Handheld Showers
I cobbled together something out of the Sottini catalog.  But I was thinking along these lines...  The handheld shower runs along rails or is fixed.  Controllers shift between handheld and overhead showers.
At least in the US, we are not allotted much code-mandated real estate to locate the handheld device and controller (above the grab bar)...
Thank you, @VIRTUALENVIRONS. I am always amazed by your modeling skills. While the world of plumbing fixtures doesn't change all that rapidly, we should probably get an update every few years through service select.
Looking back through the content releases, the last time we saw new plumbing fixtures added was September 2019. Sinks and toilets are present in almost every architectural job.
Vectorworks cannot be the best in BIM without better access to current architectural (not interiors) content.   It can't be hard to hire an intern whose only task is to hound companies for content.
You are specifying a plumbing fixture for a job, does the manufacture provide you a Revit object you could import into Vectorworks?
Institutional stuff like ADA compliant bathroom fixtures should be pretty easy to come by.
That seems like a big ask of VWX, I'de rather they focus their resources on fixing the software wouldn't you?  It would be a never ending quest trying to keep up with all the manufacture's offerings each year and then making them optimized for Vectorworks.  Revit & DWG seem to be the standard for manufacture provided BIM objects for a reason.
19 minutes ago, cberg said:
Including decent plumbing fixtures is not that huge an ask...
Yeah, but how to you get consensus on what is a "decent" plumbing fixture?
Anyhow, we've spent more time discussing it than it would take to actually model something from scratch at this point 😉
It's probably faster to model something than searching the VWX library too, unfortunately.
1 minute ago, JustinVH said:
We ask the user to hound the companies to work with Vectorworks so we can include their products as we feel that if many users complain there is a better chance of it happening.
That's good advice.  Landscape Forms seems to do a great job of getting their content into Vectorworks.  They are also awesome to work with on projects, bending over backwards to help you along every step of the process.  Consequently, they get spec'd and installed on lots of public work.
Same thing with Tuuci umbrella, they probably sold over a 100 of those rectangular cantilever units just because I found them in the Vectorworks library 🙂
