353 -
Reputation
171 SpectacularPersonal Information
Location
United States
Recent Profile Visitors
2,351 profile views
Have you tried switching to the 4th insertion option in the tool bar which used the actual insertion point?
@39TechThe properties that Jesse is talking about are accessed by right clicking on the truss symbol on the design layer and clicking on the 'Customize Truss Symbol Data' menu.This cannot be done in the edit symbol modes, only from the design layer.
@39TechThe code issue that the error has been fixed but the content still has the errors as that can only be updated once a year. The corner will have to be manually fixed per the instructions that Jesse has listed above.
Spotlight Truss Tool Additions
JustinVH replied to Jeff Bonny's question in Wishlist - Feature and Content Requests
We have reached out to Unisson, Therio, and Arcofab on several occasions and even spoken to them at trade shows and have received no response to add their products into Vectorworks other than the currently limited selection from Therio. As we have mentioned to other users who are requesting other manufacturers it may take the users of their product(s) pressuring them directly to talk to Vectorworks in order to get the process moving as opposed to just us trying to connect with them. If a manufacturer sees that there is a need from their users to be in Vectorworks it might help to push them to respond to our emails or even reach out directly. -
@Mickey You can have multiple connectable with types, all you have to do is place a semicolon followed by a space between each type.
@mhiltondesigns In the Miscellaneous Entourage>Entourage Vehicles folder there is a file of mobility scooters that contain more than just hospital style wheelchairs.
In the regular Vectorworks libraries there are 12" corner blocks for Tomcat. The blocks are located in the TC1212 Plated File and within that file is a folder of corners and hinges.
Alexander Thiel started following JustinVH
Converting Vectorworks Truss to Hybrid 2D/3D Symbols
JustinVH replied to Nina Agelvis's topic in General Discussion
@Nina Agelvis Attached is a script that will remove the BrxTrussItemRecord from all of the truss objects in your drawing. You will first want to delete the Truss Record and the Rigging-Truss-Magnets class and all accompanying magnets from your drawing before running this script. Keep in mind that this is a brutal script that will strip all of the functionality or auto-connect and Braceworks. There is no undo after you run this script so make sure that you only use it on the truss objects that you want to make simple symbols. As the truss will be reduced to a simple 2D/3D symbol and not a parametric object there will be no ability to rotate in 3D and worksheet functionality may suffer. Keep in mind that if you ever want this truss to return to functional truss you will have to reimport the symbol from the RM or do all of the truss record, auto-connect, Braceworks, and Truss Magnet setup manually. Purge_Braceworks_Record.txt -
This could also be done with a script to remove the BrxTrussItemRecord from all symbols in your document. This can be dangerous though because in order to restore the functionality the truss will have to be setup again as a truss object and not just a symbol. To second what halfcoupler asked; Why do you want to do this? -
Those plus signs represent the middle of the truss profile and used to represent the old points for auto connect. Not sure why they are red and they should only be visible in wireframe.
I was able to get the corner and the straight truss to connect without any issues. In order to clear the static system not supported issue I had to connect another straight piece of truss to the 90° corner of the corner block to make a "L" Shape. Once I added three motors to pick up all of the elements I achieved a successful report.
Circle Trusses and their weights - Vectorworks 2020/2021
JustinVH replied to martin.vacek's topic in Braceworks
You can adjust the weight of the piece of truss yourself in the Truss Properties dialog to match what is given from the manufacturer. We are currently working with Eurotruss to do a complete review of all of the Vectorworks symbols and correct any issues with weights and other items. There is no timeframe for completion but luckily those are user editable values.- 1 reply
- 1
Prolyte H40V box corner - struggling to configure correctly
JustinVH replied to Mike Wright's topic in Entertainment
Thanks for pointing this out. That is an issue that I will be fixed. All truss should have a cross section assigned so that Braceworks will function properly. If the data is not available then it should be set to Rigid. Regardless, all truss should have values in length and width. -
I took a look at the file and the issue is that the cross section values are showing the truss length and width dimensions of 0mm (screenshot with blue oval). If the dimensions have no values the auto connect will fail and that is why things were not connecting to the left. I was able to fix this by going into the Truss Properties and reassigning the H40V cross section to the piece of truss and clicking 'ok' in the dialog. The trick is to make sure that the length and width are 387mm (screenshot with green oval). By reassigning the cross section the length and with will auto populate because the dimensions are defined by the cross section. Once I corrected the missing dimensions the truss corner behaved like expected. -
@Mike WrightAre you able to share the file so I can have a look? You can message it to me is needed.
