VW to TM on Mac finally
Well ! Finally the VW Mac rendering world takes a leap forward!
Many thanks to the VW Team for this great mid-cycle bonus !
The Datasmith export/import to TM is very clean. Our models come in just as we see them in VW. The re-import update in TM for changed VW models so far is flawless and extremely fast. Even better, texture changes made to your model in TM remain so.
just short of the live link method, this is still a massive leap in realistic render workflow. Now If we could get VW lights to come into TM....
  • Like 3
If something went wrong or you use a custom Workspace,
you may need to manually add it to your Workspace by (on Mac)
Menu > Tools > Workspaces > Edit current Workspace : Menus
and search it on the left list under Files : and darg it to your
"Files > Import" on the right side.
hace 1 hora, zoomer dijo:
Should be "Export Unreal Datasmith (3D only) right?"
You do changes in VW Model,
you export the Model by Datasmith Export again, overwrite the previous datasmith file.
Go to Twinmotion with you file, but in import window you don't click on the plus sign
as with initial import, but on the small "Update" icon.
In the best case, this will update your changes but keep your changes done in TM.
Haven't tested this so far.
(strange results when updating FBX imports some while ago,
but maybe already fixed)
Edited by zoomer
Twinmotion 2021.1 shipped yesterday, it has some fixes that will help the usage with Vectorworks, you can use collapse by material on import now, no more shading problems with bump maps, no more fireflies with reflective textures.  The cloud presenter feature is super interesting to me.  Get the Update with Epic Game Launcher.
Navigating in TM needs you to use a combination of keys for movements and the right click of the mouse.  I managed to connect my 3dconnexion navigation but only for replacing the keyboard.  Navigation in TM feels a lot like a video game.
I'm not a gamer. I tend to only use my trackpad. I have been considering a 3D mouse, but and this is only what I've found so far, I think the middle mouse button is needed for some basic rotational navigation. I think I might need a basic mouse. The three finger swipe does not seem to substitute in TM
The 3d spin around?  I assume you mean our 360 panorama?  if so, then the steps are fairly simple:
Place your view at the spot and height you need to view the room > then Export Panorama > set your render mode, resolution, processing location (your computer or cloud) and place to save the final file. Click export.
Hi everyone!
What's the workflow you use when importing VW model to Twinmotion for texturing, lighting and final rendering? I've been thinking that a good idea is to export everything with dummy textures easy to find in TM, since I do all of them there. Didn't consider lighting that much since all of my stills are with day light, but also another feature to keep in mind. Still trying and playing with different options. Open to hear how you do it!
I was pretty happy with C4D export in the past.
Now with new Datasmith export it could be even better.
I have not yet enough experience though.
I only see that the same project's TM files get larger and
did not run that smooth on my M1 Mac Mini as my older
C4D exports did.
But also first need more experience with newest TM 2021.
Yes, I would also use at least VW dummy Materials.
So you already have Material assignments and can easily
overwrite those materials with TM materials.
And maybe VW Materials may be already sufficient for most
secondary simple Materials and you only have to overwrite
and care about most important, Glasses, Metals and Woods ...
