MHBrown Posted October 2, 2015 Share Posted October 2, 2015 I'm I the only person who wants the double line tool to also make curved double line entities? It would be just like the round wall tool, except not a wall tool. I don't understand how this type of tool is not considered fundamental? If I want to draw a curved solid I have to draw two arcs, make one radius smaller than the other and clip it. The I have to stitch them all together. I would be nice to have all the functionality of the arc tool, but to draw double lines. Is it there and I'm I just missing it? I hope so. Thanks, MHBrown 2 Quote Link to comment
michaelk Posted October 2, 2015 Share Posted October 2, 2015 (edited) Try using the poly line tool to draw one side of the double line (lets you use all the corner/curve options), then use the offset tool with /Offset by Distance / Offset Original Object / Offset from Nearest Edge /Close Open Curves checked. hth mk Edit: To be clear - I agree that a polyline version of the double line tool would be a good idea (Jim?). The above method is the workaround I usually use. Edited October 2, 2015 by michaelk Quote Link to comment
mac@stairworks Posted October 3, 2015 Share Posted October 3, 2015 MHBrown, Good idea. I would second that. Maybe submit it to the wish list. Quote Link to comment
Jim Smith Posted October 3, 2015 Share Posted October 3, 2015 1+ What I do is use the Curved Wall tool with a generic wall. If I need it as a 3D object as opposed to a Wall then I convert to a Poly. Quote Link to comment
Matt Hall Posted June 16, 2023 Share Posted June 16, 2023 Is there a curved double line tool yet? The site model tools have come a long way and I would like to make a curving sidewalk but cant find a one step process to make a curving polygon Quote Link to comment
Tom W. Posted June 16, 2023 Share Posted June 16, 2023 7 minutes ago, Matt Hall said: Is there a curved double line tool yet? The site model tools have come a long way and I would like to make a curving sidewalk but cant find a one step process to make a curving polygon Can you draw a single Polyline then use the Offset Tool? Quote Link to comment
bcd Posted June 16, 2023 Share Posted June 16, 2023 25 minutes ago, Matt Hall said: would like to make a curving sidewalk but cant find a one step process to make a curving polygon It would be very helpful to expand the Polyline tool so it draws either a single line, the center line, left side or right side of a double sided polyline - the offset of which was adjustable via direct input or slider during the operation or in the OIP afterwards Quote Link to comment
Jeff Prince Posted June 16, 2023 Share Posted June 16, 2023 43 minutes ago, Matt Hall said: Is there a curved double line tool yet? The site model tools have come a long way and I would like to make a curving sidewalk but cant find a one step process to make a curving polygon Are you just doing 2D illustration or trying to make hardscapes? If the latter, draw the centerline of the sidewalk using the Polyline Tool, probably Arc Tangent Mode the best, and layout your centerlines. Then, right click on the polyline, select Create Objects from Shapes, and pick the hardscape option. That works well for sidewalks of uniform width, which sounds like what you are after. When it comes to tangent arc designs with intersecting arcs, you just have to lay out the shapes the old fashion way and convert to hardscapes after the layout is complete. 2 Quote Link to comment
Matt Hall Posted June 16, 2023 Share Posted June 16, 2023 Right on Did the polyline tool the did create objects, hardscape path object Thanks thats the simple process i was looking for, in hindsight I should have figured that out. 1 Quote Link to comment
