object in my drawing on some custom parts that the drillings wont be connected to the custom part? So on CNC export the drillings are lost? Thanks for the information.
Hi, Is there a library for marionette which contains the Interiorcad objects, like NC-macro 3D, Drilling 3D, Dado 3D,...? So that the marionette can create and place these object according to the script? For example how you can place a line: Or should we place it in a control group and try to adjust it's properties with some node? I wasn't able to get this one to work. Thanks, Best regards, Bert
Change drawing title of multiple viewports not working.
Hi Pat, Thank you for your suggestion. My response might have sound a bit harsh if I read it now but that was totally not my intention. My apologies. A script is not necessary for me. But thank you for volunteering to write this. Much appreciated. Best regards, Bert -
I'm indeed changing the viewport drawing title, which is not unique. I'm not changing the viewportname (this is unique). Thank you for suggesting a script. But I think that the expected behavior would be that I can just change the drawing title of multiple selected viewports at the same time. It's like selecting 20 rectangles and changing their width in the OIP. They all change to the new width. So If I want multiple viewports to have the same drawing title, I would prefer not going through the hassle to activate a script for this simple operation but just do my adjustment in the OIP. This would make the behavior consistent as with other properties of other objects (like the rectangle example). -
Hi, When I select multiple viewports and I try to change the drawing title of all of them only one is renamed. Please see the screenshots, I have 3 section viewports and I try to rename them to 'vertical cut'. After entering the drawing title only one is renamed: Is this a bug that not all the viewports get the new title? Would be a time saver for me if I don't have to go to every viewport and copy paste the same name in. Thanks, Bert
Unshaded Polygon No Lines render mode needed
Bertf replied to Christiaan's question in Wishlist - Feature and Content Requests
@Christiaan I'm not sure if you mean this with your explanation. But we're missing Hidden line with displaying the textures/colors of the objects. A bit like OpenGL but without the need to up de DPI settings of the sheet to get a clean result. If we boost the DPI settings, other hidden line viewports take forever to render. So we mostly just draw colored polygons on our viewport: Left one is without coloring, right one is with manually coloring on the viewport itself. Would be a big improvement if there was a Hidden line with colors ofcourse.- 18 replies
- unshaded polygon no lines
- final unshaded polygon
(and 1 more)
Tagged with:
