587 -
Everything posted by Elite Exhibits
@katebjohnson Import the file with the Drag n Drop as @E|FA mentions above If it is not a Layer Plane Object to begin with, change this in the OIP Do so in the Front View (import the graphic only as a Screen Plane. First set the desired size, view, location, etcetera, then change it to a Layer Plane Object - less work) If the graphic is a rectangle you are able to resize it as you would a rectangle Move this Layer Plane graphic in 3D space, until it is just in front of where you want it to be. (Attached - GRAPHIC ON A WALL.mov - shows such an example.) Note that the Graphic is visible with the design in a wireframe state. If this graphic is not the final shape you desire, Double Click the graphic and add a Crop. The crop is any single shape you are able to draw. This Graphic / Sign is two dimensional. ie: Layer Plane is akin to extruding geometry and setting the Z to Zero. It is adjustable in 3D space. (¿ 2D or 3D ?... Confusing) If it is the face to a sign cabinet, create the cabinet with extrudes, and apply the graphic where the sign face is If you wish, for example a set of flat plate letters, on a brick wall, use a PNG with the back ground invisible / alpha channel / green screen. (Attached - BLACK LETTERS ON CABINET.mov - shows such an example.) Black Letters (logo) is a graphic (PNG) set, just in front on the cabinet face. This could be a separate piece of geometry placed as a "Decal" or if you have a few hours to kill, a Texture in a Texture as VW calls the Decal option in the OIP. BLACK LETTERS ON CABINET.mov BLACK LETTERS ON CABINET.mov BLACK LETTERS ON CABINET.mov Peter GRAPHIC ON A WALL.mov BLACK LETTERS ON CABINET.mov
Go away – Component Edit palette!
Elite Exhibits replied to Kaare Baekgaard's question in Wishlist - Feature and Content Requests
What is a long term issue is: VW not understanding the workflow ramifications of the additions / changes / features. As far as the Component Edit palette goes, the title of this thread is apropos - We have been forced to find alternates to the workflow because of it. Peter -
@line-weight maybe you know this - we have found the above to be another aggravation of Unified View Peter -
@Bruce Kieffer Ironic ... wish it WOULD auto center and often, it does not Workflow has added Command-6 to the regular mix Peter
FYI Compose should work - Make sure the end points touch exactly - arcs are often on bad behavior in VW Peter Compose Arcs.mov
Subtracting Object Disappears when the Subtraction is Ungrouped?
Elite Exhibits replied to Bruce Kieffer's question in Troubleshooting
@Bruce Kieffer FYI I have taken to using Solid Subtractions more and more as one is able to edit a solid subtraction and retain / edit the fundamental 3D Shape (Extrude for example) - Additional Subtracting items, added to the Solid Subtraction, is easy task vs recreation. That said, I have experienced on (too..) many occasions your dillemma - I have learned to close and not save or undo / undo / undo and get back to where I started. As I have not directly documented this issue, my only clues were Unified View Being Off vs On. See attached - Two Extrusions Top and Bottom... and a few Subtractions from the bottom Peter Fake it Solid Subtraction.pdf -
How to identify screen plane objects in an old file?
Elite Exhibits replied to Amanda McDermott's question in Troubleshooting
FYI A constant nuisance about Layer Plane objects is when setting a 3D Perspective View and some 2D Objects will lay down on the mythical ground plane off in the far-flung distance, when all you want is an object that will stick to your screen ... ¿ Does anyone use Layer Plane for On the Drawing worksheets ? Peter -
@serge_01 is that floorplan a variable ? ie: will it change ever ? (Is it geometry? - 2D / 3D ? Something similar in the past - the floorplan was a PDF that was static (did not need to render) Added to each Sheet in the Title Block or as another Viewport Peter
- 13 replies
- 1
FYI Unified View has been an interesting aggravation since it was introduced. The way it looks - Unified View is Auto Align Layer View - Align Layer View - a command that was/is in VW The Unified View default settings are the caused many issues - Ignore Layers with Different Scales especially. Why VW chose to set them this way is ? Thousands of drawings with Design Layers at Different Scales that output together. Likewise drawings with Screen Objects on Multiple layers. ¿ ...Reference images in a Drawing as Layer Plane ? - Or a Worksheet that counts parts ... as a Layer Plane item ? A common design may be one or two Design Layers (different scales) with Multiple Saved Views - Publish the Saved Views for client presentation. How would one implement Unified View for such a workflow ? This is a partial list of issues with Unified View we have encountered: Missing Geometry when Editing (Groups or Symbols ?) - see attached Geometry that has moves visually when Editing (Groups or Symbols ?) ie: Selection indicated geometry is in one place - actual object is in another Parts of Geometry (¿ Symbols ?) that disappear when Rendered (Open GL ?) Invisible Geometry (Open GL Rendering ?), that reappears when rotated with the Flyover Tool, then disappears again. Geometry that can not be selected or only selected with Select All Geometry that is Indicated in the OIP - Not visible in on the drawing - (Typically Group or Symbol ?) Text that is missing from a newly opened drawing (¿ Design Layer ViewPorts / Link Layer Views ?) Text in Callouts that disappears when moved / edit (¿ Delete Callout and Start Over ?) Text that is missing when switching Saved Views a temporary solution is to turn Unified View , off, if it is on - or on, if it is off. VW 2019 (?) - 2023 (on different Macs) Peter Unified View Defaults_1.pdf Unified View Issue Nov 20th.pdf
Should VW be finding me a 45 degree line here?
Elite Exhibits replied to line-weight's question in Troubleshooting
@line-weight with the Cube rendered - Press the "B" key ... Peter -
@line-weight it is a rhetorical question. as was noted - some items work well in Screen Plane, yet fail in Layer Plane Why I almost never draw Layer Plane Objects - Many ways too work in VW See the attached - Clip Surface vs Move Point to accomplish a similar (¿ easier ?) outcome. Peter Clip vs Move.mov -
FYI After you have the Snap to Bisector preference set (Thats the key to the 45 degree) - increase the time in the Acquire Edge to keep VW from jumping to the next line. (Long time will prevent this jumping - while you use the G key ...) It is quite awkward to do it this way as VW appears to jump to the next point / edge if there is simple movement. (... Hint: Don't use these settings to edit Layer Plane go to Top/Plan and edit in 2D Peter Move Point to Bisector_1.mov -
¿ Why have Layer Plane 2D if you switch to Screen Plane 2D to have the tools function correctly ...? Peter -
@Alana Check Unified View - not up to VW 2024 here yet ... Unified View (whether you use it /need it / etcetera) causes a multitude of odd aggravating visual anomalies See attached - just happened today - file has a single Design Layer, many Sheet Layers Peter Unified View Issue Nov 20th.pdf
Fake It Peter Fake It_1.pdf
@Iliesa To be fair, we have also experienced something like this. VW 2019 - 23 - The suggestions / comments above do not link into our workflow. So ... as it has been an oddity the assumption was inherited details, ancient Symbols, even operator error, though your comments echo our situation. The sleuthing equates to very specific symbols and the classes they are in. When inserting them in a drawing is the time we watch out for issues. The thought is: Class switching is based on creating or editing symbols and selecting / changing the Assign to Class. The clue to this issue is when components disappear and they are found in a rarely, though recently used Class. Peter
Option to disable classes in sheet layers
Elite Exhibits replied to Steve Murray's question in Wishlist - Feature and Content Requests
@Steve Murray Curious ¿ What class are these in on the Sheet Layer ? Peter -
Editing a Design Layer, with Specific Class settings, then Looking at the Results on a Sheet Layer ...From the Design Layer - A Saved View takes one to a specific Sheet Layer with Classes set as desired (ie: all on) Previous View then goes back to the Design Layer - Classes are back to the original Specific setting Publish the Saved View (Not just the Sheet Layer) Classes will be set as desired / expected Agreed - Automation would be great Peter Publish Export Settings.pdf -
Still puzzled on this as Saved Views (as @Tom W. states) are already available and function as requested Peter -
@Nick Armory An easy Worksheet to look at chair counts Isolate / Select chair to count only the desired set Worksheet shows the XCenter and YCenter for each symbol Symbol (=S) in the first column with Count (=Count) is in the last column Summarize the XCenter and the YCenter columns Note that the Count, where a duplicate is in this example, becomes 2 In the first Column (The Grey Column with Numbers 3.1, 3.2, 3.3 etcetera...) Right click and Select Item - this will show you where the pair in that row is on the drawing May also help to isolate the chairs in a group or on a different layer - easy to ungroup or move back after the duplicate resection. Peter Chairs.vwx
Ability to lock plan rotation
Elite Exhibits replied to Christiaan's question in Wishlist - Feature and Content Requests
@Kyle Sutton So my question in this thread... (Ability to lock plan rotation) How do we keep Rotated Plan from happening at all? We would like to Lock the Plan Rotation at Zero ie: We want Standard Views to always show the view in real world terms Top Plan is Top Pan - NOT rotated / Custom / etcetera Any advice is appreciated Peter -
@Steve Murray Try creating a Saved View - We have been able to print a Sheet Layer as it stands. ie: Classes set for the Drawing and the ViewPort Class Set in the OIP. and the same Sheet Layer as part of a Saved View controlling the Classes for the Drawing. The Save View sets the Classes for the Sheet Layer, NOT for the ViewPort(s) on that Sheet Layer. Publish: Select The Sheet Layer then select this Saved View Peter
