Art V
    2,349
Reputation
571 Spectacular
2 Followers
Personal Information
  • Location
    Netherlands
Recent Profile Visitors
  1. When importing dwg files you can/could add a prefix or suffix (or both) to a dwg layer name. I used this to import multiple dwg files that used the same layer names but I wanted to keep the imported layers separate by imported dwg file e.g. I had multiple drawings with layer names option 1, option 2 etc. Upon import I would add a prefix with the dwg file name so I would get dwg1-option 1 dwg1-option 2 then import another dwg and get (after updating the prefix/suffix before importing) dwg2-option 1 dwg2-option 2 etc. Maybe you can to this with VW files as well, i.e. create a set of classes and layers and save it into a file. Then import this file and add the required prefix and/or suffix to the imported layers and classes. I don't know if that would work because I never had to do this with VW files, but if it works it may be faster than the above described method with search/replace
  2. The way it should work is to right mouse button click on an object and then use "select by class" (or layer) as the ideal option or as you mentioned to activate the class or layer first then then "select objects in active class" (or layer). I don't know/remember if select similar can be limited to select only by class or layer property of an object in the latest VW version.
  3. Maybe they put a zombie on this task and people fired too many bullets at it causing it to lose its finger so typing code slowed down a bit? It could be an explanation of why it is taking so long 😎 Nine years after the first request and still no bullet points? It seems like that when it comes to text handling CAD software likes to stick to old methods of hand drawn drawings. Oh well, I still have some Rotring and Linex lettering guides with bulleted list symbols lying around for use after printing. Maybe you can still buy them from Amazon or else there is eBay and the likes. (if your clients can appreciate traditional drafting)
  4. Service Select cannot be transferred, only the perpetual VW license. You will have to contact your distributor or Vectorworks directly depending on you location and they will be able to provide you with the form to be filled out.
  5. You could take a look at humblebundle.com, they regularly have book or software bundles for learning software, programming etc. including Blender, Unreal engine, python etc. at considerable discounts. Last month they had a Blender core skills bundle for approximately 35 USD though you are free to spend more to extra support the charity to which part of the payment goes to, whereas at CG Cookie (where the bundle came from) is more expensive. CG Cookie is a learning/tutorials website for Blender with a monthly or yearly subscription but they do have free tutorials as well. Maybe useful to know if you want to model things that you cannot (yet) model in VW as easily as in Blender or only at considerable more cost.
  6. Often implementation is not the difficulty but convincing the developers or those in charge of development priorities that it is really useful to implement a certain request in the near future is.
  7. If there is still no way to deactivate an install you will have to contact your local tech support/distributor to let them know you need to install it on a new computer and have the activation of the decommissioned computer released so that you can install it on the new computer.
  8. On the Rhino3D forum the company employee moderaters will file a bug themselves into McNeel's bug tracking system, mention that on the discussion thread and provide a bug tracking number which is also a link to a page with the bug description as they have filed it in their system. If necessary they'll request you to send the problem file if needed. Otoh I can understand why they may ask you to file a bug report yourself if their system asks you for additional details (like I described for my other CAD program) with the option to attach files without either having to post them on the forum or use temporary upload links with the theoretical possibility that it gets attached to the wrong bug report, then it is more efficient to do it that way as things will then get properly registered etc. into their bug tracking system and may provide a more efficient way for follow-up etc. It's just that this extra advantage for follow up seems to be underused by VW, at least for the online bugreporting on the VW website. It is a bit better when done trough the local distributor's website as the local distributor is more likely to do some follow-up.
  9. Yes, but once the employee lets you know it is a bug or whatever that development needs to work on it turns into an informal bug report and it should have follow up. In my case as described with the support system of my current CAD program, the support request will at some point get closed as something that requires deveopment but... I can at any time reopen that ticket to add more information or to ask about the status of the issue and will get a response within a reasonable timeframe. That is something that I've always felt to be a bit missing with the VW online bug report system. There should be a similar option on the forum that should generate a "required" reply from either the person you talked with on the forum or from someone else from VW to inform back to you about the status etc. in case that is possible. Otoh there should also be some system to prevent that option to be "abused" by impatient people causing the developer to be flooded with status update requests.
  10. Not to bash VW people/support, but this is a stark difference with the support from my other CAD program that I am currently using as my main CAD, which does offer subscription as an option next to the perpetual licenses. When I file a support request with my current CAD program (whether it is a bug report or a how to question), I have to indicate which version I am using, the OS and what kind of issue it is, e.g. Bug report, feature request etc., and which functionality it is about (e.g. 2D drafting, 3D modelling, Mechanical, BIM etc.) and the support request will be automatically routed to the right person. In the case of a bug report it will be directed to one of the developers for that kind of issue/functionality (e.g. a BIM issue will be directed to a developer working on the BIM part and not to one involved with general 3D modelling). It may take up to two working days depending on time differences etc. but you will get contacted by an actual developer who will stay in touch until either the issue has been solved if it is something on the user's end or when you will get informed that this needs to be taken up by the developer team to solve. With more major issues it is not uncommon to get an e-mail after a while to let you know the issue has been fixed, or the feature has been implemented and that it will be included in the upcoming update/upgrade (or SP in case of VW). With VW bug filing throughout the website you're more often than not left in the dark if anything will be done, how and when etc. Maybe the above support system is what could be implemented now that they are SaaS only to remediate a lot of the frustation on end users part. Some of it is already there when filing a bug, but the rest feels like it is missing, with the exception of occasionally being contacted by support to provide further info. The local distributor's support is way more like described above but if it needs developer involvement it turns into a black hole where you can only hope that it will be taken up by the developers.
  11. Totally agree with this, this forum really needs someone like Jim Wilson who was basically a single focal contact point between users and VW inc. who you could contact for follow up etc. When he left VW inc. I was wondering if there would be anyone stepping into his (very big) shoes to continue what he did, alas that didn't really happen. No matter how well the current team is trying to respond, as you mentioned it is/feels a bit haphazard and inconsistent for the end users of VW and occasionally it gives more of a can't do than a can do/will try impression. Once you go SaaS you really need a good support framework on the forum showing the company is having at least someone dedicated on fixing issues/answering questions or directing people towards the correction direction to solve it themselves if possible if you want to attract new/potential users, otherwise the comments filled with frustration, disappointment etc. may deter new/potential users from trying VW which would be a shame imho. The other part is good CAD documentation, there was still quite a bit of useful/essential information missing with quite a few topics in the help documentation that would enable people to actually get something achieved instead of a general description of a feature or command but not telling how to actually use it to make it work. This issue is not unique to Vectorworks though, it's the same with a lot of other software where at some point you just get stuck because there is some essential bit of information missing in the documentaion/help files.
  12. It was done retrospectively in the sense that at some point they announced that (older) perpetual licenses would not be reactivated on a new computer anymore or at all from a certain date. A quick search at upFront eZine came up with this article where it is mentioned: https://www.upfrontezine.com/2020/02/upf-1043.html So it basically turned out to be perpetual on the existing computer on which it is currently activated as you stated or on a newer computer if activated before March 2021 implying that after March 2021 (re)activations were no longer possible. There is probably a line somewhere in the EULA that allows Autodesk to change the EULA terms at any time etc. etc. etc. that allows them to get away with this. Anything that works to get their customers on subscription is probably acceptable to Autodesk, if you don't want subscription then they don't want you as customer.
  13. Sorry for the confusion, my memory failed me somewhat with the replacing of blocks. If you use the Drawing Explorere and select multiple blocks to replace with a single one it does indeed not work and works only on a single instance, just tried that out myself. Then I checked an add-on to see if I perhaps used that one and that turned out to be the case. I'm using the ToolPac add-on, with that I can selecty multiple variants of a block and replace it with one single instance, or even select multiple different blocks to replact them with a single other block. In both cases it uses the substibute command from ToolPac to do that. The procedure I described does work for layers and I did manage somehow to replace a few variants with a single variant instance somehow recently without using ToolPac, that may have been a lucky circumstance as I don't recall exactly what I did with that one. ToolPac is unfortunately windows only. The BLOCKREPLACE already exists in V22, though it might be new on V23 on Mac/Linux.
  14. For regular blocks this was already possible before components got introduced. For components the procedure is still as you are used to as that works a bit different from regular blocks.
  15. After seeing the subscription rates it looks like the subscription will be at least double the VSS rate I was paying, not counting possible rate increase in the coming years. I sold my license because for the near future (say 3-4 years) I wasn't expecting to be using VW much if at all so paying for VSS didn't make sense and upgrading might not be possible either if it would be 3 years or more before I would be using it again. So it looks like I will be sticking with my other CAD program and probably not return to VW in the foreseeable future. Competition for VW, at least for my past usage of VW Landmark, is increasing and in some areas even leaving VW behind already so it will be interesting to see how this move will pan out in the future. The dwg based way of working is sometimes a big pita compared to VW's user interface and some of its tools but not worse than the AutoCAD user interface that I was used to before getting into VW so I'll manage. Vectorworks is great software despite some of its flaws, but that applies to other software as well, so I hope that for the small businesses it will remain somewhat affordable and that it won't go the Autodesk way where they basically just aim for corporate clients.
