398 -
Calendar
Everything posted by Luis M Ruiz
In order to see what is changing your panorama, I'd have to see your custom style or rendering style. These may have ambient light on or off and that'll produce obvious changes.
3Dconnexion SpaceMouse - Reversed Axes, Roll Left/Right
Luis M Ruiz replied to Mark Aceto's question in Troubleshooting
Take a look at the one for Onshape. That'll get you the feel you are looking for. These devices are mainly for 3d work as we all know, but not all 3d jobs are the same. Laying walls in a project are not the same as removing a pipe from under a car chassis. Sometimes you want the object be the things that rotates and others be the active observer who can walk thru a project -
All 3d space mose settings can be configure to your liking. -
Morpholio Trace
Luis M Ruiz replied to Christiaan's topic in 3rd Party Services, Products and Events
Try STL format -
Here is another sample from my bag of goodies. I guess diamonds are forever?
Hi. Sorry for the delay. Here is a link to the original VWX file: https://www.dropbox.com/s/hcyovqlre52ccmt/Stained Window.vwx?dl=0
@markdd Congratulations on this webinar. I am always mesmerized by how projects in Spotlight are put together. I am sure many of our users will find your video informative and inspiring.
Plenty of settings allow you to go past 100. Here is another fun use of glow texture.
Just for inspiration. Here is a sample of an interior rendering using only glowing textures.
Keep in mind, with renderings, we are dealing with digital reality. The idea is to get those images out so we can keep the ball rolling with our projects. If it means to deviate from real light values, I'd say that is valid. I imagine our clients would not ask if renderings were or not created using specific lumen. I learned my lesson the hard way. Post one of your test renderings here, or if you want, contact me directly and I could take a look at your file.
@RishieCan you post a rendering of your interior lights ON and the exterior heliodon object Off, and environment light OFF?
I was wondering if any super user here have created renderings including light caustics effects? I am curios to see your applications. To get the topic started, I thought about posting one project I recently re created testing these M1s
Morpholio Trace
Good questions. Here are my quick answers: 1 - Morpholio trace can take these 3d formats coming from Vectorworks: OBJ , STL, DAE, 3DS. and of course flat images like pdf or jpgs 2- For placing the exported pdf or image on nomad, you have to set your ipad to see the nomad integration. Check out min 2:00 of this video https://university.vectorworks.net/mod/overview/view.php?id=3056 3-I'd start saving the sketch in pdf in nomad > then import into vwx as a reference Post some of your project here using morpholio and vwx -
Morpholio Trace
If you know and love sketching for jobs, you’ll feel right at home. How to use them both? Here is what I’ve been doing for my projects: you can model in vwx let’s say, some massing models, bring it into Morpholio, rotate your 3d shapes until you find the right angle, then create a sketching layer on top and start sketching. ok, all good so far, pretty fun. Now it comes the time to bring that sketch into vwx. Export the image and save it in a Nomad, then import it into vwx but as a reference, that’s a useful ticket. If you keep making your sketch prettier or just change a few things, and replace the image in nomad, then in vwx is just a matter of updating the reference. I personally like using this method for storyboarding videos o just doodling a future rendering. Or just for a quick floor plan sketch. -
Negative. This issue seems to be on the right track
Would you mind sharing the file in a private message? I'll take a look at it.
In order to set a view, nowadays many of us make use of all of these navigation tools. Once we like the view position, typically we save the view and create a viewport from it. The next level would be to place a camera object and make the camera match the view and then create a viewport. There are many advantages for using a camera object, including being able to use its rendering effects. Then the next level would be using one of these 3dnavigators. I like the use of the Rotate 3d view but only if I know the rotation values.
- 1 reply
- 1
To start, I'd use brightness by percentage. 100-150-200%. all of these values really make a difference when using normal, smooth or realistic setting. When it gets interesting is when you make that light as a symbol. The symbol can also be control by percentage. So you could have a standard light at 100% brightness inside the symbol but when placed in your model set at only 50%.
Grainy renderings despite high DPI settings
Luis M Ruiz replied to TallulahOrcel's topic in General Discussion
I'd recommend you stick to something around tabloid size at 300dpi -
I personally think I squeezed as much as possible out of renderworks for interiors. Now, I am realizing exteriors are a different challenge. The benefits of a single light source for exteriors along with a nice environmental light and the speed at what these other third party rendering process animation. I just won't decide, I'll just embrace them all. To me, the 3d modeling is the key, 60% of my time goes into that aspect, 30% on getting those materials and lights just right, the rest is just production. Here is a another sample project, single light source and done with the help of the direct link to Enscape. only done in 2 min. Drape Enscape.mov
Based on my current experience the and rendering pros I hang out with, truly realistic renderings can be achieved using other systems. Blender, V-Ray, Unreal, Cinema4D, etc. Ray tracing is super important. Lumion, Twinmotion, Enscape are all nice and produce fast renderings but still nothing compared to the bigger brothers. Then again, not every single design firm needs ultra incredible movie level type animations or renderings. Speed, quality, budget, computer requirements, all of these are factors to consider.
And if you'd like to see its 360 panorama, here is the link: https://cloud.vectorworks.net/links/11eb93ee57b32cfe85ba12bd733fbe07/
Just a follow up with my previous post. I'll invite you to check out the making of this file here:
