lixinpm
18 -
Reputation
2 NeutralPersonal Information
Location
Canada
Recent Profile Visitors
Rendering Problem! why the model looks like this.....
lixinpm replied to lixinpm's topic in Site Design
Thank you so much for your suggestions. I copy the all model to the original and it seems to be good. This problem happens Sketchup as well and never thought VW has the same problem. Thanks! -
Hi, Everyone, I have one project which need to make 3D model. When I import SU model and plant trees, the model look like very wired. Does anyone know the reasons? But if I copy all the elements to new file, it becomes fine. But after a while, it happens again. The 2D drawing is fine and only rending 3D is wrong. Thanks! Best
Help_Why the landscape area cannot texture bed on the proposed Site Model?
Thank you very much! I recognized this issue, if it is not accurate, the site model probably would not accept this option and the landscape area will not "textbed" on the site model. That is for sure, thank you -
Hi, Amanda, Nope, I have tried all the methods you mentioned, it does not work. the thing is that this problem happens very often (one of them can be texture bed, but other cannot). Does anyone know how to fix and what is the reason? -
Help. Please see the attachment file for test I have made three pieces landscape areas with same parameters, but why is it one of them can be texture bed on the site model, but other two pieces cannot? I have choose "texture bed" and same layer "site model". This questions suffering me many hours and Next Monday is deadline. Thank you so much if there is anyone who know this reason. 2071198271_TESTforPlantingareaandsitemodel.vwx
Help, how would more information about the class be added on the worksheet?
Hi, Pat, Thank you so much! The reason why I did not use hardscape and landscape area is that this project is huge. I am concerning this huge area will slow down the computer when we use hardscape/landscape area for all object. Please correct me if I am wrong. Thanks for your suggestions, I will try again tomorrow. Thank you so much! -
Hi, I got one questions about worksheet. Now I need to make a budge sheet linking to the drawing because we need to changed and modify as per future City comments. What I do is below 1. establish different class for all budge item, for example, the class names is CIP concrete, Asphalt, Sand surface..... 2. establish the budge sheet linking to the drawing, for example, using 'class' to show the name of class, using 'area' to show the area of each class. But now I got the question. 1. How would I add the unit price and more note information on each Row (I do not want to use hardscape or landscape area too for simplicity) 2. How would the budge sheet show the class tag on the worksheet? for example, I added tag "CIP Concrete in front of entrance" on the specified class, and want to show this tag on the worksheet for note Purpose. 3. Is it possible that we can type the text or number we want on each Row, if this row has been specified by Database Header? Thank you very much!
Hi, how to fill the landscape area in the irregular shape 3D planter
Thanks, Jeff, What is the tool could be used to draw accurately for the modelling of the soil components and others? -
Hi, I have If I want to make a hardscape paver along the PL line with different elevation, as shown in the screenshot, 12.12m, 12.29m, 12.29m, 12.29m and then 12.17m. How would I do this? or I have to cut the paver three pieces with different height? Thanks!
VW2021_The autosave is closed without awareness /and also often unknown freeze
lixinpm replied to lixinpm's question in Troubleshooting
Hi Pat, Thanks for your help. the problem of freezing is suffering us a long time. My co-workers have similar problem as well and none know why and when. What I did is to use 1 min- autosave to solve this problem, but today I surprise that the autosave is closed without any notice. Yes, you are right, if this software freezes about half hour, I have to end the process from Task monitor. But before today, the autosave closing never happens. Please check the the info of mac system and VW and let us know how to solve it. Also if you need to know the error report, please click this link which I had asked about this questions another place. By the way, this freeze will happen in an unexpected way, such as copy, past or eyedroppers. If it happens, it will not be resumed at more. Please let me know if you need more info. Thanks very much! -
Hi, the vectorwork is often freezing and no responding.
lixinpm posted a question in Troubleshooting
Hi, the Vectorworks often frozen when I did some very simple options, such as moving, copy or editing object. When it became frozen, the mouse became round showing the computer is running and then is not resumed any more. Would you let me know what is the problem for that? The VW version is 2021 Please check the error report and my computer infor. below. Thank you very much! -------------------------------------------- Date/Time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 OS Version: Mac OS X 10.14.6 (Build 18G9323) Architecture: x86_64h Report Version: 28 Data Source: Stackshots Shared Cache: 0x9555000 A71CD26D-D779-3CDE-A9AF-18650323DC94 Shared Cache: 0 F81C5386-7151-356C-886A-20626377C068 Command: Vectorworks Path: /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/MacOS/Vectorworks Identifier: net.nemetschek.vectorworks Version: 26.0.5 (622768) (26.0.5) Parent: launchd [1] PID: 62926 Event: hang Duration: 1.09s (process was unresponsive for 198 seconds before sampling) Steps: 11 (100ms sampling interval) Hardware model: iMac18,3 Active cpus: 8 Time Awake Since Boot: 710000s Time Since Wake: 29000s Fan speed: 1194 rpm -------------------------------------------------- Timeline format: stacks are sorted chronologically Use -i and -heavy to re-report with count sorting -------------------------------------------------- Heaviest stack for the main thread of the target process: 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 11 ??? (Vectorworks + 3394241) [0x10e387ac1] 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 11 -[NSApplication run] + 755 (AppKit + 81100) [0x7fff324f5ccc] 11 ??? (Vectorworks + 4481429) [0x10e491195] 11 ??? (Vectorworks + 4482082) [0x10e491422] 11 -[NSApplication(NSEvent) sendEvent:] + 331 (AppKit + 152919) [0x7fff32507557] 11 ??? (Vectorworks + 604859) [0x10e0deabb] 11 -[NSWindow(NSEventRouting) sendEvent:] + 478 (AppKit + 1596787) [0x7fff32667d73] 11 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 2295 (AppKit + 1599666) [0x7fff326688b2] 11 -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 5724 (AppKit + 2424699) [0x7fff32731f7b] 11 ??? (Vectorworks + 3885724) [0x10e3ffa9c] 11 -[NSControl mouseDown:] + 791 (AppKit + 3618806) [0x7fff328557f6] 11 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 698 (AppKit + 3813236) [0x7fff32884f74] 11 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 2375 (AppKit + 3624377) [0x7fff32856db9] 11 -[NSButtonCell _sendActionFrom:] + 96 (AppKit + 3813923) [0x7fff32885223] 11 -[NSCell _sendActionFrom:] + 178 (AppKit + 3630238) [0x7fff3285849e] 11 __26-[NSCell _sendActionFrom:]_block_invoke + 136 (AppKit + 3630492) [0x7fff3285859c] 11 -[NSControl sendAction:to:] + 86 (AppKit + 3630698) [0x7fff3285866a] 11 -[NSApplication(NSResponder) sendAction:to:from:] + 312 (AppKit + 3195672) [0x7fff327ee318] 11 ??? (Vectorworks + 3544206) [0x10e3ac48e] 11 ??? (Vectorworks + 43709810) [0x1109fa572] 11 ??? (Vectorworks + 43710760) [0x1109fa928] 11 ??? (Vectorworks + 43702080) [0x1109f8740] 11 ??? (Vectorworks + 38174180) [0x1104b2de4] 11 ??? (Vectorworks + 37517611) [0x11041292b] 11 ??? (Vectorworks + 38158533) [0x1104af0c5] 11 ??? (Vectorworks + 38097118) [0x1104a00de] 11 ??? (Vectorworks + 31830500) [0x10fea61e4] 11 ExtendedProps::CEPEmoduleImp::HandleObjectEvent(char**, ParametricMessage&, int&) + 178 (Support + 339936) [0x1617dcfe0] 11 ??? (Support + 341103) [0x1617dd46f] 11 ??? (Vectorworks + 31825540) [0x10fea4e84] 11 ??? (Vectorworks + 33184827) [0x10fff0c3b] 11 ??? (Vectorworks + 33092813) [0x10ffda4cd] 11 VWFC::PluginSupport::VWParametric_EventSink::Execute(ParametricMessage*) + 299 (Landscape + 6329371) [0x13bc5e41b] 11 SiteModel::CObjectDTM_EventSink::OnObjectUIButtonHit(int) + 119 (Landscape + 170229) [0x13b67e8f5] 11 SiteModel::CObjectDTM_EventSink::ResetThisObject(bool, bool) + 102 (Landscape + 170594) [0x13b67ea62] 11 SiteModel::CObjectDTMRecalc::ResetModel(bool, bool, bool, bool) + 381 (Landscape + 1422839) [0x13b7b05f7] 11 SiteModel::CObjectDTMRecalc::ProcessModifiers(bool, VWFC::Tools::CProgressStepper&) + 352 (Landscape + 1419708) [0x13b7af9bc] 11 SiteModel::Modifiers::CVWModifiersData::ProcessModifiers(SiteModel::TIN::CTINModel&) + 141 (Landscape + 1395303) [0x13b7a9a67] 11 SiteModel::Modifiers::CSiteModifierPad::ProcessModifier(SiteModel::TIN::CTINMesh&) + 120 (Landscape + 1334174) [0x13b79ab9e] 7 SiteModel::Modifiers::CSiteModifier::CorrectInnerTIN(VectorWorks::Extension::ETINType, SiteModel::TIN::CTINMesh&, VWFC::Math::VWPolygon2D const&, bool) + 929 (Landscape + 1294909) [0x13b79123d] 4 ??? (Landscape + 4818200) [0x13baed518] Process: Vectorworks [62926] [unique pid 162509] UUID: B87780CD-7B21-35B2-AB7E-132D7E480425 Path: /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/MacOS/Vectorworks Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 13.50 GB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.999s (4.4G cycles, 2.0G instructions, 2.18c/i) Note: Unresponsive for 198 seconds before sampling Note: 2 idle work queue threads omitted Thread 0xa4b9cd DispatchQueue 1 Thread name "CrBrowserMain" 11 samples (1-11) priority 47 (base 47) cpu time 0.995s (4.4G cycles, 2.0G instructions, 2.17c/i) <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Vectorworks + 3394241) [0x10e387ac1] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 755 (AppKit + 81100) [0x7fff324f5ccc] 1-11 11 ??? (Vectorworks + 4481429) [0x10e491195] 1-11 11 ??? (Vectorworks + 4482082) [0x10e491422] 1-11 11 -[NSApplication(NSEvent) sendEvent:] + 331 (AppKit + 152919) [0x7fff32507557] 1-11 11 ??? (Vectorworks + 604859) [0x10e0deabb] 1-11 11 -[NSWindow(NSEventRouting) sendEvent:] + 478 (AppKit + 1596787) [0x7fff32667d73] 1-11 11 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 2295 (AppKit + 1599666) [0x7fff326688b2] 1-11 11 -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 5724 (AppKit + 2424699) [0x7fff32731f7b] 1-11 11 ??? (Vectorworks + 3885724) [0x10e3ffa9c] 1-11 11 -[NSControl mouseDown:] + 791 (AppKit + 3618806) [0x7fff328557f6] 1-11 11 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 698 (AppKit + 3813236) [0x7fff32884f74] 1-11 11 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 2375 (AppKit + 3624377) [0x7fff32856db9] 1-11 11 -[NSButtonCell _sendActionFrom:] + 96 (AppKit + 3813923) [0x7fff32885223] 1-11 11 -[NSCell _sendActionFrom:] + 178 (AppKit + 3630238) [0x7fff3285849e] 1-11 11 __26-[NSCell _sendActionFrom:]_block_invoke + 136 (AppKit + 3630492) [0x7fff3285859c] 1-11 11 -[NSControl sendAction:to:] + 86 (AppKit + 3630698) [0x7fff3285866a] 1-11 11 -[NSApplication(NSResponder) sendAction:to:from:] + 312 (AppKit + 3195672) [0x7fff327ee318] 1-11 11 ??? (Vectorworks + 3544206) [0x10e3ac48e] 1-11 11 ??? (Vectorworks + 43709810) [0x1109fa572] 1-11 11 ??? (Vectorworks + 43710760) [0x1109fa928] 1-11 11 ??? (Vectorworks + 43702080) [0x1109f8740] 1-11 11 ??? (Vectorworks + 38174180) [0x1104b2de4] 1-11 11 ??? (Vectorworks + 37517611) [0x11041292b] 1-11 11 ??? (Vectorworks + 38158533) [0x1104af0c5] 1-11 11 ??? (Vectorworks + 38097118) [0x1104a00de] 1-11 11 ??? (Vectorworks + 31830500) [0x10fea61e4] 1-11 11 ExtendedProps::CEPEmoduleImp::HandleObjectEvent(char**, ParametricMessage&, int&) + 178 (Support + 339936) [0x1617dcfe0] 1-11 11 ??? (Support + 341103) [0x1617dd46f] 1-11 11 ??? (Vectorworks + 31825540) [0x10fea4e84] 1-11 11 ??? (Vectorworks + 33184827) [0x10fff0c3b] 1-11 11 ??? (Vectorworks + 33092813) [0x10ffda4cd] 1-11 11 VWFC::PluginSupport::VWParametric_EventSink::Execute(ParametricMessage*) + 299 (Landscape + 6329371) [0x13bc5e41b] 1-11 11 SiteModel::CObjectDTM_EventSink::OnObjectUIButtonHit(int) + 119 (Landscape + 170229) [0x13b67e8f5] 1-11 11 SiteModel::CObjectDTM_EventSink::ResetThisObject(bool, bool) + 102 (Landscape + 170594) [0x13b67ea62] 1-11 11 SiteModel::CObjectDTMRecalc::ResetModel(bool, bool, bool, bool) + 381 (Landscape + 1422839) [0x13b7b05f7] 1-11 11 SiteModel::CObjectDTMRecalc::ProcessModifiers(bool, VWFC::Tools::CProgressStepper&) + 352 (Landscape + 1419708) [0x13b7af9bc] 1-11 11 SiteModel::Modifiers::CVWModifiersData::ProcessModifiers(SiteModel::TIN::CTINModel&) + 141 (Landscape + 1395303) [0x13b7a9a67] 1-11 11 SiteModel::Modifiers::CSiteModifierPad::ProcessModifier(SiteModel::TIN::CTINMesh&) + 120 (Landscape + 1334174) [0x13b79ab9e] 1-11 3 SiteModel::Modifiers::CSiteModifier::CorrectInnerTIN(VectorWorks::Extension::ETINType, SiteModel::TIN::CTINMesh&, VWFC::Math::VWPolygon2D const&, bool) + 865 (Landscape + 1294845) [0x13b7911fd] 1-3 1 ??? (Landscape + 4818200) [0x13baed518] (running) 1 2 ??? (Landscape + 4818204) [0x13baed51c] (running) 2-3 7 SiteModel::Modifiers::CSiteModifier::CorrectInnerTIN(VectorWorks::Extension::ETINType, SiteModel::TIN::CTINMesh&, VWFC::Math::VWPolygon2D const&, bool) + 929 (Landscape + 1294909) [0x13b79123d] 4-10 1 ??? (Landscape + 4818200) [0x13baed518] (running) 4 2 ??? (Landscape + 4818204) [0x13baed51c] (running) 5-6 1 ??? (Landscape + 4818194) [0x13baed512] (running) 7 3 ??? (Landscape + 4818200) [0x13baed518] (running) 8-10 1 SiteModel::Modifiers::CSiteModifier::CorrectInnerTIN(VectorWorks::Extension::ETINType, SiteModel::TIN::CTINMesh&, VWFC::Math::VWPolygon2D const&, bool) + 446 (Landscape + 1294426) [0x13b79105a] 11 1 ??? (Landscape + 4818200) [0x13baed518] (running) 11 Thread 0xa4b9e8 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa4b9ea Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 cef_time_delta + 2801911 (Chromium Embedded Framework + 46868023) [0x121064637] 1-11 11 cef_time_delta + 2548493 (Chromium Embedded Framework + 46614605) [0x12102684d] 1-11 11 cef_time_delta + 2549645 (Chromium Embedded Framework + 46615757) [0x121026ccd] 1-11 11 cef_time_delta + 2547256 (Chromium Embedded Framework + 46613368) [0x121026378] 1-11 11 cef_time_delta + 2862147 (Chromium Embedded Framework + 46928259) [0x121073183] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4b9eb Thread name "Chrome_IOThread" 11 samples (1-11) priority 31 (base 31) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa4b9ec Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4b9ed Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4b9f0 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4b9f1 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 cef_time_delta + 2801911 (Chromium Embedded Framework + 46868023) [0x121064637] 1-11 11 cef_time_delta + 2548637 (Chromium Embedded Framework + 46614749) [0x1210268dd] 1-11 11 cef_time_delta + 2549645 (Chromium Embedded Framework + 46615757) [0x121026ccd] 1-11 11 cef_time_delta + 2547256 (Chromium Embedded Framework + 46613368) [0x121026378] 1-11 11 cef_time_delta + 2862147 (Chromium Embedded Framework + 46928259) [0x121073183] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4b9f3 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4b9f5 Thread name "ThreadPoolSingleThreadForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4b9f9 Thread name "ThreadPoolSingleThreadSharedBackgroundBlocking1" 11 samples (1-11) priority 0 (base 0) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4b9fa Thread name "ThreadPoolSingleThreadSharedForegroundBlocking2" 11 samples (1-11) priority 31 (base 31) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4bbc4 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bbc5 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bbc6 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bbc7 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bbc8 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bbc9 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bbca 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bbcb 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bbd6 11 samples (1-11) priority 1 (base 1) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Vectorworks + 17628112) [0x10f11abd0] 1-11 11 ??? (Vectorworks + 17450057) [0x10f0ef449] 1-11 11 ??? (Vectorworks + 17447721) [0x10f0eeb29] 1-11 11 ??? (Vectorworks + 17447150) [0x10f0ee8ee] 1-11 11 __recvfrom + 10 (libsystem_kernel.dylib + 17518) [0x7fff60fd346e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 recvfrom_nocancel + 229 (kernel + 7555877) [0xffffff8000934b25] 1-11 *11 ??? (kernel + 7556385) [0xffffff8000934d21] 1-11 *11 soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11 *11 sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11 *11 msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0xa4bc46 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Vectorworks + 17628112) [0x10f11abd0] 1-11 11 ??? (Vectorworks + 17394558) [0x10f0e1b7e] 1-11 11 ??? (Vectorworks + 17396163) [0x10f0e21c3] 1-11 11 ??? (Vectorworks + 17626325) [0x10f11a4d5] 1-11 11 _dispatch_semaphore_wait_slow + 98 (libdispatch.dylib + 17311) [0x7fff60e4f39f] 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa4bc66 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (40.1K cycles, 5.1K instructions, 7.93c/i) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 cineware::BeginThread(void*) + 9 (Renderworks + 1788825) [0x145a54b99] 1-11 11 cineware::BaseThread::Action() + 62 (Renderworks + 1789086) [0x145a54c9e] 1-11 11 cineware::IpKillThread::Main() + 58 (Renderworks + 2038698) [0x145a91baa] 1-11 11 usleep + 53 (libsystem_c.dylib + 501768) [0x7fff60f5f808] 1-11 11 __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa4bccf Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 47 (base 47) cpu time 0.004s (16.6M cycles, 4.6M instructions, 3.60c/i) <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4bcf7 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bd05 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bd06 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bd07 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bd08 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bd09 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bd0a 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bd0b 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bd0c 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bd61 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, std::__1::__bind<void (sio::client_impl::*)(), sio::client_impl*> > >(void*) + 62 (Vectorworks + 32197214) [0x10feffa5e] 1-11 11 ??? (Vectorworks + 32171974) [0x10fef97c6] 1-11 11 ??? (Vectorworks + 32173555) [0x10fef9df3] 1-11 11 ??? (Vectorworks + 15150369) [0x10eebdd21] 1-11 11 ??? (Vectorworks + 15151379) [0x10eebe113] 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa4bd62 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4be28 11 samples (1-11) priority 28 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 62 (Vectorworks + 54064078) [0x1113da3ce] 1-11 11 ThreadGroup<DrawingUnit*>::WorkerThread() + 219 (Vectorworks + 54060491) [0x1113d95cb] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4be29 11 samples (1-11) priority 29 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 62 (Vectorworks + 54064078) [0x1113da3ce] 1-11 11 ThreadGroup<DrawingUnit*>::WorkerThread() + 219 (Vectorworks + 54060491) [0x1113d95cb] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4be2a 11 samples (1-11) priority 25 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 62 (Vectorworks + 54064078) [0x1113da3ce] 1-11 11 ThreadGroup<DrawingUnit*>::WorkerThread() + 219 (Vectorworks + 54060491) [0x1113d95cb] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4be2b 11 samples (1-11) priority 22 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 62 (Vectorworks + 54064078) [0x1113da3ce] 1-11 11 ThreadGroup<DrawingUnit*>::WorkerThread() + 219 (Vectorworks + 54060491) [0x1113d95cb] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4be2c 11 samples (1-11) priority 23 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 62 (Vectorworks + 54064078) [0x1113da3ce] 1-11 11 ThreadGroup<DrawingUnit*>::WorkerThread() + 219 (Vectorworks + 54060491) [0x1113d95cb] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4be2d 11 samples (1-11) priority 28 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 62 (Vectorworks + 54064078) [0x1113da3ce] 1-11 11 ThreadGroup<DrawingUnit*>::WorkerThread() + 219 (Vectorworks + 54060491) [0x1113d95cb] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4be2e 11 samples (1-11) priority 30 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 62 (Vectorworks + 54064078) [0x1113da3ce] 1-11 11 ThreadGroup<DrawingUnit*>::WorkerThread() + 219 (Vectorworks + 54060491) [0x1113d95cb] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4be2f 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 62 (Vectorworks + 54064078) [0x1113da3ce] 1-11 11 ThreadGroup<DrawingUnit*>::WorkerThread() + 219 (Vectorworks + 54060491) [0x1113d95cb] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4be32 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >*> >(void*) + 59 (VWGraphicsModule + 1114197) [0x1676e5055] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::WorkerThread() + 319 (VWGraphicsModule + 1112455) [0x1676e4987] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4beca 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa4becb 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa4becc 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa4becd 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa4bece 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa4becf 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa4bed0 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa57739 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa5773b 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa5773c 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa5773d 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa5773e 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa5773f 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa57740 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa57741 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa57742 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa578f2 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >*> >(void*) + 59 (VWGraphicsModule + 1114197) [0x1676e5055] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::WorkerThread() + 319 (VWGraphicsModule + 1112455) [0x1676e4987] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89b2b 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89b49 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89b4a 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89b4b 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89b4c 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89b4d 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89b4e 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89b4f 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89b50 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >*> >(void*) + 59 (VWGraphicsModule + 977785) [0x1676c3b79] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::TessellateGeometryJob> >::WorkerThread() + 319 (VWGraphicsModule + 974799) [0x1676c2fcf] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89bc1 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >*> >(void*) + 59 (VWGraphicsModule + 1114197) [0x1676e5055] 1-11 11 ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::WorkerThread() + 319 (VWGraphicsModule + 1112455) [0x1676e4987] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa89c33 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CTThreading::PthreadStart(void*) + 14 (DL150PDFL + 4546806) [0x140de20f6] 1-11 11 CTThreading::WorkerThread::Start() + 38 (DL150PDFL + 4548500) [0x140de2794] 1-11 11 CTThreading::ThreadSafeQueue::Dequeue() + 22 (DL150PDFL + 4547380) [0x140de2334] 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa89c34 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CTThreading::PthreadStart(void*) + 14 (DL150PDFL + 4546806) [0x140de20f6] 1-11 11 CTThreading::WorkerThread::Start() + 38 (DL150PDFL + 4548500) [0x140de2794] 1-11 11 CTThreading::ThreadSafeQueue::Dequeue() + 22 (DL150PDFL + 4547380) [0x140de2334] 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa89c35 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CTThreading::PthreadStart(void*) + 14 (DL150PDFL + 4546806) [0x140de20f6] 1-11 11 CTThreading::WorkerThread::Start() + 38 (DL150PDFL + 4548500) [0x140de2794] 1-11 11 CTThreading::ThreadSafeQueue::Dequeue() + 22 (DL150PDFL + 4547380) [0x140de2334] 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa89c36 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CTThreading::PthreadStart(void*) + 14 (DL150PDFL + 4546806) [0x140de20f6] 1-11 11 CTThreading::WorkerThread::Start() + 38 (DL150PDFL + 4548500) [0x140de2794] 1-11 11 CTThreading::ThreadSafeQueue::Dequeue() + 22 (DL150PDFL + 4547380) [0x140de2334] 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa89c37 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CTThreading::PthreadStart(void*) + 14 (DL150PDFL + 4546806) [0x140de20f6] 1-11 11 CTThreading::WorkerThread::Start() + 38 (DL150PDFL + 4548500) [0x140de2794] 1-11 11 CTThreading::ThreadSafeQueue::Dequeue() + 22 (DL150PDFL + 4547380) [0x140de2334] 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa89c38 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CTThreading::PthreadStart(void*) + 14 (DL150PDFL + 4546806) [0x140de20f6] 1-11 11 CTThreading::WorkerThread::Start() + 38 (DL150PDFL + 4548500) [0x140de2794] 1-11 11 CTThreading::ThreadSafeQueue::Dequeue() + 22 (DL150PDFL + 4547380) [0x140de2334] 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa89c39 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CTThreading::PthreadStart(void*) + 14 (DL150PDFL + 4546806) [0x140de20f6] 1-11 11 CTThreading::WorkerThread::Start() + 38 (DL150PDFL + 4548500) [0x140de2794] 1-11 11 CTThreading::ThreadSafeQueue::Dequeue() + 22 (DL150PDFL + 4547380) [0x140de2334] 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa89c3a 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CTThreading::PthreadStart(void*) + 14 (DL150PDFL + 4546806) [0x140de20f6] 1-11 11 CTThreading::WorkerThread::Start() + 38 (DL150PDFL + 4548500) [0x140de2794] 1-11 11 CTThreading::ThreadSafeQueue::Dequeue() + 22 (DL150PDFL + 4547380) [0x140de2334] 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa91fc3 Thread name "CVDisplayLink" 11 samples (1-11) priority 54 (base 54) <process frontmost, process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CVDisplayLink::runIOThread() + 695 (CoreVideo + 93723) [0x7fff36c77e1b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x10e04b000 - 0x1128a5fff net.nemetschek.vectorworks 26.0.5 (622768) (26.0.5) <B87780CD-7B21-35B2-AB7E-132D7E480425> /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/MacOS/Vectorworks 0x11e3b2000 - 0x12655ffff org.chromium.ContentShell.framework 84.3.3.0 (3.0) <33CBB18A-CD37-38C4-94FB-B9E1EDFF8658> /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework 0x13b655000 - 0x13be57fff net.nemetschek.vectorworks.LandscapeModule (1.0) <7307AC6E-23CD-33DF-AF2E-43CE67C80B39> /Applications/Vectorworks 2021/*/Landscape 0x14098c000 - 0x1410effff com.datalogics.DL150PDFL DL150PDFL 15.0.4.9 (15.0.4.9) <27AF6E78-DCCD-3973-BE38-F4F002B8D176> /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/Frameworks/DL150PDFL.framework/Versions/A/DL150PDFL 0x1458a0000 - 0x145afbfff net.nemetschek.vectorworks.Renderworks (1.0) <C2509A26-D398-3562-8C14-437D9B27FBDE> /Applications/Vectorworks 2021/*/Renderworks 0x16178a000 - 0x161d4bfff net.nemetschek.vectorworks.Support (1.0) <B1DEC882-5C8F-3C75-A0B5-6549113C009B> /Applications/Vectorworks 2021/*/Support 0x1675d5000 - 0x1677adfff net.nemetschek.vectorworks.VWGraphicsModule (1.0) <97598144-4A9E-3FAE-8654-5B4C37611D8B> /Applications/Vectorworks 2021/*/VWGraphicsModule 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff36c61000 - 0x7fff36ca1fff com.apple.CoreVideo 1.8 (281.4) <10CF8E52-07E3-382B-8091-2CEEEFFA69B4> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff5e0c2000 - 0x7fff5e115fff libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60ee5000 - 0x7fff60f6cfff libsystem_c.dylib (1272.250.3) <6016EDA1-440B-34D7-A232-686CD7FBEE90> /usr/lib/system/libsystem_c.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: 5A4RE8SF68.com.tencent.xinWeChat.IPCHelper [29126] [unique pid 128718] UUID: 4F2CECA3-DEE0-3EC7-BFE9-93EB5210AB5B Path: /Applications/WeChat.app/Contents/Library/LoginItems/5A4RE8SF68.com.tencent.xinWeChat.IPCHelper.app/Contents/MacOS/5A4RE8SF68.com.tencent.xinWeChat.IPCHelper Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 1160 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7e4271 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10dd32000 - 0x10dd35fff 5A4RE8SF68.com.tencent.xinWeChat.IPCHelper <4F2CECA3-DEE0-3EC7-BFE9-93EB5210AB5B> /Applications/WeChat.app/Contents/Library/LoginItems/5A4RE8SF68.com.tencent.xinWeChat.IPCHelper.app/Contents/MacOS/5A4RE8SF68.com.tencent.xinWeChat.IPCHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: AAM Updates Notifier [9885] Architecture: i386 Footprint: 10.94 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:30 -0800 Num samples: 1 (1) Note: 2 idle work queue threads omitted Thread 0xe5f91 DispatchQueue 1 1 sample (1) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 1 ??? [0x3edc] 1 1 ??? [0x3fad] 1 1 NSApplicationMain + 1140 (AppKit + 12235) [0x91492fcb] 1 1 -[NSApplication run] + 751 (AppKit + 78291) [0x914a31d3] 1 1 -[NSApplication(NSEvent) nextEventMatchingMask:untilDate:inMode:dequeue:] + 108 (AppKit + 101170) [0x914a8b32] 1 1 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 957 (AppKit + 102135) [0x914a8ef7] 1 1 _DPSNextEvent + 1345 (AppKit + 107489) [0x914aa3e1] 1 1 _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 40039) [0x92de9c67] 1 1 ReceiveNextEventCommon + 741 (HIToolbox + 40811) [0x92de9f6b] 1 1 RunCurrentEventLoopInMode + 323 (HIToolbox + 41585) [0x92dea271] 1 1 CFRunLoopRunInMode + 82 (CoreFoundation + 340449) [0x938651e1] 1 1 CFRunLoopRunSpecific + 584 (CoreFoundation + 238400) [0x9384c340] 1 1 __CFRunLoopRun + 2896 (CoreFoundation + 242061) [0x9384d18d] 1 1 __CFRunLoopServiceMachPort + 289 (CoreFoundation + 244323) [0x9384da63] 1 1 mach_msg_trap + 10 (libsystem_kernel.dylib + 4546) [0xa7d401c2] 1 *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1 Thread 0xe5f9d Thread name "com.apple.NSURLConnectionLoader" 1 sample (1) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 1 thread_start + 34 (libsystem_pthread.dylib + 10190) [0xa7df27ce] 1 1 _pthread_start + 78 (libsystem_pthread.dylib + 26615) [0xa7df67f7] 1 1 _pthread_body + 137 (libsystem_pthread.dylib + 13816) [0xa7df35f8] 1 1 __NSThread__start__ + 1220 (Foundation + 72459) [0x951a3b0b] 1 1 -[NSThread main] + 39 (Foundation + 72802) [0x951a3c62] 1 1 +[__CoreSchedulingSetRunnable _run:] + 129 (CFNetwork + 311833) [0x92a8c219] 1 1 -[__CoreSchedulingSetRunnable runForever] + 579 (CFNetwork + 312800) [0x92a8c5e0] 1 1 CFRunLoopRunInMode + 82 (CoreFoundation + 340449) [0x938651e1] 1 1 CFRunLoopRunSpecific + 584 (CoreFoundation + 238400) [0x9384c340] 1 1 __CFRunLoopRun + 2896 (CoreFoundation + 242061) [0x9384d18d] 1 1 __CFRunLoopServiceMachPort + 289 (CoreFoundation + 244323) [0x9384da63] 1 1 mach_msg_trap + 10 (libsystem_kernel.dylib + 4546) [0xa7d401c2] 1 *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1 Thread 0xe5f9e Thread name "com.apple.CFSocket.private" 1 sample (1) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 1 <truncated backtrace> 1 1 __select + 10 (libsystem_kernel.dylib + 33458) [0xa7d472b2] 1 *1 ??? (kernel + 7168864) [0xffffff80008d6360] 1 Thread 0xe5fa3 Thread name "com.apple.NSEventThread" 1 sample (1) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 1 thread_start + 34 (libsystem_pthread.dylib + 10190) [0xa7df27ce] 1 1 _pthread_start + 78 (libsystem_pthread.dylib + 26615) [0xa7df67f7] 1 1 _pthread_body + 137 (libsystem_pthread.dylib + 13816) [0xa7df35f8] 1 1 _NSEventThread + 165 (AppKit + 138826) [0x914b1e4a] 1 1 CFRunLoopRunInMode + 82 (CoreFoundation + 340449) [0x938651e1] 1 1 CFRunLoopRunSpecific + 584 (CoreFoundation + 238400) [0x9384c340] 1 1 __CFRunLoopRun + 2896 (CoreFoundation + 242061) [0x9384d18d] 1 1 __CFRunLoopServiceMachPort + 289 (CoreFoundation + 244323) [0x9384da63] 1 1 mach_msg_trap + 10 (libsystem_kernel.dylib + 4546) [0xa7d401c2] 1 *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1 Binary Images: 0x91490000 - 0x921d9fff com.apple.AppKit 6.9 (1671.60.112) <BB017928-5FEA-349A-B027-FB9B124D5E7D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x92a40000 - 0x92dbbfff com.apple.CFNetwork 978.6 (978.6) <62DEE66F-F853-354E-9ACB-AFC35D260B03> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x92de0000 - 0x93162fff com.apple.HIToolbox 2.1.1 (918.7) <57D8E18B-2E59-3DAF-BF46-75DEFB58CED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x93812000 - 0x93c4cfff com.apple.CoreFoundation 6.9 (1575.405) <F1CC263B-4936-396B-B6D9-8CB06EBEF2EA> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x95192000 - 0x954f8fff com.apple.Foundation 6.9 (1575.405) <A65B2384-6516-3412-85A1-6161024D4BCD> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0xa7d3f000 - 0xa7d67fff libsystem_kernel.dylib (4903.278.70) <12ABC81E-9EC6-3E76-85AA-FFD1EECD3419> /usr/lib/system/libsystem_kernel.dylib 0xa7df0000 - 0xa7dfbfff libsystem_pthread.dylib (330.250.2) <5E586CDB-3E20-39C1-8194-1FA564E947DD> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: AAM Updates Notifier [9885] UUID: 3307CE76-A723-DE76-98CC-A5D92FDA63D9 Path: /Applications/Utilities/Adobe Application Manager/*/AAM Updates Notifier.app/Contents/MacOS/AAM Updates Notifier Architecture: i386 Parent: launchd [1] UID: 504 Footprint: 10.94 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 10 (2-11) CPU Time: 8.814s (27.5G cycles, 7.7G instructions, 3.56c/i) No threads sampled Binary Images: 0x1000 - 0x26fff com.adobe.PDApp.AAMUpdatesNotifier 6.0.335.0 (6.0.335.0) <3307CE76-A723-DE76-98CC-A5D92FDA63D9> /Applications/Utilities/Adobe Application Manager/*/AAM Updates Notifier.app/Contents/MacOS/AAM Updates Notifier Process: accountsd [290] UUID: F6DED804-7E8B-3153-BC98-5C49BB5793A8 Path: /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 29.32 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x852 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (accountsd + 2490) [0x10e7239ba] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e723000 - 0x10e723fff accountsd (677.6.0.8) <F6DED804-7E8B-3153-BC98-5C49BB5793A8> /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: adid [363] UUID: FC2CF85B-F9E9-302E-8FB0-1DEE4BA24650 Path: /System/Library/PrivateFrameworks/CoreADI.framework/Versions/A/adid Architecture: x86_64 Parent: launchd [1] UID: 265 Sudden Term: Tracked (allows idle exit) Footprint: 13.39 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xce8 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (adid + 903416) [0x105c548f8] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105b78000 - 0x105d0cfff adid (4.19) <FC2CF85B-F9E9-302E-8FB0-1DEE4BA24650> /System/Library/PrivateFrameworks/CoreADI.framework/Versions/A/adid 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Adobe Flash Player Install Manager [10592] UUID: D56AB41D-A770-3265-B55D-EF948BB42BD1 Path: /Applications/Utilities/Adobe Flash Player Install Manager.app/Contents/MacOS/Adobe Flash Player Install Manager Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 21.05 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (57.6K cycles, 24.5K instructions, 2.35c/i) Note: 2 idle work queue threads omitted Thread 0xec463 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 52 (Adobe Flash Player Install Manager + 8244) [0x10f7dc034] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xec477 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xec478 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xec48c Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x10f7da000 - 0x10fa53fff com.adobe.flashplayer.installmanager 32.0.0.465 (32.0.0.465) <D56AB41D-A770-3265-B55D-EF948BB42BD1> /Applications/Utilities/Adobe Flash Player Install Manager.app/Contents/MacOS/Adobe Flash Player Install Manager 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: AdobeAcrobat [16858] Architecture: i386 Footprint: 54.62 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:30 -0800 Num samples: 1 (1) Note: 2 idle work queue threads omitted Thread 0x1c4b29 DispatchQueue 1 1 sample (1) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 1 ??? [0x2571] 1 1 ??? [0x264a] 1 1 ??? [0x2e8b] 1 1 ??? [0x7fd83f80] 1 1 ??? [0x7fd84a54] 1 1 -[NSApplication run] + 751 (AppKit + 78291) [0x914a31d3] 1 1 -[NSApplication(NSEvent) nextEventMatchingMask:untilDate:inMode:dequeue:] + 108 (AppKit + 101170) [0x914a8b32] 1 1 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 957 (AppKit + 102135) [0x914a8ef7] 1 1 _DPSNextEvent + 1345 (AppKit + 107489) [0x914aa3e1] 1 1 _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 40039) [0x92de9c67] 1 1 ReceiveNextEventCommon + 741 (HIToolbox + 40811) [0x92de9f6b] 1 1 RunCurrentEventLoopInMode + 323 (HIToolbox + 41585) [0x92dea271] 1 1 CFRunLoopRunInMode + 82 (CoreFoundation + 340449) [0x938651e1] 1 1 CFRunLoopRunSpecific + 584 (CoreFoundation + 238400) [0x9384c340] 1 1 __CFRunLoopRun + 2896 (CoreFoundation + 242061) [0x9384d18d] 1 1 __CFRunLoopServiceMachPort + 289 (CoreFoundation + 244323) [0x9384da63] 1 1 mach_msg_trap + 10 (libsystem_kernel.dylib + 4546) [0xa7d401c2] 1 *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1 Thread 0x1c4b68 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c4b69 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c4b6a 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c4b6b 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c4b6c 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c4b6d 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c4b6e 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c4b6f 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c4b70 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c4b71 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c4b9c Thread name "com.apple.NSEventThread" 1 sample (1) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 1 thread_start + 34 (libsystem_pthread.dylib + 10190) [0xa7df27ce] 1 1 _pthread_start + 78 (libsystem_pthread.dylib + 26615) [0xa7df67f7] 1 1 _pthread_body + 137 (libsystem_pthread.dylib + 13816) [0xa7df35f8] 1 1 _NSEventThread + 165 (AppKit + 138826) [0x914b1e4a] 1 1 CFRunLoopRunInMode + 82 (CoreFoundation + 340449) [0x938651e1] 1 1 CFRunLoopRunSpecific + 584 (CoreFoundation + 238400) [0x9384c340] 1 1 __CFRunLoopRun + 2896 (CoreFoundation + 242061) [0x9384d18d] 1 1 __CFRunLoopServiceMachPort + 289 (CoreFoundation + 244323) [0x9384da63] 1 1 mach_msg_trap + 10 (libsystem_kernel.dylib + 4546) [0xa7d401c2] 1 *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1 Thread 0x1c4ca7 1 sample (1) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 kevent + 10 (libsystem_kernel.dylib + 29614) [0xa7d463ae] 1 *1 ??? (kernel + 6978560) [0xffffff80008a7c00] 1 Thread 0x1c4cb3 1 sample (1) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Thread 0x1c50d2 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 thread_start + 34 (libsystem_pthread.dylib + 10190) [0xa7df27ce] 1 1 _pthread_start + 78 (libsystem_pthread.dylib + 26615) [0xa7df67f7] 1 1 _pthread_body + 137 (libsystem_pthread.dylib + 13816) [0xa7df35f8] 1 1 PrivateMPEntryPoint + 51 (CarbonCore + 541794) [0x948e9462] 1 1 ??? [0x73dde6d5] 1 1 ??? [0x73dfcdfc] 1 1 MPWaitOnQueue + 181 (CarbonCore + 540704) [0x948e9020] 1 1 TSWaitOnConditionTimedRelative + 137 (CarbonCore + 694137) [0x9490e779] 1 1 pthread_cond_timedwait_relative_np + 27 (libsystem_pthread.dylib + 20061) [0xa7df4e5d] 1 1 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18346) [0xa7d437aa] 1 *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1 Binary Images: 0x91490000 - 0x921d9fff com.apple.AppKit 6.9 (1671.60.112) <BB017928-5FEA-349A-B027-FB9B124D5E7D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x92de0000 - 0x93162fff com.apple.HIToolbox 2.1.1 (918.7) <57D8E18B-2E59-3DAF-BF46-75DEFB58CED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x93812000 - 0x93c4cfff com.apple.CoreFoundation 6.9 (1575.405) <F1CC263B-4936-396B-B6D9-8CB06EBEF2EA> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x94865000 - 0x94b44fff com.apple.CoreServices.CarbonCore 1178.33 (1178.33) <9CEC8866-FBAD-3000-88A3-3451F1A09F95> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0xa7d3f000 - 0xa7d67fff libsystem_kernel.dylib (4903.278.70) <12ABC81E-9EC6-3E76-85AA-FFD1EECD3419> /usr/lib/system/libsystem_kernel.dylib 0xa7df0000 - 0xa7dfbfff libsystem_pthread.dylib (330.250.2) <5E586CDB-3E20-39C1-8194-1FA564E947DD> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: AdobeAcrobat [16858] UUID: BD0419A6-AC29-4210-9EA0-0BBAFC5682FE Path: /Applications/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat Architecture: i386 Parent: launchd [1] UID: 504 Footprint: 54.62 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:30 -0800 Num samples: 3 (2-4) CPU Time: 41.059s (138.7G cycles, 40.1G instructions, 3.46c/i) No threads sampled Binary Images: 0x1000 - 0x2fff AdobeAcrobat <BD0419A6-AC29-4210-9EA0-0BBAFC5682FE> /Applications/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat Process: AdobeAcrobat [16858] UUID: BD0419A6-AC29-4210-9EA0-0BBAFC5682FE Path: /Applications/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat Architecture: i386 Parent: launchd [1] UID: 504 Footprint: 54.61 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 6 (6-11) CPU Time: 41.059s (138.7G cycles, 40.1G instructions, 3.46c/i) Binary Images: 0x1000 - 0x2fff AdobeAcrobat <BD0419A6-AC29-4210-9EA0-0BBAFC5682FE> /Applications/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat Process: adprivacyd [428] UUID: 084C3546-CE3A-36CD-B47E-61EDF990A4EF Path: /usr/libexec/adprivacyd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 10.54 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe87 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe6952 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b616000 - 0x10b617fff adprivacyd <084C3546-CE3A-36CD-B47E-61EDF990A4EF> /usr/libexec/adprivacyd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: AirPlayUIAgent [421] UUID: 723E9B35-AF43-3059-B177-B04457F05C89 Path: /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 4552 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (85.2K cycles, 28.9K instructions, 2.95c/i) Note: 2 idle work queue threads omitted Thread 0xe6f DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe98 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102929000 - 0x102932fff AirPlayUIAgent <723E9B35-AF43-3059-B177-B04457F05C89> /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: AirPlayXPCHelper [112] UUID: 1A758229-3364-33BD-A0FD-EA958108C0B3 Path: /usr/libexec/AirPlayXPCHelper Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 18.28 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (226.5K cycles, 48.5K instructions, 4.67c/i) Note: 4 idle work queue threads omitted Thread 0x34c DispatchQueue 11 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x106ed6000 - 0x106ed8fff AirPlayXPCHelper <1A758229-3364-33BD-A0FD-EA958108C0B3> /usr/libexec/AirPlayXPCHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: airportd [199] UUID: A5267A8F-BA7D-3838-88F3-A2C8422353C2 Path: /usr/libexec/airportd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 12.68 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 4 idle work queue threads omitted Thread 0x596 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from sharingd [319], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (airportd + 313403) [0x10025b83b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5a0 DispatchQueue 82 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default, ipc override default), process sudden termination clean, process unclamped, process received importance donation from sharingd [319], IO tier 0> 11 <truncated backtrace> 1-11 11 ??? (airportd + 411993) [0x100273959] 1-11 11 CFReadStreamRead + 249 (CoreFoundation + 468242) [0x7fff34f3e512] 1-11 11 fileRead + 31 (CoreFoundation + 470600) [0x7fff34f3ee48] 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4319092) [0xffffff800061e774] 1-11 *11 spec_read + 672 (kernel + 4425648) [0xffffff80006387b0] 1-11 *11 cdev_read + 378 (IO80211Family + 451393) [0xffffff7f81d53341] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x60c 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default, ipc override default), process sudden termination clean, process unclamped, process received importance donation from sharingd [319], IO tier 0> 11 <truncated backtrace> 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4319092) [0xffffff800061e774] 1-11 *11 spec_read + 672 (kernel + 4425648) [0xffffff80006387b0] 1-11 *11 cdev_read + 378 (IO80211Family + 451393) [0xffffff7f81d53341] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x60e 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default, ipc override default), process sudden termination clean, process unclamped, process received importance donation from sharingd [319], IO tier 0> 11 <truncated backtrace> 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4319092) [0xffffff800061e774] 1-11 *11 spec_read + 672 (kernel + 4425648) [0xffffff80006387b0] 1-11 *11 cdev_read + 378 (IO80211Family + 451393) [0xffffff7f81d53341] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x60f Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from sharingd [319], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10020f000 - 0x10033efff airportd (1380.2) <A5267A8F-BA7D-3838-88F3-A2C8422353C2> /usr/libexec/airportd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f81ce5000 - 0xffffff7f81d9afff com.apple.iokit.IO80211Family 12.0 (1200.12.2) <177476EF-3F2E-3C6B-9324-0D624FDCF290> /System/Library/Extensions/IO80211Family.kext/Contents/MacOS/IO80211Family *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: akd [361] UUID: 4165B30D-1898-3C40-88FC-15C75C0EFA27 Path: /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 13.22 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (94.9K cycles, 23.1K instructions, 4.11c/i) Note: 1 idle work queue thread omitted Thread 0xcde 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x53640 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10525b000 - 0x105309fff akd (181.8.0.2) <4165B30D-1898-3C40-88FC-15C75C0EFA27> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: amfid [192] UUID: 8A693E78-7B5D-3C10-8FBD-AA2E78F4561B Path: /usr/libexec/amfid Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 33.20 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: Suspended for 1 sample Note: 1 idle work queue thread omitted Thread 0x429 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *1 ??? (kernel + 7168864) [0xffffff80008d6360] 1 *1 ??? (kernel + 7168864) [0xffffff80008d6360] (suspended) 2 *9 ??? (kernel + 7168864) [0xffffff80008d6360] 3-11 Binary Images: 0x102a9e000 - 0x102aacfff amfid <8A693E78-7B5D-3C10-8FBD-AA2E78F4561B> /usr/libexec/amfid 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: analyticsd [306] UUID: 2E2247B3-29A9-3979-A196-1B2200210042 Path: /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd Architecture: x86_64 Parent: launchd [1] UID: 263 Sudden Term: Tracked (allows idle exit) Footprint: 9136 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x8f0 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x109209000 - 0x1092bcfff analyticsd (50.1) <2E2247B3-29A9-3979-A196-1B2200210042> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: apfsd [204] UUID: A318C4BE-A45D-3852-89F4-C84305273E92 Path: /usr/libexec/apfsd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 1292 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x5c9 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x106a74000 - 0x106a85fff apfsd (945.275.10) <A318C4BE-A45D-3852-89F4-C84305273E92> /usr/libexec/apfsd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: APFSUserAgent [355] UUID: FB95C17E-18DA-3707-A06E-C0DA2CE5F194 Path: /System/Library/CoreServices/APFSUserAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1100 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xafc 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10688a000 - 0x10688ffff APFSUserAgent <FB95C17E-18DA-3707-A06E-C0DA2CE5F194> /System/Library/CoreServices/APFSUserAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: appleeventsd [60] UUID: 3D5AB89D-29F1-3AF4-BFC2-3A0DB8898F93 Path: /System/Library/CoreServices/appleeventsd Architecture: x86_64 Parent: launchd [1] UID: 55 Footprint: 10.66 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6f3 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10fdd3000 - 0x10fdd3fff appleeventsd <3D5AB89D-29F1-3AF4-BFC2-3A0DB8898F93> /System/Library/CoreServices/appleeventsd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: AppleSpell [668] UUID: E52723D9-B46D-35AB-80E0-A3788CF4121E Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 42.27 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1e1a DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (AppleSpell + 5204) [0x10ceef454] 1-11 11 -[NSSpellServer run] + 73 (Foundation + 2208793) [0x7fff3736f419] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10ceee000 - 0x10cff9fff com.apple.AppleSpell 2.4 (430.16.16) <E52723D9-B46D-35AB-80E0-A3788CF4121E> /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: applessdstatistics [80013] UUID: A470A49C-DD14-35C6-8CE0-889B4C4760FC Path: /usr/libexec/applessdstatistics Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 800 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x508f1c 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __ulock_wait + 10 (libsystem_kernel.dylib + 14810) [0x7fff60fd29da] 1-11 *11 ??? (kernel + 7307696) [0xffffff80008f81b0] 1-11 Binary Images: 0x100a4d000 - 0x100a85fff applessdstatistics (118.260.1) <A470A49C-DD14-35C6-8CE0-889B4C4760FC> /usr/libexec/applessdstatistics 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: appstoreagent [894] UUID: 2469E0C7-E31C-3D96-B4C6-1211B4FC6786 Path: /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 13.36 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0xa1e7 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (appstoreagent + 7155) [0x106c96bf3] 1-11 11 ??? (appstoreagent + 274378) [0x106cd7fca] 1-11 11 ??? (appstoreagent + 274665) [0x106cd80e9] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x47a1f1 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x106c95000 - 0x106d1afff appstoreagent (5.4.3) <2469E0C7-E31C-3D96-B4C6-1211B4FC6786> /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: apsd [85] UUID: 399BDED0-DC36-38A3-9ADC-9F97302C3F08 Path: /System/Library/PrivateFrameworks/ApplePushService.framework/apsd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 10.93 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x26c DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (apsd + 499291) [0x103e5be5b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xde8 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xdf6 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x103de2000 - 0x103ed5fff apsd (625.35) <399BDED0-DC36-38A3-9ADC-9F97302C3F08> /System/Library/PrivateFrameworks/ApplePushService.framework/apsd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ARDAgent [366] UUID: C9097C01-A695-389B-BD31-2097BC5356C1 Path: /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 22.21 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0xd08 DispatchQueue 1 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (ARDAgent + 7180) [0x1025aec0c] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xd17 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xd18 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xd19 11 samples (1-11) priority 97 (base 97) <thread QoS utility, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0xd1b 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xd1c 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xd1d 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __accept + 10 (libsystem_kernel.dylib + 20966) [0x7fff60fd41e6] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 accept_nocancel + 562 (kernel + 7544722) [0xffffff8000931f92] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0xaa0be7 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (ARDAgent + 335428) [0x1025fee44] 1-11 11 ??? (ARDAgent + 336025) [0x1025ff099] 1-11 11 __connect + 10 (libsystem_kernel.dylib + 21822) [0x7fff60fd453e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 connect_nocancel + 650 (kernel + 7547418) [0xffffff8000932a1a] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0xaa0be8 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (ARDAgent + 335428) [0x1025fee44] 1-11 11 ??? (ARDAgent + 336025) [0x1025ff099] 1-11 11 __connect + 10 (libsystem_kernel.dylib + 21822) [0x7fff60fd453e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 connect_nocancel + 650 (kernel + 7547418) [0xffffff8000932a1a] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0xaa0c07 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (ARDAgent + 335428) [0x1025fee44] 1-11 11 ??? (ARDAgent + 336025) [0x1025ff099] 1-11 11 __connect + 10 (libsystem_kernel.dylib + 21822) [0x7fff60fd453e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 connect_nocancel + 650 (kernel + 7547418) [0xffffff8000932a1a] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Binary Images: 0x1025ad000 - 0x1026b4fff com.apple.RemoteDesktopAgent 3.9.8 (525.51) <C9097C01-A695-389B-BD31-2097BC5356C1> /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: aslmanager [145] UUID: 2C1732C8-0F63-3418-A9E3-862A12A133D6 Path: /usr/sbin/aslmanager Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2584 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x300 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 3> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x104c50000 - 0x104c59fff aslmanager <2C1732C8-0F63-3418-A9E3-862A12A133D6> /usr/sbin/aslmanager 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: aslmanager [44100] UUID: 2C1732C8-0F63-3418-A9E3-862A12A133D6 Path: /usr/sbin/aslmanager Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 772 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3b2399 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 3> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x105b9c000 - 0x105ba5fff aslmanager <2C1732C8-0F63-3418-A9E3-862A12A133D6> /usr/sbin/aslmanager 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: assertiond [4066] UUID: 3D32AB97-9560-331C-8A11-EC038C3CFD0F Path: /usr/libexec/assertiond Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 1808 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x4be3f DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10cf8d000 - 0x10cfc6fff assertiond <3D32AB97-9560-331C-8A11-EC038C3CFD0F> /usr/libexec/assertiond 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: AssetCache [800] UUID: 8FEDE7C4-E643-3F29-8F62-E1AF5CF42939 Path: /usr/libexec/AssetCache/AssetCache Architecture: x86_64 Parent: launchd [1] UID: 235 Sudden Term: Tracked (allows idle exit) Footprint: 3880 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3f5a 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101cda000 - 0x101e7ffff AssetCache <8FEDE7C4-E643-3F29-8F62-E1AF5CF42939> /usr/libexec/AssetCache/AssetCache 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: assistant_service [5602] UUID: 0CBCDE32-AA6A-331B-8CCD-5BFF625EC8AE Path: /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 47.59 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x75c05 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe692d Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104b1c000 - 0x104b28fff assistant_service (1737.195) <0CBCDE32-AA6A-331B-8CCD-5BFF625EC8AE> /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: assistantd [404] UUID: BDBA8173-6CC1-3710-BD77-1A8205C77A20 Path: /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 37.57 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (81.6K cycles, 23.2K instructions, 3.52c/i) Note: 1 idle work queue thread omitted Thread 0xe2c DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (assistantd + 79405) [0x10b84162d] 1-11 11 ??? (assistantd + 80634) [0x10b841afa] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b82e000 - 0x10bae1fff assistantd (1737.195) <BDBA8173-6CC1-3710-BD77-1A8205C77A20> /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: atsd [825] UUID: 180E9A70-84DA-3766-BE14-F400A058B32B Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/atsd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 5040 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x4dff 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user initiated), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main_handler + 4300 (libATSServer.dylib + 513971) [0x7fff333d57b3] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e0ea000 - 0x10e0edfff atsd <180E9A70-84DA-3766-BE14-F400A058B32B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/atsd 0x7fff33358000 - 0x7fff333edfff libATSServer.dylib (453.11.2.2) <37E698CA-67D9-3A99-82C9-F42157DF145A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libATSServer.dylib 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: AudioComponentRegistrar [193] UUID: C285208A-5AD6-3F78-BC69-D31BB3DA96D1 Path: /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 4164 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x42d 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a6c7000 - 0x10a6c8fff AudioComponentRegistrar (975.97) <C285208A-5AD6-3F78-BC69-D31BB3DA96D1> /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: AudioComponentRegistrar [765] UUID: C285208A-5AD6-3F78-BC69-D31BB3DA96D1 Path: /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 5468 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x32e2 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f5f1000 - 0x10f5f2fff AudioComponentRegistrar (975.97) <C285208A-5AD6-3F78-BC69-D31BB3DA96D1> /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: authd [144] UUID: 7903F716-AB62-3E2E-9AC3-862FBBA8939F Path: /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 7588 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x32b 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __read_nocancel + 10 (libsystem_kernel.dylib + 8634) [0x7fff60fd11ba] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4319092) [0xffffff800061e774] 1-11 *11 spec_read + 672 (kernel + 4425648) [0xffffff80006387b0] 1-11 *11 ??? (kernel + 6732104) [0xffffff800086b948] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x347 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10c6f2000 - 0x10c715fff com.apple.authd 1.0 (58286.270.14) <7903F716-AB62-3E2E-9AC3-862FBBA8939F> /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: autofsd [96] UUID: AD1F8C75-D277-350C-B5E9-C1AFAEA10A83 Path: /usr/libexec/autofsd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 848 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x504 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x100831000 - 0x100831fff autofsd <AD1F8C75-D277-350C-B5E9-C1AFAEA10A83> /usr/libexec/autofsd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: avconferenced [42201] UUID: 0F476CC8-645D-3B24-B860-A54963C9F1B9 Path: /usr/libexec/avconferenced Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 5792 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x35e75f 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10bf4b000 - 0x10bf4bfff avconferenced (1475.4.8) <0F476CC8-645D-3B24-B860-A54963C9F1B9> /usr/libexec/avconferenced 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: awdd [191] UUID: 94D581CA-04CA-3AA7-8087-D09B74E2AB67 Path: /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 10.59 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x41e DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102477000 - 0x10255afff awdd (930.11) <94D581CA-04CA-3AA7-8087-D09B74E2AB67> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: backgroundtaskmanagementagent [313] UUID: 8E407DD0-50B5-354F-9E63-8FA504F97D8B Path: /System/Library/CoreServices/backgroundtaskmanagementagent Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 10.85 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x930 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10e3b3000 - 0x10e3cdfff backgroundtaskmanagementagent <8E407DD0-50B5-354F-9E63-8FA504F97D8B> /System/Library/CoreServices/backgroundtaskmanagementagent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: backupd [13157] [unique pid 112763] UUID: ED3C2C56-EDE6-3E72-B8CF-EC105C7A956B Path: /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 2412 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6700b8 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 3> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (backupd + 67768) [0x101e358b8] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101e25000 - 0x101eadfff backupd (283.30) <ED3C2C56-EDE6-3E72-B8CF-EC105C7A956B> /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: backupd-helper [80] UUID: 2B55AD03-A067-3608-8808-4C13C56A08CF Path: /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 2488 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x281 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1098ea000 - 0x109906fff backupd-helper <2B55AD03-A067-3608-8808-4C13C56A08CF> /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: bird [329] UUID: 85AD688A-8111-3E36-BBAC-620C07A68E60 Path: /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 4052 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x9c4 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d5d8000 - 0x10d5d9fff bird (575.303) <85AD688A-8111-3E36-BBAC-620C07A68E60> /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Bluetooth File Exchange [42140] UUID: CF26238B-7C6B-3BD4-878D-B069CE126908 Path: /Applications/Utilities/Bluetooth File Exchange.app/Contents/MacOS/Bluetooth File Exchange Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 34.45 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (69.6K cycles, 25.4K instructions, 2.73c/i) Note: 2 idle work queue threads omitted Thread 0x35d262 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x35d28b Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10c45d000 - 0x10c46ffff Bluetooth File Exchange <CF26238B-7C6B-3BD4-878D-B069CE126908> /Applications/Utilities/Bluetooth File Exchange.app/Contents/MacOS/Bluetooth File Exchange 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: bluetoothd [108] UUID: A74E6D15-1C2B-301C-99FB-39F53044AF61 Path: /usr/sbin/bluetoothd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 25.84 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.004s (15.9M cycles, 5.1M instructions, 3.14c/i) Note: 1 idle work queue thread omitted Thread 0x27d DispatchQueue 1 11 samples (1-11) priority 31 (base 31) cpu time 0.004s (15.9M cycles, 5.1M instructions, 3.14c/i) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (bluetoothd + 1033495) [0x109282517] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x576 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x109186000 - 0x10944cfff bluetoothd (6014.1.14) <A74E6D15-1C2B-301C-99FB-39F53044AF61> /usr/sbin/bluetoothd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: bootinstalld [235] UUID: D6B1D7C1-DF03-39C1-8851-3AC4046753A4 Path: /usr/libexec/bootinstalld Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2720 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6b5 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102e91000 - 0x102e97fff bootinstalld <D6B1D7C1-DF03-39C1-8851-3AC4046753A4> /usr/libexec/bootinstalld 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Calculator [56872] [unique pid 156457] UUID: E26D5AC3-8BB4-3D87-BD39-12C55C5590CE Path: /Applications/Calculator.app/Contents/MacOS/Calculator Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 26.54 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (52.4K cycles, 24.7K instructions, 2.13c/i) Note: 2 idle work queue threads omitted Thread 0x9795d7 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x979631 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d391000 - 0x10d3aefff Calculator <E26D5AC3-8BB4-3D87-BD39-12C55C5590CE> /Applications/Calculator.app/Contents/MacOS/Calculator 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: CalendarAgent [340] UUID: DF33ECE0-1050-36DD-A273-A6907BD84488 Path: /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 39.59 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (150.3K cycles, 29.6K instructions, 5.08c/i) Note: 1 idle work queue thread omitted Thread 0xa42 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from com.apple.dock.extra [332], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (CalendarAgent + 5996) [0x10273276c] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xedf Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from com.apple.dock.extra [332], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102731000 - 0x102732fff CalendarAgent (416.5.2) <DF33ECE0-1050-36DD-A273-A6907BD84488> /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: CallHistoryPluginHelper [346] UUID: 9D3403B0-6DC7-3269-A693-F382F13F1521 Path: /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2204 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa60 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1000a5000 - 0x1000a6fff CallHistoryPluginHelper <9D3403B0-6DC7-3269-A693-F382F13F1521> /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: callservicesd [296] UUID: F6A1404C-3C40-3A04-BA99-6BA8714EFE12 Path: /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 8480 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x883 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (callservicesd + 1140624) [0x105288790] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105172000 - 0x105327fff callservicesd (977.41) <F6A1404C-3C40-3A04-BA99-6BA8714EFE12> /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: CalNCService [349] UUID: 2E0EDC39-AEE1-38B0-A471-2788866DD2DF Path: /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService Architecture: x86_64 Parent: launchd [1] Responsible: CalendarAgent [340] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 16.02 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa9f DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 111 (CalNCService + 49022) [0x10b424f7e] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b419000 - 0x10b428fff com.apple.CalendarNotification.CalNCService 1.0 (585.3.1) <2E0EDC39-AEE1-38B0-A471-2788866DD2DF> /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: captiveagent [387] UUID: E1C27CCE-BF90-3F79-8144-E1CF0900320A Path: /usr/libexec/captiveagent Architecture: x86_64 Parent: launchd [1] UID: 258 Sudden Term: Tracked (allows idle exit) Footprint: 2876 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xd81 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xd86 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xdc1 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x100f52000 - 0x100f59fff captiveagent <E1C27CCE-BF90-3F79-8144-E1CF0900320A> /usr/libexec/captiveagent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: cfprefsd [115] UUID: DABBAE9C-E74B-3420-80B8-9298628DFD56 Path: /usr/sbin/cfprefsd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 19.50 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x2a2 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10153c000 - 0x10153cfff cfprefsd <DABBAE9C-E74B-3420-80B8-9298628DFD56> /usr/sbin/cfprefsd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: cfprefsd [263] UUID: DABBAE9C-E74B-3420-80B8-9298628DFD56 Path: /usr/sbin/cfprefsd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 9096 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x7a5 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10b0da000 - 0x10b0dafff cfprefsd <DABBAE9C-E74B-3420-80B8-9298628DFD56> /usr/sbin/cfprefsd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: cfprefsd [935] UUID: DABBAE9C-E74B-3420-80B8-9298628DFD56 Path: /usr/sbin/cfprefsd Architecture: x86_64 Parent: launchd [1] UID: 501 Sudden Term: Tracked (allows idle exit) Footprint: 732 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xb144 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1075e1000 - 0x1075e1fff cfprefsd <DABBAE9C-E74B-3420-80B8-9298628DFD56> /usr/sbin/cfprefsd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: check_afp [681] UUID: 974DEDC8-BC32-3168-8D4E-838E3F05B9A3 Path: /System/Library/Filesystems/AppleShare/check_afp.app/Contents/MacOS/check_afp Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 1228 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1f1d 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x1f24 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x1f40 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10c0f5000 - 0x10c0f8fff check_afp (508.250.1) <974DEDC8-BC32-3168-8D4E-838E3F05B9A3> /System/Library/Filesystems/AppleShare/check_afp.app/Contents/MacOS/check_afp 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: chrome_crashpad_handler [725] UUID: 4C4C4451-5555-3144-A188-34ECCBD38F7D Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/chrome_crashpad_handler Architecture: x86_64 Parent: launchd [1] Responsible: Google Chrome [721] UID: 504 Footprint: 1304 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x2eef 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 CrashpadHandlerMain + 107 (chrome_crashpad_handler + 51499) [0x10ae6592b] 1-11 11 CrashpadHandlerMain + 236402 (chrome_crashpad_handler + 287794) [0x10ae9f432] 1-11 11 CrashpadHandlerMain + 249040 (chrome_crashpad_handler + 300432) [0x10aea2590] 1-11 11 CrashpadHandlerMain + 639239 (chrome_crashpad_handler + 690631) [0x10af019c7] 1-11 11 CrashpadHandlerMain + 637521 (chrome_crashpad_handler + 688913) [0x10af01311] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2ef4 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CrashpadHandlerMain + 630601 (chrome_crashpad_handler + 681993) [0x10aeff809] 1-11 11 CrashpadHandlerMain + 629275 (chrome_crashpad_handler + 680667) [0x10aeff2db] 1-11 11 CrashpadHandlerMain + 641502 (chrome_crashpad_handler + 692894) [0x10af0229e] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x2ef5 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 CrashpadHandlerMain + 630601 (chrome_crashpad_handler + 681993) [0x10aeff809] 1-11 11 CrashpadHandlerMain + 629275 (chrome_crashpad_handler + 680667) [0x10aeff2db] 1-11 11 CrashpadHandlerMain + 641502 (chrome_crashpad_handler + 692894) [0x10af0229e] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Binary Images: 0x10ae59000 - 0x10af60fff chrome_crashpad_handler <4C4C4451-5555-3144-A188-34ECCBD38F7D> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/chrome_crashpad_handler 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: chrome_crashpad_handler [840] UUID: 4C4C448D-5555-3144-A1F3-9749A01C369E Path: /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Helpers/chrome_crashpad_handler Architecture: x86_64 Parent: launchd [1] Responsible: Teams [836] UID: 504 Footprint: 1292 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6187 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 <truncated backtrace> 1-11 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 CrashpadHandlerMain + 92 (chrome_crashpad_handler + 4588) [0x10a9a91ec] 1-11 11 CrashpadHandlerMain + 147136 (chrome_crashpad_handler + 151632) [0x10a9cd050] 1-11 11 CrashpadHandlerMain + 154672 (chrome_crashpad_handler + 159168) [0x10a9cedc0] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 125930 (chrome_crashpad_handler + 506618) [0x10aa23afa] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 124233 (chrome_crashpad_handler + 504921) [0x10aa23459] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x618a 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 116810 (chrome_crashpad_handler + 497498) [0x10aa2175a] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 109051 (chrome_crashpad_handler + 489739) [0x10aa1f90b] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 128142 (chrome_crashpad_handler + 508830) [0x10aa2439e] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x618b 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 116810 (chrome_crashpad_handler + 497498) [0x10aa2175a] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 109051 (chrome_crashpad_handler + 489739) [0x10aa1f90b] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 128142 (chrome_crashpad_handler + 508830) [0x10aa2439e] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Binary Images: 0x10a9a8000 - 0x10ab19fff chrome_crashpad_handler <4C4C448D-5555-3144-A1F3-9749A01C369E> /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Helpers/chrome_crashpad_handler 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Cineware [62935] [unique pid 162518] UUID: 8A8E11EB-5237-3C94-96A7-93F983F2D90A Path: /Applications/Vectorworks 2021/*/Cineware.app/Contents/MacOS/Cineware Architecture: x86_64 Parent: Vectorworks [62926] [unique pid 162509] Responsible: Vectorworks [62926] [unique pid 162509] UID: 504 Footprint: 412.53 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.002s (6.8M cycles, 1325.0K instructions, 5.10c/i) Note: 2 idle work queue threads omitted Thread 0xa4bc67 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (4.3M cycles, 846.2K instructions, 5.10c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Cineware + 33308) [0x102ca921c] 1-11 11 ??? (Cineware + 34288) [0x102ca95f0] 1-11 11 ??? (Cineware + 28006) [0x102ca7d66] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4bc6a Thread name "CoreTimerThread" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (91.6K cycles, 7.1K instructions, 12.94c/i) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa4bc6f Thread name "Crash Handler" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4bc7d Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4bc7e 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bc85 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173146) [0x102fa7b1a] 1-11 11 ??? (c4dplugin.xlib + 832493) [0x106ac83ed] 1-11 11 ??? (c4dplugin.xlib + 833463) [0x106ac87b7] 1-11 11 usleep + 53 (libsystem_c.dylib + 501768) [0x7fff60f5f808] 1-11 11 __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa4bc86 Thread name "Default Queue #0: 0x7fe7d809d000 (Q 0x1031a5100, Id 0x70000cd95" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2079700) [0x102e9cbd4] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bc87 Thread name "Default Queue #1: 0x7fe7d81280c0 (Q 0x1031a5100, Id 0x70000ce98" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2079700) [0x102e9cbd4] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bc88 Thread name "Default Queue #2: 0x7fe7d8137080 (Q 0x1031a5100, Id 0x70000cf9b" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2079700) [0x102e9cbd4] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bc89 Thread name "Default Queue #3: 0x7fe7d8146040 (Q 0x1031a5100, Id 0x70000d09e" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2079700) [0x102e9cbd4] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bc8a Thread name "Default Queue #4: 0x7fe7d8155000 (Q 0x1031a5100, Id 0x70000d1a1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2079700) [0x102e9cbd4] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bc8b Thread name "Default Queue #5: 0x7fe7d81680c0 (Q 0x1031a5100, Id 0x70000d2a4" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2079700) [0x102e9cbd4] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bc8c Thread name "Default Queue #6: 0x7fe7d8177080 (Q 0x1031a5100, Id 0x70000d3a7" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2079700) [0x102e9cbd4] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bc8d Thread name "Default Queue #7: 0x7fe7d8186040 (Q 0x1031a5100, Id 0x70000d4aa" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2079700) [0x102e9cbd4] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4bc8f 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (68.4K cycles, 10.3K instructions, 6.67c/i) <thread QoS default (requested user initiated), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173146) [0x102fa7b1a] 1-11 11 ??? (c4dplugin.xlib + 5183129) [0x106eee699] 1-11 11 ??? (c4dplugin.xlib + 5176337) [0x106eecc11] 1-11 11 ??? (xtensions.xlib + 1769147) [0x113826ebb] 1-11 11 ??? (c4dplugin.xlib + 13401400) [0x1076c4d38] 1-11 11 ??? (network.module.xlib + 186953) [0x10e728a49] 1-11 11 ??? (network.module.xlib + 191819) [0x10e729d4b] 1-11 11 ??? (network.module.xlib + 195047) [0x10e72a9e7] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0xa4bc90 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (57.6K cycles, 10.2K instructions, 5.67c/i) <thread QoS default (requested user initiated), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173146) [0x102fa7b1a] 1-11 11 ??? (c4dplugin.xlib + 5183129) [0x106eee699] 1-11 11 ??? (c4dplugin.xlib + 5176337) [0x106eecc11] 1-11 11 ??? (xtensions.xlib + 1771033) [0x113827619] 1-11 11 usleep + 53 (libsystem_c.dylib + 501768) [0x7fff60f5f808] 1-11 11 __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa4bd63 11 samples (1-11) priority 30 (base 31) <thread QoS default (requested user initiated), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa8cf46 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user initiated), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa8cf48 Thread name "Render Queue #1: 0x7fe7d01e7080 (Q 0x7fe7d00d9d80, Id 0x70000d8" 11 samples (1-11) priority 8 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa8cf49 Thread name "Render Queue #6: 0x7fe7ec83d000 (Q 0x7fe7d00d9d80, Id 0x70000d9" 11 samples (1-11) priority 7 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa8cf4a Thread name "Render Queue #3: 0x7fe7d0205000 (Q 0x7fe7d00d9d80, Id 0x70000da" 11 samples (1-11) priority 7 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa8cf4b Thread name "Render Queue #7: 0x7fe7ec9e80c0 (Q 0x7fe7d00d9d80, Id 0x70000db" 11 samples (1-11) priority 8 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa8cf4c Thread name "Render Queue #7: 0x7fe7d028d000 (Q 0x7fe7d00d8980, Id 0x70000dc" 11 samples (1-11) priority 30 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa8cf4d Thread name "Render Queue #2: 0x7fe7d01f6040 (Q 0x7fe7d00d9d80, Id 0x70000dd" 11 samples (1-11) priority 8 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa8cf4e Thread name "Render Queue #4: 0x7fe7ec81f080 (Q 0x7fe7d00d9d80, Id 0x70000de" 11 samples (1-11) priority 8 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa8cf9f Thread name "Render Queue #5: 0x7fe7ec82e040 (Q 0x7fe7d00d9d80, Id 0x70000df" 11 samples (1-11) priority 7 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa8cfa0 Thread name "Render Queue #0: 0x7fe7d01d80c0 (Q 0x7fe7d00d9d80, Id 0x70000e0" 11 samples (1-11) priority 8 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Cineware + 2703640) [0x102f35118] 1-11 11 ??? (Cineware + 3173274) [0x102fa7b9a] 1-11 11 ??? (Cineware + 3171605) [0x102fa7515] 1-11 11 ??? (Cineware + 2080072) [0x102e9cd48] 1-11 11 ??? (Cineware + 2081950) [0x102e9d49e] 1-11 11 ??? (Cineware + 2814662) [0x102f502c6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x102ca1000 - 0x1030d4fff net.maxon.Cineware 21.2 (308675) <8A8E11EB-5237-3C94-96A7-93F983F2D90A> /Applications/Vectorworks 2021/*/Cineware.app/Contents/MacOS/Cineware 0x1069fd000 - 0x107f33fff c4dplugin.xlib (0) <E8E51742-0C47-38BC-B05B-191ED79B78C2> /Applications/Vectorworks 2021/*/c4dplugin.xlib 0x10e6fb000 - 0x10e8e9fff network.module.xlib (0) <FF48F987-C0C9-35A2-9E55-77B1E9F253C7> /Applications/Vectorworks 2021/*/network.module.xlib 0x113677000 - 0x113b80fff xtensions.xlib (0) <B439F454-7D8B-376A-913E-6A4B895EA4D4> /Applications/Vectorworks 2021/*/xtensions.xlib 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60ee5000 - 0x7fff60f6cfff libsystem_c.dylib (1272.250.3) <6016EDA1-440B-34D7-A232-686CD7FBEE90> /usr/lib/system/libsystem_c.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: cloudd [283] UUID: 5AFD8372-21B6-3AE3-8B4D-315DC1312137 Path: /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 15.28 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (126.2K cycles, 26.1K instructions, 4.83c/i) Note: 1 idle work queue thread omitted Thread 0x814 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from secd [279], process received importance donation from imagent [299], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (cloudd + 7603) [0x107010db3] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10700f000 - 0x107013fff cloudd (736.232) <5AFD8372-21B6-3AE3-8B4D-315DC1312137> /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: CloudKeychainProxy [310] UUID: 0E98A85A-90C8-30F9-BC24-6EC4A26B4F89 Path: /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1572 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x911 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102db1000 - 0x102dc2fff CloudKeychainProxy <0E98A85A-90C8-30F9-BC24-6EC4A26B4F89> /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: cloudpaird [423] UUID: 313DCA15-5878-36C7-922E-85EE5FBC235D Path: /System/Library/CoreServices/cloudpaird Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 16.93 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe81 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (cloudpaird + 158273) [0x105171a41] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10514b000 - 0x10519cfff cloudpaird (6014.1.14) <313DCA15-5878-36C7-922E-85EE5FBC235D> /System/Library/CoreServices/cloudpaird 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: cloudphotosd [794] UUID: 9A7B379F-79E0-3CB3-8D5E-83C185CC0B78 Path: /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 9856 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (53.9K cycles, 24.1K instructions, 2.24c/i) Note: 2 idle work queue threads omitted Thread 0x3f5d DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 115 (cloudphotosd + 653642) [0x10405394a] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x3fa0 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x103fb4000 - 0x10408bfff com.apple.cloudphotosd 4.0 (3461.7.160) <9A7B379F-79E0-3CB3-8D5E-83C185CC0B78> /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: cmhelperd [382] UUID: 1F51BDE3-D183-3B11-8233-0B3CD5BDE1E5 Path: /Library/MonitoringClient/*/ContactMenu.app/Contents/MacOS/cmhelperd Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 7260 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0xd44 DispatchQueue 1 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (cmhelperd + 10587) [0x10eeac95b] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xfb3 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested user interactive), timers tier 3 (coalesced), IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10eeaa000 - 0x10eeb5fff com.monitoringclient.contact-menu 8.0 (8.0) <1F51BDE3-D183-3B11-8233-0B3CD5BDE1E5> /Library/MonitoringClient/*/ContactMenu.app/Contents/MacOS/cmhelperd 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: colorsync.displayservices [226] UUID: 7157BF3E-2E37-3EC7-8C5A-4A57DBF05286 Path: /usr/libexec/colorsync.displayservices Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1352 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x648 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10ed38000 - 0x10ed3dfff colorsync.displayservices <7157BF3E-2E37-3EC7-8C5A-4A57DBF05286> /usr/libexec/colorsync.displayservices 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: colorsync.useragent [787] UUID: C4411A34-1442-3491-BDFA-13607D908ACC Path: /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2452 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3a12 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100808000 - 0x10080bfff colorsync.useragent <C4411A34-1442-3491-BDFA-13607D908ACC> /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: colorsyncd [228] UUID: D50B720A-09A1-37AF-9A5C-CD01C4FE5CEE Path: /usr/libexec/colorsyncd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2280 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x64d 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d5e3000 - 0x10d5e5fff colorsyncd <D50B720A-09A1-37AF-9A5C-CD01C4FE5CEE> /usr/libexec/colorsyncd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.accessibility.mediaaccessibilityd [1089] UUID: 88B9A527-E1CB-3D8A-8CC4-946FBE4D68B2 Path: /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1144 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x124eb 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1006d4000 - 0x1006d5fff com.apple.accessibility.mediaaccessibilityd <88B9A527-E1CB-3D8A-8CC4-946FBE4D68B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/XPCServices/com.apple.accessibility.mediaaccessibilityd.xpc/Contents/MacOS/com.apple.accessibility.mediaaccessibilityd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.AccountPolicyHelper [245] UUID: DF61919B-8E51-31EB-B6E4-B1D7FB61542D Path: /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1388 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x720 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10e86d000 - 0x10e877fff com.apple.AccountPolicyHelper <DF61919B-8E51-31EB-B6E4-B1D7FB61542D> /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.AmbientDisplayAgent [392] UUID: 41254C2E-00A1-3996-B1E1-1B57900BD7F6 Path: /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2620 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xda9 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xdb4 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xdb6 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e862000 - 0x10e869fff com.apple.AmbientDisplayAgent 1.0 (110) <41254C2E-00A1-3996-B1E1-1B57900BD7F6> /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.appkit.xpc.openAndSavePanelService [4982] UUID: 50C9373E-9EEA-3A6C-919A-1CF94F9098D9 Path: /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService Architecture: x86_64 Parent: launchd [1] Responsible: Microsoft Outlook [4828] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 63.47 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (92.4K cycles, 25.7K instructions, 3.59c/i) Note: 2 idle work queue threads omitted Thread 0x5854c DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 26542) [0x1050c67ae] 1-11 11 NSViewServiceApplicationMain + 2830 (ViewBridge + 50108) [0x7fff5c9f93bc] 1-11 11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58562 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1050c0000 - 0x1050c9fff com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <50C9373E-9EEA-3A6C-919A-1CF94F9098D9> /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff5c9ed000 - 0x7fff5cac6fff com.apple.ViewBridge 407 (407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.appkit.xpc.openAndSavePanelService [16669] [unique pid 116270] UUID: 50C9373E-9EEA-3A6C-919A-1CF94F9098D9 Path: /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 32.80 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (484.3K cycles, 128.6K instructions, 3.77c/i) Note: 3 idle work queue threads omitted Thread 0x74c949 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 26542) [0x10cd687ae] 1-11 11 NSViewServiceApplicationMain + 2830 (ViewBridge + 50108) [0x7fff5c9f93bc] 1-11 11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x74c99a Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10cd62000 - 0x10cd6bfff com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <50C9373E-9EEA-3A6C-919A-1CF94F9098D9> /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff5c9ed000 - 0x7fff5cac6fff com.apple.ViewBridge 407 (407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.appkit.xpc.openAndSavePanelService [16763] [unique pid 116363] UUID: 50C9373E-9EEA-3A6C-919A-1CF94F9098D9 Path: /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService Architecture: x86_64 Parent: launchd [1] Responsible: Preview [6302] [unique pid 105926] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 38.75 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (76.3K cycles, 24.9K instructions, 3.06c/i) Note: 2 idle work queue threads omitted Thread 0x752947 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 26542) [0x10e24a7ae] 1-11 11 NSViewServiceApplicationMain + 2830 (ViewBridge + 50108) [0x7fff5c9f93bc] 1-11 11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x752970 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e244000 - 0x10e24dfff com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <50C9373E-9EEA-3A6C-919A-1CF94F9098D9> /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff5c9ed000 - 0x7fff5cac6fff com.apple.ViewBridge 407 (407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.audio.DriverHelper [170] UUID: 10B74390-27AB-3E2D-BA86-BA4C50691315 Path: /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper Architecture: x86_64 Parent: launchd [1] Responsible: coreaudiod [155] UID: 202 Sudden Term: Tracked (allows idle exit) Footprint: 3196 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3a2 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x100f40000 - 0x100f42fff com.apple.audio.DriverHelper <10B74390-27AB-3E2D-BA86-BA4C50691315> /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.audio.SandboxHelper [194] UUID: BDEA0F2E-574E-3383-81C6-5AD30808B73B Path: /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper Architecture: x86_64 Parent: launchd [1] Responsible: coreaudiod [155] UID: 202 Sudden Term: Tracked (allows idle exit) Footprint: 932 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x433 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x108725000 - 0x108729fff com.apple.audio.SandboxHelper <BDEA0F2E-574E-3383-81C6-5AD30808B73B> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.audio.SandboxHelper [766] UUID: BDEA0F2E-574E-3383-81C6-5AD30808B73B Path: /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper Architecture: x86_64 Parent: launchd [1] Responsible: Google Chrome [721] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 932 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x32ef 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x102367000 - 0x10236bfff com.apple.audio.SandboxHelper <BDEA0F2E-574E-3383-81C6-5AD30808B73B> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.audio.SandboxHelper [845] UUID: BDEA0F2E-574E-3383-81C6-5AD30808B73B Path: /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper Architecture: x86_64 Parent: launchd [1] Responsible: assistantd [404] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1040 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x620f 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x104226000 - 0x10422afff com.apple.audio.SandboxHelper <BDEA0F2E-574E-3383-81C6-5AD30808B73B> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.audio.SandboxHelper [853] UUID: BDEA0F2E-574E-3383-81C6-5AD30808B73B Path: /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper Architecture: x86_64 Parent: launchd [1] Responsible: Teams [836] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 956 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x62c7 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x109ba5000 - 0x109ba9fff com.apple.audio.SandboxHelper <BDEA0F2E-574E-3383-81C6-5AD30808B73B> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.audio.SandboxHelper [16753] [unique pid 116353] UUID: BDEA0F2E-574E-3383-81C6-5AD30808B73B Path: /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 876 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x751311 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10697a000 - 0x10697efff com.apple.audio.SandboxHelper <BDEA0F2E-574E-3383-81C6-5AD30808B73B> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.BKAgentService [8662] [unique pid 108277] UUID: D595BCAE-22E2-34D7-9BA1-715559F52134 Path: /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAgentService.xpc/Contents/MacOS/com.apple.BKAgentService Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1848 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x5ffd3a 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10345a000 - 0x1034c8fff com.apple.BKAgentService <D595BCAE-22E2-34D7-9BA1-715559F52134> /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAgentService.xpc/Contents/MacOS/com.apple.BKAgentService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.CloudDocs.MobileDocumentsFileProvider [60039] [unique pid 159624] UUID: B65F616A-60F9-3202-9B6D-C9E1C5D7F632 Path: /System/Library/PrivateFrameworks/CloudDocs.framework/PlugIns/com.apple.CloudDocs.MobileDocumentsFileProvider.appex/Contents/MacOS/com.apple.CloudDocs.MobileDocumentsFileProvider Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1992 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x9f2a77 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10c745000 - 0x10c755fff com.apple.CloudDocs.MobileDocumentsFileProvider <B65F616A-60F9-3202-9B6D-C9E1C5D7F632> /System/Library/PrivateFrameworks/CloudDocs.framework/PlugIns/com.apple.CloudDocs.MobileDocumentsFileProvider.appex/Contents/MacOS/com.apple.CloudDocs.MobileDocumentsFileProvider 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.CloudPhotosConfiguration [805] UUID: 77A2324C-F8BB-3991-A2AD-D833B24076E9 Path: /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2636 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3fa1 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 24 (com.apple.CloudPhotosConfiguration + 10873) [0x1084dca79] 1-11 11 +[CPSConfigurationService run] + 53 (com.apple.CloudPhotosConfiguration + 11195) [0x1084dcbbb] 1-11 11 -[CPSConfigurationService run] + 199 (com.apple.CloudPhotosConfiguration + 11407) [0x1084dcc8f] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1084da000 - 0x1084eafff com.apple.CloudPhotosConfiguration 4.0 (3461.7.160) <77A2324C-F8BB-3991-A2AD-D833B24076E9> /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.cmio.registerassistantservice [495] UUID: C147D580-E0BC-32C9-9214-B3DE88D6B0BC Path: /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 808 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x151a 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10bfcb000 - 0x10bfcdfff com.apple.cmio.registerassistantservice <C147D580-E0BC-32C9-9214-B3DE88D6B0BC> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.CodeSigningHelper [187] UUID: DA9B9F7C-0121-3BF3-9941-F1F6498B7D94 Path: /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 12.85 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3f6 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x103c67000 - 0x103c68fff com.apple.CodeSigningHelper <DA9B9F7C-0121-3BF3-9941-F1F6498B7D94> /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.ctkpcscd [156] UUID: 357CFF2A-6330-3539-A2AB-812619DD5D25 Path: /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd Architecture: x86_64 Parent: launchd [1] Responsible: securityd [90] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1016 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x368 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10a535000 - 0x10a53efff com.apple.ctkpcscd <357CFF2A-6330-3539-A2AB-812619DD5D25> /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.dock.extra [332] UUID: 3F1E89E9-6587-3558-96F8-E31C12D1F07F Path: /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra Architecture: x86_64 Parent: launchd [1] Responsible: Dock [274] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 9016 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (105.8K cycles, 32.5K instructions, 3.26c/i) Note: 2 idle work queue threads omitted Thread 0x9c1 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Dock [274], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.dock.extra + 4388) [0x101ec4124] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9e0 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Dock [274], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101ec3000 - 0x101ec6fff com.apple.dock.extra 1.0 (1) <3F1E89E9-6587-3558-96F8-E31C12D1F07F> /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.geod [342] UUID: FE72F42B-C7DA-3104-91D4-D845CA2CCE66 Path: /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 17.75 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa4f 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa7f Thread name "NetworkLoad" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x202ab Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104abf000 - 0x104aedfff com.apple.geod 1.0 (1364.26.4.19.6) <FE72F42B-C7DA-3104-91D4-D845CA2CCE66> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.hiservices-xpcservice [699] UUID: BCAE3700-079A-39EC-957B-B7AB778D7852 Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2088 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: Unresponsive for 211644 seconds before sampling Note: 2 idle work queue threads omitted Thread 0x2aa2 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10b60d000 - 0x10b611fff com.apple.hiservices-xpcservice <BCAE3700-079A-39EC-957B-B7AB778D7852> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.ifdreader [203] UUID: 734438E8-0F06-3932-A1A2-CB963F73CD14 Path: /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1196 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x5c7 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101336000 - 0x101341fff com.apple.ifdreader 1.0 (1) <734438E8-0F06-3932-A1A2-CB963F73CD14> /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.iTunesLibraryService [493] UUID: B45883A0-D7FE-3F8E-BF68-AB466A221DB7 Path: /System/Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService Architecture: x86_64 Parent: launchd [1] Responsible: assistantd [404] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 3180 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1515 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10a88b000 - 0x10a984fff com.apple.iTunesLibraryService <B45883A0-D7FE-3F8E-BF68-AB466A221DB7> /System/Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.iTunesLibraryService [9952] UUID: B45883A0-D7FE-3F8E-BF68-AB466A221DB7 Path: /System/Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService Architecture: x86_64 Parent: launchd [1] Responsible: assistant_service [5602] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 5632 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe6926 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1070a9000 - 0x1071a2fff com.apple.iTunesLibraryService <B45883A0-D7FE-3F8E-BF68-AB466A221DB7> /System/Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibraryService.xpc/Contents/MacOS/com.apple.iTunesLibraryService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.MediaLibraryService [806] UUID: 7A484597-FB6E-32F8-A786-3E87357BADE8 Path: /System/Library/Frameworks/MediaLibrary.framework/Versions/A/XPCServices/com.apple.MediaLibraryService.xpc/Contents/MacOS/com.apple.MediaLibraryService Architecture: x86_64 Parent: launchd [1] Responsible: cloudphotosd [794] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 10.73 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3fb1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e76f000 - 0x10e779fff com.apple.MediaLibraryService 1.5.0 (764) <7A484597-FB6E-32F8-A786-3E87357BADE8> /System/Library/Frameworks/MediaLibrary.framework/Versions/A/XPCServices/com.apple.MediaLibraryService.xpc/Contents/MacOS/com.apple.MediaLibraryService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.PerformanceAnalysis.animationperfd [253] UUID: B8021A05-5056-3A6F-93DD-DD7BDA43F453 Path: /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 8588 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (86.8K cycles, 29.7K instructions, 2.93c/i) Note: 2 idle work queue threads omitted Thread 0x753 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10d049000 - 0x10d052fff com.apple.PerformanceAnalysis.animationperfd <B8021A05-5056-3A6F-93DD-DD7BDA43F453> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.quicklook.ThumbnailsAgent [795] UUID: 92DE2ABD-2896-3923-A137-BF9F941F5589 Path: /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1552 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3f5e 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10aabe000 - 0x10aad3fff com.apple.quicklook.ThumbnailsAgent <92DE2ABD-2896-3923-A137-BF9F941F5589> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.Safari.History [16861] UUID: 0371D741-EAC9-36E8-A8D5-050ED6422112 Path: /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 4536 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1c5123 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x1c512a Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user initiated), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x10d48e000 - 0x10d48ffff com.apple.Safari.History <0371D741-EAC9-36E8-A8D5-050ED6422112> /System/Library/StagedFrameworks/Safari/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.Safari.SafeBrowsing.Service [16870] UUID: CE4EC79B-1D39-3862-B885-47EED3C707E7 Path: /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safari.SafeBrowsing.Service Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 41.79 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (99.7K cycles, 31.2K instructions, 3.19c/i) Note: 1 idle work queue thread omitted Thread 0x1c51ff 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10eb4e000 - 0x10eb50fff com.apple.Safari.SafeBrowsing.Service <CE4EC79B-1D39-3862-B885-47EED3C707E7> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/com.apple.Safari.SafeBrowsing.Service 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.security.pboxd [15547] UUID: FD747B23-EDE1-3793-AE22-157ADC59CCA1 Path: /System/Library/PrivateFrameworks/RemoteViewServices.framework/XPCServices/com.apple.security.pboxd.xpc/Contents/MacOS/com.apple.security.pboxd Architecture: x86_64 Parent: launchd [1] Responsible: Microsoft Outlook [4828] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 7456 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (55.9K cycles, 24.0K instructions, 2.33c/i) Note: 2 idle work queue threads omitted Thread 0x16878d DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.security.pboxd + 12052) [0x10fd4df14] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x1687b2 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10fd4b000 - 0x10fd62fff com.apple.security.pboxd 2.0 (128) <FD747B23-EDE1-3793-AE22-157ADC59CCA1> /System/Library/PrivateFrameworks/RemoteViewServices.framework/XPCServices/com.apple.security.pboxd.xpc/Contents/MacOS/com.apple.security.pboxd 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.siri-distributed-evaluation [7343] UUID: 9F377692-08EA-3FA5-A8AC-C3A70462DD1F Path: /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evaluation Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 3320 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xc74e2 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1089ab000 - 0x1089c1fff com.apple.siri-distributed-evaluation <9F377692-08EA-3FA5-A8AC-C3A70462DD1F> /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evaluation 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.siri.ClientFlow.ClientScripter [5603] UUID: CFA6218C-F629-30D3-8900-C86D4EDA89FD Path: /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.ClientFlow.ClientScripter.xpc/Contents/MacOS/com.apple.siri.ClientFlow.ClientScripter Architecture: x86_64 Parent: launchd [1] Responsible: assistant_service [5602] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 3104 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x75c12 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1034a6000 - 0x1034cffff com.apple.siri.ClientFlow.ClientScripter <CFA6218C-F629-30D3-8900-C86D4EDA89FD> /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.ClientFlow.ClientScripter.xpc/Contents/MacOS/com.apple.siri.ClientFlow.ClientScripter 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.speech.speechsynthesisd [1228] UUID: FE40A427-9064-32DC-96FF-DA847EF0004B Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 16.22 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1a478 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101fc1000 - 0x101fd2fff com.apple.speech.speechsynthesisd (8.1.3) <FE40A427-9064-32DC-96FF-DA847EF0004B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [98174] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: Mail [98166] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 10.20 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x588129 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user initiated), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x10ee9f867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x10ee9f6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x588139 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user initiated), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x588151 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user initiated), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58816d Thread name "com.apple.CFNetwork.CustomProtocols" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10ee9e000 - 0x10ee9ffff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [8666] [unique pid 108281] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: iTunes [8660] [unique pid 108275] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 33.64 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x5ffe90 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user initiated), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x10049b867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x10049b6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffe9c Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user initiated), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5ffea2 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user initiated), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10049a000 - 0x10049bfff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [12063] [unique pid 111671] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2816 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x669a7d DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x104541867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x1045416e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x669a81 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x669a86 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104540000 - 0x104541fff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [12507] [unique pid 112113] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2796 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x66c364 DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x104472867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x1044726e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x66c36a Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x66c377 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104471000 - 0x104472fff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [13057] [unique pid 112663] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2812 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x66f60a DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x10100b867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x10100b6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x66f60e Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x66f61b Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10100a000 - 0x10100bfff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [13886] [unique pid 113492] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2828 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x67702d DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x103db3867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x103db36e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x677034 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x67703e Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x103db2000 - 0x103db3fff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [13920] [unique pid 113526] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2828 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x677844 DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x10072b867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x10072b6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x67784c Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x677857 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10072a000 - 0x10072bfff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [14195] [unique pid 113800] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2844 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x67b724 DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x102afa867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x102afa6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x67b72a Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x67b734 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102af9000 - 0x102afafff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [14447] [unique pid 114051] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2836 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x685c65 DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x10e6da867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x10e6da6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x685c6e Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x685c7c Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e6d9000 - 0x10e6dafff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [14524] [unique pid 114128] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2812 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x69767f DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x102429867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x1024296e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x697686 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x697690 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102428000 - 0x102429fff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [23828] [unique pid 123421] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2784 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7ce852 DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x10ebac867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x10ebac6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7ce859 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7ce866 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10ebab000 - 0x10ebacfff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [24678] [unique pid 124271] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2780 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7d3807 DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x10f61c867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x10f61c6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7d380f Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7d3819 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f61b000 - 0x10f61cfff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [25126] [unique pid 124719] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2752 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7d5f9a DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x1084f7867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x1084f76e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7d5fa2 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7d5fad Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1084f6000 - 0x1084f7fff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [25298] [unique pid 124891] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2824 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7d717f DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x10cd6e867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x10cd6e6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7d7187 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7d7193 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10cd6d000 - 0x10cd6efff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [25600] [unique pid 125193] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2852 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7d92bd DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x102acc867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x102acc6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7d92c5 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7d92d0 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102acb000 - 0x102accfff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [29128] [unique pid 128720] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 18.42 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (140.8K cycles, 23.8K instructions, 5.93c/i) Note: 1 idle work queue thread omitted Thread 0x7e4254 DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x10cfb9867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x10cfb96e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7e4269 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7e4275 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7edcf8 Thread name "WebCore: AsyncFileStream" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7edd08 Thread name "IndexedDatabase Server" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x10cfb8000 - 0x10cfb9fff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.Networking [29135] [unique pid 128727] UUID: 97B4845A-1405-364D-A61D-C44B32F26F5F Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking Architecture: x86_64 Parent: launchd [1] Responsible: Mini Program [29130] [unique pid 128722] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2624 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7e4304 DispatchQueue 1 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Mini Program [29130] [unique pid 128722], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.Networking + 6247) [0x10055b867] 1-11 11 ??? (com.apple.WebKit.Networking + 5858) [0x10055b6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7e430c Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Mini Program [29130] [unique pid 128722], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7e4316 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Mini Program [29130] [unique pid 128722], IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10055a000 - 0x10055bfff com.apple.WebKit.Networking 14607 (14607.3.9) <97B4845A-1405-364D-A61D-C44B32F26F5F> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.WebContent [8665] [unique pid 108280] UUID: B54D230D-67AC-3B7A-A529-8756CF1E4920 Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent Architecture: x86_64 Parent: launchd [1] Responsible: iTunes [8660] [unique pid 108275] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 210.19 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (122.7K cycles, 51.3K instructions, 2.39c/i) Note: 2 idle work queue threads omitted Thread 0x5ffe8f DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.WebContent + 6247) [0x103b4d867] 1-11 11 ??? (com.apple.WebKit.WebContent + 5858) [0x103b4d6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffe97 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5ffea7 Thread name "WebCore: Scrolling" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 WTF::wtfThreadEntryPoint(void*) + 9 (JavaScriptCore + 15417) [0x7fff381e1c39] 1-11 11 WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 194 (JavaScriptCore + 1984498) [0x7fff383c27f2] 1-11 11 WebCore::ScrollingThread::initializeRunLoop() + 252 (WebCore + 276892) [0x7fff41ad699c] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x103b4c000 - 0x103b4dfff com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff381de000 - 0x7fff3903efff com.apple.JavaScriptCore 14607 (14607.3.9) <E25D3B54-A072-33F3-AA89-6F8588BF5A05> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff41a93000 - 0x7fff43419fff com.apple.WebCore 14607 (14607.3.9) <4D9F69EF-D3AF-32C5-8C15-1C8CD7370AFC> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.WebContent [29134] [unique pid 128726] UUID: B54D230D-67AC-3B7A-A529-8756CF1E4920 Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent Architecture: x86_64 Parent: launchd [1] Responsible: Mini Program [29130] [unique pid 128722] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 29.14 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (62.2K cycles, 22.4K instructions, 2.78c/i) Note: 2 idle work queue threads omitted Thread 0x7e4303 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Mini Program [29130] [unique pid 128722], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.WebContent + 6247) [0x10261a867] 1-11 11 ??? (com.apple.WebKit.WebContent + 5858) [0x10261a6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7e4308 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Mini Program [29130] [unique pid 128722], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39 (JavaScriptCore + 2264807) [0x7fff38406ee7] 1-11 11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 2258297) [0x7fff38405579] 1-11 11 bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-11 11 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7e4317 Thread name "WebCore: Scrolling" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Mini Program [29130] [unique pid 128722], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102619000 - 0x10261afff com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff381de000 - 0x7fff3903efff com.apple.JavaScriptCore 14607 (14607.3.9) <E25D3B54-A072-33F3-AA89-6F8588BF5A05> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff5e0c2000 - 0x7fff5e115fff libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.WebContent [29138] [unique pid 128730] UUID: B54D230D-67AC-3B7A-A529-8756CF1E4920 Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 73.85 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (292.4K cycles, 78.0K instructions, 3.75c/i) Note: 2 idle work queue threads omitted Thread 0x7e4369 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.WebContent + 6247) [0x108566867] 1-11 11 ??? (com.apple.WebKit.WebContent + 5858) [0x1085666e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7e436e Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) cpu time <0.001s (45.9K cycles, 9.0K instructions, 5.10c/i) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39 (JavaScriptCore + 2264807) [0x7fff38406ee7] 1-11 11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 2258297) [0x7fff38405579] 1-11 4 bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-4 4 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-4 4 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-4 4 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-4 *4 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-4 7 bmalloc::Scavenger::threadRunLoop() + 262 (JavaScriptCore + 2260422) [0x7fff38405dc6] 5-11 7 std::__1::cv_status std::__1::condition_variable_any::wait_until<std::__1::unique_lock<bmalloc::Mutex>, std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<bmalloc::Mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 95 (JavaScriptCore + 2265343) [0x7fff384070ff] 5-11 7 std::__1::cv_status std::__1::condition_variable::wait_until<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 117 (JavaScriptCore + 2265653) [0x7fff38407235] 5-11 7 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 35633) [0x7fff5e0cab31] 5-11 7 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 5-11 *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x7e4371 Thread name "WebCore: Scrolling" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108565000 - 0x108566fff com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff381de000 - 0x7fff3903efff com.apple.JavaScriptCore 14607 (14607.3.9) <E25D3B54-A072-33F3-AA89-6F8588BF5A05> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff5e0c2000 - 0x7fff5e115fff libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.WebContent [29950] [unique pid 129542] UUID: B54D230D-67AC-3B7A-A529-8756CF1E4920 Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent Architecture: x86_64 Parent: launchd [1] Responsible: WeChat [11139] [unique pid 110747] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 84.54 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (169.8K cycles, 56.7K instructions, 2.99c/i) Note: 2 idle work queue threads omitted Thread 0x8050d1 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.WebContent + 6247) [0x10667e867] 1-11 11 ??? (com.apple.WebKit.WebContent + 5858) [0x10667e6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8050db Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39 (JavaScriptCore + 2264807) [0x7fff38406ee7] 1-11 11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 2258297) [0x7fff38405579] 1-11 11 bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-11 11 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8050ea Thread name "WebCore: Scrolling" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from WeChat [11139] [unique pid 110747], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10667d000 - 0x10667efff com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff381de000 - 0x7fff3903efff com.apple.JavaScriptCore 14607 (14607.3.9) <E25D3B54-A072-33F3-AA89-6F8588BF5A05> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff5e0c2000 - 0x7fff5e115fff libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.WebContent [58347] [unique pid 157932] UUID: B54D230D-67AC-3B7A-A529-8756CF1E4920 Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent Architecture: x86_64 Parent: launchd [1] Responsible: Mail [98166] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 110.00 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (123.1K cycles, 53.0K instructions, 2.32c/i) Note: 2 idle work queue threads omitted Thread 0x9e3343 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.WebContent + 6247) [0x1052ad867] 1-11 11 ??? (com.apple.WebKit.WebContent + 5858) [0x1052ad6e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9e3348 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x9e335b Thread name "WebCore: Scrolling" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1052ac000 - 0x1052adfff com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.apple.WebKit.WebContent [58348] [unique pid 157933] UUID: B54D230D-67AC-3B7A-A529-8756CF1E4920 Path: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent Architecture: x86_64 Parent: launchd [1] Responsible: Mail [98166] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 22.04 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (116.3K cycles, 55.2K instructions, 2.11c/i) Note: 2 idle work queue threads omitted Thread 0x9e3349 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (com.apple.WebKit.WebContent + 6247) [0x10a296867] 1-11 11 ??? (com.apple.WebKit.WebContent + 5858) [0x10a2966e2] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9e3351 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x9e335c Thread name "WebCore: Scrolling" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a295000 - 0x10a296fff com.apple.WebKit.WebContent 14607 (14607.3.9) <B54D230D-67AC-3B7A-A529-8756CF1E4920> /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: com.paragon-software.ntfsd [464] UUID: 815ADF1C-C681-39E9-AD7F-AD68A676A107 Path: /Library/Application Support/Paragon Software/com.paragon-software.ntfsd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 2704 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x131d 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10ab98000 - 0x10aba9fff com.paragon-software.ntfsd <815ADF1C-C681-39E9-AD7F-AD68A676A107> /Library/Application Support/Paragon Software/com.paragon-software.ntfsd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: CommCenter [272] UUID: 7A833E0C-3AF8-3AAE-94DE-176E8C099EEA Path: /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 10204 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (607.2K cycles, 149.7K instructions, 4.06c/i) Note: 3 idle work queue threads omitted Thread 0x7c9 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (CommCenter + 451341) [0x10207e30d] 1-11 11 ??? (CommCenter + 453852) [0x10207ecdc] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x846 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x861 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x870 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x87c 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (160.3K cycles, 43.2K instructions, 3.71c/i) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (CommCenter + 4963374) [0x1024cbc2e] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102010000 - 0x10281ffff CommCenter (6833.1) <7A833E0C-3AF8-3AAE-94DE-176E8C099EEA> /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: commerce [341] UUID: 1D7EC6B7-076F-3337-92E6-843D0EF32418 Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 18.73 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa4c DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (commerce + 142600) [0x10fc72d08] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x11dd Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10fc50000 - 0x10fe69fff commerce (708.6) <1D7EC6B7-076F-3337-92E6-843D0EF32418> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: configd [63] UUID: F79C3F1D-07EB-315B-8EBA-57D8C182D704 Path: /usr/libexec/configd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 9000 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x25b DispatchQueue 1 Thread name "SCDynamicStore" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (configd + 12674) [0x10501c182] 1-11 11 ??? (configd + 17518) [0x10501d46e] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2b1 Thread name "Main plugin thread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2e9 Thread name "InterfaceNamer thread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2ed 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2ef Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0x32a 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x32e 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105019000 - 0x105072fff configd (963.270.4) <F79C3F1D-07EB-315B-8EBA-57D8C182D704> /usr/libexec/configd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ContactsAccountsService [300] UUID: DD05F701-37AE-3DE8-84A9-00CB5AE29823 Path: /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2104 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x8a6 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102aad000 - 0x102ab1fff ContactsAccountsService <DD05F701-37AE-3DE8-84A9-00CB5AE29823> /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ContextService [25715] UUID: DA0A4185-C9E6-38F1-8C6B-319CD26CAD4C Path: /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 3716 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x2a9ad4 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x104380000 - 0x104773fff ContextService <DA0A4185-C9E6-38F1-8C6B-319CD26CAD4C> /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: contextstored [148] UUID: 9B8C5E12-9AA3-3D75-B261-8882EAA4D272 Path: /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/Resources/contextstored Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 12.20 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (133.4K cycles, 26.3K instructions, 5.08c/i) Note: 3 idle work queue threads omitted Thread 0x323 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (contextstored + 13746) [0x10d2d55b2] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d2d2000 - 0x10d2d6fff contextstored (915.270.2) <9B8C5E12-9AA3-3D75-B261-8882EAA4D272> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/Resources/contextstored 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: coreaudiod [155] UUID: 1CBA9A8B-76AF-317F-A1B3-CBB07EA63E0F Path: /usr/sbin/coreaudiod Architecture: x86_64 Parent: launchd [1] UID: 202 Sudden Term: Tracked (allows idle exit) Footprint: 25.97 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (51.1K cycles, 10.7K instructions, 4.77c/i) Note: 1 idle work queue thread omitted Thread 0x356 DispatchQueue 1 11 samples (1-11) priority 63 (base 63) <process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (coreaudiod + 169883) [0x109a8f79b] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x380 Thread name "HAL Async Logger" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x42b 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (51.1K cycles, 10.7K instructions, 4.77c/i) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 watchdogThreadFunc(void*) + 19 (MSTeamsAudioDevice + 6816) [0x109c7aaa0] 1-11 11 sleep + 41 (libsystem_c.dylib + 501622) [0x7fff60f5f776] 1-11 11 __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x4e1 Thread name "Audio HAL Overload Reporting Spool" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x502 Thread name "SystemSoundServer" 11 samples (1-11) priority 61 (base 61) <process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x109a66000 - 0x109bd5fff coreaudiod (99.32) <1CBA9A8B-76AF-317F-A1B3-CBB07EA63E0F> /usr/sbin/coreaudiod 0x109c79000 - 0x109c80fff com.microsoft.MSTeamsAudioDevice 2022.31.01.1 (1) <68C10D3D-2C5A-3CC0-B66C-8C3E7D593D09> /Library/Audio/Plug-Ins/HAL/MSTeamsAudioDevice.driver/Contents/MacOS/MSTeamsAudioDevice 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60ee5000 - 0x7fff60f6cfff libsystem_c.dylib (1272.250.3) <6016EDA1-440B-34D7-A232-686CD7FBEE90> /usr/lib/system/libsystem_c.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: coreauthd [260] UUID: 7FDAFA66-D925-3779-8CFA-E8FA8A556247 Path: /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1900 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x786 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100d9c000 - 0x100dc8fff coreauthd <7FDAFA66-D925-3779-8CFA-E8FA8A556247> /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: coreauthd [262] UUID: 7FDAFA66-D925-3779-8CFA-E8FA8A556247 Path: /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1776 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x79d 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10af06000 - 0x10af32fff coreauthd <7FDAFA66-D925-3779-8CFA-E8FA8A556247> /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: corebrightnessd [111] UUID: F2F31403-13E7-3B5F-98CC-32AA38C7EA7D Path: /usr/libexec/corebrightnessd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 11.90 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x278 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104ce5000 - 0x104ce6fff corebrightnessd (677.270.12) <F2F31403-13E7-3B5F-98CC-32AA38C7EA7D> /usr/libexec/corebrightnessd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: coreduetd [81] UUID: 56503287-A53B-3BC9-A00C-B875946F5B0A Path: /usr/libexec/coreduetd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 11.14 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x28a DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102e3f000 - 0x102e5afff coreduetd <56503287-A53B-3BC9-A00C-B875946F5B0A> /usr/libexec/coreduetd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: CoreLocationAgent [351] UUID: 9B2E80E2-5217-355D-B3CE-AE6E65429C27 Path: /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 6052 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (57.2K cycles, 24.1K instructions, 2.37c/i) Note: 2 idle work queue threads omitted Thread 0xabe DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xac9 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user interactive), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105a78000 - 0x105a7efff CoreLocationAgent <9B2E80E2-5217-355D-B3CE-AE6E65429C27> /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: coreservicesd [146] UUID: 62E24649-7D14-3FF6-BB09-AE23238E874D Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 12.46 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (31.0K cycles, 6.2K instructions, 4.98c/i) Note: 1 idle work queue thread omitted Thread 0x31f DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 _CoreServicesServerMain + 734 (CarbonCore + 563977) [0x7fff3622bb09] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x333 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (31.0K cycles, 6.2K instructions, 4.98c/i) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 3 fmodWatchConsumer + 198 (CarbonCore + 310728) [0x7fff361eddc8] 1-3 3 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-3 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 8 fmodWatchConsumer + 285 (CarbonCore + 310815) [0x7fff361ede1f] 4-11 8 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 4-11 *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x334 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4405643) [0xffffff800063398b] 1-11 *11 ??? (kernel + 7168593) [0xffffff80008d6251] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Binary Images: 0x107954000 - 0x107954fff coreservicesd <62E24649-7D14-3FF6-BB09-AE23238E874D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff361a2000 - 0x7fff36479fff com.apple.CoreServices.CarbonCore 1178.33 (1178.33) <CB87F0C7-2CD6-3983-8E32-B6A2EC925352> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: CoreServicesUIAgent [64900] [unique pid 164483] UUID: 93749292-A63D-3931-A288-8094A215251A Path: /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 4340 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (76.9K cycles, 24.1K instructions, 3.19c/i) Note: 2 idle work queue threads omitted Thread 0xa6b1ce DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa6b1e2 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user interactive), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a01d000 - ??? CoreServicesUIAgent <93749292-A63D-3931-A288-8094A215251A> /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: corespeechd [405] UUID: 5E7C0DEC-9CA3-3E90-B708-49DF0EEB8018 Path: /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 1276 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe6b 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108a52000 - 0x108a5efff corespeechd <5E7C0DEC-9CA3-3E90-B708-49DF0EEB8018> /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: corespotlightd [481] UUID: 6AEBF759-35E0-35BD-81D0-73D466D925A8 Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 6320 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x13c8 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 3> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x13cd 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 3> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108748000 - 0x108754fff corespotlightd <6AEBF759-35E0-35BD-81D0-73D466D925A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: coresymbolicationd [692] UUID: 2A2B6FF3-46B6-3938-9C96-0CE3D097112C Path: /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2652 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x262b 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10f731000 - 0x10f73cfff coresymbolicationd <2A2B6FF3-46B6-3938-9C96-0CE3D097112C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: CrashReporterSupportHelper [325] UUID: 5B9DCA60-E972-3BC2-8B71-4AA9F66AE5CE Path: /System/Library/CoreServices/CrashReporterSupportHelper Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 1388 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x976 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x103ceb000 - 0x103cedfff CrashReporterSupportHelper <5B9DCA60-E972-3BC2-8B71-4AA9F66AE5CE> /System/Library/CoreServices/CrashReporterSupportHelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ctkahp [312] UUID: 765D8CB0-55E0-38BB-8A67-A1DFEE962E4B Path: /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2828 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x928 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x109223000 - 0x10923dfff ctkahp <765D8CB0-55E0-38BB-8A67-A1DFEE962E4B> /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ctkahp [315] UUID: 765D8CB0-55E0-38BB-8A67-A1DFEE962E4B Path: /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2920 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x93a 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104c97000 - 0x104cb1fff ctkahp <765D8CB0-55E0-38BB-8A67-A1DFEE962E4B> /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ctkd [163] UUID: 75C75C15-A3AD-394C-8DCC-5AD92AA9C165 Path: /System/Library/Frameworks/CryptoTokenKit.framework/ctkd Architecture: x86_64 Parent: launchd [1] UID: 259 Sudden Term: Tracked (allows idle exit) Footprint: 2500 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x383 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10e960000 - 0x10e96dfff ctkd <75C75C15-A3AD-394C-8DCC-5AD92AA9C165> /System/Library/Frameworks/CryptoTokenKit.framework/ctkd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ctkd [317] UUID: 75C75C15-A3AD-394C-8DCC-5AD92AA9C165 Path: /System/Library/Frameworks/CryptoTokenKit.framework/ctkd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2708 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x94f 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x107581000 - 0x10758efff ctkd <75C75C15-A3AD-394C-8DCC-5AD92AA9C165> /System/Library/Frameworks/CryptoTokenKit.framework/ctkd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: cupsd [212] UUID: A64801E0-FD75-389A-912B-720CB81E1519 Path: /usr/sbin/cupsd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 15.99 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x626 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (cupsd + 97908) [0x10dbe6e74] 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x151f 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10dbcf000 - 0x10dc25fff cupsd (462.16) <A64801E0-FD75-389A-912B-720CB81E1519> /usr/sbin/cupsd 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: CVMServer [225] UUID: 3246C88D-0E30-3A4A-BED4-2790B8DAC5E2 Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 2652 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x645 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x106641000 - 0x10664afff CVMServer <3246C88D-0E30-3A4A-BED4-2790B8DAC5E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: dasd [98] UUID: 1A72AA3E-9F03-3595-A5A2-C375A16F137E Path: /usr/libexec/dasd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 6404 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x290 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10eafe000 - 0x10eafffff dasd (626.250.5) <1A72AA3E-9F03-3595-A5A2-C375A16F137E> /usr/libexec/dasd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: DataDetectorsSourceAccess [60974] UUID: 5B9ED6E2-04A7-3BDD-869C-20666D4455D8 Path: /usr/libexec/DataDetectorsSourceAccess Architecture: x86_64 Parent: launchd [1] UID: 257 Sudden Term: Tracked (allows idle exit) Footprint: 2364 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x43372e 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10bbac000 - 0x10bbadfff DataDetectorsSourceAccess <5B9ED6E2-04A7-3BDD-869C-20666D4455D8> /usr/libexec/DataDetectorsSourceAccess 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: dbfseventsd [449] UUID: 80DC5F36-CF3D-304D-97C6-3E622C45519E Path: /Library/DropboxHelperTools/*/dbfseventsd Architecture: x86_64 Parent: Dropbox [386] UID: 0 Footprint: 376 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (73.8K cycles, 22.9K instructions, 3.22c/i) Thread 0xfca 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (73.8K cycles, 22.9K instructions, 3.22c/i) <thread QoS default (requested user interactive), process unclamped, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (dbfseventsd + 2867) [0x10bb34b33] 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4405643) [0xffffff800063398b] 1-11 *11 ??? (kernel + 7168593) [0xffffff80008d6251] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Binary Images: 0x10bb34000 - 0x10bb3dfff dbfseventsd (0) <80DC5F36-CF3D-304D-97C6-3E622C45519E> /Library/DropboxHelperTools/*/dbfseventsd 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: dbfseventsd [450] UUID: 80DC5F36-CF3D-304D-97C6-3E622C45519E Path: /Library/DropboxHelperTools/*/dbfseventsd Architecture: x86_64 Parent: dbfseventsd [449] UID: 0 Footprint: 4468 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (247.4K cycles, 102.4K instructions, 2.42c/i) Thread 0xfcb 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (247.4K cycles, 102.4K instructions, 2.42c/i) <IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (dbfseventsd + 3481) [0x10bb34d99] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10bb34000 - 0x10bb3dfff dbfseventsd (0) <80DC5F36-CF3D-304D-97C6-3E622C45519E> /Library/DropboxHelperTools/*/dbfseventsd 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: dbfseventsd [451] UUID: 80DC5F36-CF3D-304D-97C6-3E622C45519E Path: /Library/DropboxHelperTools/*/dbfseventsd Architecture: x86_64 Parent: dbfseventsd [450] UID: 504 Footprint: 276 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (339.9K cycles, 158.2K instructions, 2.15c/i) Thread 0xfcc 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (339.9K cycles, 158.2K instructions, 2.15c/i) <IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (dbfseventsd + 3481) [0x10bb34d99] 1-11 11 ??? (dbfseventsd + 10009) [0x10bb36719] 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 7294931) [0xffffff80008f4fd3] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Binary Images: 0x10bb34000 - 0x10bb3dfff dbfseventsd (0) <80DC5F36-CF3D-304D-97C6-3E622C45519E> /Library/DropboxHelperTools/*/dbfseventsd 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: dbkextd [484] UUID: 0E4C8DB6-3621-3ACF-8E15-3245DF2E0905 Path: /Library/DropboxHelperTools/*/dbkextd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 3432 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x13e2 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0x13e4 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility, ipc override utility), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __recvfrom + 10 (libsystem_kernel.dylib + 17518) [0x7fff60fd346e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 recvfrom_nocancel + 229 (kernel + 7555877) [0xffffff8000934b25] 1-11 *11 ??? (kernel + 7556385) [0xffffff8000934d21] 1-11 *11 soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11 *11 sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11 *11 msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Binary Images: 0x10143f000 - 0x10144afff dbkextd <0E4C8DB6-3621-3ACF-8E15-3245DF2E0905> /Library/DropboxHelperTools/*/dbkextd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: deleted [575] UUID: E778FD40-C21A-3399-BE62-8D331B0C263D Path: /System/Library/PrivateFrameworks/CacheDelete.framework/deleted Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 3968 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x18e5 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10fe95000 - 0x10fee3fff deleted <E778FD40-C21A-3399-BE62-8D331B0C263D> /System/Library/PrivateFrameworks/CacheDelete.framework/deleted 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: diagnostics_agent [425] UUID: B7FE0902-4C63-3140-BA35-8940FD7FC07D Path: /System/Library/CoreServices/diagnostics_agent Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 3812 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (106.2K cycles, 32.0K instructions, 3.32c/i) Note: 2 idle work queue threads omitted Thread 0xe83 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 3> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1039b1000 - 0x1039cdfff diagnostics_agent <B7FE0902-4C63-3140-BA35-8940FD7FC07D> /System/Library/CoreServices/diagnostics_agent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: diskarbitrationd [77] UUID: 277C434C-AACE-3589-9B85-C9E572E39BB6 Path: /usr/libexec/diskarbitrationd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 2268 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x266 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f584000 - 0x10f59cfff diskarbitrationd (297.250.7) <277C434C-AACE-3589-9B85-C9E572E39BB6> /usr/libexec/diskarbitrationd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: diskjournald [236] UUID: 2AFE2477-AFE9-3F95-8217-356FB03A049F Path: /Library/MonitoringClient/*/diskjournald Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 1600 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6da 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f39e000 - 0x10f3a5fff diskjournald (0) <2AFE2477-AFE9-3F95-8217-356FB03A049F> /Library/MonitoringClient/*/diskjournald 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: diskmanagementd [80005] UUID: EAF7247B-4681-310B-9BA2-6ED43A0A5C79 Path: /usr/libexec/diskmanagementd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 3636 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x508e20 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x508e22 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x508e6b 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x106245000 - 0x1063f1fff diskmanagementd (1555.270.2) <EAF7247B-4681-310B-9BA2-6ED43A0A5C79> /usr/libexec/diskmanagementd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: DiskUnmountWatcher [10124] UUID: 95E93163-6465-3F6C-B750-81BD6C853527 Path: /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 1184 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe6f05 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10c905000 - 0x10c905fff DiskUnmountWatcher <95E93163-6465-3F6C-B750-81BD6C853527> /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: displaypolicyd [97] UUID: 862CF853-A279-31A5-A79D-5987ED115768 Path: /usr/libexec/displaypolicyd Architecture: x86_64 Parent: launchd [1] UID: 244 Footprint: 2220 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x27c DispatchQueue 1 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5f8 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __accept + 10 (libsystem_kernel.dylib + 20966) [0x7fff60fd41e6] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 accept_nocancel + 562 (kernel + 7544722) [0xffffff8000931f92] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x6c6 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6c7 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6c8 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x10dc33000 - 0x10dc69fff displaypolicyd (3.50.16) <862CF853-A279-31A5-A79D-5987ED115768> /usr/libexec/displaypolicyd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: distnoted [114] UUID: 186D92BD-74DA-3CA9-9959-2633D3EFB9E7 Path: /usr/sbin/distnoted Architecture: x86_64 Parent: launchd [1] UID: 241 Sudden Term: Tracked (allows idle exit) Footprint: 2776 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (1260.1K cycles, 1022.4K instructions, 1.23c/i) Note: 1 idle work queue thread omitted Thread 0x405 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10892d000 - 0x108936fff distnoted (1575.405) <186D92BD-74DA-3CA9-9959-2633D3EFB9E7> /usr/sbin/distnoted 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: distnoted [270] UUID: 186D92BD-74DA-3CA9-9959-2633D3EFB9E7 Path: /usr/sbin/distnoted Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 7128 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (3.1M cycles, 3.7M instructions, 0.85c/i) Note: 1 idle work queue thread omitted Thread 0x7c1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1077a5000 - 0x1077aefff distnoted (1575.405) <186D92BD-74DA-3CA9-9959-2633D3EFB9E7> /usr/sbin/distnoted 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: distnoted [384] UUID: 186D92BD-74DA-3CA9-9959-2633D3EFB9E7 Path: /usr/sbin/distnoted Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2304 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (189.3K cycles, 70.5K instructions, 2.68c/i) Note: 1 idle work queue thread omitted Thread 0xd61 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f926000 - 0x10f92ffff distnoted (1575.405) <186D92BD-74DA-3CA9-9959-2633D3EFB9E7> /usr/sbin/distnoted 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: distnoted [611] UUID: 186D92BD-74DA-3CA9-9959-2633D3EFB9E7 Path: /usr/sbin/distnoted Architecture: x86_64 Parent: launchd [1] UID: 89 Sudden Term: Tracked (allows idle exit) Footprint: 2452 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (188.5K cycles, 70.4K instructions, 2.68c/i) Note: 1 idle work queue thread omitted Thread 0x1ae5 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x107518000 - 0x107521fff distnoted (1575.405) <186D92BD-74DA-3CA9-9959-2633D3EFB9E7> /usr/sbin/distnoted 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: distnoted [936] UUID: 186D92BD-74DA-3CA9-9959-2633D3EFB9E7 Path: /usr/sbin/distnoted Architecture: x86_64 Parent: launchd [1] UID: 501 Sudden Term: Tracked (allows idle exit) Footprint: 2328 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (212.4K cycles, 77.7K instructions, 2.73c/i) Note: 1 idle work queue thread omitted Thread 0xb176 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100413000 - 0x10041cfff distnoted (1575.405) <186D92BD-74DA-3CA9-9959-2633D3EFB9E7> /usr/sbin/distnoted 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: dmd [412] UUID: 32CE22BA-1B70-3921-9067-F20A2429934D Path: /usr/libexec/dmd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2460 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe85 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (dmd + 412834) [0x101226ca2] 1-11 11 ??? (dmd + 367644) [0x10121bc1c] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1011c2000 - 0x101240fff dmd (21.1) <32CE22BA-1B70-3921-9067-F20A2429934D> /usr/libexec/dmd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: dmd [488] UUID: 32CE22BA-1B70-3921-9067-F20A2429934D Path: /usr/libexec/dmd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2404 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x145a 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1062bb000 - 0x106339fff dmd (21.1) <32CE22BA-1B70-3921-9067-F20A2429934D> /usr/libexec/dmd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Dock [274] UUID: 4B8B4B37-6468-3F26-A9AD-AFFD3205FBD2 Path: /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 126.40 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.002s (8.1M cycles, 4.3M instructions, 1.89c/i) Note: 5 idle work queue threads omitted Thread 0x7cf DispatchQueue 1 11 samples (1-11) priority 47 (base 47) cpu time 0.002s (7.7M cycles, 4.2M instructions, 1.85c/i) <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Dock + 22343) [0x103328747] 1-11 11 autoreleasepool<A>(invoking:) + 47 (libswiftObjectiveC.dylib + 12111) [0x7fff60ba9f4f] 1-11 11 ??? (Dock + 1637182) [0x1034b2b3e] 1-11 11 ??? (Dock + 1638515) [0x1034b3073] 1-11 11 autoreleasepool<A>(invoking:) + 47 (libswiftObjectiveC.dylib + 12111) [0x7fff60ba9f4f] 1-11 11 ??? (Dock + 1638414) [0x1034b300e] 1-11 11 ??? (Dock + 1638803) [0x1034b3193] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 1 __CFRunLoopRun + 2524 (CoreFoundation + 243468) [0x7fff34f0770c] 1 1 __CFRunLoopDoSource1 + 527 (CoreFoundation + 341985) [0x7fff34f1f7e1] 1 1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation + 342147) [0x7fff34f1f883] 1 1 mshPerform + 11 (HIServices + 51057) [0x7fff336e4771] 1 1 ??? (Dock + 141157) [0x103345765] 1 1 ??? (Dock + 300160) [0x10336c480] 1 1 ??? (Dock + 480587) [0x10339854b] 1 1 ??? (Dock + 482376) [0x103398c48] 1 1 ??? (Dock + 599300) [0x1033b5504] 1 1 _HandlePopUpMenuSelection7 + 49 (HIToolbox + 1761281) [0x7fff34308001] 1 1 _HandlePopUpMenuSelection8(OpaqueMenuRef*, OpaqueEventRef*, unsigned int, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 418 (HIToolbox + 1761705) [0x7fff343081a9] 1 1 PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1601 (HIToolbox + 1764561) [0x7fff34308cd1] 1 1 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96 (HIToolbox + 655333) [0x7fff341f9fe5] 1 1 SendMenuItemSelectedEvent + 192 (HIToolbox + 655613) [0x7fff341fa0fd] 1 1 SendMenuCommandWithContextAndModifiers + 49 (HIToolbox + 655694) [0x7fff341fa14e] 1 1 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 375 (HIToolbox + 490706) [0x7fff341d1cd2] 1 1 SendEventToEventTarget + 39 (HIToolbox + 154038) [0x7fff3417f9b6] 1 1 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 371 (HIToolbox + 34271) [0x7fff341625df] 1 1 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1422 (HIToolbox + 37422) [0x7fff3416322e] 1 1 ??? (Dock + 481083) [0x10339873b] 1 1 ??? (Dock + 534772) [0x1033a58f4] 1 1 ??? (Dock + 476826) [0x10339769a] 1 1 LQForceQuit + 93 (libquit.dylib + 6208) [0x7fff5ffa2840] 1 1 _CRProcessWillBeForceQuit + 237 (CrashReporterSupport + 37037) [0x7fff4998a0ad] 1 1 _CRWriteCrashHistoryForProcess + 74 (CrashReporterSupport + 36450) [0x7fff49989e62] 1 1 WriteCrashHistoryToURL + 86 (CrashReporterSupport + 36670) [0x7fff49989f3e] 1 1 _CRWritePropertyListWithPathAndMode + 122 (CrashReporterSupport + 23985) [0x7fff49986db1] 1 1 ftruncate + 10 (libsystem_kernel.dylib + 16982) [0x7fff60fd3256] 1 *1 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1 *1 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1 *1 ftruncate + 404 (kernel + 4272388) [0xffffff8000613104] 1 *1 vnode_setattr + 331 (kernel + 4372683) [0xffffff800062b8cb] 1 *1 VNOP_SETATTR + 102 (kernel + 4372982) [0xffffff800062b9f6] 1 *1 apfs_vnop_setattr + 6583 (apfs + 218589) [0xffffff7f81b8f5dd] 1 *1 do_iterative_file_extent_removal + 341 (apfs + 479380) [0xffffff7f81bcf094] 1 *1 iterate_jobjs_with_hint_and_snap + 433 (apfs + 459423) [0xffffff7f81bca29f] 1 *1 _remove_extents_of_file_cb + 797 (apfs + 482656) [0xffffff7f81bcfd60] 1 *1 remove_extent_of_file + 282 (apfs + 484154) [0xffffff7f81bd033a] 1 *1 dereference_phys_range + 96 (apfs + 458819) [0xffffff7f81bca043] 1 *1 apfs_update_phys_range + 96 (apfs + 454877) [0xffffff7f81bc90dd] 1 *1 apfs_lock_phys_extents + 432 (apfs + 454185) [0xffffff7f81bc8e29] 1 *1 tree_lookup_gt + 48 (apfs + 552335) [0xffffff7f81be0d8f] 1 *1 _bt_lookup_variant + 838 (apfs + 626292) [0xffffff7f81bf2e74] 1 *1 btree_node_get + 105 (apfs + 591156) [0xffffff7f81bea534] 1 *1 btree_node_get_internal + 355 (apfs + 591526) [0xffffff7f81bea6a6] 1 *1 obj_get + 1599 (apfs + 726329) [0xffffff7f81c0b539] 1 *1 obj_read + 285 (apfs + 728865) [0xffffff7f81c0bf21] 1 *1 vnode_dev_read + 30 (apfs + 8812) [0xffffff7f81b5c26c] 1 *1 _vnode_dev_read + 619 (apfs + 12912) [0xffffff7f81b5d270] 1 *1 buf_biowait + 124 (kernel + 4051148) [0xffffff80005dd0cc] 1 *1 ??? (kernel + 7168269) [0xffffff80008d610d] 1 *1 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1 *1 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1 *1 ??? (kernel + 1882937) [0xffffff80003cbb39] 1 *1 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1 9 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 2-10 9 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 2-10 9 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 2-10 *9 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 2-10 1 __CFRunLoopRun + 2130 (CoreFoundation + 243074) [0x7fff34f07582] 11 1 __CFRunLoopDoTimers + 330 (CoreFoundation + 369770) [0x7fff34f2646a] 11 1 __CFRunLoopDoTimer + 851 (CoreFoundation + 370980) [0x7fff34f26924] 11 1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20 (CoreFoundation + 372088) [0x7fff34f26d78] 11 1 LQSendSignal + 65 (libquit.dylib + 6771) [0x7fff5ffa2a73] 11 1 _LSKillApplication + 329 (LaunchServices + 841888) [0x7fff365998a0] 11 1 _LSCopyApplicationInformationItem + 173 (LaunchServices + 49264) [0x7fff364d8070] 11 1 _LSCopyApplicationInformation + 4235 (LaunchServices + 75159) [0x7fff364de597] 11 1 LSClientToServerConnection::sendWithReply(void*) + 213 (LaunchServices + 63141) [0x7fff364db6a5] 11 1 xpc_connection_send_message_with_reply_sync + 178 (libxpc.dylib + 42539) [0x7fff610cd62b] 11 1 dispatch_mach_send_with_result_and_wait_for_reply + 50 (libdispatch.dylib + 96386) [0x7fff60e62882] 11 1 _dispatch_mach_send_and_wait_for_reply + 609 (libdispatch.dylib + 95207) [0x7fff60e623e7] 11 1 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 11 *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 11 Thread 0x9b7 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (261.3K cycles, 93.2K instructions, 2.80c/i) <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Dock + 136618) [0x1033445aa] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x103323000 - 0x103765fff com.apple.dock 1.8 (1963.6) <4B8B4B37-6468-3F26-A9AD-AFFD3205FBD2> /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock 0x7fff336d8000 - 0x7fff3372afff com.apple.HIServices 1.22 (628) <2BE461FF-80B9-30D3-A574-AED5724B1C1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff364cc000 - 0x7fff3667dfff com.apple.LaunchServices 947.2 (947.2) <42EA9E02-37CD-36DD-8265-5E5F0D8C62C9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff49981000 - 0x7fff49992fff com.apple.CrashReporterSupport 10.13 (938.29) <5942C233-DB5E-3119-8DA3-201A5C080191> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport 0x7fff5ffa1000 - 0x7fff5ffa2fff libquit.dylib (267.3) <FF577E42-737C-3240-9547-E7F784FDEB2F> /usr/lib/libquit.dylib 0x7fff60ba7000 - 0x7fff60baafff libswiftObjectiveC.dylib (1001.8.63.13) <A4201F26-A2B3-3F2A-8B0F-D17F166C26BC> /usr/lib/swift/libswiftObjectiveC.dylib 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f81b5a000 - 0xffffff7f81c52fff com.apple.filesystems.apfs 945.275.10 (945.275.10) <A2F8A55F-1345-3CF7-80F5-9AD3619428DD> /System/Library/Extensions/apfs.kext/Contents/MacOS/apfs *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: DocumentPopoverViewService [56950] [unique pid 156535] UUID: 655D06D3-D23D-3180-A827-936BE1655D36 Path: /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/DocumentPopoverViewService.xpc/Contents/MacOS/DocumentPopoverViewService Architecture: x86_64 Parent: launchd [1] Responsible: Preview [6302] [unique pid 105926] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 15.41 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (119.3K cycles, 31.6K instructions, 3.78c/i) Note: 2 idle work queue threads omitted Thread 0x980539 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 37 (DocumentPopoverViewService + 4435) [0x101902153] 1-11 11 NSViewServiceApplicationMain + 2830 (ViewBridge + 50108) [0x7fff5c9f93bc] 1-11 11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x980557 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101901000 - 0x101908fff com.apple.appkit.xpc.documentPopoverViewService 6.9 (1) <655D06D3-D23D-3180-A827-936BE1655D36> /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/DocumentPopoverViewService.xpc/Contents/MacOS/DocumentPopoverViewService 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff5c9ed000 - 0x7fff5cac6fff com.apple.ViewBridge 407 (407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: dprivacyd [1133] UUID: DA7D7288-0AB7-3DDB-9D42-0186B9C09D6E Path: /usr/libexec/dprivacyd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 3848 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x12b62 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x100e91000 - 0x100e91fff dprivacyd <DA7D7288-0AB7-3DDB-9D42-0186B9C09D6E> /usr/libexec/dprivacyd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Dropbox [344] UUID: 55A7E285-2AC3-3AB2-9008-2C7324DBAFB5 Path: /Applications/Dropbox.app/Contents/MacOS/Dropbox Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 9900 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa58 11 samples (1-11) priority 62 (base 62) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa76 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCrashpad + 123372) [0x10e2761ec] 1-11 11 ??? (DropboxCrashpad + 116865) [0x10e274881] 1-11 11 ??? (DropboxCrashpad + 145857) [0x10e27b9c1] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xa77 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCrashpad + 123372) [0x10e2761ec] 1-11 11 ??? (DropboxCrashpad + 116865) [0x10e274881] 1-11 11 ??? (DropboxCrashpad + 145857) [0x10e27b9c1] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Binary Images: 0x1090bf000 - 0x1090c6fff Dropbox <55A7E285-2AC3-3AB2-9008-2C7324DBAFB5> /Applications/Dropbox.app/Contents/MacOS/Dropbox 0x10e258000 - 0x10e2d3fff com.dropbox.Crashpad 1.0 (1.0) <9F8A4524-A985-3017-BEEF-4E622B13AB46> /Applications/Dropbox.app/Contents/Frameworks/DropboxCrashpad.framework/DropboxCrashpad 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Dropbox [386] UUID: 928C2064-C6DF-351A-B160-4CD1026B2844 Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/MacOS/Dropbox Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 1398.46 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.004s (16.6M cycles, 6.9M instructions, 2.41c/i) Note: 3 idle work queue threads omitted Thread 0xd7f DispatchQueue 1 Thread name "CrBrowserMain" 11 samples (1-11) priority 62 (base 62) cpu time 0.002s (9.8M cycles, 2.7M instructions, 3.64c/i) <process unclamped, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Dropbox + 18573) [0x10fda788d] 1-11 11 ??? (Dropbox + 18227) [0x10fda7733] 1-11 11 bootstrap_application + 5603 (DropboxCore + 10847011) [0x11080e323] 1-11 11 ??? (DropboxCore + 10554996) [0x1107c6e74] 1-11 11 ??? (DropboxCore + 10769365) [0x1107fb3d5] 1-11 11 de_main + 145 (Electron Framework + 108737) [0x1139cd8c1] 1-11 11 electron::fuses::IsRunAsNodeEnabled() + 5710690 (Electron Framework + 7589282) [0x1140efda2] 1-11 11 electron::fuses::IsRunAsNodeEnabled() + 5710449 (Electron Framework + 7589041) [0x1140efcb1] 1-11 11 electron::fuses::IsRunAsNodeEnabled() + 5714216 (Electron Framework + 7592808) [0x1140f0b68] 1-11 11 electron::fuses::IsRunAsNodeEnabled() + 5715495 (Electron Framework + 7594087) [0x1140f1067] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2918084 (Electron Framework + 19809172) [0x114c97394] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2934722 (Electron Framework + 19825810) [0x114c9b492] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2928705 (Electron Framework + 19819793) [0x114c99d11] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x11531232c] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x11533f81f] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10118539 (Electron Framework + 27009627) [0x11537525b] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10123574 (Electron Framework + 27014662) [0x115376606] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xdb1 Thread name "APEX_CONTEXT_NETWORK" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 41869253) [0x1125a3fc5] 1-11 11 ??? (DropboxCore + 41832908) [0x11259b1cc] 1-11 11 ??? (DropboxCore + 41844498) [0x11259df12] 1-11 11 ??? (DropboxCore + 41893160) [0x1125a9d28] 1-11 11 ??? (DropboxCore + 41854043) [0x1125a045b] 1-11 11 ??? (DropboxCore + 47650338) [0x112b27622] 1-11 11 ??? (DropboxCore + 47710078) [0x112b35f7e] 1-11 11 ??? (DropboxCore + 47710505) [0x112b36129] 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0xdbb Thread name "APEX_BOUNDARY" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 9373968) [0x1106a6910] 1-11 11 ??? (DropboxCore + 9659067) [0x1106ec2bb] 1-11 11 ??? (DropboxCore + 9735255) [0x1106fec57] 1-11 11 ??? (DropboxCore + 9099796) [0x110663a14] 1-11 11 ??? (DropboxCore + 9098309) [0x110663445] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xe31 Thread name "PYTHON_LOGGER" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xea8 Thread name "Dropbox::ActorThread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xea9 Thread name "Dropbox::ActorThread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeaa Thread name "Dropbox::ActorThread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeab Thread name "Dropbox::ActorThread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeac Thread name "Dropbox::ActorThread" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (458.3K cycles, 190.1K instructions, 2.41c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (libpython3.8.dylib + 4388852) [0x11c2507f4] 1-11 11 ??? (libpython3.8.dylib + 5174215) [0x11c3103c7] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xead Thread name "Dropbox::ActorThread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeae Thread name "Dropbox::ActorThread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeaf Thread name "Dropbox::ActorThread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeb0 Thread name "Dropbox::xtl-netreq-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeb1 Thread name "Dropbox::xtl-netreq-1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeb2 Thread name "Dropbox::xtl-netreq-2" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeb3 Thread name "Dropbox::xtl-netreq-3" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeb4 Thread name "Dropbox::xtl-netreq-4" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeb5 Thread name "Dropbox::xtl-netreq-5" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeb6 Thread name "Dropbox::xtl-netreq-6" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeb7 Thread name "Dropbox::xtl-netreq-7" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeb8 Thread name "Dropbox::sleep thread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeb9 Thread name "Dropbox::GLOBAL_POOL_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeba Thread name "Dropbox::GLOBAL_POOL_1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xebb Thread name "Dropbox::GLOBAL_POOL_2" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xebc Thread name "Dropbox::GLOBAL_POOL_3" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xec0 Thread name "Dropbox::RTRACE" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xec1 Thread name "Dropbox::PERSISTENT_EVENT_REPORTER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xec2 Thread name "Dropbox::BACKGROUNDWORKER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xece Thread name "Dropbox::ELECTRON_IPC" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2793022) [0x11c0cae3e] 1-11 11 ??? (libpython3.8.dylib + 5349640) [0x11c33b108] 1-11 11 ??? (libpython3.8.dylib + 5361372) [0x11c33dedc] 1-11 11 __recvfrom + 10 (libsystem_kernel.dylib + 17518) [0x7fff60fd346e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 recvfrom_nocancel + 229 (kernel + 7555877) [0xffffff8000934b25] 1-11 *11 ??? (kernel + 7556385) [0xffffff8000934d21] 1-11 *11 soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11 *11 sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11 *11 msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *3 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-3 <process clamped> *8 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 4-11 Thread 0xed2 Thread name "APEX_CONTEXT_WORKER" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (808.8K cycles, 347.7K instructions, 2.33c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 37699712) [0x1121aa080] 1-11 11 ??? (DropboxCore + 37708463) [0x1121ac2af] 1-11 11 ??? (DropboxCore + 37727878) [0x1121b0e86] 1-11 11 ??? (DropboxCore + 37695157) [0x1121a8eb5] 1-11 11 ??? (DropboxCore + 37719723) [0x1121aeeab] 1-11 11 ??? (DropboxCore + 47650338) [0x112b27622] 1-11 11 ??? (DropboxCore + 47710078) [0x112b35f7e] 1-11 11 ??? (DropboxCore + 47710505) [0x112b36129] 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0xed7 Thread name "DBXLOG_WORKER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 7960280) [0x11054d6d8] 1-11 11 ??? (DropboxCore + 8021676) [0x11055c6ac] 1-11 11 ??? (DropboxCore + 8010601) [0x110559b69] 1-11 11 ??? (DropboxCore + 7926165) [0x110545195] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xee2 Thread name "Dropbox::SYNC_UI_UPDATE" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xee4 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0xee6 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x115371148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981677 (Electron Framework + 26872765) [0x115353bbd] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x115353f27] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x11535370e] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x115379c37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xee8 Thread name "Chrome_IOThread" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x115371148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016615 (Electron Framework + 26907703) [0x11535c437] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2937951 (Electron Framework + 19829039) [0x114c9c12f] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016104 (Electron Framework + 26907192) [0x11535c238] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x11531232c] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x11533f81f] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0xee9 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xeea 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0xeeb 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 node::OnFatalError(char const*, char const*) + 428695 (Electron Framework + 55341991) [0x116e7a3a7] 1-11 11 node::MultiIsolatePlatform::CancelPendingDelayedTasks(v8::Isolate*) + 1154 (Electron Framework + 55352210) [0x116e7cb92] 1-11 11 uv_cond_wait + 9 (Electron Framework + 85577) [0x1139c7e49] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeec 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 node::OnFatalError(char const*, char const*) + 428695 (Electron Framework + 55341991) [0x116e7a3a7] 1-11 11 node::MultiIsolatePlatform::CancelPendingDelayedTasks(v8::Isolate*) + 1154 (Electron Framework + 55352210) [0x116e7cb92] 1-11 11 uv_cond_wait + 9 (Electron Framework + 85577) [0x1139c7e49] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xeed 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 node::OnFatalError(char const*, char const*) + 428695 (Electron Framework + 55341991) [0x116e7a3a7] 1-11 11 node::MultiIsolatePlatform::CancelPendingDelayedTasks(v8::Isolate*) + 1154 (Electron Framework + 55352210) [0x116e7cb92] 1-11 11 uv_cond_wait + 9 (Electron Framework + 85577) [0x1139c7e49] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xef0 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *3 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-3 <process clamped> *8 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 4-11 Thread 0xefc Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xefd Thread name "CrShutdownDetector" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 7294931) [0xffffff80008f4fd3] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *3 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-3 <process clamped> *8 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 4-11 Thread 0xefe Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xf00 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf01 Thread name "ThreadPoolSingleThreadForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xf03 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 de_register_electron_app + 1323992 (Electron Framework + 1432760) [0x113b10cb8] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *3 ??? (kernel + 7168864) [0xffffff80008d6360] 1-3 <process clamped> *8 ??? (kernel + 7168864) [0xffffff80008d6360] 4-11 Thread 0xf08 Thread name "JS_HTTP_WORKER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0xf09 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf0a 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf0b 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf0c 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf10 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xf1f Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) cpu time <0.001s (390.6K cycles, 94.6K instructions, 4.13c/i) <thread QoS user interactive (requested user interactive), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xf2a Thread name "Dropbox::CONNECTIVITY_WATCH" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf2c Thread name "Dropbox::AUTHENTICATE" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf3d Thread name "ThreadPoolSingleThreadSharedBackgroundBlocking1" 11 samples (1-11) priority 0 (base 0) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xf47 Thread name "Dropbox::DBXCONN_PYTHON_WORKER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf4a Thread name "Dropbox::USER-CACHE" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf51 Thread name "Dropbox::NavigationServiceWorker" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf52 Thread name "Dropbox::NativeIcon-IconRead_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf53 Thread name "Dropbox::NativeIcon-IconRead_1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf54 Thread name "Dropbox::NativeIcon-IconRead_2" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf55 Thread name "Dropbox::NativeIcon-IconRead_3" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf56 Thread name "Dropbox::NativeIcon-IconRead_4" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf57 Thread name "Dropbox::NativeIcon-IconRead_5" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf58 Thread name "Dropbox::NativeIcon-IconWrite_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf59 Thread name "Dropbox::NativeIcon-ThumbnailRead_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf5a Thread name "Dropbox::NativeIcon-ThumbnailRead_1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf5b Thread name "Dropbox::NativeIcon-ThumbnailRead_2" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf5c Thread name "Dropbox::NativeIcon-ThumbnailWrite_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf5d Thread name "Dropbox::NativeIcon-IconRead_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf5e Thread name "Dropbox::NativeIcon-IconRead_1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf5f Thread name "Dropbox::NativeIcon-IconRead_2" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf60 Thread name "Dropbox::NativeIcon-IconRead_3" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf61 Thread name "Dropbox::NativeIcon-IconRead_4" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf62 Thread name "Dropbox::NativeIcon-IconRead_5" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf63 Thread name "Dropbox::NativeIcon-IconWrite_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf64 Thread name "Dropbox::NativeIcon-ThumbnailRead_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf65 Thread name "Dropbox::NativeIcon-ThumbnailRead_1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf66 Thread name "Dropbox::NativeIcon-ThumbnailRead_2" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf67 Thread name "Dropbox::NativeIcon-ThumbnailWrite_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf68 Thread name "Dropbox::PERIODIC" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf69 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking2" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xf6a Thread name "CacheThread_BlockFile" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x115371148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016615 (Electron Framework + 26907703) [0x11535c437] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016104 (Electron Framework + 26907192) [0x11535c238] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x11531232c] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x11533f81f] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0xf82 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf84 Thread name "Dropbox::EVENTREPORTER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xf85 Thread name "Dropbox::DESKTOP_LOGIN_PREFETCH-PRIMARY" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (libpython3.8.dylib + 4388852) [0x11c2507f4] 1-11 11 ??? (libpython3.8.dylib + 5174215) [0x11c3103c7] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfa2 Thread name "Dropbox::SubscribeThread" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfa3 Thread name "Dropbox::NOTIFICATION_RETRIEVAL" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfa4 Thread name "Dropbox::SUPPORTACTIONUPDATETHREAD" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfa5 Thread name "Dropbox::SUPPORT_ACTION_MANAGER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfa6 Thread name "Dropbox::USERNOTIFICATION" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfa7 Thread name "Dropbox::HOURLY_REFRESH" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfa8 Thread name "Dropbox::BOUNDARY_FUTURE_COMPLETION_THREAD_POOL_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfa9 Thread name "Dropbox::BOUNDARY_FUTURE_COMPLETION_THREAD_POOL_1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfaa Thread name "Dropbox::p2p-client-threadpool-worker-1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfab Thread name "Dropbox::p2p-client-threadpool-worker-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfac Thread name "Dropbox::NUCLEUS_P2P_THREAD" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfad Thread name "TPRT_API_WORKER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 33388256) [0x111d8d6e0] 1-11 11 ??? (DropboxCore + 32698234) [0x111ce4f7a] 1-11 11 ??? (DropboxCore + 47808224) [0x112b4dee0] 1-11 11 ??? (DropboxCore + 47793916) [0x112b4a6fc] 1-11 11 ??? (DropboxCore + 47775492) [0x112b45f04] 1-11 11 ??? (DropboxCore + 47773526) [0x112b45756] 1-11 11 ??? (DropboxCore + 47773281) [0x112b45661] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfae Thread name "FS_API_CONTROL" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (274.5K cycles, 100.7K instructions, 2.73c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 33388720) [0x111d8d8b0] 1-11 11 ??? (DropboxCore + 32700041) [0x111ce5689] 1-11 11 ??? (DropboxCore + 33373334) [0x111d89c96] 1-11 11 ??? (DropboxCore + 32430897) [0x111ca3b31] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfaf Thread name "TIMER" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (270.0K cycles, 59.0K instructions, 4.58c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 47575904) [0x112b15360] 1-11 11 ??? (DropboxCore + 47552354) [0x112b0f762] 1-11 11 ??? (DropboxCore + 47583589) [0x112b17165] 1-11 11 ??? (DropboxCore + 5210602) [0x1102ae1ea] 1-11 11 ??? (DropboxCore + 5209982) [0x1102adf7e] 1-11 11 ??? (DropboxCore + 46630552) [0x112a2e698] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfb0 Thread name "OSX FSYNC WORKER" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfb1 Thread name "OSX FS WORKER" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 43908704) [0x112795e60] 1-11 11 ??? (DropboxCore + 43659918) [0x11275928e] 1-11 11 ??? (DropboxCore + 43224264) [0x1126eecc8] 1-11 11 ??? (DropboxCore + 43897014) [0x1127930b6] 1-11 11 ??? (DropboxCore + 43498878) [0x112731d7e] 1-11 11 ??? (DropboxCore + 43491494) [0x1127300a6] 1-11 11 ??? (DropboxCore + 43491249) [0x11272ffb1] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfb2 Thread name "nucleus-threadpool-0" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfbc Thread name "Dropbox::FILEEVENTS" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (libpython3.8.dylib + 4388852) [0x11c2507f4] 1-11 11 ??? (libpython3.8.dylib + 5174215) [0x11c3103c7] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfbe Thread name "Dropbox::BOUNDARY_PUBLISHED_EVENTS_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfcd Thread name "Dropbox::DBFSEventThread" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (1017.9K cycles, 1035.2K instructions, 0.98c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (libpython3.8.dylib + 4388852) [0x11c2507f4] 1-11 11 ??? (libpython3.8.dylib + 5174215) [0x11c3103c7] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2793022) [0x11c0cae3e] 1-11 11 ??? (libpython3.8.dylib + 5349640) [0x11c33b108] 1-11 11 ??? (libpython3.8.dylib + 5361372) [0x11c33dedc] 1-11 11 __recvfrom + 10 (libsystem_kernel.dylib + 17518) [0x7fff60fd346e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 recvfrom_nocancel + 229 (kernel + 7555877) [0xffffff8000934b25] 1-11 *11 ??? (kernel + 7556385) [0xffffff8000934d21] 1-11 *11 soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11 *11 sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11 *11 msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *3 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-3 <process clamped> *8 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 4-11 Thread 0xfce Thread name "TPRT_API_WORKER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 13057473) [0x110a29dc1] 1-11 11 ??? (DropboxCore + 23299050) [0x1113ee3ea] 1-11 11 ??? (DropboxCore + 47808224) [0x112b4dee0] 1-11 11 ??? (DropboxCore + 47793916) [0x112b4a6fc] 1-11 11 ??? (DropboxCore + 47775492) [0x112b45f04] 1-11 11 ??? (DropboxCore + 47773526) [0x112b45756] 1-11 11 ??? (DropboxCore + 47773281) [0x112b45661] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfcf Thread name "NUCLEUS_CONTROL" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (1231.1K cycles, 1343.3K instructions, 0.92c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 13056961) [0x110a29bc1] 1-11 11 ??? (DropboxCore + 23300857) [0x1113eeaf9] 1-11 11 ??? (DropboxCore + 12177307) [0x110952f9b] 1-11 11 ??? (DropboxCore + 23181725) [0x1113d199d] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfd0 Thread name "TIMER" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (310.8K cycles, 65.9K instructions, 4.72c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 47575904) [0x112b15360] 1-11 11 ??? (DropboxCore + 47552354) [0x112b0f762] 1-11 11 ??? (DropboxCore + 47583589) [0x112b17165] 1-11 11 ??? (DropboxCore + 5210602) [0x1102ae1ea] 1-11 11 ??? (DropboxCore + 5209982) [0x1102adf7e] 1-11 11 ??? (DropboxCore + 46630552) [0x112a2e698] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfd1 Thread name "nucleus-threadpool-0" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 34559984) [0x111eab7f0] 1-11 11 ??? (DropboxCore + 34563473) [0x111eac591] 1-11 11 ??? (DropboxCore + 34591020) [0x111eb312c] 1-11 11 ??? (DropboxCore + 34572926) [0x111eaea7e] 1-11 11 ??? (DropboxCore + 34575701) [0x111eaf555] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfd2 Thread name "NUCLEUS_NETWORK" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 41868805) [0x1125a3e05] 1-11 11 ??? (DropboxCore + 41834780) [0x11259b91c] 1-11 11 ??? (DropboxCore + 41844498) [0x11259df12] 1-11 11 ??? (DropboxCore + 41893160) [0x1125a9d28] 1-11 11 ??? (DropboxCore + 41854043) [0x1125a045b] 1-11 11 ??? (DropboxCore + 47650338) [0x112b27622] 1-11 11 ??? (DropboxCore + 47710078) [0x112b35f7e] 1-11 11 ??? (DropboxCore + 47710505) [0x112b36129] 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0xfd5 Thread name "OSX FSYNC WORKER" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 43908235) [0x112795c8b] 1-11 11 ??? (DropboxCore + 43660532) [0x1127594f4] 1-11 11 ??? (DropboxCore + 43207431) [0x1126eab07] 1-11 11 ??? (DropboxCore + 5210602) [0x1102ae1ea] 1-11 11 ??? (DropboxCore + 5210008) [0x1102adf98] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0xfd6 Thread name "OSX FS WORKER" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 43908704) [0x112795e60] 1-11 11 ??? (DropboxCore + 43659918) [0x11275928e] 1-11 11 ??? (DropboxCore + 43224264) [0x1126eecc8] 1-11 11 ??? (DropboxCore + 43897014) [0x1127930b6] 1-11 11 ??? (DropboxCore + 43498878) [0x112731d7e] 1-11 11 ??? (DropboxCore + 43491494) [0x1127300a6] 1-11 11 ??? (DropboxCore + 43491249) [0x11272ffb1] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x133b Thread name "Dropbox::RECV_EVENTS" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x133c Thread name "Dropbox::NUCLEUS_STREAMED_EVENTS" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32500 (libpython3.8.dylib + 3935172) [0x11c1e1bc4] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751635) [0x11c0c0c93] 1-11 11 _PyObject_MakeTpCall + 416 (libpython3.8.dylib + 2733808) [0x11c0bc6f0] 1-11 11 ??? (tprt.cpython-38-darwin.so + 84354) [0x12565b982] 1-11 11 ??? (tprt.cpython-38-darwin.so + 47922) [0x125652b32] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 3070114) [0x11c10e8a2] 1-11 11 ??? (libpython3.8.dylib + 6682112) [0x11c480600] 1-11 11 ??? (libpython3.8.dylib + 6683747) [0x11c480c63] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x133d Thread name "Dropbox::NUCLEUS_STREAMED_EVENTS" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x133e Thread name "Dropbox::p2p_server_handler_pool_head-worker-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751904) [0x11c0c0da0] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x133f Thread name "Dropbox::p2p_server_handler_pool_get-worker-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751904) [0x11c0c0da0] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1340 Thread name "Dropbox::p2p-request-threadpool-head-worker-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1341 Thread name "Dropbox::p2p-request-threadpool-get-worker-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1342 Thread name "Dropbox::P2P_SERVER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2791145) [0x11c0ca6e9] 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0x1343 Thread name "Dropbox::P2P_DISCOVER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1344 Thread name "Dropbox::LIST_LEGACY" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (libpython3.8.dylib + 4388852) [0x11c2507f4] 1-11 11 ??? (libpython3.8.dylib + 5174215) [0x11c3103c7] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1345 Thread name "Dropbox::FINDER_SYNC_RESPONDER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 ??? [0x12def7b50] 1-11 11 ffi_call_unix64 + 76 (libffi.dylib + 3948) [0x7fff5ea42f6c] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0x134e Thread name "Dropbox::WATCHDOG" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x134f Thread name "Dropbox::INFINITE_PAGING_WORKER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1350 Thread name "Dropbox::INFINITE_CONFIGURATION" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x14f0 Thread name "Dropbox::KEXT_LOG_REPORTER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32500 (libpython3.8.dylib + 3935172) [0x11c1e1bc4] 1-11 11 ??? (libpython3.8.dylib + 3952435) [0x11c1e5f33] 1-11 11 _PyObject_MakeTpCall + 416 (libpython3.8.dylib + 2733808) [0x11c0bc6f0] 1-11 11 ??? (libpython3.8.dylib + 2735738) [0x11c0bce7a] 1-11 11 __recvfrom + 10 (libsystem_kernel.dylib + 17518) [0x7fff60fd346e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 recvfrom_nocancel + 229 (kernel + 7555877) [0xffffff8000934b25] 1-11 *11 ??? (kernel + 7556385) [0xffffff8000934d21] 1-11 *11 soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11 *11 sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11 *11 msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *3 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-3 <process clamped> *8 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 4-11 Thread 0x1523 Thread name "Dropbox::INFINITE_PAGING" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __recvfrom + 10 (libsystem_kernel.dylib + 17518) [0x7fff60fd346e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 recvfrom_nocancel + 229 (kernel + 7555877) [0xffffff8000934b25] 1-11 *11 ??? (kernel + 7556385) [0xffffff8000934d21] 1-11 *11 soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11 *11 sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11 *11 msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *3 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-3 <process clamped> *8 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 4-11 Thread 0x152e Thread name "Dropbox::QUICKLOOK_SERVER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0x152f Thread name "Dropbox::CLIENT_SHARING" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1530 Thread name "Dropbox::CLIENT_SHARING_NETWORK" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1531 Thread name "Dropbox::IDLEHANDLER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (libpython3.8.dylib + 4388852) [0x11c2507f4] 1-11 11 ??? (libpython3.8.dylib + 5174215) [0x11c3103c7] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1533 Thread name "Dropbox::SCREENSHOTS_PROCESSING" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1536 Thread name "Dropbox::ACTIVITY_PROVIDER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1537 Thread name "Dropbox::fileop_write_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1538 Thread name "Dropbox::fileop_read_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1539 Thread name "Dropbox::fileop_read_1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x153a Thread name "Dropbox::fileop_read_2" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x153b Thread name "Dropbox::fileop_read_3" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x153c Thread name "Dropbox::fileop_read_4" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x153d Thread name "Dropbox::SEARCHTHREAD" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x155e Thread name "Dropbox::CONTACTSBOLTUPDATE" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x155f Thread name "Dropbox::UNITYSTARTSTOP" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x1560 Thread name "Dropbox::UNITYWORKER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0x1561 Thread name "Dropbox::PHOTOUPLOADER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x159c Thread name "Dropbox::EVENTREPORTER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x159d Thread name "Dropbox::DESKTOP_LOGIN_PREFETCH-SECONDARY" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (libpython3.8.dylib + 4388852) [0x11c2507f4] 1-11 11 ??? (libpython3.8.dylib + 5174215) [0x11c3103c7] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 1623 (libpython3.8.dylib + 3904295) [0x11c1da327] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 33159 (libpython3.8.dylib + 3935831) [0x11c1e1e57] 1-11 11 PyVectorcall_Call + 100 (libpython3.8.dylib + 2734852) [0x11c0bcb04] 1-11 11 ??? (libpython3.8.dylib + 2751708) [0x11c0c0cdc] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x159e Thread name "Dropbox::p2p-client-threadpool-worker-1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x159f Thread name "Dropbox::p2p-client-threadpool-worker-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15a0 Thread name "Dropbox::NUCLEUS_P2P_THREAD" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15a1 Thread name "TPRT_API_WORKER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15a2 Thread name "FS_API_CONTROL" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (260.9K cycles, 107.6K instructions, 2.43c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 ??? (DropboxCore + 33373334) [0x111d89c96] 1-11 11 ??? (DropboxCore + 32430897) [0x111ca3b31] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15a3 Thread name "TIMER" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (244.1K cycles, 42.2K instructions, 5.78c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 47575904) [0x112b15360] 1-11 11 ??? (DropboxCore + 47552354) [0x112b0f762] 1-11 11 ??? (DropboxCore + 47583589) [0x112b17165] 1-11 11 ??? (DropboxCore + 5210602) [0x1102ae1ea] 1-11 11 ??? (DropboxCore + 5209982) [0x1102adf7e] 1-11 11 ??? (DropboxCore + 46630552) [0x112a2e698] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15a4 Thread name "OSX FSYNC WORKER" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15a5 Thread name "OSX FS WORKER" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15a6 Thread name "nucleus-threadpool-0" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15a7 Thread name "Dropbox::BOUNDARY_PUBLISHED_EVENTS_SECONDARY_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 475 (libpython3.8.dylib + 4389899) [0x11c250c0b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15a8 Thread name "TPRT_API_WORKER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 13057473) [0x110a29dc1] 1-11 11 ??? (DropboxCore + 23299050) [0x1113ee3ea] 1-11 11 ??? (DropboxCore + 47808224) [0x112b4dee0] 1-11 11 ??? (DropboxCore + 47793916) [0x112b4a6fc] 1-11 11 ??? (DropboxCore + 47775492) [0x112b45f04] 1-11 11 ??? (DropboxCore + 47773526) [0x112b45756] 1-11 11 ??? (DropboxCore + 47773281) [0x112b45661] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15a9 Thread name "NUCLEUS_CONTROL" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (973.5K cycles, 661.8K instructions, 1.47c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 13056961) [0x110a29bc1] 1-11 11 ??? (DropboxCore + 23300857) [0x1113eeaf9] 1-11 11 ??? (DropboxCore + 12177307) [0x110952f9b] 1-11 11 ??? (DropboxCore + 23181725) [0x1113d199d] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15aa Thread name "TIMER" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (310.4K cycles, 66.4K instructions, 4.67c/i) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 47575904) [0x112b15360] 1-11 11 ??? (DropboxCore + 47552354) [0x112b0f762] 1-11 11 ??? (DropboxCore + 47583589) [0x112b17165] 1-11 11 ??? (DropboxCore + 5210602) [0x1102ae1ea] 1-11 11 ??? (DropboxCore + 5209982) [0x1102adf7e] 1-11 11 ??? (DropboxCore + 46630552) [0x112a2e698] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15ab Thread name "nucleus-threadpool-0" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15ac Thread name "NUCLEUS_NETWORK" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 41868805) [0x1125a3e05] 1-11 11 ??? (DropboxCore + 41834780) [0x11259b91c] 1-11 11 ??? (DropboxCore + 41844498) [0x11259df12] 1-11 11 ??? (DropboxCore + 41893160) [0x1125a9d28] 1-11 11 ??? (DropboxCore + 41854043) [0x1125a045b] 1-11 11 ??? (DropboxCore + 47650338) [0x112b27622] 1-11 11 ??? (DropboxCore + 47710078) [0x112b35f7e] 1-11 11 ??? (DropboxCore + 47710505) [0x112b36129] 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0x15ae Thread name "OSX FSYNC WORKER" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15af Thread name "OSX FS WORKER" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process unclamped, IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCore + 46708922) [0x112a418ba] 1-11 11 ??? (DropboxCore + 43908704) [0x112795e60] 1-11 11 ??? (DropboxCore + 43659918) [0x11275928e] 1-11 11 ??? (DropboxCore + 43224264) [0x1126eecc8] 1-11 11 ??? (DropboxCore + 43897014) [0x1127930b6] 1-11 11 ??? (DropboxCore + 43498878) [0x112731d7e] 1-11 11 ??? (DropboxCore + 43491494) [0x1127300a6] 1-11 11 ??? (DropboxCore + 43491249) [0x11272ffb1] 1-11 11 ??? (DropboxCore + 46629979) [0x112a2e45b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15cc Thread name "Dropbox::RECV_EVENTS" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15cd Thread name "Dropbox::NUCLEUS_STREAMED_EVENTS" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15ce Thread name "Dropbox::NUCLEUS_STREAMED_EVENTS" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15cf Thread name "Dropbox::p2p_server_handler_pool_head-worker-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15d0 Thread name "Dropbox::p2p_server_handler_pool_get-worker-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15d1 Thread name "Dropbox::p2p-request-threadpool-head-worker-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15d2 Thread name "Dropbox::p2p-request-threadpool-get-worker-0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15d3 Thread name "Dropbox::P2P_SERVER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *3 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-3 <process clamped> *8 ??? (kernel + 6978560) [0xffffff80008a7c00] 4-11 Thread 0x15d4 Thread name "Dropbox::LIST_LEGACY" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15d5 Thread name "Dropbox::P2P_DISCOVER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2736839) [0x11c0bd2c7] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32675 (libpython3.8.dylib + 3935347) [0x11c1e1c73] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2751533) [0x11c0c0c2d] 1-11 11 _PyFunction_Vectorcall + 235 (libpython3.8.dylib + 2737211) [0x11c0bd43b] 1-11 11 _PyEval_EvalCodeWithName + 3544 (libpython3.8.dylib + 3901464) [0x11c1d9818] 1-11 11 _PyEval_EvalFrameDefault + 32467 (libpython3.8.dylib + 3935139) [0x11c1e1ba3] 1-11 11 ??? (libpython3.8.dylib + 3951950) [0x11c1e5d4e] 1-11 11 ??? (libpython3.8.dylib + 2790639) [0x11c0ca4ef] 1-11 11 ??? (libpython3.8.dylib + 5176956) [0x11c310e7c] 1-11 11 ??? (libpython3.8.dylib + 5176490) [0x11c310caa] 1-11 11 PyThread_acquire_lock_timed + 302 (libpython3.8.dylib + 4389726) [0x11c250b5e] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15d7 Thread name "Dropbox::fileop_write_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15d8 Thread name "Dropbox::fileop_read_0" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15d9 Thread name "Dropbox::fileop_read_1" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15da Thread name "Dropbox::fileop_read_2" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15db Thread name "Dropbox::fileop_read_3" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15dc Thread name "Dropbox::fileop_read_4" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x15e7 Thread name "Dropbox::INFINITE_PAGING" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __recvfrom + 10 (libsystem_kernel.dylib + 17518) [0x7fff60fd346e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 recvfrom_nocancel + 229 (kernel + 7555877) [0xffffff8000934b25] 1-11 *11 ??? (kernel + 7556385) [0xffffff8000934d21] 1-11 *11 soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11 *11 sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11 *11 msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *3 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-3 <process clamped> *8 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 4-11 Thread 0x15f0 Thread name "Dropbox::EXTERNAL_DRIVE_EVENTS" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0x15fa Thread name "Dropbox::PHOTOUPLOADER" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x248c4d Thread name "Dropbox::SMARTSYNC_THUMBS" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x58585f Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped> *8 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4-11 Thread 0x64d2dd Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x115371148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981773 (Electron Framework + 26872861) [0x115353c1d] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x115353f27] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x11535370e] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x115379c37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped> *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Binary Images: 0x10fda3000 - 0x10fdaafff com.getdropbox.dropbox 163.4.5456 (163.4.5456) <928C2064-C6DF-351A-B160-4CD1026B2844> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/MacOS/Dropbox 0x10fdb6000 - 0x1136c5fff com.dropbox.core 1.0 (1.0) <027878E1-8F64-3EA1-9D27-FFC06193FD2E> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/DropboxCore.framework/Versions/A/DropboxCore 0x1139b3000 - 0x11b396fff com.dropbox.Electron.framework (13.1.0-dropbox.20221010.faa890d59) <99083138-0C5C-30AD-8FCB-CC3F2662F5DA> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x11be21000 - 0x11c810fff libpython3.8.dylib (0) <7CB97AB5-BB44-3721-BB4B-8A757B1FD823> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/libpython3.8.dylib 0x125647000 - 0x125662fff tprt.cpython-38-darwin.so (0) <4D99ABD8-6227-3EA0-8DAF-2805BC8235DE> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/python-extensions/tprt.cpython-38-darwin.so 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff5ea42000 - 0x7fff5ea43fff libffi.dylib (18.1) <DA1198F8-9789-3F16-BF60-9DA170519295> /usr/lib/libffi.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Dropbox [391] UUID: 928C2064-C6DF-351A-B160-4CD1026B2844 Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/MacOS/Dropbox Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 10.15 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xda0 11 samples (1-11) priority 62 (base 62) <process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xdad 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCrashpad + 108940) [0x110dee98c] 1-11 11 ??? (DropboxCrashpad + 102353) [0x110decfd1] 1-11 11 ??? (DropboxCrashpad + 131057) [0x110df3ff1] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xdae 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (DropboxCrashpad + 108940) [0x110dee98c] 1-11 11 ??? (DropboxCrashpad + 102353) [0x110decfd1] 1-11 11 ??? (DropboxCrashpad + 131057) [0x110df3ff1] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Binary Images: 0x104881000 - 0x104888fff com.getdropbox.dropbox 163.4.5456 (163.4.5456) <928C2064-C6DF-351A-B160-4CD1026B2844> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/MacOS/Dropbox 0x110dd4000 - 0x110e4bfff com.dropbox.Crashpad 1.0 (1.0) <2F2625A7-E5D6-3C68-B503-7818B8BD88D9> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/DropboxCrashpad.framework/Versions/A/DropboxCrashpad 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Dropbox [393] UUID: 928C2064-C6DF-351A-B160-4CD1026B2844 Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/MacOS/Dropbox Architecture: x86_64 Parent: Dropbox [386] UID: 504 Footprint: 10.71 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xdb0 11 samples (1-11) priority 62 (base 62) <IO tier 0> 11 <truncated backtrace> 1-11 11 __recvfrom + 10 (libsystem_kernel.dylib + 17518) [0x7fff60fd346e] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 recvfrom_nocancel + 229 (kernel + 7555877) [0xffffff8000934b25] 1-11 *11 ??? (kernel + 7556385) [0xffffff8000934d21] 1-11 *11 soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11 *11 sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11 *11 msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0xdbc 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x1097be000 - 0x1097c5fff com.getdropbox.dropbox 163.4.5456 (163.4.5456) <928C2064-C6DF-351A-B160-4CD1026B2844> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/MacOS/Dropbox 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Dropbox Helper [435] UUID: F02A05BD-FC27-36B5-BDD7-8703972062E9 Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper.app/Contents/MacOS/Dropbox Helper Architecture: x86_64 Parent: Dropbox [386] UID: 504 Footprint: 10072 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xf0f Thread name "CrUtilityMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf2e Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xf30 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x10a207148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981677 (Electron Framework + 26872765) [0x10a1e9bbd] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x10a1e9f27] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x10a1e970e] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x10a20fc37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf31 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xf34 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9e3470 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x10a207148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981773 (Electron Framework + 26872861) [0x10a1e9c1d] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x10a1e9f27] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x10a1e970e] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x10a20fc37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108829000 - 0x108838fff com.dropbox.Electron.helper (0) <F02A05BD-FC27-36B5-BDD7-8703972062E9> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper.app/Contents/MacOS/Dropbox Helper 0x108849000 - 0x11022cfff com.dropbox.Electron.framework (13.1.0-dropbox.20221010.faa890d59) <99083138-0C5C-30AD-8FCB-CC3F2662F5DA> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Dropbox Helper (GPU) [433] UUID: 20E2CB6F-CB69-332D-B3B7-E89BED0B74F8 Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (GPU).app/Contents/MacOS/Dropbox Helper (GPU) Architecture: x86_64 Parent: Dropbox [386] UID: 504 Footprint: 76.36 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xf02 Thread name "CrGpuMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf49 Thread name "GpuWatchdog" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x1073f3148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016615 (Electron Framework + 26907703) [0x1073de437] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016104 (Electron Framework + 26907192) [0x1073de238] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x10739432c] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x1073c181f] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9597957 (Electron Framework + 26489045) [0x1073780d5] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x1073fbc37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf4b Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xf4c Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x1073f3148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981773 (Electron Framework + 26872861) [0x1073d5c1d] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x1073d5f27] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x1073d570e] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x1073fbc37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf4d Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x1073f3148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981677 (Electron Framework + 26872765) [0x1073d5bbd] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x1073d5f27] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x1073d570e] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x1073fbc37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf4e Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xf50 Thread name "VizCompositorThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1019ad000 - 0x1019bcfff com.dropbox.Electron.helper (0) <20E2CB6F-CB69-332D-B3B7-E89BED0B74F8> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (GPU).app/Contents/MacOS/Dropbox Helper (GPU) 0x105a35000 - 0x10d418fff com.dropbox.Electron.framework (13.1.0-dropbox.20221010.faa890d59) <99083138-0C5C-30AD-8FCB-CC3F2662F5DA> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Dropbox Helper (Renderer) [440] UUID: B74BC5D1-7690-3CA0-B685-2BBD3D4BE9E5 Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (Renderer).app/Contents/MacOS/Dropbox Helper (Renderer) Architecture: x86_64 Parent: Dropbox [386] UID: 504 Footprint: 103.17 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xf6b DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Dropbox Helper (Renderer) + 6304) [0x1076e38a0] 1-11 11 ElectronMain + 145 (Electron Framework + 108401) [0x10d072771] 1-11 11 electron::fuses::IsRunAsNodeEnabled() + 5710690 (Electron Framework + 7589282) [0x10d794da2] 1-11 11 electron::fuses::IsRunAsNodeEnabled() + 5710449 (Electron Framework + 7589041) [0x10d794cb1] 1-11 11 electron::fuses::IsRunAsNodeEnabled() + 5714198 (Electron Framework + 7592790) [0x10d795b56] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 36546778 (Electron Framework + 53437866) [0x11034e5aa] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x10e9b732c] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x10e9e481f] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10118539 (Electron Framework + 27009627) [0x10ea1a25b] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10123401 (Electron Framework + 27014489) [0x10ea1b559] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf6f Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xf71 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x10ea16148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981677 (Electron Framework + 26872765) [0x10e9f8bbd] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x10e9f8f27] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x10e9f870e] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x10ea1ec37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf72 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x10ea16148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016615 (Electron Framework + 26907703) [0x10ea01437] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016104 (Electron Framework + 26907192) [0x10ea01238] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x10e9b732c] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x10e9e481f] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xf74 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf77 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf78 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xf79 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xf7a Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xf7b Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xf7c Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xf7d Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa9c99c Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x10ea16148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981773 (Electron Framework + 26872861) [0x10e9f8c1d] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x10e9f8f27] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x10e9f870e] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x10ea1ec37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1076e2000 - 0x1076f1fff com.dropbox.Electron.helper (0) <B74BC5D1-7690-3CA0-B685-2BBD3D4BE9E5> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (Renderer).app/Contents/MacOS/Dropbox Helper (Renderer) 0x10d058000 - 0x114a3bfff com.dropbox.Electron.framework (13.1.0-dropbox.20221010.faa890d59) <99083138-0C5C-30AD-8FCB-CC3F2662F5DA> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Dropbox Helper (Renderer) [10160] [unique pid 109769] UUID: B74BC5D1-7690-3CA0-B685-2BBD3D4BE9E5 Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (Renderer).app/Contents/MacOS/Dropbox Helper (Renderer) Architecture: x86_64 Parent: Dropbox [386] UID: 504 Footprint: 42.44 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x64d6dc DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Dropbox Helper (Renderer) + 6304) [0x103f228a0] 1-11 11 ElectronMain + 145 (Electron Framework + 108401) [0x103f5c771] 1-11 11 electron::fuses::IsRunAsNodeEnabled() + 5710690 (Electron Framework + 7589282) [0x10467eda2] 1-11 11 electron::fuses::IsRunAsNodeEnabled() + 5710449 (Electron Framework + 7589041) [0x10467ecb1] 1-11 11 electron::fuses::IsRunAsNodeEnabled() + 5714198 (Electron Framework + 7592790) [0x10467fb56] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 36546778 (Electron Framework + 53437866) [0x1072385aa] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x1058a132c] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x1058ce81f] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10118539 (Electron Framework + 27009627) [0x10590425b] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10123401 (Electron Framework + 27014489) [0x105905559] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64d6e8 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x64d6ea Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x105900148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981677 (Electron Framework + 26872765) [0x1058e2bbd] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x1058e2f27] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x1058e270e] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x105908c37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64d6eb Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x105900148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016615 (Electron Framework + 26907703) [0x1058eb437] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10016104 (Electron Framework + 26907192) [0x1058eb238] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9713244 (Electron Framework + 26604332) [0x1058a132c] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9898831 (Electron Framework + 26789919) [0x1058ce81f] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x64d6ed Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64d6ef Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64d6f0 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64d6f1 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x105900148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 36241077 (Electron Framework + 53132165) [0x1071edb85] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10099296 (Electron Framework + 26990384) [0x1058ff730] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64d6f2 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64d6f3 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64d6f4 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64d6f5 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64d703 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10101880 (Electron Framework + 26992968) [0x105900148] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9981773 (Electron Framework + 26872861) [0x1058e2c1d] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9982551 (Electron Framework + 26873639) [0x1058e2f27] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 9980478 (Electron Framework + 26871566) [0x1058e270e] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 10137447 (Electron Framework + 27028535) [0x105908c37] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x103f21000 - 0x103f30fff com.dropbox.Electron.helper (0) <B74BC5D1-7690-3CA0-B685-2BBD3D4BE9E5> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Dropbox Helper (Renderer).app/Contents/MacOS/Dropbox Helper (Renderer) 0x103f42000 - 0x10b925fff com.dropbox.Electron.framework (13.1.0-dropbox.20221010.faa890d59) <99083138-0C5C-30AD-8FCB-CC3F2662F5DA> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: DropboxActivityProvider [500] UUID: D0EACB89-0531-3AEF-8614-D06DE4C1255F Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/XPCServices/DropboxActivityProvider.xpc/Contents/MacOS/DropboxActivityProvider Architecture: x86_64 Parent: launchd [1] Responsible: Dropbox [386] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 5116 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (76.1K cycles, 23.5K instructions, 3.24c/i) Note: 2 idle work queue threads omitted Thread 0x153f DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 16 (DropboxActivityProvider + 60062) [0x10d229a9e] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x1547 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d21b000 - 0x10d22efff com.dropbox.activityprovider 1.0 (163.4.5456) <D0EACB89-0531-3AEF-8614-D06DE4C1255F> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/XPCServices/DropboxActivityProvider.xpc/Contents/MacOS/DropboxActivityProvider 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: DropboxNotificationService [441] UUID: FA9BF1BD-9896-395C-8E53-CCD4E64A06CA Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/XPCServices/DropboxNotificationService.xpc/Contents/MacOS/DropboxNotificationService Architecture: x86_64 Parent: launchd [1] Responsible: Dropbox [386] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1468 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xf7f 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10596c000 - 0x105973fff DropboxNotificationService <FA9BF1BD-9896-395C-8E53-CCD4E64A06CA> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/XPCServices/DropboxNotificationService.xpc/Contents/MacOS/DropboxNotificationService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: EscrowSecurityAlert [4389] UUID: 90B55EB5-EF5A-32D0-A814-57B971B96D67 Path: /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1532 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x536a8 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100c87000 - 0x100c8cfff EscrowSecurityAlert <90B55EB5-EF5A-32D0-A814-57B971B96D67> /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ethcheck [209] UUID: 11EFA59B-89BC-3B5E-909F-EEB1B4A6E237 Path: /usr/libexec/firmwarecheckers/ethcheck/ethcheck Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 860 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6ad 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10c976000 - 0x10c97dfff ethcheck <11EFA59B-89BC-3B5E-909F-EEB1B4A6E237> /usr/libexec/firmwarecheckers/ethcheck/ethcheck 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: familycircled [357] UUID: 57CB71EB-3D3A-304A-9881-1A99EF0F25C0 Path: /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 2372 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xb56 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10c3ab000 - 0x10c3bafff familycircled <57CB71EB-3D3A-304A-9881-1A99EF0F25C0> /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: filecoordinationd [331] UUID: 044CD0FB-E6BB-34D3-8DA8-5D071348A278 Path: /usr/sbin/filecoordinationd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1712 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x9c8 DispatchQueue 11 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10b3e5000 - 0x10b3e5fff filecoordinationd <044CD0FB-E6BB-34D3-8DA8-5D071348A278> /usr/sbin/filecoordinationd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: fileproviderd [337] UUID: 93483853-37BF-394E-B28E-E857EEBD8FF1 Path: /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2876 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa0f 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x107d21000 - 0x107d56fff fileproviderd <93483853-37BF-394E-B28E-E857EEBD8FF1> /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Finder [278] UUID: A0E7FB21-BD6B-322F-A694-976B8BCCA775 Path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 791.05 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.007s (31.0M cycles, 9.8M instructions, 3.17c/i) Note: 3 idle work queue threads omitted Thread 0x7d7 DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46) cpu time 0.007s (30.1M cycles, 9.6M instructions, 3.15c/i) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0, priority 46 (46)> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Finder + 25553) [0x109a523d1] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped, process suppressed, timers tier 4 (throttled), IO tier 2, priority 4 (4)> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 46 (46)> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x92a Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0, priority 46 (46)> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped, process suppressed, timers tier 4 (throttled), IO tier 2, priority 4 (4)> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 46 (46)> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x242c 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped, process suppressed, timers tier 4 (throttled), IO tier 2, priority 4 (4)> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x86c9c5 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 4 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x86d28a 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 4 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Binary Images: 0x109a4c000 - 0x10a1a2fff com.apple.finder 10.14.7 (1143.7.1) <A0E7FB21-BD6B-322F-A694-976B8BCCA775> /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: findmydeviced [339] UUID: 4E8CD738-9023-3B9F-B5B6-066EACB672EE Path: /usr/libexec/findmydeviced Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2448 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa45 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e676000 - 0x10e6f7fff findmydeviced <4E8CD738-9023-3B9F-B5B6-066EACB672EE> /usr/libexec/findmydeviced 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: fmfd [322] UUID: F4CF4C9F-2B9F-3EEE-8752-73454F7C57A1 Path: /usr/libexec/fmfd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 6668 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x95a 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x107edb000 - 0x107f3bfff fmfd (339) <F4CF4C9F-2B9F-3EEE-8752-73454F7C57A1> /usr/libexec/fmfd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: FMIPClientXPCService [9954] UUID: 8B2C30F7-DBE5-3465-938A-BE57FF01CC53 Path: /System/Library/PrivateFrameworks/FMClient.framework/Versions/A/XPCServices/FMIPClientXPCService.xpc/Contents/MacOS/FMIPClientXPCService Architecture: x86_64 Parent: launchd [1] Responsible: assistant_service [5602] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2040 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe6947 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10848e000 - 0x108519fff FMIPClientXPCService <8B2C30F7-DBE5-3465-938A-BE57FF01CC53> /System/Library/PrivateFrameworks/FMClient.framework/Versions/A/XPCServices/FMIPClientXPCService.xpc/Contents/MacOS/FMIPClientXPCService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: followupd [898] UUID: 81FEAFBA-8AB6-39C7-A67D-5C59CC9F03D9 Path: /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1448 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa746 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1064ac000 - 0x1064c1fff followupd (74.3.0.1.1) <81FEAFBA-8AB6-39C7-A67D-5C59CC9F03D9> /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: fontd [304] UUID: 36469CA0-7FA5-32F6-B0D3-ED7BB9F9F5D8 Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 15.72 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x8e4 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10a042000 - 0x10a084fff fontd <36469CA0-7FA5-32F6-B0D3-ED7BB9F9F5D8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: fpsd [8661] [unique pid 108276] UUID: BB4D7B2C-6D25-33AA-B591-E583B4677E80 Path: /System/Library/PrivateFrameworks/CoreFP.framework/Versions/A/fpsd Architecture: x86_64 Parent: launchd [1] UID: 265 Footprint: 1284 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (53.4K cycles, 11.6K instructions, 4.61c/i) Note: 1 idle work queue thread omitted Thread 0x5ffd29 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffd55 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (53.4K cycles, 11.6K instructions, 4.61c/i) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (fpsd + 88307) [0x1021f68f3] 1-11 11 sleep + 41 (libsystem_c.dylib + 501622) [0x7fff60f5f776] 1-11 11 __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Binary Images: 0x1021e1000 - 0x10226bfff fpsd (2.13.61) <BB4D7B2C-6D25-33AA-B591-E583B4677E80> /System/Library/PrivateFrameworks/CoreFP.framework/Versions/A/fpsd 0x7fff60ee5000 - 0x7fff60f6cfff libsystem_c.dylib (1272.250.3) <6016EDA1-440B-34D7-A232-686CD7FBEE90> /usr/lib/system/libsystem_c.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: fseventsd [55] UUID: 2114A6F5-90C6-3A5F-9B9B-E4E6BB55C3D9 Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 14.05 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (1584.5K cycles, 700.2K instructions, 2.26c/i) Note: 1 idle work queue thread omitted Thread 0x255 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (fseventsd + 6802) [0x1033a8a92] 1-11 11 mach_msg_server + 378 (libsystem_kernel.dylib + 100170) [0x7fff60fe774a] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x286 11 samples (1-11) priority 49 (base 49) cpu time <0.001s (357.4K cycles, 121.6K instructions, 2.94c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (fseventsd + 50949) [0x1033b3705] 1-11 11 ??? (fseventsd + 49830) [0x1033b32a6] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x292 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0 and passive> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x293 11 samples (1-11) priority 50 (base 50) cpu time <0.001s (49.5K cycles, 10.0K instructions, 4.95c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4405643) [0xffffff800063398b] 1-11 *11 ??? (kernel + 7168593) [0xffffff80008d6251] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x294 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0 and passive> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (fseventsd + 34818) [0x1033af802] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7e8ad7 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (152.6K cycles, 78.8K instructions, 1.94c/i) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (fseventsd + 34892) [0x1033af84c] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7e8ad8 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (185.9K cycles, 82.9K instructions, 2.24c/i) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (fseventsd + 34892) [0x1033af84c] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7e8af6 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (499.6K cycles, 253.9K instructions, 1.97c/i) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (fseventsd + 34892) [0x1033af84c] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x98055b 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (168.5K cycles, 76.9K instructions, 2.19c/i) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (fseventsd + 34892) [0x1033af84c] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa57cf3 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (171.1K cycles, 76.1K instructions, 2.25c/i) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (fseventsd + 34892) [0x1033af84c] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x1033a7000 - 0x1033b7fff fseventsd (1239.200.13) <2114A6F5-90C6-3A5F-9B9B-E4E6BB55C3D9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: gamecontrollerd [333] UUID: 7CDBC003-AC7C-3698-9978-3CCCF83AD6EA Path: /usr/libexec/gamecontrollerd Architecture: x86_64 Parent: launchd [1] UID: 247 Sudden Term: Tracked (allows idle exit) Footprint: 1900 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x9c5 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (gamecontrollerd + 37106) [0x10d7740f2] 1-11 11 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 970970) [0x7fff372410da] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d76b000 - 0x10d776fff gamecontrollerd (6.22.7) <7CDBC003-AC7C-3698-9978-3CCCF83AD6EA> /usr/libexec/gamecontrollerd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: garcon [330] UUID: 807E70BC-329F-354B-B43D-2EDB6E7DE3AD Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 22.64 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x9c2 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSExtensionMain + 51 (Foundation + 2339980) [0x7fff3738f48c] 1-11 11 ??? (PlugInKit + 84895) [0x7fff57147b9f] 1-11 11 ??? (PlugInKit + 83603) [0x7fff57147693] 1-11 11 ??? (PlugInKit + 84043) [0x7fff5714784b] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xab9 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x109d9b000 - 0x109da6fff garcon <807E70BC-329F-354B-B43D-2EDB6E7DE3AD> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff57133000 - 0x7fff57156fff com.apple.pluginkit.framework 1.0 (1) <B00A2028-4490-3BEA-B0F1-082BB7C050DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: garcon [362] UUID: 807E70BC-329F-354B-B43D-2EDB6E7DE3AD Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 19.45 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (141.8K cycles, 38.7K instructions, 3.67c/i) Note: 2 idle work queue threads omitted Thread 0xce0 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSExtensionMain + 51 (Foundation + 2339980) [0x7fff3738f48c] 1-11 11 ??? (PlugInKit + 84895) [0x7fff57147b9f] 1-11 11 ??? (PlugInKit + 83603) [0x7fff57147693] 1-11 11 ??? (PlugInKit + 84043) [0x7fff5714784b] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xcf8 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1063ad000 - 0x1063b8fff garcon <807E70BC-329F-354B-B43D-2EDB6E7DE3AD> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff57133000 - 0x7fff57156fff com.apple.pluginkit.framework 1.0 (1) <B00A2028-4490-3BEA-B0F1-082BB7C050DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: garcon [7210] UUID: 807E70BC-329F-354B-B43D-2EDB6E7DE3AD Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 26.43 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (71.9K cycles, 23.9K instructions, 3.01c/i) Note: 2 idle work queue threads omitted Thread 0xbb55b DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSExtensionMain + 51 (Foundation + 2339980) [0x7fff3738f48c] 1-11 11 ??? (PlugInKit + 84895) [0x7fff57147b9f] 1-11 11 ??? (PlugInKit + 83603) [0x7fff57147693] 1-11 11 ??? (PlugInKit + 84043) [0x7fff5714784b] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xbb565 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d13c000 - 0x10d147fff garcon <807E70BC-329F-354B-B43D-2EDB6E7DE3AD> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff57133000 - 0x7fff57156fff com.apple.pluginkit.framework 1.0 (1) <B00A2028-4490-3BEA-B0F1-082BB7C050DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: garcon [6304] [unique pid 105928] UUID: 807E70BC-329F-354B-B43D-2EDB6E7DE3AD Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 18.05 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (72.8K cycles, 25.3K instructions, 2.88c/i) Note: 2 idle work queue threads omitted Thread 0x5cd264 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSExtensionMain + 51 (Foundation + 2339980) [0x7fff3738f48c] 1-11 11 ??? (PlugInKit + 84895) [0x7fff57147b9f] 1-11 11 ??? (PlugInKit + 83603) [0x7fff57147693] 1-11 11 ??? (PlugInKit + 84043) [0x7fff5714784b] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5cd26d Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10c5d9000 - 0x10c5e4fff garcon <807E70BC-329F-354B-B43D-2EDB6E7DE3AD> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff57133000 - 0x7fff57156fff com.apple.pluginkit.framework 1.0 (1) <B00A2028-4490-3BEA-B0F1-082BB7C050DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: garcon [16673] [unique pid 116274] UUID: 807E70BC-329F-354B-B43D-2EDB6E7DE3AD Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 18.82 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (101.4K cycles, 28.6K instructions, 3.55c/i) Note: 2 idle work queue threads omitted Thread 0x74ca19 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSExtensionMain + 51 (Foundation + 2339980) [0x7fff3738f48c] 1-11 11 ??? (PlugInKit + 84895) [0x7fff57147b9f] 1-11 11 ??? (PlugInKit + 83603) [0x7fff57147693] 1-11 11 ??? (PlugInKit + 84043) [0x7fff5714784b] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x74ca3a Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100331000 - 0x10033cfff garcon <807E70BC-329F-354B-B43D-2EDB6E7DE3AD> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff57133000 - 0x7fff57156fff com.apple.pluginkit.framework 1.0 (1) <B00A2028-4490-3BEA-B0F1-082BB7C050DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: garcon [63190] [unique pid 162773] UUID: 807E70BC-329F-354B-B43D-2EDB6E7DE3AD Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 18.86 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (93.0K cycles, 28.3K instructions, 3.29c/i) Note: 2 idle work queue threads omitted Thread 0xa57d00 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSExtensionMain + 51 (Foundation + 2339980) [0x7fff3738f48c] 1-11 11 ??? (PlugInKit + 84895) [0x7fff57147b9f] 1-11 11 ??? (PlugInKit + 83603) [0x7fff57147693] 1-11 11 ??? (PlugInKit + 84043) [0x7fff5714784b] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa57d0b Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104be1000 - 0x104becfff garcon <807E70BC-329F-354B-B43D-2EDB6E7DE3AD> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff57133000 - 0x7fff57156fff com.apple.pluginkit.framework 1.0 (1) <B00A2028-4490-3BEA-B0F1-082BB7C050DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: garcon [67150] [unique pid 166733] UUID: 807E70BC-329F-354B-B43D-2EDB6E7DE3AD Path: /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 15.56 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0xa8e869 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSExtensionMain + 51 (Foundation + 2339980) [0x7fff3738f48c] 1-11 11 ??? (PlugInKit + 84895) [0x7fff57147b9f] 1-11 11 ??? (PlugInKit + 83603) [0x7fff57147693] 1-11 11 ??? (PlugInKit + 84043) [0x7fff5714784b] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa8e888 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105696000 - 0x1056a1fff garcon <807E70BC-329F-354B-B43D-2EDB6E7DE3AD> /Users/USER/Library/Application Support/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff57133000 - 0x7fff57156fff com.apple.pluginkit.framework 1.0 (1) <B00A2028-4490-3BEA-B0F1-082BB7C050DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome [721] UUID: 4C4C44C9-5555-3144-A14C-FD20701C5D68 Path: /Applications/Google Chrome.app/Contents/MacOS/Google Chrome Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 388.13 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.007s (32.2M cycles, 17.2M instructions, 1.87c/i) Note: 3 idle work queue threads omitted Thread 0x2eb2 DispatchQueue 1 Thread name "CrBrowserMain" 11 samples (1-11) priority 46 (base 46) cpu time 0.005s (20.3M cycles, 12.7M instructions, 1.60c/i) <thread QoS user interactive (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 205 (Google Chrome + 6013) [0x10d92a77d] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x112dfb0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x114fe347f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x114533367] 1-11 11 ChromeMain + 25049845 (Google Chrome Framework + 25061861) [0x1145de9e5] 1-11 11 ChromeMain + 36126554 (Google Chrome Framework + 36138570) [0x11506ee4a] 1-11 11 ChromeMain + 30451759 (Google Chrome Framework + 30463775) [0x114b0571f] 1-11 11 ChromeMain + 30452258 (Google Chrome Framework + 30464274) [0x114b05912] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x113a791c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x113a79bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x114c10cd4] 1-11 11 ChromeMain + 39964550 (Google Chrome Framework + 39976566) [0x115417e76] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 ChromeMain + 48445938 (Google Chrome Framework + 48457954) [0x115c2e8e2] 1-11 11 ChromeMain + 12202 (Google Chrome Framework + 24218) [0x112dfde9a] 1-11 11 ChromeMain + 94890799 (Google Chrome Framework + 94902815) [0x118879a1f] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2ef8 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f1b Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x118ba5f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x115c844c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f1c Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x114d4e2f5] 1-11 11 ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x115c7deb8] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x113a791c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x113a79bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x2f22 Thread name "Chrome_IOThread" 11 samples (1-11) priority 31 (base 31) cpu time 0.002s (10.7M cycles, 4.2M instructions, 2.56c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x114d4e2f5] 1-11 11 ChromeMain + 47967713 (Google Chrome Framework + 47979729) [0x115bb9cd1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x113a791c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x113a79bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x2f23 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x114d4e2f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x114d4e598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x113a791c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x113a79bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x115c65d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f32 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f34 Thread name "CrShutdownDetector" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 7294931) [0xffffff80008f4fd3] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x2f44 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f4c Thread name "NetworkNotificationThreadMac" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f4f Thread name "ThreadPoolSingleThreadForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 15757273 (Google Chrome Framework + 15769289) [0x113d01ec9] 1-11 11 ChromeMain + 15758109 (Google Chrome Framework + 15770125) [0x113d0220d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f51 Thread name "CacheThread_BlockFile" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x114d4e2f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x114d4e598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x113a791c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x113a79bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x2f52 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 12781790 (Google Chrome Framework + 12793806) [0x113a2b7ce] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x113195f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x2f54 Thread name "ThreadPoolSingleThreadSharedForeground1" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (318.0K cycles, 69.4K instructions, 4.58c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x113d01eba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x113d021dd] 1-11 2 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-2 2 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-2 2 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-2 *2 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-2 9 ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x114b4a555] 3-11 9 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 3-11 *9 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 3-11 Thread 0x2f84 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f85 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x113d01eba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x113d021dd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f87 Thread name "ThreadPoolSingleThreadSharedBackgroundBlocking3" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f89 Thread name "Service Discovery Thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f8a Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0x2f9c Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2fa3 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2fa9 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2fd7 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x3010 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x31e7 Thread name "org.libusb.device-hotplug" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x31e8 Thread name "UsbEventHandler" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 29318071 (Google Chrome Framework + 29330087) [0x1149f0aa7] 1-11 11 poll + 10 (libsystem_kernel.dylib + 37738) [0x7fff60fd836a] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 poll_nocancel + 1184 (kernel + 7282560) [0xffffff80008f1f80] 1-11 *11 kqueue_scan + 415 (kernel + 6973295) [0xffffff80008a676f] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x343e Thread name "PowerSaveBlocker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x114d4e2f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x114d4e598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x113a791c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x113a79bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x115c65d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3886 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3888 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa77254 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x113d01eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x113d01f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9d392 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x113d01e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x113d01efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f29b Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (240.3K cycles, 61.3K instructions, 3.92c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x113d01eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x113d01f2d] 1-11 3 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-3 3 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-3 3 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-3 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 8 ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x114b4a555] 4-11 8 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 4-11 *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xaa0570 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x113d01e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x113d01efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0572 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x113d01e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x113d01efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0786 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1138a8374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x113d01e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x113d01efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x114b4ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1130be4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d929000 - 0x10d95cfff com.google.Chrome 108.0.5359.124 (5359.124) <4C4C44C9-5555-3144-A14C-FD20701C5D68> /Applications/Google Chrome.app/Contents/MacOS/Google Chrome 0x112df8000 - 0x11d90dfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper [734] UUID: 4C4C442C-5555-3144-A14B-566CC46741BF Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 44.72 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.003s (13.4M cycles, 5.1M instructions, 2.61c/i) Note: 1 idle work queue thread omitted Thread 0x2f5b DispatchQueue 1 Thread name "CrUtilityMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper + 6412) [0x1089ea90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10ccad0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10ee9547f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10e3e5367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10e49082f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10e4912f5] 1-11 11 ChromeMain + 28237985 (Google Chrome Framework + 28250001) [0x10e79af91] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d92b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d92bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10fb17d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cf704fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f91 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d75a374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x112a57f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10fb364c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cf704fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2f92 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d75a374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10ec002f5] 1-11 11 ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x10fb2feb8] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d92b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d92bbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x2f95 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) cpu time 0.003s (12.9M cycles, 5.0M instructions, 2.61c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d75a374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10ec002f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10fc5d3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d92b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d92bbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x2f98 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x109a2 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa732b3 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (102.1K cycles, 19.4K instructions, 5.25c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d75a374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10dbb3eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10dbb3f2d] 1-11 3 ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x10e9fc555] 1-3 3 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-3 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 8 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e9fce33] 4-11 8 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cf704fd] 4-11 8 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 4-11 *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Thread 0xa9f048 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d75a374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10dbb3eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10dbb3f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e9fce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cf704fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f2ac Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d75a374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10dbb3e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10dbb3efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e9fce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cf704fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0574 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (349.8K cycles, 151.7K instructions, 2.31c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d75a374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10dbb3e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10dbb3efd] 1-11 3 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e9fce33] 1-3 3 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cf704fd] 1-3 3 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-3 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 8 ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x10e9fc555] 4-11 8 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 4-11 *8 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4-11 Binary Images: 0x1089e9000 - 0x108a19fff com.google.Chrome.helper 108.0.5359.124 (5359.124) <4C4C442C-5555-3144-A14B-566CC46741BF> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper 0x10ccaa000 - 0x1177bffff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper [735] UUID: 4C4C442C-5555-3144-A14B-566CC46741BF Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 21.17 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x2f81 Thread name "CrUtilityMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper + 6412) [0x10936990c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10e8580b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x110a4047f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10ff90367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11003b82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x11003c2f5] 1-11 11 ChromeMain + 28237985 (Google Chrome Framework + 28250001) [0x110345f91] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10f4d61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10f4d6bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x1116c2d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10eb1b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2fac Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10f305374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x114602f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1116e14c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10eb1b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2fad Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x2faf Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10f305374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10f75eeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10f75ef2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1105a7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10eb1b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2fb6 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10f305374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1107ab2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1118083f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10f4d61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10f4d6bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x109a3 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa86029 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10f305374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10f75ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10f75eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1105a7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10eb1b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f646 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10f305374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10f75ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10f75eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1105a7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10eb1b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa064a Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10f305374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10f75ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10f75eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1105a7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10eb1b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x109368000 - 0x109398fff com.google.Chrome.helper 108.0.5359.124 (5359.124) <4C4C442C-5555-3144-A14B-566CC46741BF> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper 0x10e855000 - 0x11936afff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper [764] UUID: 4C4C442C-5555-3144-A14B-566CC46741BF Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 14.02 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x32ce DispatchQueue 1 Thread name "CrUtilityMain" 11 samples (1-11) priority 47 (base 47) <process frontmost, thread QoS user interactive (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper + 6412) [0x104f5690c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10c2540b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10e43c47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10d98c367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10da3782f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10da382f5] 1-11 11 ChromeMain + 28237985 (Google Chrome Framework + 28250001) [0x10dd41f91] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10ced21c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10ced2bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10e069cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10e069e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x32d8 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <process frontmost, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cd01374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x111ffef88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10f0dd4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c5174fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x32d9 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <process frontmost, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cd01374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e1a72f5] 1-11 11 ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x10f0d6eb8] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10ced21c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10ced2bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x32da Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process frontmost, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cd01374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10d15ae82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10d15aefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10dfa3e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c5174fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x32db Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <process frontmost, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cd01374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10d15aeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10d15af2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10dfa3e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c5174fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x32dc Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <process frontmost, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cd01374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e1a72f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10f2043f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10ced21c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10ced2bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x109a8 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <process frontmost, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104f55000 - 0x104f85fff com.google.Chrome.helper 108.0.5359.124 (5359.124) <4C4C442C-5555-3144-A14B-566CC46741BF> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper 0x10c251000 - 0x116d66fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper [67359] [unique pid 166942] UUID: 4C4C442C-5555-3144-A14B-566CC46741BF Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 12.70 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (319.7K cycles, 55.9K instructions, 5.72c/i) Note: 2 idle work queue threads omitted Thread 0xa9f2a3 DispatchQueue 1 Thread name "CrUtilityMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (264.8K cycles, 49.1K instructions, 5.39c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper + 6412) [0x1049e690c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10fbb60b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x111d9e47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x1112ee367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11139982f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x11139a2f5] 1-11 11 ChromeMain + 28237985 (Google Chrome Framework + 28250001) [0x1116a3f91] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1108341c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x110834bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x112a20d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fe794fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f2af Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (54.9K cycles, 6.8K instructions, 8.06c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110663374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x115960f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x112a3f4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fe794fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f2b0 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110663374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x111b092f5] 1-11 11 ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x112a38eb8] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1108341c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x110834bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa9f2b1 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110663374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x110abce82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x110abcefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111905e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fe794fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f2b2 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110663374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x110abceab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x110abcf2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111905e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fe794fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f2b4 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110663374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x111b092f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x112b663f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1108341c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x110834bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Binary Images: 0x1049e5000 - 0x104a15fff com.google.Chrome.helper 108.0.5359.124 (5359.124) <4C4C442C-5555-3144-A14B-566CC46741BF> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper 0x10fbb3000 - 0x11a6c8fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (GPU) [733] UUID: 4C4C4418-5555-3144-A1B2-D65FE009D631 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (GPU).app/Contents/MacOS/Google Chrome Helper (GPU) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 2053.59 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x2f53 DispatchQueue 1 Thread name "CrGpuMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (GPU) + 6412) [0x10e76190c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1168ab0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x118a9347f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x117fe3367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11808e82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x11808f2f5] 1-11 11 ChromeMain + 41395209 (Google Chrome Framework + 41407225) [0x1190252f9] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1175291c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x117529bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x1186c0cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x1186c0e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2fd9 Thread name "GpuWatchdog" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x117358374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1187fe2f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x1187fe598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1175291c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x117529bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x119715d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x116b6e4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2fef Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x2ff3 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x117358374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1187fe2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x11985b3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1175291c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x117529bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x2ff5 Thread name "VizCompositorThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x117358374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1187fe2f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x1187fe598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1175291c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x117529bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x119715d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x116b6e4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x32cc Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x32cd Thread name "ThreadPoolSingleThreadSharedForeground1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x109aa Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa5091 Thread name "com.apple.coremedia.imagequeue.coreanimation.common" 11 samples (1-11) priority 54 (base 54) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 figThreadMain + 276 (CoreMedia + 71999) [0x7fff35fd493f] 1-11 11 ??? (MediaToolbox + 2922460) [0x7fff396ac7dc] 1-11 11 FigSemaphoreWaitRelative + 145 (CoreMedia + 83275) [0x7fff35fd754b] 1-11 11 WaitOnCondition + 11 (CoreMedia + 154667) [0x7fff35fe8c2b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa81478 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x117358374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1177b1eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1177b1f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1185fae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x116b6e4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa8cecf Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x117358374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1177b1e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1177b1efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1185fae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x116b6e4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f1a9 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x117358374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1177b1eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1177b1f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1185fae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x116b6e4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa09dd Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x117358374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1177b1e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1177b1efd] 1-11 11 ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x1185f9bab] 1-11 11 ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x116b6e149] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x116b6e4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e760000 - 0x10e790fff com.google.Chrome.helper 108.0.5359.124 (5359.124) <4C4C4418-5555-3144-A1B2-D65FE009D631> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (GPU).app/Contents/MacOS/Google Chrome Helper (GPU) 0x1168a8000 - 0x1213bdfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff35fc3000 - 0x7fff360c7fff com.apple.CoreMedia 1.0 (2290.14) <2C7A5348-7F19-3E28-97E4-6065A64B1DC9> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff393e3000 - 0x7fff39a89fff com.apple.MediaToolbox 1.0 (2290.14) <927F9E24-32DB-33F9-9866-4DD8092A51F4> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8016] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 497.68 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (3.7M cycles, 1300.5K instructions, 2.84c/i) Note: 1 idle work queue thread omitted Thread 0xe38b1 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (2.7M cycles, 1074.4K instructions, 2.53c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1054a190c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10d81d0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10fa0547f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10ef55367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10f00082f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10f0012f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10f5eaef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10e49b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10e49bbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10f632cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10f632e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38bd Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e2ca374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1135c7f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1106a64c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10dae04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38be Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xe38c0 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e2ca374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10e723eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10e723f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10f56ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10dae04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38c1 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (966.5K cycles, 226.2K instructions, 4.27c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e2ca374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10f7702f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1107cd3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10e49b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10e49bbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xe38c3 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38c5 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38c6 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38d0 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe38d1 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe38d2 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe38d3 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe38d4 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe39ac Thread name "WebCrypto" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe63ec Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0394 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e2ca374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10e723e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10e723efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10f56ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10dae04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa05bc Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e2ca374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10e723e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10e723efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10f56ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10dae04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1054a0000 - 0x1054d0fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10d81a000 - 0x11832ffff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8017] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 126.10 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.009s (39.9M cycles, 18.3M instructions, 2.18c/i) Note: 1 idle work queue thread omitted Thread 0xe38c9 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time 0.008s (35.9M cycles, 16.8M instructions, 2.15c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x109a7f90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10bbb50b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10dd9d47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10d2ed367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10d39882f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10d3992f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10d982ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10c8331c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10c833bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10d9cacd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10d9cae1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38df Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c662374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11195ff88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10ea3e4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10be784fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38e1 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xe38e3 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c662374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10cabbeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10cabbf2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10d904e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10be784fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38e4 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (3.9M cycles, 1532.3K instructions, 2.56c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c662374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10db082f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10eb653f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10c8331c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10c833bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xe38e6 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38e8 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38e9 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38ec Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe38ed Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe38ee Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe38ef Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe38f0 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe63ef Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x24179b Thread name "ThreadPoolSingleThreadSharedForeground1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x743c06 Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x743c0b Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9cdb1 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c662374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10cabbe82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10cabbefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10d904e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10be784fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f73d Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c662374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10cabbe82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10cabbefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10d904e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10be784fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa04b0 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c662374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10cabbe82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10cabbefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10d904e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10be784fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0789 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c662374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10cabbe82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10cabbefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10d904e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10be784fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa078a Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c662374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10cabbe82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10cabbefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10d904e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10be784fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x109a7e000 - 0x109aaefff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10bbb2000 - 0x1166c7fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8018] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 31.56 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe38dc DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10da9e90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x11513c0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11732447f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x116874367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11691f82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1169202f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x116f09ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x115dba1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x115dbabf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x116f51cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x116f51e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38fc Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x115be9374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11aee6f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x117fc54c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1153ff4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38fd Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xe38fe Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x115be9374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x116042e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x116042efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x116e8be33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1153ff4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe38ff Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x115be9374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x116042eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x116042f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x116e8be33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1153ff4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3900 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x115be9374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x11708f2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1180ec3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x115dba1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x115dbabf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xe3902 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3906 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3907 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe390e Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe390f Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe3910 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe3911 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe3912 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe63f0 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10da9d000 - 0x10dacdfff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x115139000 - 0x11fc4efff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8020] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 42.71 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe38f1 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1019f090c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10c7f90b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10e9e147f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10df31367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10dfdc82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10dfdd2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10e5c6ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d4771c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d477bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10e60ecd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10e60ee1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3923 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d2a6374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1125a3f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10f6824c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cabc4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3924 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xe3926 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d2a6374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10d6ffeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10d6fff2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e548e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cabc4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3927 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d2a6374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e74c2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10f7a93f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d4771c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d477bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xe3929 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3936 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3937 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3958 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe3959 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe395a Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe395b Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe395c Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe63f2 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x865291 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d2a6374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10d6ffe82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10d6ffefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e548e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cabc4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1019ef000 - 0x101a1ffff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10c7f6000 - 0x11730bfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8021] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 61.94 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe38fa DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10de0490c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10de630b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11004b47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10f59b367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10f64682f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10f6472f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10fc30ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10eae11c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10eae1bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10fc78cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10fc78e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3939 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e910374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x113c0df88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x110cec4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1264fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe393a Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xe393c Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e910374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10ed69eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10ed69f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10fbb2e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1264fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe393d Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e910374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10fdb62f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x110e133f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10eae11c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10eae1bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xe3943 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3946 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3947 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe3952 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe3953 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe3954 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe3955 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe3956 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xe39e2 Thread name "WebCrypto" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xe63f3 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa03da Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e910374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10ed69e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10ed69efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10fbb2e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1264fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10de03000 - 0x10de33fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10de60000 - 0x118975fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [14405] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 85.07 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x15c69b DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10f02b90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1179c00b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x119ba847f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x1190f8367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1191a382f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1191a42f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x11978def0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x11863e1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x11863ebf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x1197d5cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x1197d5e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x15c6a7 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11846d374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11d76af88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x11a8494c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x117c834fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x15c6a8 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x15c6aa Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11846d374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1188c6eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1188c6f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11970fe33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x117c834fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x15c6ab Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11846d374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1199132f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x11a9703f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x11863e1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x11863ebf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x15c6ad Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x15c6ae Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x15c6af Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x15c903 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x15c904 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x15c905 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x15c906 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x15c907 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x15d7f8 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9fcb5 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11846d374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1188c6e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1188c6efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11970fe33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x117c834fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f02a000 - 0x10f05afff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x1179bd000 - 0x1224d2fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [98292] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 192.89 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (440.1K cycles, 99.6K instructions, 4.42c/i) Note: 2 idle work queue threads omitted Thread 0x58be4c DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (306.1K cycles, 69.1K instructions, 4.43c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10fe6390c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x114cf00b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x116ed847f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x116428367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1164d382f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1164d42f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x116abdef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x11596e1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x11596ebf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x116b05cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x116b05e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be5a Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11579d374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11aa9af88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x117b794c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x114fb34fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be5b Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x58be5d Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11579d374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x115bf6eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x115bf6f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x116a3fe33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x114fb34fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be5e Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11579d374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x116c432f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x117ca03f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x11596e1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x11596ebf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x58be60 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be61 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be62 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be78 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x58be79 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x58be7a Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x58be7b Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x58be7c Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x58bf1d Thread name "Database thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58bf9f Thread name "Database thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58bfa0 Thread name "Database thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58bfa1 Thread name "Database thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58bfa2 Thread name "Database thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58bfa3 Thread name "Database thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58bfa4 Thread name "Database thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58bfe4 Thread name "Database thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58cd19 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0668 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11579d374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x115bf6e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x115bf6efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x116a3fe33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x114fb34fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10fe62000 - 0x10fe92fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x114ced000 - 0x11f802fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [98293] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 165.95 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (535.4K cycles, 124.6K instructions, 4.30c/i) Note: 2 idle work queue threads omitted Thread 0x58be77 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (399.0K cycles, 84.7K instructions, 4.71c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1048d990c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1049380b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x106b2047f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x106070367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10611b82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10611c2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x106705ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1055b61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1055b6bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10674dcd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10674de1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be89 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1053e5374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10a6e2f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1077c14c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x104bfb4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be8a Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x58be8c Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1053e5374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10583eeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10583ef2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x106687e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x104bfb4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be8e Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1053e5374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10688b2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1078e83f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1055b61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1055b6bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x58be8f Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be91 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58be92 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58bf55 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x58bf56 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x58bf57 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x58bf58 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x58bf59 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x58ff70 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa786f3 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1053e5374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10583ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10583eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x106687e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x104bfb4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1048d8000 - 0x104908fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x104935000 - 0x10f44afff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8617] [unique pid 108232] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 59.43 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (47.8K cycles, 8.6K instructions, 5.59c/i) Note: 1 idle work queue thread omitted Thread 0x5fddc6 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10575490c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10cceb0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10eed347f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10e423367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10e4ce82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10e4cf2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10eab8ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d9691c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d969bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10eb00cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10eb00e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5fddd3 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d798374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x112a95f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10fb744c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cfae4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5fddd4 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x5fddd6 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (47.8K cycles, 8.6K instructions, 5.59c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d798374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10dbf1eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10dbf1f2d] 1-11 7 ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x10ea3a555] 1-7 7 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-7 *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-7 4 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10ea3ae33] 8-11 4 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cfae4fd] 8-11 4 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 8-11 *4 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 8-11 Thread 0x5fddd7 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d798374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10ec3e2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10fc9b3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d9691c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d969bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x5fddd9 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5fddda Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5fdddb Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffab3 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5ffab4 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5ffab5 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5ffab6 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5ffab7 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x600ed5 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9fb2e Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d798374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10dbf1e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10dbf1efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10ea3ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10cfae4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105753000 - 0x105783fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10cce8000 - 0x1177fdfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8814] [unique pid 108429] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 527.82 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x609b63 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x105a1d90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x107e0c0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x109ff447f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x109544367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1095ef82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1095f02f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x109bd9ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x108a8a1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x108a8abf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x109c21cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x109c21e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x609b6f Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1088b9374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10dbb6f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10ac954c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1080cf4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x609b70 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x609b72 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1088b9374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x108d12eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x108d12f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x109b5be33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1080cf4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x609b73 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1088b9374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x109d5f2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10adbc3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x108a8a1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x108a8abf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x609b75 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x609b76 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x609b77 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a7e7 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a7e8 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a7e9 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a7ea Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a7eb Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a834 Thread name "ThreadPoolSingleThreadSharedForeground1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60bab4 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9b556 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1088b9374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x108d12e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x108d12efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x109b5be33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1080cf4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0911 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1088b9374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x108d12e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x108d12efd] 1-11 11 ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x109b5abab] 1-11 11 ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x1080cf149] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1080cf4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105a1c000 - 0x105a4cfff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x107e09000 - 0x11291efff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8845] [unique pid 108460] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 177.66 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x60a7e6 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x106b9590c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x106bf40b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x108ddc47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10832c367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1083d782f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1083d82f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1089c1ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1078721c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107872bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x108a09cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x108a09e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a7f5 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1076a1374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10c99ef88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x109a7d4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x106eb74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a7f6 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a7f8 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1076a1374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x107afaeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x107afaf2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x108943e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x106eb74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a7f9 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1076a1374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x108b472f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x109ba43f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1078721c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107872bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a7fb Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a7fc Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a7fd Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a86a Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a86b Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a86c Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a86d Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a86e Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x61f058 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa7c96c Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1076a1374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x107afae82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x107afaefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x108943e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x106eb74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x106b94000 - 0x106bc4fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x106bf1000 - 0x111706fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8846] [unique pid 108461] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 51.79 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x60a869 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10c2a890c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10c3070b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10e4ef47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10da3f367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10daea82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10daeb2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10e0d4ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10cf851c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10cf85bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10e11ccd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10e11ce1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a87c Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cdb4374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1120b1f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10f1904c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c5ca4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a87d Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a87f Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cdb4374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10d20deab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10d20df2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e056e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c5ca4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a880 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cdb4374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e25a2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10f2b73f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10cf851c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10cf85bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a882 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a883 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a884 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a8bd Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a8be Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a8bf Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a8c0 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a8c1 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x61f059 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7a8daf Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10cdb4374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10d20de82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10d20defd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e056e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c5ca4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10c2a7000 - 0x10c2d7fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10c304000 - 0x116e19fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8847] [unique pid 108462] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 52.07 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x60a8bb DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10850690c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x11363e0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11582647f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x114d76367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x114e2182f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x114e222f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x11540bef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1142bc1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1142bcbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x115453cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x115453e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a8cd Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1140eb374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1193e8f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1164c74c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1139014fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a8ce Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a8d0 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1140eb374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x114544eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x114544f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11538de33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1139014fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a8d1 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1140eb374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1155912f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1165ee3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1142bc1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1142bcbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a8d3 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a8d5 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a8d6 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a928 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a929 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a92a Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a92b Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a92c Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x61f05a Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7aa987 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1140eb374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x114544e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x114544efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11538de33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1139014fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108505000 - 0x108535fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x11363b000 - 0x11e150fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8849] [unique pid 108464] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 51.42 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x60a946 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x104f9090c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x106ce90b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x108ed147f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x108421367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1084cc82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1084cd2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x108ab6ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1079671c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107967bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x108afecd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x108afee1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a953 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107796374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10ca93f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x109b724c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x106fac4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a954 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a956 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107796374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x107befeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x107beff2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x108a38e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x106fac4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a957 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107796374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x108c3c2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x109c993f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1079671c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107967bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a959 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a95a Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a95b Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9aa Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a9ab Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a9ac Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a9ad Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a9ae Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x61f05b Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7ba7ba Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107796374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x107befe82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x107befefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x108a38e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x106fac4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104f8f000 - 0x104fbffff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x106ce6000 - 0x1117fbfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8852] [unique pid 108467] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 67.60 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x60a9af DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10c81f90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1140310b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11621947f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x115769367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11581482f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1158152f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x115dfeef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x114caf1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x114cafbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x115e46cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x115e46e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9d0 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x114ade374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x119ddbf88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x116eba4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1142f44fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9d1 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a9d3 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x114ade374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x114f37eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x114f37f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x115d80e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1142f44fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9d4 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x114ade374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x115f842f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x116fe13f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x114caf1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x114cafbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a9d6 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9db Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9dc Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9e5 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a9e6 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a9e7 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a9e9 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60a9ea Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x61f05c Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7fa766 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x114ade374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x114f37e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x114f37efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x115d80e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1142f44fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10c81e000 - 0x10c84efff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x11402e000 - 0x11eb43fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [8853] [unique pid 108468] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 51.05 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x60a9bd DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10ff4b90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1137840b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11596c47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x114ebc367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x114f6782f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x114f682f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x115551ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1144021c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x114402bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x115599cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x115599e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9f4 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x114231374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11952ef88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x11660d4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x113a474fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9f5 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a9f7 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x114231374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x11468aeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x11468af2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1154d3e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x113a474fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9f8 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x114231374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1156d72f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1167343f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1144021c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x114402bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x60a9fa Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9fb Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60a9fc Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x60abb7 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60abb8 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60abb9 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60abba Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x60abbb Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x61f05e Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7baf29 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x114231374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11468ae82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11468aefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1154d3e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x113a474fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10ff4a000 - 0x10ff7afff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x113781000 - 0x11e296fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [10098] [unique pid 109709] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 180.05 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x649307 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10f7e990c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10f8480b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x111a3047f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x110f80367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11102b82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x11102c2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x111615ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1104c61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1104c6bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x11165dcd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x11165de1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x649322 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1155f2f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1126d14c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fb0b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x649323 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x649325 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x11074eeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x11074ef2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111597e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fb0b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x649326 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x11179b2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1127f83f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1104c61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1104c6bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x649328 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x649329 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x110595914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1104c61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1104c6bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x1126b2d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fb0b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64932a Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64ff7a Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x117b39037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x10fbe2f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64ff7b Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x117b39037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x10fbe2f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64ff7c Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x117b39037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x10fbe2f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64ff7d Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x117b39037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x10fbe2f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64ff7e Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x651257 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x660c32 Thread name "ThreadPoolSingleThreadSharedForeground1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x11074eeba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x11074f1dd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111597e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fb0b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa8ced2 Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x110595914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1104c61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1104c6bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x1126b2d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fb0b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa8ed5a Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11074ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11074eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111597e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fb0b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa030c Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11074ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11074eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111597e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fb0b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa030d Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1102f5374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11074ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11074eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111597e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fb0b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f7e8000 - 0x10f818fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10f845000 - 0x11a35afff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [10222] [unique pid 109831] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 82.60 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6501f5 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x103a6a90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10d1fa0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10f3e247f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10e932367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10e9dd82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10e9de2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10efc7ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10de781c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10de78bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10f00fcd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10f00fe1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x650203 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10dca7374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x112fa4f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1100834c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10d4bd4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x650204 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x650207 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10dca7374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10f14d2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1101aa3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10de781c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10de78bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x650209 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x65020c Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x65020d Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6574d5 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x65bed1 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x65bed2 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x65bed3 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x65bed4 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x65bed5 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x65c46f Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10dca7374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10e100eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10e100f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10ef49e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10d4bd4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa05d2 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10dca7374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10e100e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10e100efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10ef49e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10d4bd4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x103a69000 - 0x103a99fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10d1f7000 - 0x117d0cfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [14325] [unique pid 113930] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 120.14 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (500.5K cycles, 107.7K instructions, 4.65c/i) Note: 2 idle work queue threads omitted Thread 0x68227c DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (300.8K cycles, 69.9K instructions, 4.30c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10fef190c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10ff500b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11213847f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x111688367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11173382f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1117342f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x111d1def0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x110bce1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x110bcebf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x111d65cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x111d65e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68229a Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1109fd374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x115cfaf88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x112dd94c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1102134fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68229c Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x68229e Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) cpu time <0.001s (50.9K cycles, 7.1K instructions, 7.12c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1109fd374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x110e56eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x110e56f2d] 1-11 2 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111c9fe33] 1-2 2 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1102134fd] 1-2 2 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-2 *2 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-2 9 ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x111c9f555] 3-11 9 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 3-11 *9 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 3-11 Thread 0x6822a0 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1109fd374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x111ea32f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x112f003f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x110bce1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x110bcebf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6822a1 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6822a2 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6822a3 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682403 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682404 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682405 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682406 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682407 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682f23 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa07de Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1109fd374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x110e56e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x110e56efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111c9fe33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1102134fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10fef0000 - 0x10ff20fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10ff4d000 - 0x11aa62fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [14326] [unique pid 113931] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 105.42 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (60.1K cycles, 7.1K instructions, 8.48c/i) Note: 1 idle work queue thread omitted Thread 0x682402 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10467990c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1046d80b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1068c047f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x105e10367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x105ebb82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x105ebc2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1064a5ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1053561c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x105356bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x1064edcd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x1064ede1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682412 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (60.1K cycles, 7.1K instructions, 8.48c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x105185374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10a482f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1075614c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10499b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682413 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x682415 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x105185374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1055deeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1055def2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x106427e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10499b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682416 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x105185374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10662b2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1076883f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1053561c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x105356bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x682418 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682419 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68241a Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682528 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682529 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x68252a Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x68252b Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x68252c Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682f39 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f663 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x105185374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1055dee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1055deefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x106427e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10499b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104678000 - 0x1046a8fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x1046d5000 - 0x10f1eafff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [14354] [unique pid 113959] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 94.99 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x68260e DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10a27390c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10a2d20b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10c4ba47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10ba0a367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10bab582f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10bab62f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10c09fef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10af501c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10af50bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10c0e7cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10c0e7e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68261a Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10ad7f374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11007cf88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10d15b4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10a5954fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68261b Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x68261d Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10ad7f374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10b1d8eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10b1d8f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10c021e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10a5954fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68261e Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10ad7f374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10c2252f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10d2823f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10af501c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10af50bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x682620 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682621 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682622 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682696 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682697 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682698 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682699 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x68269a Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x685740 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9fd4f Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10ad7f374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10b1d8e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10b1d8efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10c021e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10a5954fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a272000 - 0x10a2a2fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10a2cf000 - 0x114de4fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [14355] [unique pid 113960] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 126.03 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (388.0K cycles, 93.1K instructions, 4.17c/i) Note: 2 idle work queue threads omitted Thread 0x682695 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (213.0K cycles, 51.0K instructions, 4.18c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x108cbb90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10d5830b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10f76b47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10ecbb367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10ed6682f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10ed672f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10f350ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10e2011c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10e201bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10f398cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10f398e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6826a2 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (59.1K cycles, 6.8K instructions, 8.65c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e030374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11332df88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x11040c4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10d8464fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6826a3 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6826a5 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e030374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10e489eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10e489f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10f2d2e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10d8464fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6826a6 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e030374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10f4d62f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1105333f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10e2011c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10e201bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6826a9 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6826aa Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6826ab Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682757 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682758 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682759 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x68275a Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x68275b Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6831a1 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9ffb3 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e030374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10e489e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10e489efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10f2d2e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10d8464fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108cba000 - 0x108ceafff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10d580000 - 0x118095fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [14360] [unique pid 113965] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 122.16 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (358.9K cycles, 93.1K instructions, 3.85c/i) Note: 2 idle work queue threads omitted Thread 0x682756 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (233.4K cycles, 59.0K instructions, 3.95c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10897790c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1089d60b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10abbe47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10a10e367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10a1b982f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10a1ba2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10a7a3ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1096541c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x109654bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10a7ebcd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10a7ebe1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68276d Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109483374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10e780f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10b85f4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x108c994fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68276e Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x682770 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109483374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1098dceab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1098dcf2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10a725e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x108c994fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682771 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109483374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10a9292f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10b9863f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1096541c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x109654bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x682773 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682774 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682775 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x682d51 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682d52 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682d53 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682d54 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x682d55 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x684025 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa8cf15 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109483374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1098dce82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1098dcefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10a725e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x108c994fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108976000 - 0x1089a6fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x1089d3000 - 0x1134e8fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [14399] [unique pid 114004] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 126.19 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (374.7K cycles, 97.6K instructions, 3.84c/i) Note: 2 idle work queue threads omitted Thread 0x684744 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (229.9K cycles, 59.5K instructions, 3.87c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1079ff90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x107a5e0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x109c4647f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x109196367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10924182f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1092422f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10982bef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1086dc1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1086dcbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x109873cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x109873e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x684756 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10850b374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10d808f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10a8e74c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x107d214fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x684757 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x684759 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10850b374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x108964eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x108964f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1097ade33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x107d214fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68475a Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10850b374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1099b12f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10aa0e3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1086dc1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1086dcbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x68475c Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68475d Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x68475e Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x684976 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x684977 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x684978 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x684979 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x68497a Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x684e2b Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f29d Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10850b374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x108964e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x108964efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1097ade33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x107d214fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1079fe000 - 0x107a2efff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x107a5b000 - 0x112570fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [15092] [unique pid 114696] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 156.37 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6e2029 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10ef0e90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1101e20b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1123ca47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x11191a367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1119c582f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1119c62f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x111fafef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x110e601c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x110e60bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x111ff7cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x111ff7e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6e203e Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110c8f374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x115f8cf88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x11306b4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1104a54fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6e2040 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6e2042 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110c8f374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1110e8eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1110e8f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111f31e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1104a54fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6e2043 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110c8f374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1121352f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1131923f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x110e601c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x110e60bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6e2045 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6e2047 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6e2048 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6e2670 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x742ad3 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x742ad4 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x742ad5 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x742ad6 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x742ad7 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa9fcb2 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x110c8f374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1110e8e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1110e8efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x111f31e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1104a54fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10ef0d000 - 0x10ef3dfff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x1101df000 - 0x11acf4fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [29530] [unique pid 129122] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 303.31 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7f56b4 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10aac190c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x110f940b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11317c47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x1126cc367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11277782f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1127782f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x112d61ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x111c121c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x111c12bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x112da9cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x112da9e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f56d1 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x111a41374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x116d3ef88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x113e1d4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1112574fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f56d2 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x7f56d4 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x111a41374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x111e9aeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x111e9af2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x112ce3e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1112574fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f56d5 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x111a41374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x112ee72f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x113f443f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x111c121c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x111c12bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x7f56d7 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f56d8 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f56d9 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f5985 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f5986 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f5987 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f5988 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f5989 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f6c36 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0304 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x111a41374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x111e9ae82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x111e9aefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x112ce3e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1112574fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10aac0000 - 0x10aaf0fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x110f91000 - 0x11baa6fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [29532] [unique pid 129124] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 94.93 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (363.5K cycles, 96.6K instructions, 3.76c/i) Note: 2 idle work queue threads omitted Thread 0x7f5983 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (197.1K cycles, 55.0K instructions, 3.59c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10217390c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10ae570b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10d03f47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10c58f367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10c63a82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10c63b2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10cc24ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10bad51c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10bad5bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10cc6ccd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10cc6ce1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f598f Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10b904374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x110c01f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10dce04c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10b11a4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f5990 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x7f5992 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10b904374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10bd5deab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10bd5df2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10cba6e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10b11a4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f5993 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10b904374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10cdaa2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10de073f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10bad51c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10bad5bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x7f5995 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f5996 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f5997 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f63d0 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f63d1 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f63d2 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f63d3 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f63d4 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f728b Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa93661 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10b904374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10bd5de82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10bd5defd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10cba6e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10b11a4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102172000 - 0x1021a2fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10ae54000 - 0x115969fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [29539] [unique pid 129131] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 48.64 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7f63cf DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10aafc90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x11232b0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11451347f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x113a63367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x113b0e82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x113b0f2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1140f8ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x112fa91c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x112fa9bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x114140cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x114140e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f63dc Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112dd8374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1180d5f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1151b44c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1125ee4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f63dd Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x7f63df Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112dd8374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x113231eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x113231f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11407ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1125ee4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f63e0 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112dd8374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x11427e2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1152db3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x112fa91c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x112fa9bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x7f63e2 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f63e3 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f63e4 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7f64ca Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f64cb Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f64cc Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f64cd Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7f64ce Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x83064b Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9fb2b Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112dd8374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x113231e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x113231efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11407ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1125ee4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10aafb000 - 0x10ab2bfff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x112328000 - 0x11ce3dfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [29888] [unique pid 129480] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 312.07 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7ffc4d DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10310490c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1031630b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10534b47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10489b367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10494682f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1049472f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x104f30ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x103de11c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x103de1bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x104f78cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x104f78e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7ffc5c Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x103c10374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x108f0df88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x105fec4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1034264fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7ffc5d Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x7ffc5f Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x103c10374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x104069eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x104069f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x104eb2e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1034264fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7ffc61 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x103c10374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1050b62f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1061133f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x103de11c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x103de1bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x7ffc62 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7ffc64 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7ffc65 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x800f3d Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x800f3e Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x800f3f Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x800f40 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x800f41 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x802374 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0698 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x103c10374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x104069e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x104069efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x104eb2e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1034264fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x103103000 - 0x103133fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x103160000 - 0x10dc75fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [34828] [unique pid 134420] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 405.33 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (1121.4K cycles, 263.1K instructions, 4.26c/i) Note: 2 idle work queue threads omitted Thread 0x853862 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (755.7K cycles, 165.2K instructions, 4.58c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x108a6a90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x11177c0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11396447f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x112eb4367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x112f5f82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x112f602f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x113549ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1123fa1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1123fabf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x113591cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x113591e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x85387a Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112229374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x117526f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1146054c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x111a3f4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x85387b Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112229374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1136cf2f5] 1-11 11 ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x1145feeb8] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1123fa1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1123fabf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x85387e Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112229374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1136cf2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x11472c3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1123fa1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1123fabf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x853880 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x853881 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x853882 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112229374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x112682eba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x1126831dd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1134cbe33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x111a3f4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x853887 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x853888 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x853889 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x85388a Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x85388b Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x85398c Thread name "Media" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x853c1e Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x854550 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112229374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x112682eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x112682f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1134cbe33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x111a3f4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x858470 Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x85848d Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x85848e Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x85849d Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9ab4b Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x112229374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x112682e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x112682efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1134cbe33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x111a3f4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108a69000 - 0x108a99fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x111779000 - 0x11c28efff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [34829] [unique pid 134421] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 47.85 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x853886 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x109c4490c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10b7f90b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10d9e147f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10cf31367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10cfdc82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10cfdd2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10d5c6ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10c4771c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10c477bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10d60ecd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10d60ee1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x853894 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c2a6374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1115a3f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10e6824c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10babc4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x853895 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x853897 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c2a6374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10c6ffeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10c6fff2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10d548e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10babc4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x853898 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c2a6374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10d74c2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10e7a93f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10c4771c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10c477bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x85389a Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x85389b Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x85389c Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8538c1 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8538c2 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8538c3 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8538c4 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8538c5 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x853c1f Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa87321 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10c2a6374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10c6ffe82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10c6ffefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10d548e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10babc4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x109c43000 - 0x109c73fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10b7f6000 - 0x11630bfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [34831] [unique pid 134423] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 64.18 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x8538c0 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10290190c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x102bce0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x104db647f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x104306367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1043b182f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1043b22f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10499bef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10384c1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10384cbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x1049e3cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x1049e3e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8538d6 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10367b374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x108978f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x105a574c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x102e914fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8538d7 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x8538d9 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10367b374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x103ad4eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x103ad4f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10491de33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x102e914fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8538da Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10367b374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x104b212f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x105b7e3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10384c1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10384cbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x8538dc Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8538df Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8538e0 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x853a84 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x853a85 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x853a86 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x853a87 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x853a88 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x853aa3 Thread name "ThreadPoolSingleThreadSharedForeground1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x853c20 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa7c1c5 Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10367b374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10391b914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10384c1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10384cbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x105a38d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x102e914fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9fb25 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10367b374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x103ad4e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x103ad4efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10491de33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x102e914fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102900000 - 0x102930fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x102bcb000 - 0x10d6e0fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [35669] [unique pid 135261] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 126.52 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x861576 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10a41e90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10f9600b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x111b4847f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x111098367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x11114382f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1111442f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x11172def0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1105de1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1105debf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x111775cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x111775e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x861589 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11040d374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11570af88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1127e94c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fc234fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x86158a Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x86158c Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11040d374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x110866eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x110866f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1116afe33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fc234fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x86158d Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11040d374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1118b32f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1129103f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1105de1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1105debf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x86158f Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x861590 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x861591 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x861720 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x861721 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x861722 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x861723 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x861724 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8623ed Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa069c Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x11040d374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x110866e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x110866efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x1116afe33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10fc234fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a41d000 - 0x10a44dfff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10f95d000 - 0x11a472fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [35813] [unique pid 135405] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 259.60 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x868bc1 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x104ed290c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10a8250b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10ca0d47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10bf5d367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10c00882f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10c0092f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10c5f2ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10b4a31c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10b4a3bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10c63acd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10c63ae1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x868bce Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10b2d2374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1105cff88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10d6ae4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10aae84fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x868bcf Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x868bd1 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10b2d2374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10b72beab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10b72bf2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10c574e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10aae84fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x868bd2 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10b2d2374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10c7782f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10d7d53f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10b4a31c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10b4a3bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x868bd4 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x868bd5 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x868bd6 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x869739 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x86973a Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x86973b Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x86973c Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x86973d Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x86a673 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa8e13d Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10b2d2374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10b72be82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10b72befd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10c574e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10aae84fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104ed1000 - 0x104f01fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10a822000 - 0x115337fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [36177] [unique pid 135769] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 300.11 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (1171.1K cycles, 249.6K instructions, 4.69c/i) Note: 1 idle work queue thread omitted Thread 0x87c39d DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (663.9K cycles, 142.7K instructions, 4.65c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10159290c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10c6240b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10e80c47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10dd5c367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10de0782f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10de082f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10e3f1ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d2a21c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d2a2bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10e439cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10e439e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x87c3b2 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d0d1374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1123cef88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10f4ad4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c8e74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x87c3b3 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d0d1374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e5772f5] 1-11 11 ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x10f4a6eb8] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d2a21c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d2a2bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x87c3b5 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d0d1374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10d52aeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10d52af2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e373e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c8e74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x87c3b6 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (90.4K cycles, 21.3K instructions, 4.24c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d0d1374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e5772f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10f5d43f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d2a21c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d2a2bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x87c3b9 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x87c3bb Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x87c3bc Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d0d1374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x10d52aeba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x10d52b1dd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e373e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c8e74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x87c3bf Thread name "WebCrypto" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d0d1374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10e5772f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x10e577598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10d2a21c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10d2a2bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10f48ed7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c8e74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x87c401 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x87c402 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x87c403 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x87c404 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x87c405 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x87cddf Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9e820 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d0d1374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10d52ae82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10d52aefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e373e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c8e74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9fd55 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (78.9K cycles, 14.4K instructions, 5.49c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10d0d1374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10d52ae82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10d52aefd] 1-11 10 ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x10e373555] 1-10 10 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-10 *10 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-10 1 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10e373e33] 11 1 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10c8e74fd] 11 1 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 11 *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 11 Binary Images: 0x101591000 - 0x1015c1fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10c621000 - 0x117136fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [43546] [unique pid 143135] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 254.25 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (1164.6K cycles, 264.1K instructions, 4.41c/i) Note: 1 idle work queue thread omitted Thread 0x8d4bb9 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (740.6K cycles, 155.1K instructions, 4.77c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10e9e090c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x11642d0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11861547f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x117b65367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x117c1082f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x117c112f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1181faef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1170ab1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1170abbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x118242cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x118242e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8d4bcd Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x116eda374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x11c1d7f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1192b64c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1166f04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8d4bce Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x8d4bd0 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x116eda374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x117333eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x117333f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11817ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1166f04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8d4bd1 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x116eda374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1183802f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1193dd3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1170ab1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1170abbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x8d4bd3 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8d4bd5 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x116eda374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x11717a914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1170ab1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x1170abbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x119297d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1166f04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8d4bd6 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8d4cc6 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8d4cc7 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8d4cc8 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8d4cc9 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8d4cca Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x8d4d0d Thread name "Media" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8d5787 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f6b4 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x116eda374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x117333e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x117333efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x11817ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1166f04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0880 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x116eda374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x117333e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x117333efd] 1-11 11 ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x11817bbab] 1-11 11 ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x1166f0149] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1166f04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e9df000 - 0x10ea0ffff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x11642a000 - 0x120f3ffff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [53802] [unique pid 153387] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 101.90 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x9139c2 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x101f3b90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x101f9a0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10418247f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x1036d2367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10377d82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10377e2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x103d67ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x102c181c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x102c18bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x103dafcd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x103dafe1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9139d7 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x102a47374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x107d44f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x104e234c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10225d4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9139d8 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x9139da Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x102a47374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x102ea0eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x102ea0f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x103ce9e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10225d4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9139db Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x102a47374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x103eed2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x104f4a3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x102c181c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x102c18bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x9139de Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9139e0 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9139e1 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x913a89 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x913a8a Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x913a8b Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x913a8c Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x913a8d Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x913d1e Thread name "ThreadPoolSingleThreadSharedForeground1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x91479c Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa92695 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x102a47374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x102ea0e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x102ea0efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x103ce9e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10225d4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101f3a000 - 0x101f6afff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x101f97000 - 0x10caacfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [55592] [unique pid 155177] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 460.44 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (1152.0K cycles, 257.3K instructions, 4.48c/i) Note: 2 idle work queue threads omitted Thread 0x932fd9 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (770.5K cycles, 155.1K instructions, 4.97c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1094cf90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10952e0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10b71647f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10ac66367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10ad1182f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10ad122f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10b2fbef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10a1ac1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10a1acbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10b343cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10b343e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x932fec Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10f2d8f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10c3b74c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1097f14fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x932fed Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x932fef Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10a434eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10a434f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10b27de33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1097f14fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x932ff0 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10b4812f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10c4de3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10a1ac1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10a1acbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x932ff2 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x932ff3 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10a27b914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10a1ac1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10a1acbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10c398d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1097f14fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x932ff4 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x93300b Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x11181f037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x1098c8f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x93300c Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x11181f037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x1098c8f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x93300d Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x11181f037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x1098c8f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x93300e Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x11181f037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x1098c8f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x93300f Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x933054 Thread name "Media" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x933bbf Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f8aa Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10a434e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10a434efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10b27de33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1097f14fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa087f Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109fdb374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10a434e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10a434efd] 1-11 11 ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x10b27cbab] 1-11 11 ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x1097f1149] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1097f14fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1094ce000 - 0x1094fefff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10952b000 - 0x114040fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [56287] [unique pid 155872] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 93.56 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (333.0K cycles, 89.6K instructions, 3.71c/i) Note: 2 idle work queue threads omitted Thread 0x9587c4 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (227.8K cycles, 58.9K instructions, 3.87c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x1042ac90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10430b0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1064f347f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x105a43367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x105aee82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x105aef2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1060d8ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x104f891c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x104f89bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x106120cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x106120e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9587d4 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x104db8374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10a0b5f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1071944c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1045ce4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9587d5 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x9587d7 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x104db8374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x105211eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x105211f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10605ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1045ce4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9587d8 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x104db8374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10625e2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1072bb3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x104f891c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x104f89bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x9587da Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9587db Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9587dc Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x958a9e Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x958a9f Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x958aa0 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x958aa1 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x958aa2 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x959e86 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa067f Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x104db8374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x105211e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x105211efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10605ae33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1045ce4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1042ab000 - 0x1042dbfff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x104308000 - 0x10ee1dfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [56288] [unique pid 155873] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 183.12 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (824.1K cycles, 216.4K instructions, 3.81c/i) Note: 1 idle work queue thread omitted Thread 0x958a9d DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (639.1K cycles, 177.1K instructions, 3.61c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10138490c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1072fd0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1094e547f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x108a35367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x108ae082f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x108ae12f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1090caef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x107f7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107f7bbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x109112cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x109112e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x958aae Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10d0a7f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10a1864c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1075c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x958aaf Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x958ab1 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x108203eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x108203f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10904ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1075c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x958ab2 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1092502f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10a2ad3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x107f7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107f7bbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x958ab4 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x958ab5 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10804a914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x107f7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107f7bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10a167d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1075c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x958ab6 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x96271e Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x10f5ee037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x107697f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x96271f Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x962720 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x10f5ee037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x107697f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x962721 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x10f5ee037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x107697f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x962722 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x963f0d Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x99cd5a Thread name "ThreadPoolSingleThreadSharedForeground1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x108203eba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x1082041dd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10904ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1075c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa8dfcd Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10804a914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x107f7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107f7bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10a167d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1075c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9d6d4 Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10804a914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x107f7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107f7bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10a167d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1075c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa07ca Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x108203e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x108203efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10904ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1075c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa07cb Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x108203e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x108203efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10904ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1075c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa07ce Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107daa374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10804a914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x107f7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x107f7bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10a167d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1075c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101383000 - 0x1013b3fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x1072fa000 - 0x111e0ffff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [56437] [unique pid 156022] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 83.28 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x96271d DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10a42f90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10a48e0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10c67647f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10bbc6367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10bc7182f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10bc722f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10c25bef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10b10c1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10b10cbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10c2a3cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10c2a3e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x962728 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10af3b374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x110238f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10d3174c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10a7514fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x962729 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x96272b Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10af3b374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10b394eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10b394f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10c1dde33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10a7514fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x96272d Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10af3b374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10c3e12f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10d43e3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10b10c1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10b10cbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x96272e Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x96272f Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x962730 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x96b2ca Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9703e2 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x9703e3 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x9703e4 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x9703e5 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x9703e6 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa9366b Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10af3b374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10b394e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10b394efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10c1dde33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10a7514fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a42e000 - 0x10a45efff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10a48b000 - 0x114fa0fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [56647] [unique pid 156232] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 90.66 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x9703df DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10a75190c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1116010b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1137e947f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x112d39367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x112de482f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x112de52f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1133ceef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x11227f1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x11227fbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x113416cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x113416e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9703f4 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1120ae374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x1173abf88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x11448a4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1118c44fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9703f5 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1120ae374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1135542f5] 1-11 11 ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x114483eb8] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x11227f1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x11227fbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x9703f7 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1120ae374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x112507eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x112507f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x113350e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1118c44fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9703f8 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1120ae374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1135542f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1145b13f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x11227f1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x11227fbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x9703fa Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9703fc Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9703fd Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1120ae374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x112507eba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x1125081dd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x113350e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1118c44fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9aa8b4 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa02514 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa02515 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa02516 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa02517 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa02518 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa9ff39 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x1120ae374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x112507e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x112507efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x113350e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1118c44fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a750000 - 0x10a780fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x1115fe000 - 0x11c113fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [62957] [unique pid 162540] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 194.76 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (3.1M cycles, 1029.3K instructions, 2.99c/i) Note: 1 idle work queue thread omitted Thread 0xa4cc9c DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (669.1K cycles, 155.2K instructions, 4.31c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10d76e90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10defd0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1100e547f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10f635367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10f6e082f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10f6e12f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10fccaef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10eb7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10eb7bbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10fd12cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10fd12e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4ccab Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e9aa374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x113ca7f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x110d864c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4ccac Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa4ccae Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e9aa374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10ee03eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10ee03f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10fc4ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4ccaf Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (332.8K cycles, 85.5K instructions, 3.89c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e9aa374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10fe502f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x110ead3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10eb7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10eb7bbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa4ccb1 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4ccbb Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e9aa374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10ec4a914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10eb7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10eb7bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x110d67d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4ccbc Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e9aa374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x10ee03eba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x10ee041dd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10fc4ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4ce77 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4ce78 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4ce79 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4ce7a Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4ce7b Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa4cec9 Thread name "Media" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4e187 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e9aa374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10fe502f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x10fe50598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10eb7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10eb7bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x110d67d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f299 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e9aa374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10ee03e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10ee03efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10fc4ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa064b Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e9aa374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10ee03e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10ee03efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10fc4ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa091c Thread name "ServiceWorker thread" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (1700.9K cycles, 673.5K instructions, 2.53c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10e9aa374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10ec4a914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10eb7b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10eb7bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x110d67d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10e1c04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d76d000 - 0x10d79dfff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10defa000 - 0x118a0ffff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [66140] [unique pid 165723] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 482.62 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.009s (41.4M cycles, 34.7M instructions, 1.19c/i) Note: 1 idle work queue thread omitted Thread 0xa74570 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time 0.008s (37.2M cycles, 33.4M instructions, 1.11c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10f1f990c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x10f2580b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x11144047f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x110990367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x110a3b82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x110a3c2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x111025ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10fed61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10fed6bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x11106dcd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x11106de1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa7457c Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x115002f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1120e14c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa7457d Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1111ab2f5] 1-11 11 ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x1120daeb8] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10fed61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10fed6bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa7457f Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x11015eeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x11015ef2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa74580 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (1789.5K cycles, 539.2K instructions, 3.32c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1111ab2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x1122083f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10fed61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10fed6bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa74582 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1111ab2f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x1111ab598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10fed61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10fed6bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x1120c2d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa74583 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10ffa5914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10fed61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10fed6bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x1120c2d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa74584 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x11015eeba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x11015f1dd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa7459a Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x117549037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x10f5f2f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa7459b Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x117549037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x10f5f2f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa7459c Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x117549037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x10f5f2f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa7459d Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x117549037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x10f5f2f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa7459e Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa745e7 Thread name "Media" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1111ab2f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x1111ab598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10fed61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10fed6bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x1120c2d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa75470 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1111ab2f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x1111ab598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10fed61c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10fed6bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x1120c2d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa7b2ca Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11015ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11015eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa7eba4 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11015ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11015eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0932 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11015ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11015eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0933 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (1590.6K cycles, 642.6K instructions, 2.48c/i) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11015ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11015eefd] 1-11 2 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-2 2 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-2 2 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-2 *2 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-2 9 ChromeMain + 30733925 (Google Chrome Framework + 30745941) [0x110fa7555] 3-11 9 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 3-11 *9 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 3-11 Thread 0xaa0934 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11015ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11015eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0935 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11015ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11015eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0936 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10fd05374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x11015ee82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x11015eefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x110fa7e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10f51b4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f1f8000 - 0x10f228fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x10f255000 - 0x119d6afff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [67230] [unique pid 166813] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 36.06 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa935a0 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10150890c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1074040b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x1095ec47f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x108b3c367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x108be782f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x108be82f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1091d1ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1080821c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x108082bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x109219cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x109219e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa935af Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107eb1374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10d1aef88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10a28d4c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1076c74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa935b0 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa935b2 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107eb1374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10830aeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10830af2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x109153e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1076c74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa935b3 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107eb1374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1093572f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10a3b43f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1080821c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x108082bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa935b5 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa935b6 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa935b7 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107eb1374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x10830aeba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x10830b1dd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x109153e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1076c74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa935ba Thread name "ServiceWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107eb1374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x108151914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x1080821c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x108082bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10a26ed7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1076c74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f263 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107eb1374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10830ae82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10830aefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x109153e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1076c74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9fb4e Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107eb1374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10830ae82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10830aefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x109153e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1076c74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0938 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x107eb1374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10830ae82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10830aefd] 1-11 11 ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x109152bab] 1-11 11 ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x1076c7149] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x1076c74fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101507000 - 0x101537fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x107401000 - 0x111f16fff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [67409] [unique pid 166992] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 113.04 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (897.5K cycles, 205.8K instructions, 4.36c/i) Note: 1 idle work queue thread omitted Thread 0xaa0533 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (580.0K cycles, 135.1K instructions, 4.29c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10097e90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1009dd0b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x102bc547f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x102115367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x1021c082f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x1021c12f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x1027aaef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10165b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10165bbf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x1027f2cd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x1027f2e1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0541 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x106787f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x1038664c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0542 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1029302f5] 1-11 11 ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x10385feb8] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10165b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10165bbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xaa0543 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1018e3e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1018e3efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10272ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0544 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x1018e3eab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x1018e3f2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10272ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0545 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1029302f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10398d3f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10165b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10165bbf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xaa0546 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1018e3e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1018e3efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10272ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0547 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x1029302f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x102930598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10165b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10165bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x103847d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0548 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10172a914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10165b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10165bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x103847d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0549 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x1018e3eba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x1018e41dd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10272ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa076c Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x108cce037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x100d77f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xaa076d Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x108cce037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x100d77f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xaa076e Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x108cce037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x100d77f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xaa076f Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x108cce037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x100d77f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xaa0770 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 137302343 (Google Chrome Framework + 137314359) [0x108cce037] 1-11 11 ChromeMain + 3780733 (Google Chrome Framework + 3792749) [0x100d77f6d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xaa0794 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1018e3e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1018e3efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10272ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0795 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1018e3e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1018e3efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10272ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0796 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1018e3e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1018e3efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10272ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa07a5 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1018e3e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1018e3efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10272ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa07a6 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x1018e3e82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x1018e3efd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10272ce33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa09cc Thread name "ServiceWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x10148a374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x10172a914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x10165b1c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x10165bbf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x103847d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x100ca04fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10097d000 - 0x1009adfff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x1009da000 - 0x10b4effff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Google Chrome Helper (Renderer) [67410] [unique pid 166993] UUID: 4C4C44A9-5555-3144-A132-36D8EA20CB02 Path: /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) Architecture: x86_64 Parent: Google Chrome [721] Responsible: Google Chrome [721] UID: 504 Footprint: 17.32 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xaa076b DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 252 (Google Chrome Helper (Renderer) + 6412) [0x10915a90c] 1-11 11 ChromeMain + 453 (Google Chrome Framework + 12469) [0x1091b90b5] 1-11 11 ChromeMain + 35554703 (Google Chrome Framework + 35566719) [0x10b3a147f] 1-11 11 ChromeMain + 24347767 (Google Chrome Framework + 24359783) [0x10a8f1367] 1-11 11 ChromeMain + 25049407 (Google Chrome Framework + 25061423) [0x10a99c82f] 1-11 11 ChromeMain + 25052165 (Google Chrome Framework + 25064181) [0x10a99d2f5] 1-11 11 ChromeMain + 31252480 (Google Chrome Framework + 31264496) [0x10af86ef0] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x109e371c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x109e37bf6] 1-11 11 ChromeMain + 31546852 (Google Chrome Framework + 31558868) [0x10afcecd4] 1-11 11 ChromeMain + 31547182 (Google Chrome Framework + 31559198) [0x10afcee1e] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0777 Thread name "HangWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109c66374] 1-11 11 ChromeMain + 98218136 (Google Chrome Framework + 98230152) [0x10ef63f88] 1-11 11 ChromeMain + 48797143 (Google Chrome Framework + 48809159) [0x10c0424c7] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10947c4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0778 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109c66374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10b10c2f5] 1-11 11 ChromeMain + 48771016 (Google Chrome Framework + 48783032) [0x10c03beb8] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x109e371c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x109e37bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xaa0779 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109c66374] 1-11 11 ChromeMain + 15757202 (Google Chrome Framework + 15769218) [0x10a0bfe82] 1-11 11 ChromeMain + 15757325 (Google Chrome Framework + 15769341) [0x10a0bfefd] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10af08e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10947c4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa077a Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109c66374] 1-11 11 ChromeMain + 15757243 (Google Chrome Framework + 15769259) [0x10a0bfeab] 1-11 11 ChromeMain + 15757373 (Google Chrome Framework + 15769389) [0x10a0bff2d] 1-11 11 ChromeMain + 30736195 (Google Chrome Framework + 30748211) [0x10af08e33] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10947c4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa077b Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109c66374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10b10c2f5] 1-11 11 ChromeMain + 50005249 (Google Chrome Framework + 50017265) [0x10c1693f1] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x109e371c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x109e37bf6] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xaa077d Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109c66374] 1-11 11 ChromeMain + 32846853 (Google Chrome Framework + 32858869) [0x10b10c2f5] 1-11 11 ChromeMain + 32847528 (Google Chrome Framework + 32859544) [0x10b10c598] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x109e371c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x109e37bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10c023d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10947c4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa077e Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109c66374] 1-11 11 ChromeMain + 13949476 (Google Chrome Framework + 13961492) [0x109f06914] 1-11 11 ChromeMain + 13099732 (Google Chrome Framework + 13111748) [0x109e371c4] 1-11 11 ChromeMain + 13102342 (Google Chrome Framework + 13114358) [0x109e37bf6] 1-11 11 ChromeMain + 48672398 (Google Chrome Framework + 48684414) [0x10c023d7e] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10947c4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa077f Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ChromeMain + 11195524 (Google Chrome Framework + 11207540) [0x109c66374] 1-11 11 ChromeMain + 15757258 (Google Chrome Framework + 15769274) [0x10a0bfeba] 1-11 11 ChromeMain + 15758061 (Google Chrome Framework + 15770077) [0x10a0c01dd] 1-11 11 ChromeMain + 30731451 (Google Chrome Framework + 30743467) [0x10af07bab] 1-11 11 ChromeMain + 2896473 (Google Chrome Framework + 2908489) [0x10947c149] 1-11 11 ChromeMain + 2897421 (Google Chrome Framework + 2909437) [0x10947c4fd] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x109159000 - 0x109189fff com.google.Chrome.helper.renderer 108.0.5359.124 (5359.124) <4C4C44A9-5555-3144-A132-36D8EA20CB02> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) 0x1091b6000 - 0x113ccbfff com.google.Chrome.framework 108.0.5359.124 (5359.124) <4C4C4475-5555-3144-A123-1586F8E96E56> /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/108.0.5359.124/Google Chrome Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: GSSCred [248] UUID: 6C0101E1-3D7A-3EBC-9C9A-1E99785A9E97 Path: /System/Library/Frameworks/GSS.framework/Helpers/GSSCred Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 864 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x73b 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __read_nocancel + 10 (libsystem_kernel.dylib + 8634) [0x7fff60fd11ba] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4319092) [0xffffff800061e774] 1-11 *11 spec_read + 672 (kernel + 4425648) [0xffffff80006387b0] 1-11 *11 ??? (kernel + 6732104) [0xffffff800086b948] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x73d 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x104e27000 - 0x104e2efff GSSCred (520.270.8) <6C0101E1-3D7A-3EBC-9C9A-1E99785A9E97> /System/Library/Frameworks/GSS.framework/Helpers/GSSCred 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: helpd [61016] [unique pid 160599] UUID: C6A58A15-0037-3B3D-B0C3-B72275B8BCCE Path: /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1252 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa223fa 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10bb8d000 - 0x10bba3fff helpd <C6A58A15-0037-3B3D-B0C3-B72275B8BCCE> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: hidd [109] UUID: 44A8BE5C-4536-36D0-BA5B-E63674BACEC1 Path: /usr/libexec/hidd Architecture: x86_64 Parent: launchd [1] UID: 261 Sudden Term: Tracked Footprint: 3956 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.003s (12.4M cycles, 3.0M instructions, 4.10c/i) Note: 1 idle work queue thread omitted Thread 0x350 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (761.0K cycles, 308.8K instructions, 2.46c/i) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (hidd + 3707) [0x10b6dde7b] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x377 Thread name "IOHIDService - RunLoopCompatibilityThread" 11 samples (1-11) priority 63 (base 63) <process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa093b 11 samples (1-11) priority 63 (base 63) cpu time 0.001s (6.2M cycles, 1764.3K instructions, 3.53c/i) <process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _dispatch_worker_thread + 317 (libdispatch.dylib + 70141) [0x7fff60e5c1fd] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xaa0aaa 11 samples (1-11) priority 63 (base 63) <process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _dispatch_worker_thread + 317 (libdispatch.dylib + 70141) [0x7fff60e5c1fd] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Binary Images: 0x10b6dd000 - 0x10b6ddfff hidd (1090.270.7) <44A8BE5C-4536-36D0-BA5B-E63674BACEC1> /usr/libexec/hidd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: icdd [415] UUID: 41A04085-D015-3C46-9A05-D8FC965CB04E Path: /System/Library/Image Capture/Support/icdd Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 6800 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe71 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10253f000 - 0x10256efff icdd (1534.2) <41A04085-D015-3C46-9A05-D8FC965CB04E> /System/Library/Image Capture/Support/icdd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: iconservicesagent [293] UUID: 420F1282-060C-39EB-A7D6-811DF569A396 Path: /System/Library/CoreServices/iconservicesagent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 20.11 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (397.7K cycles, 105.2K instructions, 3.78c/i) Note: 2 idle work queue threads omitted Thread 0x87e DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x102f16000 - 0x102f20fff iconservicesagent <420F1282-060C-39EB-A7D6-811DF569A396> /System/Library/CoreServices/iconservicesagent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: iconservicesagent [467] UUID: 420F1282-060C-39EB-A7D6-811DF569A396 Path: /System/Library/CoreServices/iconservicesagent Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 3732 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1264 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10c7d4000 - 0x10c7defff iconservicesagent <420F1282-060C-39EB-A7D6-811DF569A396> /System/Library/CoreServices/iconservicesagent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: iconservicesd [76] UUID: 75B2D7C4-6817-3480-B918-B3DE935AFB2C Path: /System/Library/CoreServices/iconservicesd Architecture: x86_64 Parent: launchd [1] UID: 240 Sudden Term: Tracked (allows idle exit) Footprint: 2728 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x63e DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x108c24000 - 0x108c27fff iconservicesd <75B2D7C4-6817-3480-B918-B3DE935AFB2C> /System/Library/CoreServices/iconservicesd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: identityservicesd [298] UUID: 07ED13B5-6D42-3B16-9DB1-1779485312B5 Path: /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 11.46 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x88c DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 299 (identityservicesd + 422411) [0x10dd3620b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8f1 Thread name "TransportThread Primary" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x8f2 Thread name "TransportThread URGENT" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x8f3 Thread name "TransportThread Default" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x8f4 Thread name "TransportThread Sync" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Binary Images: 0x10dccf000 - 0x10e194fff com.apple.identityservicesd 10.0 (1000) <07ED13B5-6D42-3B16-9DB1-1779485312B5> /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: imagent [299] UUID: A38E8E09-3273-3AC5-9479-F1EC3EBBA71D Path: /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 3896 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x89f 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b891000 - 0x10b8f1fff com.apple.imagent 10.0 (1000) <A38E8E09-3273-3AC5-9479-F1EC3EBBA71D> /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: IMAutomaticHistoryDeletionAgent [4392] UUID: 7CC6C869-9E8D-33C3-8EE2-CF3D0A794CA9 Path: /System/Library/PrivateFrameworks/IMDPersistence.framework/IMAutomaticHistoryDeletionAgent.app/Contents/MacOS/IMAutomaticHistoryDeletionAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 2520 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x5372c 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x108d47000 - 0x108d49fff IMAutomaticHistoryDeletionAgent <7CC6C869-9E8D-33C3-8EE2-CF3D0A794CA9> /System/Library/PrivateFrameworks/IMDPersistence.framework/IMAutomaticHistoryDeletionAgent.app/Contents/MacOS/IMAutomaticHistoryDeletionAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: IMDPersistenceAgent [303] UUID: F025E7EE-121F-3FAD-AC0D-6A14F0DD95C5 Path: /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 3396 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x8bc 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10ec45000 - 0x10ec46fff com.apple.imdpersistence.IMDPersistenceAgent 10.0 (1000) <F025E7EE-121F-3FAD-AC0D-6A14F0DD95C5> /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: imklaunchagent [354] UUID: 0DEB181A-D95C-3FB2-926D-5ECE7C36F322 Path: /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 3140 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xaf5 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (imklaunchagent + 26159) [0x1048bc62f] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1048b6000 - 0x1048c2fff imklaunchagent (365.26) <0DEB181A-D95C-3FB2-926D-5ECE7C36F322> /System/Library/Frameworks/InputMethodKit.framework/Versions/A/Resources/imklaunchagent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: IMRemoteURLConnectionAgent [399] UUID: 8026AD1F-C961-3EC6-8EC9-677A5DB83984 Path: /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent Architecture: x86_64 Parent: launchd [1] Responsible: callservicesd [296] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1096 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xded 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1062c9000 - 0x1062d3fff com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <8026AD1F-C961-3EC6-8EC9-677A5DB83984> /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: IMRemoteURLConnectionAgent [42202] UUID: 8026AD1F-C961-3EC6-8EC9-677A5DB83984 Path: /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent Architecture: x86_64 Parent: launchd [1] Responsible: avconferenced [42201] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 3036 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x35e776 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x35e77a Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10c53e000 - 0x10c548fff com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <8026AD1F-C961-3EC6-8EC9-677A5DB83984> /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: IMRemoteURLConnectionAgent [44143] UUID: 8026AD1F-C961-3EC6-8EC9-677A5DB83984 Path: /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent Architecture: x86_64 Parent: launchd [1] Responsible: imagent [299] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 3596 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3b29d1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x3b29fb Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10df43000 - 0x10df4dfff com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <8026AD1F-C961-3EC6-8EC9-677A5DB83984> /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: IMRemoteURLConnectionAgent [44144] UUID: 8026AD1F-C961-3EC6-8EC9-677A5DB83984 Path: /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent Architecture: x86_64 Parent: launchd [1] Responsible: identityservicesd [298] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 4160 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3b29d6 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (IMRemoteURLConnectionAgent + 7212) [0x10a9bcc2c] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x3b29fc Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a9bb000 - 0x10a9c5fff com.apple.imfoundation.IMRemoteURLConnectionAgent 10.0 (1000) <8026AD1F-C961-3EC6-8EC9-677A5DB83984> /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: installd [798] UUID: F019E35E-BE11-3F3F-8A55-42254D1B0677 Path: /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1536 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3f58 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1040e3000 - 0x1040e4fff installd <F019E35E-BE11-3F3F-8A55-42254D1B0677> /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: iTunes [8660] [unique pid 108275] UUID: 91006EE5-C8C4-3A53-B7F7-69A3B2FD991A Path: /Applications/iTunes.app/Contents/MacOS/iTunes Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 167.69 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (537.3K cycles, 121.9K instructions, 4.41c/i) Note: 4 idle work queue threads omitted Thread 0x5ffc77 DispatchQueue 1 Thread name "iTunes main" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (iTunes + 16106610) [0x103fbd472] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffc8b 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffcc3 Thread name "CFRunLoopThread" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (iTunes + 24547263) [0x1047c9fbf] 1-11 11 ??? (iTunes + 24542979) [0x1047c8f03] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffd2c Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0x5ffd2d Thread name "CoreAudioNotificationThread" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffd67 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (122.4K cycles, 27.7K instructions, 4.41c/i) <thread QoS user initiated (requested user initiated), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39 (JavaScriptCore + 2264807) [0x7fff38406ee7] 1-11 11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 2258297) [0x7fff38405579] 1-11 4 bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-4 4 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-4 4 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-4 4 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-4 *4 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-4 7 bmalloc::Scavenger::threadRunLoop() + 262 (JavaScriptCore + 2260422) [0x7fff38405dc6] 5-11 7 std::__1::cv_status std::__1::condition_variable_any::wait_until<std::__1::unique_lock<bmalloc::Mutex>, std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<bmalloc::Mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 95 (JavaScriptCore + 2265343) [0x7fff384070ff] 5-11 7 std::__1::cv_status std::__1::condition_variable::wait_until<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 117 (JavaScriptCore + 2265653) [0x7fff38407235] 5-11 7 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 35633) [0x7fff5e0cab31] 5-11 7 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 5-11 *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x5ffda7 Thread name "AudioDeviceManager - Client Command Processor Thread" 11 samples (1-11) priority 4 (base 4) <thread QoS background, thread darwinbg, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (iTunes + 24547263) [0x1047c9fbf] 1-11 11 ??? (iTunes + 24536992) [0x1047c77a0] 1-11 11 ??? (iTunes + 24403101) [0x1047a6c9d] 1-11 11 ??? (iTunes + 24402596) [0x1047a6aa4] 1-11 11 ??? (iTunes + 24411369) [0x1047a8ce9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5ffda8 Thread name "AFCVolumeNotificationThread" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffdac Thread name "AVOutputDeviceManager - Client Command Processor Thread" 11 samples (1-11) priority 4 (base 4) <thread QoS background, thread darwinbg, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (iTunes + 24547263) [0x1047c9fbf] 1-11 11 ??? (iTunes + 24536992) [0x1047c77a0] 1-11 11 ??? (iTunes + 24403101) [0x1047a6c9d] 1-11 11 ??? (iTunes + 24402596) [0x1047a6aa4] 1-11 11 ??? (iTunes + 24411369) [0x1047a8ce9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5ffdd2 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffddb Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5ffe6b Thread name "iCloud Music Library - Client Command Processor Thread" 11 samples (1-11) priority 4 (base 4) <thread QoS background, thread darwinbg, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (iTunes + 24547263) [0x1047c9fbf] 1-11 11 ??? (iTunes + 24536992) [0x1047c77a0] 1-11 11 ??? (iTunes + 24403101) [0x1047a6c9d] 1-11 11 ??? (iTunes + 24402596) [0x1047a6aa4] 1-11 11 ??? (iTunes + 24411369) [0x1047a8ce9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5ffe6c Thread name "iTunes Store Purchases - Client Command Processor Thread" 11 samples (1-11) priority 4 (base 4) <thread QoS background, thread darwinbg, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (iTunes + 24547263) [0x1047c9fbf] 1-11 11 ??? (iTunes + 24536992) [0x1047c77a0] 1-11 11 ??? (iTunes + 24403101) [0x1047a6c9d] 1-11 11 ??? (iTunes + 24402596) [0x1047a6aa4] 1-11 11 ??? (iTunes + 24411369) [0x1047a8ce9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5ffe8c Thread name "com.apple.coreanimation.render-server" 11 samples (1-11) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5fff6e Thread name "Sharing Artwork Manager Worker Thread" 11 samples (1-11) priority 4 (base 4) <thread QoS background, thread darwinbg, process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x600160 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (CoreFP + 2847931) [0x1096664bb] 1-11 11 sleep + 41 (libsystem_c.dylib + 501622) [0x7fff60f5f776] 1-11 11 __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x600233 Thread name "CFRunLoopThread (Download)" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7ca1ad 11 samples (1-11) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa228ed Thread name "iCloud Music LibraryAssetDL - Client Command Processor Thread" 11 samples (1-11) priority 4 (base 4) <thread QoS background, thread darwinbg, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (iTunes + 24547263) [0x1047c9fbf] 1-11 11 ??? (iTunes + 24536992) [0x1047c77a0] 1-11 11 ??? (iTunes + 24403101) [0x1047a6c9d] 1-11 11 ??? (iTunes + 24402596) [0x1047a6aa4] 1-11 11 ??? (iTunes + 24411369) [0x1047a8ce9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x103061000 - 0x104d8bfff com.apple.iTunes 12.9.5 (12.9.5) <91006EE5-C8C4-3A53-B7F7-69A3B2FD991A> /Applications/iTunes.app/Contents/MacOS/iTunes 0x1093af000 - 0x10a89bfff com.apple.CoreFP 2.13.61 (2.13.61) <17D97459-6C26-3299-BCEB-1327CF36C4A2> /System/Library/PrivateFrameworks/CoreFP.framework/CoreFP 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff381de000 - 0x7fff3903efff com.apple.JavaScriptCore 14607 (14607.3.9) <E25D3B54-A072-33F3-AA89-6F8588BF5A05> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff5e0c2000 - 0x7fff5e115fff libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60ee5000 - 0x7fff60f6cfff libsystem_c.dylib (1272.250.3) <6016EDA1-440B-34D7-A232-686CD7FBEE90> /usr/lib/system/libsystem_c.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: kdc [99] UUID: 028121B0-16D5-334F-B9F3-87362BD23627 Path: /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 3616 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6c0 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10ba32000 - 0x10ba64fff kdc <028121B0-16D5-334F-B9F3-87362BD23627> /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: KernelEventAgent [105] UUID: A770FF79-5B99-3A4E-815D-4ED9D6C862BA Path: /usr/sbin/KernelEventAgent Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 944 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x27b 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x28b Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x106607000 - 0x10660cfff KernelEventAgent <A770FF79-5B99-3A4E-815D-4ED9D6C862BA> /usr/sbin/KernelEventAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: kextd [54] UUID: AC0D8B5E-1319-3F3D-9A21-44E33FC3F002 Path: /usr/libexec/kextd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 21.57 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x253 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108e99000 - 0x108ebefff kextd (528.250.4) <AC0D8B5E-1319-3F3D-9A21-44E33FC3F002> /usr/libexec/kextd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: keybagd [69] UUID: C9DD550F-1084-3895-B8E4-BC31DA94B3BB Path: /usr/libexec/keybagd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 888 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x261 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105606000 - 0x10562afff keybagd <C9DD550F-1084-3895-B8E4-BC31DA94B3BB> /usr/libexec/keybagd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: keyboardservicesd [670] UUID: 40536557-2424-30D3-B3FC-78AEE701AAA6 Path: /usr/libexec/keyboardservicesd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 7444 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (110.0K cycles, 28.6K instructions, 3.84c/i) Note: 1 idle work queue thread omitted Thread 0x1e2c DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101bce000 - 0x101bcefff keyboardservicesd (99.15) <40536557-2424-30D3-B3FC-78AEE701AAA6> /usr/libexec/keyboardservicesd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: knowledge-agent [422] UUID: 19D9BAB0-38C7-394D-8331-5C747A6039CC Path: /usr/libexec/knowledge-agent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 6572 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe86 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10038d000 - 0x100394fff knowledge-agent <19D9BAB0-38C7-394D-8331-5C747A6039CC> /usr/libexec/knowledge-agent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: launchd [1] UUID: 8E81517F-114F-3276-9F42-11E387EAFB81 Path: /sbin/launchd Architecture: x86_64 Parent: kernel_task [0] UID: 0 Footprint: 23.70 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x194 DispatchQueue 11 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 _dispatch_sig_thread + 53 (libdispatch.dylib + 77534) [0x7fff60e5dede] 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10e59c000 - ??? launchd <8E81517F-114F-3276-9F42-11E387EAFB81> /sbin/launchd 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: launchservicesd [87] UUID: 792A3E4F-9072-3897-A01A-17F34CF0751D Path: /System/Library/CoreServices/launchservicesd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 19.12 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (1236.8K cycles, 629.5K instructions, 1.96c/i) Note: 4 idle work queue threads omitted Thread 0x3e2 DispatchQueue 11 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2, priority 4 (4)> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *10 ??? (kernel + 7168864) [0xffffff80008d6360] 1-10 <thread QoS default, process unclamped, thread not darwinbg, process not darwinbg, process received importance donation from Dock [274], IO tier 0, priority 31 (31)> *1 ??? (kernel + 7168864) [0xffffff80008d6360] 11 Thread 0xa9fe44 1 sample (11) priority 37 (base 37) cpu time <0.001s (467.1K cycles, 200.5K instructions, 2.33c/i) <Thread in another stack for 10 samples, thread QoS user initiated (requested user initiated, requested override user initiated), process unclamped, process received importance donation from Dock [274], IO tier 0> 1 ??? [0x111200000005] 11 1 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 11 1 __workq_kernreturn + 10 (libsystem_kernel.dylib + 11258) [0x7fff60fd1bfa] 11 *1 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 11 *1 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 11 *1 workq_kernreturn + 2446 (kernel + 6776974) [0xffffff800087688e] 11 *1 ??? (kernel + 6757610) [0xffffff8000871cea] (running) 11 Thread 0xaa0ace 1 sample (11) priority 37 (base 37) cpu time <0.001s (618.5K cycles, 380.5K instructions, 1.63c/i) <Thread in another stack for 10 samples, thread QoS user initiated (requested user initiated, ipc override user initiated), process unclamped, process received importance donation from Dock [274], IO tier 0> 1 ??? [0x7c00001112] 11 1 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 11 1 __workq_kernreturn + 10 (libsystem_kernel.dylib + 11258) [0x7fff60fd1bfa] 11 *1 call_continuation + 46 (kernel + 1417422) [0xffffff800035a0ce] 11 *1 ??? (kernel + 6756799) [0xffffff80008719bf] 11 *1 ??? (kernel + 6757992) [0xffffff8000871e68] 11 *1 ??? (kernel + 6760238) [0xffffff800087272e] 11 *1 workq_setup_thread + 380 (pthread + 6593) [0xffffff7f82d939c1] 11 *1 workq_kevent + 132 (pthread + 6792) [0xffffff7f82d93a88] 11 *1 kevent_id_internal + 55 (kernel + 6980215) [0xffffff80008a8277] 11 *1 ??? (kernel + 6965794) [0xffffff80008a4a22] 11 *1 kqueue_scan + 77 (kernel + 6972957) [0xffffff80008a661d] 11 *1 ??? (kernel + 6977259) [0xffffff80008a76eb] 11 *1 ??? (kernel + 6972842) [0xffffff80008a65aa] 11 *1 ??? (kernel + 6951044) [0xffffff80008a1084] 11 *1 _bcopy + 11 (kernel + 1416683) [0xffffff8000359deb] (running) 11 Binary Images: 0x1030e5000 - 0x1030eefff launchservicesd <792A3E4F-9072-3897-A01A-17F34CF0751D> /System/Library/CoreServices/launchservicesd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: locationd [93] UUID: B8F4AC31-17CD-3FF0-A2B6-1C5C17631E79 Path: /usr/libexec/locationd Architecture: x86_64 Parent: launchd [1] UID: 205 Footprint: 8472 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x404 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x107aa2000 - 0x107f3afff locationd (2245.16.14) <B8F4AC31-17CD-3FF0-A2B6-1C5C17631E79> /usr/libexec/locationd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: logd [68] UUID: 47327F38-4CDF-31C7-A817-B14B211B2199 Path: /usr/libexec/logd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 38.32 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (247.5K cycles, 55.3K instructions, 4.48c/i) Note: 3 idle work queue threads omitted Thread 0x2a9 DispatchQueue 11 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x107094000 - 0x1070b5fff logd <47327F38-4CDF-31C7-A817-B14B211B2199> /usr/libexec/logd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: logind [103] UUID: D1BEC1E4-E071-323E-A458-209E318B794C Path: /System/Library/CoreServices/logind Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 1428 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x277 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102217000 - 0x10222dfff logind (100) <D1BEC1E4-E071-323E-A458-209E318B794C> /System/Library/CoreServices/logind 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: loginitemregisterd [705] UUID: 8060E0DE-ABCC-3EEC-93B1-BA36110DE7E7 Path: /usr/libexec/loginitemregisterd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1388 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x2b68 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10ca1a000 - 0x10ca1bfff loginitemregisterd <8060E0DE-ABCC-3EEC-93B1-BA36110DE7E7> /usr/libexec/loginitemregisterd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: LoginUserService [350] UUID: 85BE5FD0-D500-32D6-944D-D6EEA072D0AF Path: /System/Library/PrivateFrameworks/login.framework/Versions/A/XPCServices/LoginUserService.xpc/Contents/MacOS/LoginUserService Architecture: x86_64 Parent: launchd [1] Responsible: SystemUIServer [275] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 948 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xaaa 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1005e3000 - 0x1005e5fff LoginUserService <85BE5FD0-D500-32D6-944D-D6EEA072D0AF> /System/Library/PrivateFrameworks/login.framework/Versions/A/XPCServices/LoginUserService.xpc/Contents/MacOS/LoginUserService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: loginwindow [102] UUID: 6266338C-6F6C-32A1-8C75-A6E00DA259F3 Path: /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 40.06 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (72.9K cycles, 27.2K instructions, 2.68c/i) Note: 2 idle work queue threads omitted Thread 0x271 DispatchQueue 1 11 samples (1-11) priority 47 (base 47) <thread QoS user interactive (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (loginwindow + 24144) [0x10ddcae50] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10ddc5000 - 0x10deb3fff com.apple.loginwindow 9.0 (1932.7.2) <6266338C-6F6C-32A1-8C75-A6E00DA259F3> /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: lsd [176] UUID: 5CAA3AB9-D746-3CFE-B1E3-E3EFFE83DB74 Path: /usr/libexec/lsd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 15.14 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3bc DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10fec1000 - 0x10fec1fff lsd <5CAA3AB9-D746-3CFE-B1E3-E3EFFE83DB74> /usr/libexec/lsd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: lsd [276] UUID: 5CAA3AB9-D746-3CFE-B1E3-E3EFFE83DB74 Path: /usr/libexec/lsd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 8832 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x7d4 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x106252000 - 0x106252fff lsd <5CAA3AB9-D746-3CFE-B1E3-E3EFFE83DB74> /usr/libexec/lsd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: lsd [937] UUID: 5CAA3AB9-D746-3CFE-B1E3-E3EFFE83DB74 Path: /usr/libexec/lsd Architecture: x86_64 Parent: launchd [1] UID: 501 Sudden Term: Tracked Footprint: 1896 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xb1a8 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10baf6000 - 0x10baf6fff lsd <5CAA3AB9-D746-3CFE-B1E3-E3EFFE83DB74> /usr/libexec/lsd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Mail [98166] UUID: F994B41C-3868-3B50-9A05-B4FA72788739 Path: /Applications/Mail.app/Contents/MacOS/Mail Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 154.77 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (628.2K cycles, 193.8K instructions, 3.24c/i) Note: 3 idle work queue threads omitted Thread 0x587f3e DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x587f85 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (268.4K cycles, 109.5K instructions, 2.45c/i) <thread QoS user initiated (requested user initiated), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39 (JavaScriptCore + 2264807) [0x7fff38406ee7] 1-11 11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 2258297) [0x7fff38405579] 1-11 2 bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-2 2 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-2 2 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-2 2 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-2 *2 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-2 2 bmalloc::Scavenger::threadRunLoop() + 262 (JavaScriptCore + 2260422) [0x7fff38405dc6] 3-4 2 std::__1::cv_status std::__1::condition_variable_any::wait_until<std::__1::unique_lock<bmalloc::Mutex>, std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<bmalloc::Mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 95 (JavaScriptCore + 2265343) [0x7fff384070ff] 3-4 2 std::__1::cv_status std::__1::condition_variable::wait_until<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 117 (JavaScriptCore + 2265653) [0x7fff38407235] 3-4 2 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 35633) [0x7fff5e0cab31] 3-4 2 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 3-4 *2 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 3-4 7 bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 5-11 7 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 5-11 7 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 5-11 7 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 5-11 *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x587fe7 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x588126 Thread name "com.apple.coreanimation.render-server" 11 samples (1-11) priority 4 (base 4) <process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x58817c Thread name "com.apple.CFNetwork.CustomProtocols" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9e31da Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f8a9000 - 0x10fc58fff Mail <F994B41C-3868-3B50-9A05-B4FA72788739> /Applications/Mail.app/Contents/MacOS/Mail 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff381de000 - 0x7fff3903efff com.apple.JavaScriptCore 14607 (14607.3.9) <E25D3B54-A072-33F3-AA89-6F8588BF5A05> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff5e0c2000 - 0x7fff5e115fff libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mapspushd [2903] UUID: 4B8E71BB-547B-366C-8FAB-173C5977BD0B Path: /System/Library/CoreServices/mapspushd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 11.01 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x45765 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104631000 - 0x10464ffff mapspushd <4B8E71BB-547B-366C-8FAB-173C5977BD0B> /System/Library/CoreServices/mapspushd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mDNSResponder [189] UUID: 6E56C00A-5128-3E80-8B3E-F1213081DF13 Path: /usr/sbin/mDNSResponder Architecture: x86_64 Parent: launchd [1] UID: 65 Footprint: 5364 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3fc 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x412 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x504e21 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x504e26 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1003ff000 - 0x1004a2fff mDNSResponder (878.270.3) <6E56C00A-5128-3E80-8B3E-F1213081DF13> /usr/sbin/mDNSResponder 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mDNSResponderHelper [190] UUID: 255FA049-A136-3B25-A153-6E10E681E006 Path: /usr/sbin/mDNSResponderHelper Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 1732 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (83.5K cycles, 17.2K instructions, 4.87c/i) Note: 1 idle work queue thread omitted Thread 0x40c 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (83.5K cycles, 17.2K instructions, 4.87c/i) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 idletimer + 72 (mDNSResponderHelper + 30125) [0x10d4f75ad] 1-11 11 sleep + 41 (libsystem_c.dylib + 501622) [0x7fff60f5f776] 1-11 11 __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x40d 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10d4f0000 - 0x10d4fcfff mDNSResponderHelper (878.270.3) <255FA049-A136-3B25-A153-6E10E681E006> /usr/sbin/mDNSResponderHelper 0x7fff60ee5000 - 0x7fff60f6cfff libsystem_c.dylib (1272.250.3) <6016EDA1-440B-34D7-A232-686CD7FBEE90> /usr/lib/system/libsystem_c.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mds [75] UUID: 95FEB9D4-E067-37DE-A86D-B84A96F94EE0 Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 122.10 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (512.2K cycles, 114.9K instructions, 4.46c/i) Note: 4 idle work queue threads omitted Thread 0x264 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0 and passive> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x51b 11 samples (1-11) priority 50 (base 50) cpu time <0.001s (88.2K cycles, 14.7K instructions, 5.98c/i) <IO tier 0 and passive> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4405643) [0xffffff800063398b] 1-11 *11 ??? (kernel + 7168593) [0xffffff80008d6251] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x76d 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0 and passive> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102c76000 - 0x102e0afff mds (1191.59) <95FEB9D4-E067-37DE-A86D-B84A96F94EE0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mds_stores [251] UUID: 8D62948F-3F1E-3441-B94E-1C4DCD8E0018 Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 207.01 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 3 idle work queue threads omitted Thread 0x745 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0 and passive> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (mds_stores + 12259) [0x104a92fe3] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x74e 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0 and passive> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104a90000 - 0x104ad1fff mds_stores (1191.59) <8D62948F-3F1E-3441-B94E-1C4DCD8E0018> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds_stores 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mdworker_shared [67342] [unique pid 166925] UUID: EB02EF4C-A825-3EAE-81D8-30198EFEC09F Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 13.69 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa9cec4 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (mdworker_shared + 37345) [0x102f6f1e1] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9ced0 11 samples (1-11) priority 4 (base 4) <thread QoS maintenance (requested maintenance), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mdworker_shared + 45374) [0x102f7113e] 1-11 11 ??? (mdworker_shared + 59363) [0x102f747e3] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9ced2 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mdworker_shared + 117140) [0x102f82994] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102f66000 - 0x102fb5fff mdworker_shared (1191.59) <EB02EF4C-A825-3EAE-81D8-30198EFEC09F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mdworker_shared [67360] [unique pid 166943] UUID: EB02EF4C-A825-3EAE-81D8-30198EFEC09F Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 11.94 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa9f38d DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (mdworker_shared + 37345) [0x10044a1e1] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f395 11 samples (1-11) priority 4 (base 4) <thread QoS maintenance (requested maintenance), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mdworker_shared + 45374) [0x10044c13e] 1-11 11 ??? (mdworker_shared + 59363) [0x10044f7e3] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f398 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mdworker_shared + 117140) [0x10045d994] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100441000 - 0x100490fff mdworker_shared (1191.59) <EB02EF4C-A825-3EAE-81D8-30198EFEC09F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mdworker_shared [67363] [unique pid 166946] UUID: EB02EF4C-A825-3EAE-81D8-30198EFEC09F Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 19.20 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa9f3f9 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (mdworker_shared + 37345) [0x10f6631e1] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f3fd 11 samples (1-11) priority 4 (base 4) <thread QoS maintenance (requested maintenance), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mdworker_shared + 45374) [0x10f66513e] 1-11 11 ??? (mdworker_shared + 59363) [0x10f6687e3] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9f3fe 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mdworker_shared + 117140) [0x10f676994] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f65a000 - 0x10f6a9fff mdworker_shared (1191.59) <EB02EF4C-A825-3EAE-81D8-30198EFEC09F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mdworker_shared [67416] [unique pid 166999] UUID: EB02EF4C-A825-3EAE-81D8-30198EFEC09F Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared Architecture: x86_64 Parent: launchd [1] UID: 89 Sudden Term: Tracked (allows idle exit) Footprint: 3276 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xaa0905 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (mdworker_shared + 37345) [0x108ccf1e1] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa090b 11 samples (1-11) priority 4 (base 4) <thread QoS maintenance (requested maintenance), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mdworker_shared + 45374) [0x108cd113e] 1-11 11 ??? (mdworker_shared + 59363) [0x108cd47e3] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108cc6000 - 0x108d15fff mdworker_shared (1191.59) <EB02EF4C-A825-3EAE-81D8-30198EFEC09F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mdwrite [694] UUID: 682C97DD-90FA-3EAE-9C93-26009EC55056 Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdwrite Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 2700 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x267a 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1047d9000 - 0x1047ebfff mdwrite <682C97DD-90FA-3EAE-9C93-26009EC55056> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdwrite 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: media-indexer [490] UUID: E3D3B060-22D1-3719-AF76-C59E0A6F651E Path: /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer Architecture: x86_64 Parent: launchd [1] Responsible: assistantd [404] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 55.81 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x14f8 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x107e09000 - 0x107e13fff media-indexer <E3D3B060-22D1-3719-AF76-C59E0A6F651E> /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mediaremoted [57] UUID: EE689C22-C7FC-368C-8CC2-9EC8BCA54261 Path: /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 4112 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 3 idle work queue threads omitted Thread 0x258 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 445 (mediaremoted + 309869) [0x10e78aa6d] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e73f000 - 0x10e82cfff mediaremoted (4016.700.1) <EE689C22-C7FC-368C-8CC2-9EC8BCA54261> /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Microsoft Excel [1251] UUID: F95C3997-A9A0-3920-BBC7-1DA91090A6DE Path: /Applications/Microsoft Excel.app/Contents/MacOS/Microsoft Excel Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 255.77 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.012s (51.8M cycles, 16.4M instructions, 3.16c/i) Note: 4 idle work queue threads omitted Thread 0x1bbae DispatchQueue 1 11 samples (1-11) priority 4-46 (base 4-46) cpu time 0.007s (29.1M cycles, 10.1M instructions, 2.89c/i) <thread QoS user interactive (requested user interactive), process unclamped, IO tier 0, priority 46 (46)> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 46 (46)> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x1bca7 DispatchQueue 10 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process unclamped, thread darwinbg, IO tier 2> 11 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 1-11 11 _pthread_wqthread + 583 (libsystem_pthread.dylib + 9907) [0x7fff6108e6b3] 1-11 11 _dispatch_worker_thread2 + 90 (libdispatch.dylib + 72518) [0x7fff60e5cb46] 1-11 11 _dispatch_root_queue_drain + 324 (libdispatch.dylib + 70588) [0x7fff60e5c3bc] 1-11 11 _dispatch_queue_override_invoke + 763 (libdispatch.dylib + 23123) [0x7fff60e50a53] 1-11 11 _dispatch_client_callout + 8 (libdispatch.dylib + 13885) [0x7fff60e4e63d] 1-11 11 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 9720) [0x7fff60e4d5f8] 1-11 11 ??? (WLMKernel + 20022) [0x11a1f0e36] 1-11 11 ??? (mso20 + 16314) [0x1130a8fba] 1-11 11 Mso::Async::InvokeInCallbackContext(Mso::Functor<void ()>&&, Mso::Async::IDispatchQueue*, Mso::Async::Details::IIdleDispatchQueue*, bool) + 151 (mso20 + 16530) [0x1130a9092] 1-11 11 ??? (mso20 + 264761) [0x1130e5a39] 1-11 11 ??? (mso30 + 200414) [0x1137a3ede] 1-11 11 ??? (mso30 + 200526) [0x1137a3f4e] 1-11 11 ??? (mso30 + 201153) [0x1137a41c1] 1-11 11 ??? (MicrosoftCSI + 142119) [0x111235b27] 1-11 11 Mso::Synchronization::MsoWaitForMultipleObjects(unsigned int, void* const*, bool, MsoTimeoutInterval const&, bool, bool) + 359 (mso20 + 341138) [0x1130f8492] 1-11 11 ??? (mso20 + 364873) [0x1130fe149] 1-11 11 ??? (WLMKernel + 41423) [0x11a1f61cf] 1-11 11 ??? (WLMKernel + 41615) [0x11a1f628f] 1-11 11 ??? (WLMKernel + 42585) [0x11a1f6659] 1-11 11 ??? (WLMKernel + 57210) [0x11a1f9f7a] 1-11 11 MBUSignaledCondition::WaitForDuration(unsigned int) + 58 (mbukernel + 58562) [0x112e354c2] 1-11 11 MBUCondition::WaitForDuration(unsigned int) + 25 (mbukernel + 58637) [0x112e3550d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc41 11 samples (1-11) priority 4-37 (base 4-37) <thread QoS user initiated (requested user initiated), process unclamped, IO tier 0, priority 37 (37)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 37 (37)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc43 11 samples (1-11) priority 4-31 (base 4-31) cpu time <0.001s (27.2K cycles, 5.4K instructions, 5.02c/i) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (merp + 39972) [0x112ef4c24] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x1bc45 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x1bc47 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc48 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc49 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc4a 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc4b 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc4c 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc4d 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc4e 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc56 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process unclamped, thread darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bc57 11 samples (1-11) priority 4-37 (base 4-37) <thread QoS user initiated (requested user initiated), process unclamped, IO tier 0, priority 37 (37)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 37 (37)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bcb4 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4-46 (base 4-46) cpu time 0.004s (17.4M cycles, 5.1M instructions, 3.43c/i) <thread QoS user interactive (requested user interactive), process unclamped, IO tier 0, priority 46 (46)> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 46 (46)> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x1bcdd Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 -[__CoreSchedulingSetRunnable runForever] + 210 (CFNetwork + 314940) [0x7fff33deae3c] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x1bcf9 11 samples (1-11) priority 4-31 (base 4-31) cpu time <0.001s (89.5K cycles, 17.3K instructions, 5.18c/i) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mso20 + 2177272) [0x1132b88f8] 1-11 11 ??? (mso20 + 2170488) [0x1132b6e78] 1-11 11 ??? (mso20 + 2170001) [0x1132b6c91] 1-11 11 WaitForSingleObjectEx + 35 (WLMKernel + 48256) [0x11a1f7c80] 1-11 11 ??? (WLMKernel + 41423) [0x11a1f61cf] 1-11 11 ??? (WLMKernel + 41615) [0x11a1f628f] 1-11 11 ??? (WLMKernel + 42585) [0x11a1f6659] 1-11 11 ??? (WLMKernel + 57210) [0x11a1f9f7a] 1-11 11 MBUSignaledCondition::WaitForDuration(unsigned int) + 58 (mbukernel + 58562) [0x112e354c2] 1-11 11 MBUCondition::WaitForDuration(unsigned int) + 85 (mbukernel + 58697) [0x112e35549] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bcfa 11 samples (1-11) priority 4-31 (base 4-31) cpu time <0.001s (82.7K cycles, 19.4K instructions, 4.27c/i) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mso20 + 2177272) [0x1132b88f8] 1-11 11 ??? (mso20 + 2170488) [0x1132b6e78] 1-11 11 ??? (mso20 + 2170001) [0x1132b6c91] 1-11 11 WaitForSingleObjectEx + 35 (WLMKernel + 48256) [0x11a1f7c80] 1-11 11 ??? (WLMKernel + 41423) [0x11a1f61cf] 1-11 11 ??? (WLMKernel + 41615) [0x11a1f628f] 1-11 11 ??? (WLMKernel + 42585) [0x11a1f6659] 1-11 11 ??? (WLMKernel + 57210) [0x11a1f9f7a] 1-11 11 MBUSignaledCondition::WaitForDuration(unsigned int) + 58 (mbukernel + 58562) [0x112e354c2] 1-11 11 MBUCondition::WaitForDuration(unsigned int) + 85 (mbukernel + 58697) [0x112e35549] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x1bd0c 11 samples (1-11) priority 4-31 (base 4-31) <thread QoS default (requested default), process unclamped, IO tier 0, priority 31 (31)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 31 (31)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0xf8f62 11 samples (1-11) priority 4-37 (base 4-37) <thread QoS user initiated (requested user initiated), process unclamped, IO tier 0, priority 37 (37)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 37 (37)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0xf9060 Thread name "com.facebook.react.JavaScript" 11 samples (1-11) priority 4-46 (base 4-46) <thread QoS user interactive (requested user interactive), process unclamped, IO tier 0, priority 46 (46)> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 46 (46)> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0xf9061 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4-37 (base 4-37) <thread QoS user initiated (requested user initiated), process unclamped, IO tier 0, priority 37 (37)> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process clamped, process suppressed, timers tier 5 (throttled), IO tier 2, priority 4 (4)> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process unclamped, process unsuppressed, timers tier 0 (normal), IO tier 0, priority 37 (37)> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Binary Images: 0x10cc55000 - ??? Microsoft Excel <F95C3997-A9A0-3920-BBC7-1DA91090A6DE> /Applications/Microsoft Excel.app/Contents/MacOS/Microsoft Excel 0x111213000 - 0x111d76fff com.microsoft.csi 16.54 (16.54.21101001) <7E7BA304-03EB-3E0A-9F77-D070EA4B736C> /Applications/Microsoft Outlook.app/Contents/Frameworks/MicrosoftCSI.framework/Versions/A/MicrosoftCSI 0x112e27000 - 0x112e9afff com.microsoft.mbukernel 16.54 (16.54.21101001) <6F64D620-0598-32E7-8519-B8F0D1CEC374> /Applications/Microsoft Outlook.app/Contents/Frameworks/mbukernel.framework/Versions/A/mbukernel 0x112eeb000 - 0x112f02fff com.microsoft.merp 16.54 (16.54.21101001) <B8DF2092-F9C5-3E24-ADFE-797453982157> /Applications/Microsoft Outlook.app/Contents/Frameworks/merp.framework/Versions/A/merp 0x1130a5000 - 0x11362cfff com.microsoft.mso20 16.54 (16.54.21101001) <45FA0676-7958-3751-82CA-1C2825CF6985> /Applications/Microsoft Outlook.app/Contents/Frameworks/mso20.framework/Versions/A/mso20 0x113773000 - 0x1142c2fff com.microsoft.mso30 16.54 (16.54.21101001) <6BFCC7A8-7B3A-3849-8377-55A61492A1D2> /Applications/Microsoft Outlook.app/Contents/Frameworks/mso30.framework/Versions/A/mso30 0x11a1ec000 - 0x11a25bfff com.microsoft.wlmkernel 16.54 (16.54.21101001) <33E466A0-59B7-38CB-BDED-195E68C6305A> /Applications/Microsoft Outlook.app/Contents/Frameworks/WLMKernel.framework/Versions/A/WLMKernel 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff33d9e000 - 0x7fff34140fff com.apple.CFNetwork 978.6 (978.6) <F6AC3859-B6F9-3212-A357-54AA096DAA9E> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Microsoft Outlook [4828] UUID: 129B1EA8-6D54-3106-BDD5-8151AFFDDE1A Path: /Applications/Microsoft Outlook.app/Contents/MacOS/Microsoft Outlook Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 1211.37 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (2.4M cycles, 1100.1K instructions, 2.16c/i) Note: 5 idle work queue threads omitted Thread 0x5623c DispatchQueue 1 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (1837.5K cycles, 943.8K instructions, 1.95c/i) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 4 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 ??? (Microsoft Outlook + 32969) [0x10fcaf0c9] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x56334 DispatchQueue 10 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process suppressed, timers tier 4 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5634f DispatchQueue 10 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process suppressed, timers tier 4 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x56382 DispatchQueue 10 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process suppressed, timers tier 4 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa315c3 DispatchQueue 936 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated, ipc override user initiated), process suppressed, timers tier 4 (throttled), IO tier 2> 11 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 1-11 11 _pthread_wqthread + 421 (libsystem_pthread.dylib + 9745) [0x7fff6108e611] 1-11 11 _dispatch_workloop_worker_thread + 598 (libdispatch.dylib + 75501) [0x7fff60e5d6ed] 1-11 11 _dispatch_lane_invoke + 385 (libdispatch.dylib + 41878) [0x7fff60e55396] 1-11 11 _dispatch_lane_serial_drain + 602 (libdispatch.dylib + 39136) [0x7fff60e548e0] 1-11 11 _dispatch_client_callout + 8 (libdispatch.dylib + 13885) [0x7fff60e4e63d] 1-11 11 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 9720) [0x7fff60e4d5f8] 1-11 11 ??? (WLMKernel + 20022) [0x11b93ee36] 1-11 11 ??? (OutlookCore + 165976) [0x117418858] 1-11 11 CCommandQueue::ExecuteCommand(std::__1::shared_ptr<CCommand>) + 174 (OutlookCore + 163666) [0x117417f52] 1-11 11 CExchangeHangingNotificationMgr::Command::Threaded_StreamingEvents() + 1346 (Microsoft Outlook + 9484296) [0x1105b2808] 1-11 11 CExchangeHangingNotificationMgr::Command::GetStreamingEvent(std::__1::shared_ptr<EWS::CBaseResponseStreamObj>&, unsigned int) + 250 (Microsoft Outlook + 9479546) [0x1105b157a] 1-11 11 EWS::CBaseResponseStreamObj::NextResponse(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1l> > const&) + 475 (OutlookCore + 2335873) [0x11762a481] 1-11 11 EWS::CBaseResponseStreamObj::WaitForEvent(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1l> > const&) + 196 (OutlookCore + 2335298) [0x11762a242] 1-11 11 ??? (OutlookCore + 2339256) [0x11762b1b8] 1-11 11 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 35633) [0x7fff5e0cab31] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x562ef 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (27.0K cycles, 5.2K instructions, 5.22c/i) <thread QoS default (requested default), process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (merp + 39972) [0x1152d3c24] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5635c Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x56370 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 -[__CoreSchedulingSetRunnable runForever] + 210 (CFNetwork + 314940) [0x7fff33deae3c] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x56374 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated, ipc override user initiated), process suppressed, timers tier 4 (throttled), IO tier 2> 11 ??? [0x1ffea500000001] 1-11 11 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 1-11 11 _pthread_wqthread + 421 (libsystem_pthread.dylib + 9745) [0x7fff6108e611] 1-11 11 _dispatch_workloop_worker_thread + 598 (libdispatch.dylib + 75501) [0x7fff60e5d6ed] 1-11 11 _dispatch_lane_invoke + 385 (libdispatch.dylib + 41878) [0x7fff60e55396] 1-11 11 _dispatch_lane_serial_drain + 602 (libdispatch.dylib + 39136) [0x7fff60e548e0] 1-11 11 _dispatch_client_callout + 8 (libdispatch.dylib + 13885) [0x7fff60e4e63d] 1-11 11 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 9720) [0x7fff60e4d5f8] 1-11 11 ??? (WLMKernel + 20022) [0x11b93ee36] 1-11 11 ??? (OutlookCore + 165976) [0x117418858] 1-11 11 CCommandQueue::ExecuteCommand(std::__1::shared_ptr<CCommand>) + 174 (OutlookCore + 163666) [0x117417f52] 1-11 11 Service::Outlook::CServiceOutlookStreamingNotificationMgr::Command::Threaded_StreamingEvents() + 922 (Microsoft Outlook + 12846894) [0x1108e772e] 1-11 11 Service::Outlook::CServiceOutlookStreamingNotificationMgr::Command::GetStreamingEvent(std::__1::shared_ptr<REST::CRestResponseStreamObj>&, unsigned int) + 43 (Microsoft Outlook + 12845833) [0x1108e7309] 1-11 11 REST::CRestResponseStreamObj::NextResponse(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1l> > const&) + 832 (Microsoft Outlook + 984458) [0x10fd9758a] 1-11 11 REST::CRestResponseStreamObj::WaitForEvent(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1l> > const&) + 195 (Microsoft Outlook + 983525) [0x10fd971e5] 1-11 11 ??? (Microsoft Outlook + 9297126) [0x110584ce6] 1-11 11 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 35633) [0x7fff5e0cab31] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x56386 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39 (JavaScriptCore + 2264807) [0x7fff38406ee7] 1-11 11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 2258297) [0x7fff38405579] 1-11 11 bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-11 11 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x5638d Thread name "com.facebook.react.JavaScript" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 ??? (mso40ui + 436153) [0x11682c7b9] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x563ba Thread name "com.apple.CFNetwork.CustomProtocols" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 -[__CoreSchedulingSetRunnable runForever] + 210 (CFNetwork + 314940) [0x7fff33deae3c] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x563ff 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 4 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x56461 Thread name "com.facebook.react.JavaScript" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 ??? (mso40ui + 436153) [0x11682c7b9] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x56532 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mso20 + 4293599) [0x1157703df] 1-11 11 ??? (mso20 + 708254) [0x115404e9e] 1-11 11 ??? (mso20 + 708798) [0x1154050be] 1-11 11 ??? (mso20 + 1398862) [0x1154ad84e] 1-11 11 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93 (libc++.1.dylib + 35633) [0x7fff5e0cab31] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x152b24 Thread name "com.squareup.SocketRocket.NetworkThread" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 4 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x152b2c Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 4 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0xa97b3a 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (OutlookCore + 3399595) [0x11772dfab] 1-11 11 Network::Http::CHttpMessage::SendInternal(std::__1::shared_ptr<Network::Http::CHttpRequest>, std::__1::shared_ptr<Network::Http::IHttpDataStream>, unsigned long, bool, std::__1::shared_ptr<Network::Http::IHttpDataStream>) + 163 (OutlookCore + 3274527) [0x11770f71f] 1-11 11 ??? (mso20 + 690388) [0x1154008d4] 1-11 11 ??? (mso20 + 2713733) [0x1155ee885] 1-11 11 ??? (mbukernel + 74618) [0x11521a37a] 1-11 11 ??? (mbukernel + 51554) [0x115214962] 1-11 11 ??? (mbukernel + 58444) [0x11521644c] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0xa98369 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (OutlookCore + 3399595) [0x11772dfab] 1-11 11 Network::Http::CHttpMessage::SendInternal(std::__1::shared_ptr<Network::Http::CHttpRequest>, std::__1::shared_ptr<Network::Http::IHttpDataStream>, unsigned long, bool, std::__1::shared_ptr<Network::Http::IHttpDataStream>) + 163 (OutlookCore + 3274527) [0x11770f71f] 1-11 11 ??? (mso20 + 690388) [0x1154008d4] 1-11 11 ??? (mso20 + 2713733) [0x1155ee885] 1-11 11 ??? (mbukernel + 74618) [0x11521a37a] 1-11 11 ??? (mbukernel + 51554) [0x115214962] 1-11 11 ??? (mbukernel + 58444) [0x11521644c] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x10fca7000 - 0x11137afff com.microsoft.Outlook 16.54 (16.54.21101001) <129B1EA8-6D54-3106-BDD5-8151AFFDDE1A> /Applications/Microsoft Outlook.app/Contents/MacOS/Microsoft Outlook 0x115208000 - 0x11527bfff com.microsoft.mbukernel 16.54 (16.54.21101001) <6F64D620-0598-32E7-8519-B8F0D1CEC374> /Applications/Microsoft Outlook.app/Contents/Frameworks/mbukernel.framework/Versions/A/mbukernel 0x1152ca000 - 0x1152e1fff com.microsoft.merp 16.54 (16.54.21101001) <B8DF2092-F9C5-3E24-ADFE-797453982157> /Applications/Microsoft Outlook.app/Contents/Frameworks/merp.framework/Versions/A/merp 0x115358000 - 0x1158dffff com.microsoft.mso20 16.54 (16.54.21101001) <45FA0676-7958-3751-82CA-1C2825CF6985> /Applications/Microsoft Outlook.app/Contents/Frameworks/mso20.framework/Versions/A/mso20 0x1167c2000 - 0x116f3dfff com.microsoft.mso40ui 16.54 (16.54.21101001) <53FA5437-82E5-32DE-9160-ECE76034F279> /Applications/Microsoft Outlook.app/Contents/Frameworks/mso40ui.framework/Versions/A/mso40ui 0x1173f0000 - 0x1178dffff com.microsoft.outlook.core.framework 16.54 (16.54.21101001) <628031FB-6A4A-34B5-BCC1-4D146AF116EF> /Applications/Microsoft Outlook.app/Contents/Frameworks/OutlookCore.framework/Versions/A/OutlookCore 0x11b93a000 - 0x11b9a9fff com.microsoft.wlmkernel 16.54 (16.54.21101001) <33E466A0-59B7-38CB-BDED-195E68C6305A> /Applications/Microsoft Outlook.app/Contents/Frameworks/WLMKernel.framework/Versions/A/WLMKernel 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff33d9e000 - 0x7fff34140fff com.apple.CFNetwork 978.6 (978.6) <F6AC3859-B6F9-3212-A357-54AA096DAA9E> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff381de000 - 0x7fff3903efff com.apple.JavaScriptCore 14607 (14607.3.9) <E25D3B54-A072-33F3-AA89-6F8588BF5A05> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff5e0c2000 - 0x7fff5e115fff libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Microsoft Teams Helper [843] UUID: 4C4C4432-5555-3144-A1D1-18CB51E6E4EF Path: /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper.app/Contents/MacOS/Microsoft Teams Helper Architecture: x86_64 Parent: Teams [836] Responsible: Teams [836] UID: 504 Footprint: 18.50 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x61bd Thread name "CrUtilityMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x61ef Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x61f2 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10e7d5f48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x10e7b801d] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x10e7b7e88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x10e7655d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x10e79b6ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x61f4 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6239 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10e7d5f48] 1-11 11 _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x10e7b164d] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x10e7b1c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10e7e372c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9d9dae Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10e7d5f48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x10e7b16dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x10e7b1c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10e7e372c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b54c000 - 0x10b571fff com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4432-5555-3144-A1D1-18CB51E6E4EF> /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper.app/Contents/MacOS/Microsoft Teams Helper 0x10b583000 - 0x1138cbfff com.github.Electron.framework (16.2.8) <4C4C4462-5555-3144-A1AC-15EC19C8E608> /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Microsoft Teams Helper [851] UUID: 4C4C4432-5555-3144-A1D1-18CB51E6E4EF Path: /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper.app/Contents/MacOS/Microsoft Teams Helper Architecture: x86_64 Parent: Teams [836] Responsible: Teams [836] UID: 504 Footprint: 10.55 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6294 DispatchQueue 1 Thread name "CrUtilityMain" 11 samples (1-11) priority 47 (base 47) <process frontmost, thread QoS user interactive (requested user interactive), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x62ac Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <process frontmost, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10624bf48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x10622e01d] 1-11 11 _TIFFSwab64BitData + 5241469 (Electron Framework + 52567213) [0x10621acad] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x10622de88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1061db5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x1062116ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x62ad Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process frontmost, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10624bf48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x1062276dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x106227c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10625972c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x62ae Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <process frontmost, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10624bf48] 1-11 11 _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x10622764d] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x106227c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10625972c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x62b0 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <process frontmost, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10624bf48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x10622e01d] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x10622de88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1061db5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x1062116ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Binary Images: 0x102fbf000 - 0x102fe4fff com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4432-5555-3144-A1D1-18CB51E6E4EF> /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper.app/Contents/MacOS/Microsoft Teams Helper 0x102ff9000 - 0x10b341fff com.github.Electron.framework (16.2.8) <4C4C4462-5555-3144-A1AC-15EC19C8E608> /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Microsoft Teams Helper (GPU) [841] UUID: 4C4C4417-5555-3144-A16C-46E835C938B6 Path: /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (GPU).app/Contents/MacOS/Microsoft Teams Helper (GPU) Architecture: x86_64 Parent: Teams [836] Responsible: Teams [836] UID: 504 Footprint: 521.45 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6195 DispatchQueue 1 Thread name "CrGpuMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Microsoft Teams Helper (GPU) + 2670) [0x10754ca6e] 1-11 11 ElectronMain + 146 (Electron Framework + 108402) [0x10759b772] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x108671349] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x108670a4b] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10354957 (Electron Framework + 17764429) [0x10867204d] 1-11 11 device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 492644 (Electron Framework + 98494884) [0x10d36f9a4] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x10a7635d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x10a7996ba] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x10a7d99b2] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 5817 (Electron Framework + 52797401) [0x10a7dafd9] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x61fc Thread name "GpuWatchdog" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10a7d3f48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x10a7b601d] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x10a7b5e88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x10a7635d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x10a7996ba] 1-11 11 _TIFFSwab64BitData + 4840202 (Electron Framework + 52165946) [0x10a740d3a] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10a7e172c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6200 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6201 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10a7d3f48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x10a7af6dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x10a7afc7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10a7e172c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6202 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10a7d3f48] 1-11 11 _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x10a7af64d] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x10a7afc7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10a7e172c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6203 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10a7d3f48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x10a7b601d] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x10a7b5e88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x10a7635d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x10a7996ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6205 Thread name "VizCompositorThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x628c Thread name "ThreadPoolSingleThreadSharedForeground0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10754c000 - 0x107571fff com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4417-5555-3144-A16C-46E835C938B6> /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (GPU).app/Contents/MacOS/Microsoft Teams Helper (GPU) 0x107581000 - 0x10f8c9fff com.github.Electron.framework (16.2.8) <4C4C4462-5555-3144-A1AC-15EC19C8E608> /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Microsoft Teams Helper (Renderer) [846] UUID: 4C4C4481-5555-3144-A13B-0A2785B65108 Path: /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer) Architecture: x86_64 Parent: Teams [836] Responsible: Teams [836] UID: 504 Footprint: 30.29 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x6219 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Microsoft Teams Helper (Renderer) + 2670) [0x10de71a6e] 1-11 11 ElectronMain + 146 (Electron Framework + 108402) [0x1118c8772] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x11299e349] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x11299da4b] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10354957 (Electron Framework + 17764429) [0x11299f04d] 1-11 11 device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 14793423 (Electron Framework + 112795663) [0x11844000f] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x114a905d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x114ac66ba] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x114b069b2] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 5817 (Electron Framework + 52797401) [0x114b07fd9] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6232 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6234 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x114b00f48] 1-11 11 _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x114adc64d] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x114adcc7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x114b0e72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6235 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x114b00f48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x114ae301d] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x114ae2e88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x114a905d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x114ac66ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6236 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x114b00f48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x114adc6dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x114adcc7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x114b0e72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6237 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x623c Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x623d Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6242 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6244 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6246 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6248 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6249 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6288 Thread name "Media" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x4b1ed Thread name "ThreadPoolSingleThreadSharedForeground1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10de71000 - 0x10de96fff com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4481-5555-3144-A13B-0A2785B65108> /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer) 0x1118ae000 - 0x119bf6fff com.github.Electron.framework (16.2.8) <4C4C4462-5555-3144-A1AC-15EC19C8E608> /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Microsoft Teams Helper (Renderer) [848] UUID: 4C4C4481-5555-3144-A13B-0A2785B65108 Path: /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer) Architecture: x86_64 Parent: Teams [836] Responsible: Teams [836] UID: 504 Footprint: 417.55 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (2.1M cycles, 319.2K instructions, 6.68c/i) Note: 1 idle work queue thread omitted Thread 0x6255 DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (2.1M cycles, 319.2K instructions, 6.68c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Microsoft Teams Helper (Renderer) + 2670) [0x105b81a6e] 1-11 11 ElectronMain + 146 (Electron Framework + 108402) [0x105bd5772] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x106cab349] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x106caaa4b] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10354957 (Electron Framework + 17764429) [0x106cac04d] 1-11 11 device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 14793423 (Electron Framework + 112795663) [0x10c74d00f] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x108d9d5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x108dd36ba] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x108e139b2] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 5817 (Electron Framework + 52797401) [0x108e14fd9] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x626c Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x626e Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x108e0df48] 1-11 11 _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x108de964d] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x108de9c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x108e1b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x626f Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x108e0df48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x108df001d] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x108defe88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x108d9d5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x108dd36ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6271 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6276 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6277 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6278 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6279 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x627a Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x627b Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x627c Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x62c4 Thread name "Watchdog" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x108e0df48] 1-11 11 electron::fuses::IsOnlyLoadAppFromAsarEnabled() + 59623 (Electron Framework + 2101111) [0x105dbbf77] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x108e1b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x634c Thread name "SharedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x108e0df48] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2620787 (Electron Framework + 34077811) [0x107c3ac73] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x108d9d5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x108dd36ba] 1-11 11 _TIFFSwab64BitData + 4840202 (Electron Framework + 52165946) [0x108d7ad3a] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x108e1b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x63de Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x108e0df48] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2620787 (Electron Framework + 34077811) [0x107c3ac73] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x108d9d5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x108dd36ba] 1-11 11 _TIFFSwab64BitData + 4840202 (Electron Framework + 52165946) [0x108d7ad3a] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x108e1b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6528 Thread name "Media" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x4bbb4 Thread name "AudioOutputDevice" 11 samples (1-11) priority 97 (base 97) <IO tier 0> 11 <truncated backtrace> 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 soreceive + 2219 (kernel + 7487339) [0xffffff8000923f6b] 1-11 *11 sbwait + 297 (kernel + 7528409) [0xffffff800092dfd9] 1-11 *11 msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0xaa0311 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x108e0df48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x108de96dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x108de9c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x108e1b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa092f Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x108e0df48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x108de96dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x108de9c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x108e1b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa0930 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x108e0df48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x108de96dd] 1-11 11 _TIFFSwab64BitData + 5293588 (Electron Framework + 52619332) [0x108de9844] 1-11 11 _TIFFSwab64BitData + 5291678 (Electron Framework + 52617422) [0x108de90ce] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x108e1b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105b81000 - 0x105ba6fff com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4481-5555-3144-A13B-0A2785B65108> /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer) 0x105bbb000 - 0x10df03fff com.github.Electron.framework (16.2.8) <4C4C4462-5555-3144-A1AC-15EC19C8E608> /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Microsoft Teams Helper (Renderer) [855] UUID: 4C4C4481-5555-3144-A13B-0A2785B65108 Path: /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer) Architecture: x86_64 Parent: Teams [836] Responsible: Teams [836] UID: 504 Footprint: 122.05 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (552.0K cycles, 117.8K instructions, 4.69c/i) Note: 2 idle work queue threads omitted Thread 0x638d DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 46 (base 46) cpu time <0.001s (304.4K cycles, 52.0K instructions, 5.86c/i) <thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Microsoft Teams Helper (Renderer) + 2670) [0x10e4f1a6e] 1-11 11 ElectronMain + 146 (Electron Framework + 108402) [0x110d45772] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x111e1b349] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x111e1aa4b] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10354957 (Electron Framework + 17764429) [0x111e1c04d] 1-11 11 device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 14793423 (Electron Framework + 112795663) [0x1178bd00f] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x113f0d5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x113f436ba] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x113f839b2] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 5817 (Electron Framework + 52797401) [0x113f84fd9] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6395 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6397 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x113f5964d] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x113f59c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x113f8b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6398 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x113f6001d] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x113f5fe88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x113f0d5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x113f436ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x639a Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x639c Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x639d Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x639e Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x639f Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 14704420 (Electron Framework + 112706660) [0x1178a7464] 1-11 11 _TIFFSwab64BitData + 5439771 (Electron Framework + 52765515) [0x113f7d34b] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x63a0 Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x63a1 Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x63a2 Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x63a4 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ElectronMain + 1482632 (Electron Framework + 1590888) [0x110eaf668] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0x63ae Thread name "Watchdog" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 electron::fuses::IsOnlyLoadAppFromAsarEnabled() + 59623 (Electron Framework + 2101111) [0x110f2bf77] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x113f8b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64ae 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x64af 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x64b2 11 samples (1-11) priority 33 (base 33) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (libskypert.dylib + 236557) [0x11c30ec0d] 1-11 11 ??? (libskypert.dylib + 873540) [0x11c3aa444] 1-11 11 ??? (libskypert.dylib + 873789) [0x11c3aa53d] 1-11 11 ??? (libskypert.dylib + 919229) [0x11c3b56bd] 1-11 11 ??? (libskypert.dylib + 856130) [0x11c3a6042] 1-11 11 ??? (slimcore.node + 4809242) [0x11ba2b21a] 1-11 11 ??? (slimcore.node + 4844661) [0x11ba33c75] 1-11 11 ??? (slimcore.node + 4885937) [0x11ba3ddb1] 1-11 11 spl::eventWait(spl::EventGCD*&, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000l> >) + 83 (libskypert.dylib + 202627) [0x11c306783] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x64b3 11 samples (1-11) priority 47 (base 47) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x64b4 11 samples (1-11) priority 47 (base 47) cpu time <0.001s (91.3K cycles, 15.7K instructions, 5.80c/i) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (libskypert.dylib + 236557) [0x11c30ec0d] 1-11 11 ??? (libskypert.dylib + 873540) [0x11c3aa444] 1-11 11 ??? (libskypert.dylib + 873789) [0x11c3aa53d] 1-11 11 ??? (libskypert.dylib + 919229) [0x11c3b56bd] 1-11 11 ??? (libskypert.dylib + 856130) [0x11c3a6042] 1-11 11 ??? (libskypert.dylib + 891947) [0x11c3aec2b] 1-11 11 spl::semaWait(spl::EventGCD*&, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000l> >) + 68 (libskypert.dylib + 203044) [0x11c306924] 1-11 11 _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 17271) [0x7fff60e4f377] 1-11 11 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 4718) [0x7fff60fd026e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x64c5 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64c6 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64c7 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64c8 11 samples (1-11) priority 97 (base 97) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x64c9 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64da 11 samples (1-11) priority 97 (base 97) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64db 11 samples (1-11) priority 97 (base 97) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64dc 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x4bdcd 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x4bdcf 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default, ipc override default), process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa02db Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x113f596dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x113f59c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x113f8b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa09b0 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x113f596dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x113f59c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x113f8b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa09b1 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x113f596dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x113f59c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x113f8b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa09b2 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x113f596dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x113f59c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x113f8b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa09b3 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x113f596dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x113f59c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x113f8b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa09b4 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x113f596dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x113f59c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x113f8b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa09b5 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <process unclamped, process received importance donation from WindowServer [197], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x113f7df48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x113f596dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x113f59c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x113f8b72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e4f1000 - 0x10e516fff com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4481-5555-3144-A13B-0A2785B65108> /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer) 0x110d2b000 - 0x119073fff com.github.Electron.framework (16.2.8) <4C4C4462-5555-3144-A1AC-15EC19C8E608> /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x11b595000 - 0x11c09cfff slimcore.node (0) <B242AE45-7AE1-3851-9B27-1CE8C4AA6464> /Applications/Microsoft Teams.app/Contents/Resources/app.asar.unpacked/node_modules/slimcore/bin/slimcore.node 0x11c2d5000 - 0x11c6ccfff libskypert.dylib (0) <ED5FA20C-9486-3165-B580-59068806BEEB> /Applications/Microsoft Teams.app/Contents/Resources/app.asar.unpacked/node_modules/slimcore/bin/libskypert.dylib 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Microsoft Teams Helper (Renderer) [856] UUID: 4C4C4481-5555-3144-A13B-0A2785B65108 Path: /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer) Architecture: x86_64 Parent: Teams [836] Responsible: Teams [836] UID: 504 Footprint: 299.17 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (236.0K cycles, 42.5K instructions, 5.55c/i) Note: 1 idle work queue thread omitted Thread 0x649c DispatchQueue 1 Thread name "CrRendererMain" 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (236.0K cycles, 42.5K instructions, 5.55c/i) <thread QoS default (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Microsoft Teams Helper (Renderer) + 2670) [0x1055b4a6e] 1-11 11 ElectronMain + 146 (Electron Framework + 108402) [0x105604772] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x1066da349] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x1066d9a4b] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10354957 (Electron Framework + 17764429) [0x1066db04d] 1-11 11 device::MapperSwitchPro(device::Gamepad const&, device::Gamepad*) + 14793423 (Electron Framework + 112795663) [0x10c17c00f] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1087cc5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x1088026ba] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x1088429b2] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 5817 (Electron Framework + 52797401) [0x108843fd9] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64a0 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x64a2 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10883cf48] 1-11 11 _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x10881864d] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x108818c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10884a72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64a3 Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10883cf48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x10881f01d] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x10881ee88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1087cc5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x1088026ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x64a5 Thread name "GpuMemoryThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64a6 Thread name "Compositor" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64a7 Thread name "ThreadPoolSingleThreadSharedForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64a8 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64a9 Thread name "CompositorTileWorker2" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64aa Thread name "CompositorTileWorker3" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64ab Thread name "CompositorTileWorker4" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64ac Thread name "CompositorTileWorkerBackground" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64c2 Thread name "DedicatedWorker thread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10883cf48] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 2620787 (Electron Framework + 34077811) [0x107669c73] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1087cc5d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x1088026ba] 1-11 11 _TIFFSwab64BitData + 4840202 (Electron Framework + 52165946) [0x1087a9d3a] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10884a72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa9fd36 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10883cf48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x1088186dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x108818c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10884a72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa09fd Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10883cf48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x1088186dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x108818c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10884a72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xaa09fe Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x10883cf48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x1088186dd] 1-11 11 _TIFFSwab64BitData + 5293588 (Electron Framework + 52619332) [0x108818844] 1-11 11 _TIFFSwab64BitData + 5291678 (Electron Framework + 52617422) [0x1088180ce] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x10884a72c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1055b4000 - 0x1055d9fff com.microsoft.teams.helper 1.00.533356 (533356) <4C4C4481-5555-3144-A13B-0A2785B65108> /Applications/Microsoft Teams.app/Contents/Frameworks/Microsoft Teams Helper (Renderer).app/Contents/MacOS/Microsoft Teams Helper (Renderer) 0x1055ea000 - 0x10d932fff com.github.Electron.framework (16.2.8) <4C4C4462-5555-3144-A1AC-15EC19C8E608> /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Microsoft Word [76988] UUID: 8B281AE7-626F-3575-AA9B-2C3471F6CAD3 Path: /Applications/Microsoft Word.app/Contents/MacOS/Microsoft Word Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 223.73 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (445.8K cycles, 82.2K instructions, 5.42c/i) Note: 3 idle work queue threads omitted Thread 0x49c185 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x49c293 DispatchQueue 10 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), thread darwinbg, process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x49c2e6 DispatchQueue 10 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x49c30b DispatchQueue 10 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x49c39a DispatchQueue 10 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), thread darwinbg, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 1-11 11 _pthread_wqthread + 583 (libsystem_pthread.dylib + 9907) [0x7fff6108e6b3] 1-11 11 _dispatch_worker_thread2 + 90 (libdispatch.dylib + 72518) [0x7fff60e5cb46] 1-11 11 _dispatch_root_queue_drain + 324 (libdispatch.dylib + 70588) [0x7fff60e5c3bc] 1-11 11 _dispatch_queue_override_invoke + 763 (libdispatch.dylib + 23123) [0x7fff60e50a53] 1-11 11 _dispatch_client_callout + 8 (libdispatch.dylib + 13885) [0x7fff60e4e63d] 1-11 11 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 9720) [0x7fff60e4d5f8] 1-11 11 ??? (WLMKernel + 20022) [0x10e4b0e36] 1-11 11 ??? (mso20 + 16314) [0x107a14fba] 1-11 11 Mso::Async::InvokeInCallbackContext(Mso::Functor<void ()>&&, Mso::Async::IDispatchQueue*, Mso::Async::Details::IIdleDispatchQueue*, bool) + 151 (mso20 + 16530) [0x107a15092] 1-11 11 ??? (mso20 + 264761) [0x107a51a39] 1-11 11 ??? (mso30 + 200414) [0x108110ede] 1-11 11 ??? (mso30 + 200526) [0x108110f4e] 1-11 11 ??? (mso30 + 201153) [0x1081111c1] 1-11 11 ??? (MicrosoftCSI + 142119) [0x105f56b27] 1-11 11 Mso::Synchronization::MsoWaitForMultipleObjects(unsigned int, void* const*, bool, MsoTimeoutInterval const&, bool, bool) + 359 (mso20 + 341138) [0x107a64492] 1-11 11 ??? (mso20 + 364873) [0x107a6a149] 1-11 11 ??? (WLMKernel + 41423) [0x10e4b61cf] 1-11 11 ??? (WLMKernel + 41615) [0x10e4b628f] 1-11 11 ??? (WLMKernel + 42585) [0x10e4b6659] 1-11 11 ??? (WLMKernel + 57210) [0x10e4b9f7a] 1-11 11 MBUSignaledCondition::WaitForDuration(unsigned int) + 58 (mbukernel + 58562) [0x1077c04c2] 1-11 11 MBUCondition::WaitForDuration(unsigned int) + 25 (mbukernel + 58637) [0x1077c050d] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x49c270 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (52.4K cycles, 5.9K instructions, 8.90c/i) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (merp + 39972) [0x107882c24] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x49c2ee 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x49c381 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x49c3b5 Thread name "com.facebook.react.JavaScript" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 ??? (mso40ui + 436153) [0x108ee37b9] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x49c3b7 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39 (JavaScriptCore + 2264807) [0x7fff38406ee7] 1-11 11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 2258297) [0x7fff38405579] 1-11 11 bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-11 11 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x49c3c7 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x49c4ec 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (82.6K cycles, 22.0K instructions, 3.75c/i) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mso20 + 2177272) [0x107c248f8] 1-11 11 ??? (mso20 + 2170488) [0x107c22e78] 1-11 11 ??? (mso20 + 2170001) [0x107c22c91] 1-11 11 WaitForSingleObjectEx + 35 (WLMKernel + 48256) [0x10e4b7c80] 1-11 11 ??? (WLMKernel + 41423) [0x10e4b61cf] 1-11 11 ??? (WLMKernel + 41615) [0x10e4b628f] 1-11 11 ??? (WLMKernel + 42585) [0x10e4b6659] 1-11 11 ??? (WLMKernel + 57210) [0x10e4b9f7a] 1-11 11 MBUSignaledCondition::WaitForDuration(unsigned int) + 58 (mbukernel + 58562) [0x1077c04c2] 1-11 11 MBUCondition::WaitForDuration(unsigned int) + 85 (mbukernel + 58697) [0x1077c0549] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x49c4ed 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (140.1K cycles, 24.9K instructions, 5.62c/i) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (mso20 + 2177272) [0x107c248f8] 1-11 11 ??? (mso20 + 2170488) [0x107c22e78] 1-11 11 ??? (mso20 + 2170001) [0x107c22c91] 1-11 11 WaitForSingleObjectEx + 35 (WLMKernel + 48256) [0x10e4b7c80] 1-11 11 ??? (WLMKernel + 41423) [0x10e4b61cf] 1-11 11 ??? (WLMKernel + 41615) [0x10e4b628f] 1-11 11 ??? (WLMKernel + 42585) [0x10e4b6659] 1-11 11 ??? (WLMKernel + 57210) [0x10e4b9f7a] 1-11 11 MBUSignaledCondition::WaitForDuration(unsigned int) + 58 (mbukernel + 58562) [0x1077c04c2] 1-11 11 MBUCondition::WaitForDuration(unsigned int) + 85 (mbukernel + 58697) [0x1077c0549] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x49c546 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7ef094 Thread name "com.squareup.SocketRocket.NetworkThread" 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7ef0bb Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x102097000 - 0x10419efff Microsoft Word <8B281AE7-626F-3575-AA9B-2C3471F6CAD3> /Applications/Microsoft Word.app/Contents/MacOS/Microsoft Word 0x105f34000 - 0x106a97fff com.microsoft.csi 16.54 (16.54.21101001) <7E7BA304-03EB-3E0A-9F77-D070EA4B736C> /Applications/Microsoft Outlook.app/Contents/Frameworks/MicrosoftCSI.framework/Versions/A/MicrosoftCSI 0x1077b2000 - 0x107825fff com.microsoft.mbukernel 16.54 (16.54.21101001) <6F64D620-0598-32E7-8519-B8F0D1CEC374> /Applications/Microsoft Outlook.app/Contents/Frameworks/mbukernel.framework/Versions/A/mbukernel 0x107879000 - 0x107890fff com.microsoft.merp 16.54 (16.54.21101001) <B8DF2092-F9C5-3E24-ADFE-797453982157> /Applications/Microsoft Outlook.app/Contents/Frameworks/merp.framework/Versions/A/merp 0x107a11000 - 0x107f98fff com.microsoft.mso20 16.54 (16.54.21101001) <45FA0676-7958-3751-82CA-1C2825CF6985> /Applications/Microsoft Outlook.app/Contents/Frameworks/mso20.framework/Versions/A/mso20 0x1080e0000 - 0x108c2ffff com.microsoft.mso30 16.54 (16.54.21101001) <6BFCC7A8-7B3A-3849-8377-55A61492A1D2> /Applications/Microsoft Outlook.app/Contents/Frameworks/mso30.framework/Versions/A/mso30 0x108e79000 - 0x1095f4fff com.microsoft.mso40ui 16.54 (16.54.21101001) <53FA5437-82E5-32DE-9160-ECE76034F279> /Applications/Microsoft Outlook.app/Contents/Frameworks/mso40ui.framework/Versions/A/mso40ui 0x10e4ac000 - 0x10e51bfff com.microsoft.wlmkernel 16.54 (16.54.21101001) <33E466A0-59B7-38CB-BDED-195E68C6305A> /Applications/Microsoft Outlook.app/Contents/Frameworks/WLMKernel.framework/Versions/A/WLMKernel 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff381de000 - 0x7fff3903efff com.apple.JavaScriptCore 14607 (14607.3.9) <E25D3B54-A072-33F3-AA89-6F8588BF5A05> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff5e0c2000 - 0x7fff5e115fff libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Mini Program [29130] [unique pid 128722] UUID: 4B111166-4E93-3F5B-AA42-7D57E7A3D45E Path: /Applications/WeChat.app/Contents/MacOS/Mini Program.app/Contents/MacOS/Mini Program Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 50.07 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (474.2K cycles, 183.8K instructions, 2.58c/i) Note: 2 idle work queue threads omitted Thread 0x7e42a2 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 288 (Mini Program + 842247) [0x1058d4a07] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7e42ab 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 Thread::start_routine(void*) + 97 (matrixreport + 565441) [0x107c770c1] 1-11 11 detail::RunnableFunctor<void (*)()>::run() + 19 (matrixreport + 572019) [0x107c78a73] 1-11 11 (anonymous namespace)::__anr_checker_thread() + 282 (matrixreport + 832874) [0x107cb856a] 1-11 11 Condition::wait(BaseScopedLock<Mutex>&) + 160 (matrixreport + 546864) [0x107c72830] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7e42c6 Thread name " *8274630" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 mars::comm::Thread::start_routine(void*) + 68 (Mini Program + 5868044) [0x105d9fa0c] 1-11 11 mars::xlog::XloggerAppender::__AsyncLogThread() + 191 (Mini Program + 5850639) [0x105d9b60f] 1-11 11 mars::comm::Condition::wait(long) + 57 (Mini Program + 5865509) [0x105d9f025] 1-11 11 mars::comm::Condition::wait(mars::comm::BaseScopedLock<mars::comm::Mutex>&, long) + 271 (Mini Program + 5868617) [0x105d9fc49] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7e42d0 Thread name "mars::mrs" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 Thread::start_routine(void*) + 97 (matrixreport + 565441) [0x107c770c1] 1-11 11 detail::RunnableFunctor<mars_boost::_bi::bind_t<void, void (*)(SpinLock*), mars_boost::_bi::list1<mars_boost::_bi::value<SpinLock*> > > >::run() + 30 (matrixreport + 1053342) [0x107cee29e] 1-11 11 mars_boost::_bi::bind_t<void, void (*)(SpinLock*), mars_boost::_bi::list1<mars_boost::_bi::value<SpinLock*> > >::operator()() + 57 (matrixreport + 1053449) [0x107cee309] 1-11 11 void mars_boost::_bi::list1<mars_boost::_bi::value<SpinLock*> >::operator()<void (*)(SpinLock*), mars_boost::_bi::list0>(mars_boost::_bi::type<void>, void (*&)(SpinLock*), mars_boost::_bi::list0&, int) + 80 (matrixreport + 1053536) [0x107cee360] 1-11 11 MessageQueue::MessageQueueCreater::__ThreadNewRunloop(SpinLock*) + 87 (matrixreport + 950535) [0x107cd5107] 1-11 11 MessageQueue::RunLoop::Run() + 1977 (matrixreport + 940025) [0x107cd27f9] 1-11 11 MessageQueue::Cond::Wait(BaseScopedLock<Mutex>&, long) + 46 (matrixreport + 1028766) [0x107ce829e] 1-11 11 Condition::wait(BaseScopedLock<Mutex>&, long) + 181 (matrixreport + 555717) [0x107c74ac5] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7e42e5 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (Mini Program + 13175736) [0x106497bb8] 1-11 11 sleep + 41 (libsystem_c.dylib + 501622) [0x7fff60f5f776] 1-11 11 __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x7e42e6 Thread name "KSCrash Exception Handler (Secondary)" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7e42e7 Thread name "KSCrash Exception Handler (Primary)" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ??? (kernel + 2007488) [0xffffff80003ea1c0] (suspended) 1-11 Thread 0x7e42e8 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (326.8K cycles, 144.5K instructions, 2.26c/i) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 ??? (Mini Program + 13201110) [0x10649ded6] 1-11 11 ??? (Mini Program + 13202155) [0x10649e2eb] 1-11 11 usleep + 53 (libsystem_c.dylib + 501768) [0x7fff60f5f808] 1-11 11 __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x7e42e9 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user initiated), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 39 (JavaScriptCore + 2264807) [0x7fff38406ee7] 1-11 11 bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 2258297) [0x7fff38405579] 1-11 11 bmalloc::Scavenger::threadRunLoop() + 139 (JavaScriptCore + 2260299) [0x7fff38405d4b] 1-11 11 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 82 (JavaScriptCore + 2243650) [0x7fff38401c42] 1-11 11 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 35338) [0x7fff5e0caa0a] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x7e42ee Thread name "com.apple.coreanimation.render-server" 11 samples (1-11) priority 55 (base 55) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7e42f9 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x7e4305 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105807000 - 0x10684efff com.tencent.xinWeChat.MiniProgram 1.1.0 (1) <4B111166-4E93-3F5B-AA42-7D57E7A3D45E> /Applications/WeChat.app/Contents/MacOS/Mini Program.app/Contents/MacOS/Mini Program 0x107bed000 - 0x107d38fff com.tencent.wc.mp.matrixreport 1.0 (1) <C29DB913-09F8-3137-8325-0AA3A0E8C429> /Applications/WeChat.app/Contents/MacOS/Mini Program.app/Contents/Frameworks/matrixreport.framework/Versions/A/matrixreport 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff381de000 - 0x7fff3903efff com.apple.JavaScriptCore 14607 (14607.3.9) <E25D3B54-A072-33F3-AA89-6F8588BF5A05> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff5e0c2000 - 0x7fff5e115fff libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60ee5000 - 0x7fff60f6cfff libsystem_c.dylib (1272.250.3) <6016EDA1-440B-34D7-A232-686CD7FBEE90> /usr/lib/system/libsystem_c.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mobileactivationd [4510] UUID: 97B53C64-6FE2-3298-AF9A-4645E85D9F79 Path: /usr/libexec/mobileactivationd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2636 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x53a17 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x107193000 - 0x1071c3fff mobileactivationd <97B53C64-6FE2-3298-AF9A-4645E85D9F79> /usr/libexec/mobileactivationd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: mobileassetd [168] UUID: CF303F19-4927-3D00-A605-EA778CBE6F0C Path: /usr/libexec/mobileassetd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 32.60 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x387 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b603000 - 0x10b657fff mobileassetd <CF303F19-4927-3D00-A605-EA778CBE6F0C> /usr/libexec/mobileassetd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: MTLCompilerService [463] UUID: 5100C43B-717E-37CB-82DD-BC3DE4B9BEF3 Path: /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService Architecture: x86_64 Parent: launchd [1] Responsible: WindowServer [197] UID: 88 Sudden Term: Tracked (allows idle exit) Footprint: 12.86 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1252 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10569a000 - 0x10569bfff MTLCompilerService <5100C43B-717E-37CB-82DD-BC3DE4B9BEF3> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: MTLCompilerService [789] UUID: 5100C43B-717E-37CB-82DD-BC3DE4B9BEF3 Path: /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService Architecture: x86_64 Parent: launchd [1] Responsible: Dropbox Helper (GPU) [433] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 6876 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3cf4 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10a950000 - 0x10a951fff MTLCompilerService <5100C43B-717E-37CB-82DD-BC3DE4B9BEF3> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: MTLCompilerService [4080] UUID: 5100C43B-717E-37CB-82DD-BC3DE4B9BEF3 Path: /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService Architecture: x86_64 Parent: launchd [1] Responsible: Finder [278] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 10.57 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x4c7c9 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1059f6000 - 0x1059f7fff MTLCompilerService <5100C43B-717E-37CB-82DD-BC3DE4B9BEF3> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: MTLCompilerService [14007] UUID: 5100C43B-717E-37CB-82DD-BC3DE4B9BEF3 Path: /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService Architecture: x86_64 Parent: launchd [1] Responsible: Microsoft Outlook [4828] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 9160 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x152631 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x105751000 - 0x105752fff MTLCompilerService <5100C43B-717E-37CB-82DD-BC3DE4B9BEF3> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: MTLCompilerService [8667] [unique pid 108282] UUID: 5100C43B-717E-37CB-82DD-BC3DE4B9BEF3 Path: /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService Architecture: x86_64 Parent: launchd [1] Responsible: iTunes [8660] [unique pid 108275] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 12.88 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x5ffef6 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1062ad000 - 0x1062aefff MTLCompilerService <5100C43B-717E-37CB-82DD-BC3DE4B9BEF3> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: MTLCompilerService [8671] [unique pid 108286] UUID: 5100C43B-717E-37CB-82DD-BC3DE4B9BEF3 Path: /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService Architecture: x86_64 Parent: launchd [1] Responsible: iTunes [8660] [unique pid 108275] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 10.33 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x600389 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10af65000 - 0x10af66fff MTLCompilerService <5100C43B-717E-37CB-82DD-BC3DE4B9BEF3> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: MTLCompilerService [10152] [unique pid 109761] UUID: 5100C43B-717E-37CB-82DD-BC3DE4B9BEF3 Path: /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService Architecture: x86_64 Parent: launchd [1] Responsible: Preview [6302] [unique pid 105926] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 26.43 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x64cbc3 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10e0c9000 - 0x10e0cafff MTLCompilerService <5100C43B-717E-37CB-82DD-BC3DE4B9BEF3> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: MTLCompilerService [62960] [unique pid 162543] UUID: 5100C43B-717E-37CB-82DD-BC3DE4B9BEF3 Path: /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService Architecture: x86_64 Parent: launchd [1] Responsible: Vectorworks [62926] [unique pid 162509] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 8076 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa4d0f7 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10ccd0000 - 0x10ccd1fff MTLCompilerService <5100C43B-717E-37CB-82DD-BC3DE4B9BEF3> /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: nbagent [424] UUID: 5E82B72A-AE32-3B85-9F33-90F41E15DE3C Path: /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 5128 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (52.3K cycles, 22.3K instructions, 2.35c/i) Note: 2 idle work queue threads omitted Thread 0xe84 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x13c6 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a79f000 - 0x10a7abfff nbagent <5E82B72A-AE32-3B85-9F33-90F41E15DE3C> /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbagent.app/Contents/MacOS/nbagent 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: nbstated [86] UUID: F1462440-2D6A-3941-BDF6-7AF1E3CB71A5 Path: /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbstated Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 2400 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x288 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10167a000 - 0x10167bfff nbstated <F1462440-2D6A-3941-BDF6-7AF1E3CB71A5> /System/Library/PrivateFrameworks/Noticeboard.framework/Versions/A/Resources/nbstated 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: nehelper [153] UUID: DB827C65-2DED-32FB-9ECE-716FC20D9443 Path: /usr/libexec/nehelper Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 3784 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x349 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f67b000 - 0x10f6a9fff nehelper <DB827C65-2DED-32FB-9ECE-716FC20D9443> /usr/libexec/nehelper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: nesessionmanager [460] UUID: BAAA6310-7768-349B-B247-992E93AB181F Path: /usr/libexec/nesessionmanager Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 3364 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x11bb 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x11c1 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10defb000 - 0x10df81fff nesessionmanager <BAAA6310-7768-349B-B247-992E93AB181F> /usr/libexec/nesessionmanager 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: netbiosd [398] UUID: 70C46A62-0860-33F1-BB7A-4C732657A7EC Path: /usr/sbin/netbiosd Architecture: x86_64 Parent: launchd [1] UID: 222 Sudden Term: Tracked Footprint: 3068 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xeee DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 3> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1033ae000 - 0x1033eefff netbiosd <70C46A62-0860-33F1-BB7A-4C732657A7EC> /usr/sbin/netbiosd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: networkserviceproxy [353] UUID: 4E11F2FB-C008-3B77-844D-4A5258993E02 Path: /usr/libexec/networkserviceproxy Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 4400 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xaec 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b482000 - 0x10b49dfff networkserviceproxy (269.200.11) <4E11F2FB-C008-3B77-844D-4A5258993E02> /usr/libexec/networkserviceproxy 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: nfcd [16874] UUID: 435F71E5-A973-308B-8D09-ED664584C3F0 Path: /usr/libexec/nfcd Architecture: x86_64 Parent: launchd [1] UID: 260 Sudden Term: Tracked (allows idle exit) Footprint: 2068 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1c5293 11 samples (1-11) priority 50 (base 50) <process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10ce3a000 - 0x10cf49fff nfcd (296.2) <435F71E5-A973-308B-8D09-ED664584C3F0> /usr/libexec/nfcd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: NotificationAgent [420] UUID: 5E9FF1C1-7BBC-3E2C-8087-B26C44BD3D60 Path: /Library/Application Support/Paragon Software/com.paragon-software.ntfs.notification-agent.app/Contents/MacOS/NotificationAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 8716 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0xe74 DispatchQueue 1 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (NotificationAgent + 13662) [0x102f9055e] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x1327 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested user interactive), timers tier 3 (coalesced), IO tier 1> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102f8d000 - 0x102feafff com.paragon-software.ntfs.notification-agent 15.5.90 (15.5.90) <5E9FF1C1-7BBC-3E2C-8087-B26C44BD3D60> /Library/Application Support/Paragon Software/com.paragon-software.ntfs.notification-agent.app/Contents/MacOS/NotificationAgent 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: NotificationCenter [314] UUID: 37463780-AEB5-36C2-A082-1A7AAFCBC1F5 Path: /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 65.41 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (52.9K cycles, 24.7K instructions, 2.14c/i) Note: 2 idle work queue threads omitted Thread 0x932 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (NotificationCenter + 386506) [0x10d8555ca] 1-11 11 autoreleasepool<A>(invoking:) + 47 (libswiftObjectiveC.dylib + 12111) [0x7fff60ba9f4f] 1-11 11 ??? (NotificationCenter + 391918) [0x10d856aee] 1-11 11 ??? (NotificationCenter + 388583) [0x10d855de7] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa46 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d7f7000 - 0x10d952fff com.apple.notificationcenterui 1.0 (747.8) <37463780-AEB5-36C2-A082-1A7AAFCBC1F5> /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60ba7000 - 0x7fff60baafff libswiftObjectiveC.dylib (1001.8.63.13) <A4201F26-A2B3-3F2A-8B0F-D17F166C26BC> /usr/lib/swift/libswiftObjectiveC.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: notifyd [113] Path: /usr/sbin/notifyd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 2080 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (245.0K cycles, 60.5K instructions, 4.05c/i) Note: 2 idle work queue threads omitted Thread 0x282 DispatchQueue 11 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: nsurlsessiond [171] UUID: F67E0649-7522-3D71-A2A9-CDD24596382C Path: /usr/libexec/nsurlsessiond Architecture: x86_64 Parent: launchd [1] UID: 242 Sudden Term: Tracked (allows idle exit) Footprint: 8516 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (67.0K cycles, 24.5K instructions, 2.74c/i) Note: 1 idle work queue thread omitted Thread 0x3b0 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 662 (nsurlsessiond + 23935) [0x10c0efd7f] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10c0ea000 - 0x10c145fff nsurlsessiond (978.6) <F67E0649-7522-3D71-A2A9-CDD24596382C> /usr/libexec/nsurlsessiond 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: nsurlsessiond [285] UUID: F67E0649-7522-3D71-A2A9-CDD24596382C Path: /usr/libexec/nsurlsessiond Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 5324 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (81.9K cycles, 23.8K instructions, 3.44c/i) Note: 2 idle work queue threads omitted Thread 0x81f DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 662 (nsurlsessiond + 23935) [0x10b6c5d7f] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b6c0000 - 0x10b71bfff nsurlsessiond (978.6) <F67E0649-7522-3D71-A2A9-CDD24596382C> /usr/libexec/nsurlsessiond 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: nsurlstoraged [352] UUID: E203D2F5-CA2C-33E6-861A-4BDFCFD31446 Path: /usr/libexec/nsurlstoraged Architecture: x86_64 Parent: launchd [1] UID: 243 Sudden Term: Tracked (allows idle exit) Footprint: 4556 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xace 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10cfb9000 - 0x10cfd1fff nsurlstoraged <E203D2F5-CA2C-33E6-861A-4BDFCFD31446> /usr/libexec/nsurlstoraged 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: nsurlstoraged [364] UUID: E203D2F5-CA2C-33E6-861A-4BDFCFD31446 Path: /usr/libexec/nsurlstoraged Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 15.39 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xce7 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 _nsurlstoraged_main + 740 (CFNetwork + 758476) [0x7fff33e572cc] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100d20000 - 0x100d38fff nsurlstoraged <E203D2F5-CA2C-33E6-861A-4BDFCFD31446> /usr/libexec/nsurlstoraged 0x7fff33d9e000 - 0x7fff34140fff com.apple.CFNetwork 978.6 (978.6) <F6AC3859-B6F9-3212-A357-54AA096DAA9E> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: opendirectoryd [84] UUID: 6BEA93C4-817A-3246-95B2-54AF33CF14D1 Path: /usr/libexec/opendirectoryd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 28.02 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 4 idle work queue threads omitted Thread 0x2c4 DispatchQueue 10 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 1-11 11 _pthread_wqthread + 583 (libsystem_pthread.dylib + 9907) [0x7fff6108e6b3] 1-11 11 _dispatch_worker_thread2 + 90 (libdispatch.dylib + 72518) [0x7fff60e5cb46] 1-11 11 _dispatch_root_queue_drain + 657 (libdispatch.dylib + 70921) [0x7fff60e5c509] 1-11 11 _dispatch_client_callout + 8 (libdispatch.dylib + 13885) [0x7fff60e4e63d] 1-11 11 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 9720) [0x7fff60e4d5f8] 1-11 11 ??? (opendirectoryd + 169634) [0x1043b06a2] 1-11 11 sleep + 41 (libsystem_c.dylib + 501622) [0x7fff60f5f776] 1-11 11 __semwait_signal + 10 (libsystem_kernel.dylib + 20270) [0x7fff60fd3f2e] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x30a DispatchQueue 10 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2ce DispatchQueue 969 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 1-11 11 _pthread_wqthread + 583 (libsystem_pthread.dylib + 9907) [0x7fff6108e6b3] 1-11 11 _dispatch_worker_thread2 + 90 (libdispatch.dylib + 72518) [0x7fff60e5cb46] 1-11 11 _dispatch_root_queue_drain + 324 (libdispatch.dylib + 70588) [0x7fff60e5c3bc] 1-11 11 _dispatch_async_redirect_invoke + 703 (libdispatch.dylib + 21667) [0x7fff60e504a3] 1-11 11 _dispatch_continuation_pop + 414 (libdispatch.dylib + 24038) [0x7fff60e50de6] 1-11 11 _dispatch_client_callout + 8 (libdispatch.dylib + 13885) [0x7fff60e4e63d] 1-11 11 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 9720) [0x7fff60e4d5f8] 1-11 11 __identitysvc + 10 (libsystem_kernel.dylib + 127430) [0x7fff60fee1c6] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0x2c6 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0x2d1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104387000 - 0x1043fffff opendirectoryd (483.250.4) <6BEA93C4-817A-3246-95B2-54AF33CF14D1> /usr/libexec/opendirectoryd 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60ee5000 - 0x7fff60f6cfff libsystem_c.dylib (1272.250.3) <6016EDA1-440B-34D7-A232-686CD7FBEE90> /usr/lib/system/libsystem_c.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: PAH_Extension [356] UUID: A52374C3-0F9D-3062-A636-131B737C4589 Path: /System/Library/Input Methods/PressAndHold.app/Contents/PlugIns/PAH_Extension.appex/Contents/MacOS/PAH_Extension Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 7628 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0xb02 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSExtensionMain + 51 (Foundation + 2339980) [0x7fff3738f48c] 1-11 11 ??? (PlugInKit + 84895) [0x7fff57147b9f] 1-11 11 ??? (PlugInKit + 83603) [0x7fff57147693] 1-11 11 ??? (PlugInKit + 84043) [0x7fff5714784b] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xb09 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1010ec000 - 0x1010effff PAH_Extension <A52374C3-0F9D-3062-A636-131B737C4589> /System/Library/Input Methods/PressAndHold.app/Contents/PlugIns/PAH_Extension.appex/Contents/MacOS/PAH_Extension 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff57133000 - 0x7fff57156fff com.apple.pluginkit.framework 1.0 (1) <B00A2028-4490-3BEA-B0F1-082BB7C050DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit 0x7fff5c9ed000 - 0x7fff5cac6fff com.apple.ViewBridge 407 (407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: parsecd [336] UUID: 48852833-EE0D-3AED-A1A9-DCF39924F8AE Path: /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 12.20 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa08 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 9 (parsecd + 48633) [0x10d226df9] 1-11 11 main() + 248 (parsecd + 58376) [0x10d229408] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d21b000 - 0x10d341fff parsecd (213.5.3) <48852833-EE0D-3AED-A1A9-DCF39924F8AE> /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: passd [16872] UUID: 4F1B53B8-7CBC-3D71-B75B-3ABE7348C2C4 Path: /System/Library/PrivateFrameworks/PassKitCore.framework/passd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 12.78 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (116.0K cycles, 23.9K instructions, 4.85c/i) Note: 1 idle work queue thread omitted Thread 0x1c522b DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (passd + 8340) [0x10536d094] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10536b000 - 0x105554fff passd (1418.48.7.18.1) <4F1B53B8-7CBC-3D71-B75B-3ABE7348C2C4> /System/Library/PrivateFrameworks/PassKitCore.framework/passd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: pboard [282] UUID: DE2DD400-84BD-36B4-B0CE-2AF6CFA7C112 Path: /usr/libexec/pboard Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 6328 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x809 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (pboard + 3426) [0x10b277d62] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b277000 - 0x10b277fff pboard (1575.405) <DE2DD400-84BD-36B4-B0CE-2AF6CFA7C112> /usr/libexec/pboard 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: pbs [400] UUID: A1D371F0-3488-36F5-8C62-AD1DA072C355 Path: /System/Library/CoreServices/pbs Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2776 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xdf2 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10b5f0000 - 0x10b601fff pbs <A1D371F0-3488-36F5-8C62-AD1DA072C355> /System/Library/CoreServices/pbs 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: periodic-wrapper [4391] UUID: C0C2A67A-3895-3108-AF4A-5A8C78CC8CB5 Path: /usr/libexec/periodic-wrapper Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 460 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x53715 DispatchQueue 11 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 3> 11 _dispatch_sig_thread + 53 (libdispatch.dylib + 77534) [0x7fff60e5dede] 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10c63b000 - 0x10c63bfff periodic-wrapper <C0C2A67A-3895-3108-AF4A-5A8C78CC8CB5> /usr/libexec/periodic-wrapper 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: periodic-wrapper [60955] UUID: C0C2A67A-3895-3108-AF4A-5A8C78CC8CB5 Path: /usr/libexec/periodic-wrapper Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 464 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x4336dc 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 3> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x102871000 - 0x102871fff periodic-wrapper <C0C2A67A-3895-3108-AF4A-5A8C78CC8CB5> /usr/libexec/periodic-wrapper 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: photoanalysisd [895] UUID: 700158DC-EFDE-36C6-85BD-DB92AA5681A0 Path: /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1552 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa1e8 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e802000 - 0x10e803fff photoanalysisd <700158DC-EFDE-36C6-85BD-DB92AA5681A0> /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: photolibraryd [807] UUID: 71A15FE1-FB24-35A0-ABD6-A40A48083499 Path: /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Support/photolibraryd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 3664 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3fbd 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x107619000 - 0x107942fff photolibraryd <71A15FE1-FB24-35A0-ABD6-A40A48083499> /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Support/photolibraryd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: pkd [302] UUID: 82FB7D9A-0856-3F4B-AB5B-75E545299CFA Path: /usr/libexec/pkd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 7692 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x8b8 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1037e2000 - 0x103808fff pkd (212.250.3) <82FB7D9A-0856-3F4B-AB5B-75E545299CFA> /usr/libexec/pkd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: PowerCADD [12485] Architecture: i386 Footprint: 118.46 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:30 -0800 Num samples: 1 (1) Note: 2 idle work queue threads omitted Thread 0x101fe8 DispatchQueue 1 1 sample (1) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 1 ??? [0x24b5] 1 1 ??? [0x24ec] 1 1 ??? [0x519dd5] 1 1 ??? [0x519d31] 1 1 ??? [0x4fe934] 1 1 RunApplicationEventLoop + 174 (HIToolbox + 1712601) [0x92f821d9] 1 1 _AcquireNextEvent + 58 (HIToolbox + 1762476) [0x92f8e4ac] 1 1 ReceiveNextEventCommon + 741 (HIToolbox + 40811) [0x92de9f6b] 1 1 RunCurrentEventLoopInMode + 323 (HIToolbox + 41585) [0x92dea271] 1 1 CFRunLoopRunInMode + 82 (CoreFoundation + 340449) [0x938651e1] 1 1 CFRunLoopRunSpecific + 584 (CoreFoundation + 238400) [0x9384c340] 1 1 __CFRunLoopRun + 2896 (CoreFoundation + 242061) [0x9384d18d] 1 1 __CFRunLoopServiceMachPort + 289 (CoreFoundation + 244323) [0x9384da63] 1 1 mach_msg_trap + 10 (libsystem_kernel.dylib + 4546) [0xa7d401c2] 1 *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1 Thread 0x10201d 1 sample (1) priority 4 (base 4) <process suppressed, timers tier 5 (throttled), IO tier 2> 1 thread_start + 34 (libsystem_pthread.dylib + 10190) [0xa7df27ce] 1 1 _pthread_start + 78 (libsystem_pthread.dylib + 26615) [0xa7df67f7] 1 1 _pthread_body + 137 (libsystem_pthread.dylib + 13816) [0xa7df35f8] 1 1 PrivateMPEntryPoint + 51 (CarbonCore + 541794) [0x948e9462] 1 1 ??? [0xd1a5e7] 1 1 ??? [0xd1a6aa] 1 1 ??? [0xcfd761] 1 1 mach_wait_until + 10 (libsystem_kernel.dylib + 4894) [0xa7d4031e] 1 *1 ??? (kernel + 1739280) [0xffffff80003a8a10] 1 Thread 0x102097 Thread name "com.apple.CFSocket.private" 1 sample (1) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process suppressed, timers tier 5 (throttled), IO tier 2> 1 <truncated backtrace> 1 1 __select + 10 (libsystem_kernel.dylib + 33458) [0xa7d472b2] 1 *1 ??? (kernel + 7168864) [0xffffff80008d6360] 1 Binary Images: 0x92de0000 - 0x93162fff com.apple.HIToolbox 2.1.1 (918.7) <57D8E18B-2E59-3DAF-BF46-75DEFB58CED0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x93812000 - 0x93c4cfff com.apple.CoreFoundation 6.9 (1575.405) <F1CC263B-4936-396B-B6D9-8CB06EBEF2EA> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x94865000 - 0x94b44fff com.apple.CoreServices.CarbonCore 1178.33 (1178.33) <9CEC8866-FBAD-3000-88A3-3451F1A09F95> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0xa7d3f000 - 0xa7d67fff libsystem_kernel.dylib (4903.278.70) <12ABC81E-9EC6-3E76-85AA-FFD1EECD3419> /usr/lib/system/libsystem_kernel.dylib 0xa7df0000 - 0xa7dfbfff libsystem_pthread.dylib (330.250.2) <5E586CDB-3E20-39C1-8194-1FA564E947DD> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: PowerCADD [12485] UUID: 586572E1-B471-317B-A1FE-A2C6EDDE073B Path: /Applications/PowerCADD 9/PowerCADD.app/Contents/MacOS/PowerCADD Architecture: i386 Parent: launchd [1] UID: 504 Footprint: 118.46 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:30 -0800 Num samples: 3 (2-4) CPU Time: 7.556s (27.9G cycles, 14.8G instructions, 1.89c/i) Binary Images: 0x1000 - 0x6fff PowerCADD <586572E1-B471-317B-A1FE-A2C6EDDE073B> /Applications/PowerCADD 9/PowerCADD.app/Contents/MacOS/PowerCADD Process: PowerCADD [12485] UUID: 586572E1-B471-317B-A1FE-A2C6EDDE073B Path: /Applications/PowerCADD 9/PowerCADD.app/Contents/MacOS/PowerCADD Architecture: i386 Parent: launchd [1] UID: 504 Footprint: 118.46 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 6 (6-11) CPU Time: 7.556s (27.9G cycles, 14.8G instructions, 1.89c/i) Binary Images: 0x1000 - 0x6fff PowerCADD <586572E1-B471-317B-A1FE-A2C6EDDE073B> /Applications/PowerCADD 9/PowerCADD.app/Contents/MacOS/PowerCADD Process: powerd [64] UUID: 871EA0E0-E5CD-3CF1-8EED-641D96503C48 Path: /System/Library/CoreServices/powerd.bundle/powerd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 2672 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (910.1K cycles, 291.3K instructions, 3.12c/i) Note: 1 idle work queue thread omitted Thread 0x25a DispatchQueue 1 11 samples (1-11) priority 31 (base 31) cpu time <0.001s (707.6K cycles, 256.6K instructions, 2.76c/i) <thread QoS default (requested default), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (powerd + 185251) [0x1056923a3] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105665000 - 0x1056a4fff powerd (733.250.13) <871EA0E0-E5CD-3CF1-8EED-641D96503C48> /System/Library/CoreServices/powerd.bundle/powerd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Preview [6302] [unique pid 105926] UUID: 9BDA0774-432D-30FB-91EA-C7A1A8966169 Path: /Applications/Preview.app/Contents/MacOS/Preview Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 1155.31 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (542.5K cycles, 106.1K instructions, 5.11c/i) Note: 3 idle work queue threads omitted Thread 0x5cd1ed DispatchQueue 1 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (404.9K cycles, 75.5K instructions, 5.36c/i) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 4 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5cd248 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 4 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x5dd4fd Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 4 (base 4) <thread QoS user initiated (requested user initiated), process sudden termination dirty, process suppressed, timers tier 4 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x64cbb9 11 samples (1-11) priority 4 (base 4) <thread QoS default (requested default), process sudden termination dirty, process suppressed, timers tier 4 (throttled), IO tier 2> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x100b1b000 - 0x100d1cfff Preview <9BDA0774-432D-30FB-91EA-C7A1A8966169> /Applications/Preview.app/Contents/MacOS/Preview 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: printtool [775] UUID: 681E00AB-8CFC-3341-9F3C-CBF5A1669273 Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/printtool Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1732 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x341f 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10e4fa000 - 0x10e50afff printtool <681E00AB-8CFC-3341-9F3C-CBF5A1669273> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/printtool 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ProtectedCloudKeySyncing [30480] [unique pid 130072] UUID: AAE1FA81-91E3-3C85-8BDD-69B17AFC757A Path: /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Helpers/ProtectedCloudKeySyncing Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2664 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x8225a8 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (ProtectedCloudKeySyncing + 141749) [0x10d44b9b5] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d429000 - 0x10d456fff ProtectedCloudKeySyncing (475.270.1) <AAE1FA81-91E3-3C85-8BDD-69B17AFC757A> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Helpers/ProtectedCloudKeySyncing 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: QuickLookUIService [690] UUID: 11379BE0-60A7-3A9A-9BC4-BD4D6ACE71A2 Path: /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService Architecture: x86_64 Parent: launchd [1] Responsible: Finder [278] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 175.62 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x2524 DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Finder [278], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 40 (QuickLookUIService + 7197) [0x102617c1d] 1-11 11 NSViewServiceApplicationMain + 2830 (ViewBridge + 50108) [0x7fff5c9f93bc] 1-11 11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process dropped importance donation from Finder [278]> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process received importance donation from Finder [278]> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x2540 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Finder [278], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process dropped importance donation from Finder [278]> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process received importance donation from Finder [278]> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x248f51 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Finder [278], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process dropped importance donation from Finder [278]> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process received importance donation from Finder [278]> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Thread 0x4eb9f7 Thread name "com.apple.coremedia.imagequeue.coreanimation.common" 11 samples (1-11) priority 54 (base 54) <process sudden termination dirty, process unclamped, process received importance donation from Finder [278], IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *3 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-3 <process dropped importance donation from Finder [278]> *1 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 4 <process received importance donation from Finder [278]> *7 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 5-11 Binary Images: 0x102616000 - 0x102620fff com.apple.quicklook.QuickLookUIService 1.0 (1) <11379BE0-60A7-3A9A-9BC4-BD4D6ACE71A2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff5c9ed000 - 0x7fff5cac6fff com.apple.ViewBridge 407 (407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: QuickLookUIService [16690] UUID: 11379BE0-60A7-3A9A-9BC4-BD4D6ACE71A2 Path: /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService Architecture: x86_64 Parent: launchd [1] Responsible: Microsoft Outlook [4828] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 42.84 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (114.8K cycles, 35.1K instructions, 3.27c/i) Note: 2 idle work queue threads omitted Thread 0x1bda92 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 40 (QuickLookUIService + 7197) [0x108fcac1d] 1-11 11 NSViewServiceApplicationMain + 2830 (ViewBridge + 50108) [0x7fff5c9f93bc] 1-11 11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x1bdaac Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108fc9000 - 0x108fd3fff com.apple.quicklook.QuickLookUIService 1.0 (1) <11379BE0-60A7-3A9A-9BC4-BD4D6ACE71A2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff5c9ed000 - 0x7fff5cac6fff com.apple.ViewBridge 407 (407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: rapportd [309] UUID: A79549D9-1151-321F-81C4-43626418E420 Path: /usr/libexec/rapportd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 4496 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x900 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (rapportd + 170400) [0x10383f9a0] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x103816000 - 0x103883fff rapportd (174.23) <A79549D9-1151-321F-81C4-43626418E420> /usr/libexec/rapportd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: recentsd [98175] UUID: B25EDB5A-1968-36E4-B223-059B513D3D4A Path: /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/Support/recentsd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2604 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x58813e DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (recentsd + 7700) [0x1029aae14] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1029a9000 - 0x1029cffff recentsd (656) <B25EDB5A-1968-36E4-B223-059B513D3D4A> /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/Support/recentsd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ReportCrash [510] UUID: 706046B6-DEA3-3914-917D-D4562B1561C5 Path: /System/Library/CoreServices/ReportCrash Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1056 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x159b 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x508ebc 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a18b000 - 0x10a1aafff ReportCrash (938.29) <706046B6-DEA3-3914-917D-D4562B1561C5> /System/Library/CoreServices/ReportCrash 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ReportCrash [511] UUID: 706046B6-DEA3-3914-917D-D4562B1561C5 Path: /System/Library/CoreServices/ReportCrash Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 84.89 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x15e2 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (ReportCrash + 10163) [0x10bd617b3] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa3cfc6 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa3d00c 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10bd5f000 - 0x10bd7efff ReportCrash (938.29) <706046B6-DEA3-3914-917D-D4562B1561C5> /System/Library/CoreServices/ReportCrash 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: revisiond [104] UUID: DD098DE8-7997-335E-9B39-0A6F46F6AF48 Path: /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 13.74 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x28d 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x138a 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4319092) [0xffffff800061e774] 1-11 *11 spec_read + 672 (kernel + 4425648) [0xffffff80006387b0] 1-11 *11 ??? (AppleFSCompressionTypeDataless + 6351) [0xffffff7f8331b8cf] 1-11 *11 msleep + 98 (kernel + 7169490) [0xffffff80008d65d2] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Binary Images: 0x100ef8000 - 0x100f3dfff revisiond <DD098DE8-7997-335E-9B39-0A6F46F6AF48> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff7f8331a000 - 0xffffff7f8331bfff com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 96.200.3 (1.0.0d1) <BAB0211D-FAAD-3C27-B780-EA7D44D5A24B> /System/Library/Extensions/AppleFSCompressionTypeDataless.kext/Contents/MacOS/AppleFSCompressionTypeDataless *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: routined [321] UUID: 4802BBE0-B59A-3913-83BC-A3E0059BAF4A Path: /usr/libexec/routined Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 17.45 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x959 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (routined + 5946) [0x10f88773a] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f886000 - 0x10f887fff routined (558.12.5) <4802BBE0-B59A-3913-83BC-A3E0059BAF4A> /usr/libexec/routined 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: rtcreportingd [72172] UUID: BA6C6932-7A4F-3D7B-B94B-F80098809679 Path: /usr/libexec/rtcreportingd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 3640 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x47a34a DispatchQueue 1 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10aedd000 - 0x10af09fff rtcreportingd (9.50.2) <BA6C6932-7A4F-3D7B-B94B-F80098809679> /usr/libexec/rtcreportingd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SafariBookmarksSyncAgent [716] UUID: C1CA5E76-4753-3885-97E7-B95FA8BA6460 Path: /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 11.95 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (314.5K cycles, 82.8K instructions, 3.80c/i) Note: 3 idle work queue threads omitted Thread 0x2c5f DispatchQueue 1 11 samples (1-11) priority 20 (base 20) cpu time <0.001s (107.5K cycles, 31.0K instructions, 3.47c/i) <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (SafariBookmarksSyncAgent + 8668) [0x10e2e51dc] 1-11 11 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 970970) [0x7fff372410da] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2c65 Thread name "JavaScriptCore bmalloc scavenger" 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested user initiated), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Binary Images: 0x10e2e3000 - 0x10e36efff com.apple.SafariBookmarksSyncAgent 14611 (14611.3.10.1.7) <C1CA5E76-4753-3885-97E7-B95FA8BA6460> /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SafariLaunchAgent [16865] UUID: 9B469083-B821-3866-94D4-F57C7282BA40 Path: /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariLaunchAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 10.64 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1c5228 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x107954000 - 0x107955fff SafariLaunchAgent <9B469083-B821-3866-94D4-F57C7282BA40> /System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariLaunchAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SafeEjectGPUAgent [394] UUID: 95550CE5-E8DA-3AFA-945A-2DBF9AEF9347 Path: /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/MacOS/SafeEjectGPUAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1080 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xdc5 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, process unclamped, IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x109951000 - 0x109953fff SafeEjectGPUAgent <95550CE5-E8DA-3AFA-945A-2DBF9AEF9347> /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/MacOS/SafeEjectGPUAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SafeEjectGPUService [395] UUID: F48801BA-8995-3BCF-8C50-9247471805E9 Path: /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/XPCServices/SafeEjectGPUService.xpc/Contents/MacOS/SafeEjectGPUService Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1720 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xdcc 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x105bb7000 - 0x105bbdfff SafeEjectGPUService <F48801BA-8995-3BCF-8C50-9247471805E9> /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/XPCServices/SafeEjectGPUService.xpc/Contents/MacOS/SafeEjectGPUService 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: sandboxd [60808] [unique pid 160393] UUID: C77FDC9C-3415-39DA-8B59-5248ABD043AB Path: /usr/libexec/sandboxd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 4456 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0xa210a7 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0xa21175 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), process sudden termination clean, IO tier 1> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x107639000 - 0x107664fff sandboxd <C77FDC9C-3415-39DA-8B59-5248ABD043AB> /usr/libexec/sandboxd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SandboxedServiceRunner [16859] UUID: E8F27F82-757A-3705-9B21-EF771C2DB66C Path: /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/SandboxedServiceRunner.xpc/Contents/MacOS/SandboxedServiceRunner Architecture: x86_64 Parent: launchd [1] Responsible: Microsoft Outlook [4828] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2424 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1c50fe DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 21 (SandboxedServiceRunner + 3111) [0x10fa95c27] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10fa95000 - 0x10fa96fff com.apple.appkit.xpc.sandboxedServiceRunner 6.9 (1120) <E8F27F82-757A-3705-9B21-EF771C2DB66C> /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/SandboxedServiceRunner.xpc/Contents/MacOS/SandboxedServiceRunner 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SCIM_Extension [1807] UUID: 88C7275F-31A3-3669-A373-6FFC1AD11553 Path: /System/Library/Input Methods/SCIM.app/Contents/PlugIns/SCIM_Extension.appex/Contents/MacOS/SCIM_Extension Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 56.18 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (98.6K cycles, 26.1K instructions, 3.77c/i) Note: 2 idle work queue threads omitted Thread 0x38af0 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSExtensionMain + 51 (Foundation + 2339980) [0x7fff3738f48c] 1-11 11 ??? (PlugInKit + 84895) [0x7fff57147b9f] 1-11 11 ??? (PlugInKit + 83603) [0x7fff57147693] 1-11 11 ??? (PlugInKit + 84043) [0x7fff5714784b] 1-11 11 -[NSXPCListener resume] + 162 (Foundation + 169082) [0x7fff3717d47a] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x38b1c Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination dirty, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10c72d000 - 0x10c72dfff SCIM_Extension <88C7275F-31A3-3669-A373-6FFC1AD11553> /System/Library/Input Methods/SCIM.app/Contents/PlugIns/SCIM_Extension.appex/Contents/MacOS/SCIM_Extension 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff57133000 - 0x7fff57156fff com.apple.pluginkit.framework 1.0 (1) <B00A2028-4490-3BEA-B0F1-082BB7C050DD> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit 0x7fff5c9ed000 - 0x7fff5cac6fff com.apple.ViewBridge 407 (407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ScopedBookmarkAgent [12254] UUID: 7C59EF68-91E4-3F27-9046-78A8961B07E3 Path: /System/Library/CoreServices/ScopedBookmarkAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 4564 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xf9032 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x107745000 - 0x107748fff ScopedBookmarkAgent <7C59EF68-91E4-3F27-9046-78A8961B07E3> /System/Library/CoreServices/ScopedBookmarkAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: secd [279] UUID: 4C87FB1C-4C50-30B4-814C-605BF864EE74 Path: /usr/libexec/secd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 6416 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7fc 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x100fce000 - 0x1011e1fff secd <4C87FB1C-4C50-30B4-814C-605BF864EE74> /usr/libexec/secd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: secinitd [200] UUID: 053A2B5D-B2E1-3AA4-9FF0-06C83B5CA11E Path: /usr/libexec/secinitd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 4268 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x59f 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10917d000 - 0x109186fff secinitd <053A2B5D-B2E1-3AA4-9FF0-06C83B5CA11E> /usr/libexec/secinitd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: secinitd [301] UUID: 053A2B5D-B2E1-3AA4-9FF0-06C83B5CA11E Path: /usr/libexec/secinitd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 19.19 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x8a9 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1078c5000 - 0x1078cefff secinitd <053A2B5D-B2E1-3AA4-9FF0-06C83B5CA11E> /usr/libexec/secinitd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: securityd [90] UUID: 4AB05D09-318B-3B45-934D-9DD63DE1F414 Path: /usr/sbin/securityd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 15.16 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x26d DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (securityd + 115380) [0x10a2262b4] 1-11 11 ??? (securityd + 24253) [0x10a20febd] 1-11 11 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 4646) [0x7fff60fd0226] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x2ba 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 __read_nocancel + 10 (libsystem_kernel.dylib + 8634) [0x7fff60fd11ba] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 4319092) [0xffffff800061e774] 1-11 *11 spec_read + 672 (kernel + 4425648) [0xffffff80006387b0] 1-11 *11 ??? (kernel + 6732104) [0xffffff800086b948] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x351 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0xaa0171 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (securityd + 21844) [0x10a20f554] 1-11 11 ??? (securityd + 22314) [0x10a20f72a] 1-11 11 ??? (securityd + 24253) [0x10a20febd] 1-11 11 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 4646) [0x7fff60fd0226] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a20a000 - 0x10a2befff securityd (58286.270.14) <4AB05D09-318B-3B45-934D-9DD63DE1F414> /usr/sbin/securityd 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: securityd_service [261] UUID: 9DCC06E6-412E-343E-8930-4F27EBAB8625 Path: /usr/libexec/securityd_service Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 2360 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7b0 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10af51000 - 0x10af60fff securityd_service <9DCC06E6-412E-343E-8930-4F27EBAB8625> /usr/libexec/securityd_service 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: sharedfilelistd [255] UUID: 87CEAA36-AC88-35A7-8788-D9E27E1A04D7 Path: /System/Library/CoreServices/sharedfilelistd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 2640 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x763 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10e3bc000 - 0x10e3d9fff sharedfilelistd <87CEAA36-AC88-35A7-8788-D9E27E1A04D7> /System/Library/CoreServices/sharedfilelistd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: sharedfilelistd [288] UUID: 87CEAA36-AC88-35A7-8788-D9E27E1A04D7 Path: /System/Library/CoreServices/sharedfilelistd Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 11.58 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x848 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10da74000 - 0x10da91fff sharedfilelistd <87CEAA36-AC88-35A7-8788-D9E27E1A04D7> /System/Library/CoreServices/sharedfilelistd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: sharingd [319] UUID: 929EC19E-615A-338C-AB09-58DA5D952596 Path: /usr/libexec/sharingd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 30.28 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x94c DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Finder [278], process received importance donation from com.apple.appkit.xpc.openAndSavePanelService [16669] [unique pid 116270], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 1401 (sharingd + 1382736) [0x105b78950] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *3 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-3 <process dropped importance donation from Finder [278]> *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 4 <process received importance donation from Finder [278]> *7 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 5-11 Thread 0x96a Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Finder [278], process received importance donation from com.apple.appkit.xpc.openAndSavePanelService [16669] [unique pid 116270], IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *3 ??? (kernel + 7168864) [0xffffff80008d6360] 1-3 <process dropped importance donation from Finder [278]> *1 ??? (kernel + 7168864) [0xffffff80008d6360] 4 <process received importance donation from Finder [278]> *7 ??? (kernel + 7168864) [0xffffff80008d6360] 5-11 Binary Images: 0x105a27000 - 0x105c89fff sharingd (1288.62.5) <929EC19E-615A-338C-AB09-58DA5D952596> /usr/libexec/sharingd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: silhouette [4473] UUID: 1E396B01-804B-3374-BCEC-3F9215315ADF Path: /usr/libexec/silhouette Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 9052 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x53845 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102ed4000 - 0x102edcfff silhouette <1E396B01-804B-3374-BCEC-3F9215315ADF> /usr/libexec/silhouette 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Siri [414] UUID: 3B452143-A99E-3B56-A326-C28EE32E6FB6 Path: /System/Library/CoreServices/Siri.app/Contents/MacOS/Siri Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 5936 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (74.4K cycles, 23.8K instructions, 3.13c/i) Note: 2 idle work queue threads omitted Thread 0xe72 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Siri + 7250) [0x100cadc52] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xea4 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user interactive), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100cac000 - 0x100cbafff com.apple.Siri 146.16.1 (146.16.1) <3B452143-A99E-3B56-A326-C28EE32E6FB6> /System/Library/CoreServices/Siri.app/Contents/MacOS/Siri 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: siriknowledged [9953] UUID: A5301D7E-C9EA-3998-B490-E717AF02BAA7 Path: /usr/libexec/siriknowledged Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2176 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: Suspended for 1 sample Note: 1 idle work queue thread omitted Thread 0xe6934 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *5 ??? (kernel + 7168864) [0xffffff80008d6360] 1-5 *1 ??? (kernel + 7168864) [0xffffff80008d6360] (suspended) 6 *5 ??? (kernel + 7168864) [0xffffff80008d6360] 7-11 Binary Images: 0x10c724000 - 0x10c73cfff siriknowledged <A5301D7E-C9EA-3998-B490-E717AF02BAA7> /usr/libexec/siriknowledged 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SiriNCService [688] UUID: C1E0615F-6FCF-3A0E-8C76-564BAEC367AC Path: /System/Library/CoreServices/Siri.app/Contents/XPCServices/SiriNCService.xpc/Contents/MacOS/SiriNCService Architecture: x86_64 Parent: launchd [1] Responsible: Siri [414] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 5484 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x2178 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 main + 180 (SiriNCService + 6580) [0x105c659b4] 1-11 11 NSViewServiceApplicationMain + 2830 (ViewBridge + 50108) [0x7fff5c9f93bc] 1-11 11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 612 (libxpc.dylib + 69783) [0x7fff610d4097] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 99 (ViewBridge + 72259) [0x7fff5c9fea43] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x218b Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105c64000 - 0x105c72fff com.apple.SiriNCService 146.16.1 (146.16.1) <C1E0615F-6FCF-3A0E-8C76-564BAEC367AC> /System/Library/CoreServices/Siri.app/Contents/XPCServices/SiriNCService.xpc/Contents/MacOS/SiriNCService 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff5c9ed000 - 0x7fff5cac6fff com.apple.ViewBridge 407 (407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: smd [475] UUID: 7DD9E755-0B11-3C18-9CB7-44BDEF1FD752 Path: /usr/libexec/smd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 992 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x136b 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1021f6000 - 0x1021fcfff smd <7DD9E755-0B11-3C18-9CB7-44BDEF1FD752> /usr/libexec/smd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: soagent [316] UUID: 5A3C1846-5C97-36D9-B4DC-A77B057218A8 Path: /System/Library/PrivateFrameworks/MessagesKit.framework/Versions/A/Resources/soagent.app/Contents/MacOS/soagent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 6940 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x941 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (soagent + 4879) [0x10555630f] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105555000 - 0x105556fff com.apple.soagent 7.0 (5500) <5A3C1846-5C97-36D9-B4DC-A77B057218A8> /System/Library/PrivateFrameworks/MessagesKit.framework/Versions/A/Resources/soagent.app/Contents/MacOS/soagent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SocialPushAgent [409] UUID: C3F0E74F-A9EF-3DC4-A315-19481A5E4049 Path: /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 1740 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe82 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x105830000 - 0x105845fff com.apple.SocialPushAgent 61 (61) <C3F0E74F-A9EF-3DC4-A315-19481A5E4049> /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: softwareupdate_notify_agent [434] UUID: E6D00F23-92E1-3FC2-BAEC-3471E7F14634 Path: /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent Architecture: x86_64 Footprint: 3232 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xf0e 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100e4b000 - 0x100e51fff softwareupdate_notify_agent (1173.10) <E6D00F23-92E1-3FC2-BAEC-3471E7F14634> /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: softwareupdated [445] UUID: 01BA3A8C-7E62-3C09-9642-4037FD3B4291 Path: /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated Architecture: x86_64 Footprint: 4556 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xfb8 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1010c8000 - 0x1010c9fff softwareupdated <01BA3A8C-7E62-3C09-9642-4037FD3B4291> /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: spindump [326] UUID: B90F40C3-A3BD-316A-B962-FC6C678400F3 Path: /usr/sbin/spindump Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 44.12 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.819s (3.6G cycles, 5.3G instructions, 0.68c/i) Note: 6 idle work queue threads omitted Thread 0x990 DispatchQueue 11 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 _dispatch_sig_thread + 53 (libdispatch.dylib + 77534) [0x7fff60e5dede] 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0xaa0c12 11 samples (1-11) priority 63 (base 63) cpu time 0.021s (96.1M cycles, 46.7M instructions, 2.06c/i) <process sudden termination dirty, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ??? (spindump + 191231) [0x108392aff] 1-11 11 __stack_snapshot_with_config + 10 (libsystem_kernel.dylib + 129014) [0x7fff60fee7f6] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 stack_snapshot_with_config + 182 (kernel + 7256182) [0xffffff80008eb876] 1-11 *11 kern_stack_snapshot_internal + 1003 (kernel + 1561243) [0xffffff800037d29b] (running) 1-11 Thread 0xaa0c11 DispatchQueue 278 7 samples (2-8) priority 37 (base 37) cpu time 0.466s (2.0G cycles, 3.3G instructions, 0.61c/i) <DispatchQueue not seen for 1 sample, thread QoS user initiated (requested user initiated, ipc override user initiated), process sudden termination dirty, IO tier 0> 7 ??? [0x367000186a7] 2-8 7 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 2-8 7 _pthread_wqthread + 421 (libsystem_pthread.dylib + 9745) [0x7fff6108e611] 2-8 7 _dispatch_workloop_worker_thread + 598 (libdispatch.dylib + 75501) [0x7fff60e5d6ed] 2-8 7 _dispatch_lane_invoke + 385 (libdispatch.dylib + 41878) [0x7fff60e55396] 2-8 7 _dispatch_lane_serial_drain + 913 (libdispatch.dylib + 39447) [0x7fff60e54a17] 2-8 7 _dispatch_client_callout + 8 (libdispatch.dylib + 13885) [0x7fff60e4e63d] 2-8 7 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 9720) [0x7fff60e4d5f8] 2-8 7 ??? (spindump + 199388) [0x108394adc] 2-8 7 -[SASampleStore addKCDataStackshots:createSeparateSamplePerStackshot:] + 615 (SampleAnalysis + 80415) [0x7fff589a9a1f] 2-8 7 -[SASampleStore _addKCDataStackshot:timestamp:sampleIndex:shouldSkipSampleOut:backfillKPerf:addStaticInfoOnly:] + 27906 (SampleAnalysis + 109503) [0x7fff589b0bbf] 2-8 7 -[SASampleStore taskForKCDataTask:loadInfos:numLoadInfos:machineArchitecture:timestamp:sharedCache:] + 1061 (SampleAnalysis + 68091) [0x7fff589a69fb] 2-8 7 -[SATask gatherLoadInfoFromLiveProcessWithDataGatheringOptions:] + 204 (SampleAnalysis + 476377) [0x7fff58a0a4d9] 2-8 7 CreateSymbolicatorForLiveProcess + 208 (SampleAnalysis + 46088) [0x7fff589a1408] 2-8 7 CSSymbolicatorCreateWithPidFlagsAndNotification + 45 (CoreSymbolication + 94201) [0x7fff494ffff9] 2-8 7 CSSymbolicatorCreateWithCSCppMachTaskFlagsAndNotification(std::__1::unique_ptr<CSCppMachTask, std::__1::default_delete<CSCppMachTask> >, unsigned int, void (unsigned int, _CSNotificationData) block_pointer) + 57 (CoreSymbolication + 93276) [0x7fff494ffc5c] 2-8 1 CSCppMachTask::symbol_owners(unsigned int) + 116 (CoreSymbolication + 386516) [0x7fff495475d4] 2 1 TMachOHeaderIterator<SizeAndEndianness<Pointer64, LittleEndian> >::TMachOHeaderIterator(CSCppMachTaskContainer const&, dyld_process_info_base const*, char*, char*, unsigned long, unsigned int, TMachOHeaderIteratorHelper<SizeAndEndianness<Pointer64, LittleEndian> >&) + 253 (CoreSymbolication + 387789) [0x7fff49547acd] 2 1 CSCppExceptionSafeThread::CSCppExceptionSafeThread(void () block_pointer) + 209 (CoreSymbolication + 8223) [0x7fff494eb01f] 2 1 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 2 *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 2 3 CSCppMachTask::symbol_owners(unsigned int) + 214 (CoreSymbolication + 386614) [0x7fff49547636] 3-5 3 CSCppTaskMemory::~CSCppTaskMemory() + 122 (CoreSymbolication + 7748) [0x7fff494eae44] 3-5 3 _kernelrpc_mach_vm_deallocate_trap + 10 (libsystem_kernel.dylib + 4430) [0x7fff60fd014e] 3-5 *3 hndl_mach_scall64 + 22 (kernel + 1421750) [0xffffff800035b1b6] 3-5 *3 mach_call_munger64 + 599 (kernel + 2885703) [0xffffff80004c0847] 3-5 *3 _kernelrpc_mach_vm_deallocate_trap + 126 (kernel + 1705278) [0xffffff80003a053e] 3-5 *3 vm_map_remove + 117 (kernel + 2414261) [0xffffff800044d6b5] 3-5 *3 ??? (kernel + 2382379) [0xffffff8000445a2b] 3-5 *3 vm_map_submap_pmap_clean + 376 (kernel + 2388040) [0xffffff8000447048] 3-5 *3 pmap_remove_options + 182 (kernel + 2868118) [0xffffff80004bc396] 3-5 *2 pmap_remove_range_options + 614 (kernel + 2864870) [0xffffff80004bb6e6] 3-4 *1 _rtc_nanotime_read + 43 (kernel + 1417323) [0xffffff800035a06b] (running) 3 *1 _rtc_nanotime_read + 12 (kernel + 1417292) [0xffffff800035a04c] (running) 4 *1 pmap_remove_range_options + 1156 (kernel + 2865412) [0xffffff80004bb904] (running) 5 1 CSCppMachTask::symbol_owners(unsigned int) + 116 (CoreSymbolication + 386516) [0x7fff495475d4] 6 1 TMachOHeaderIterator<SizeAndEndianness<Pointer64, LittleEndian> >::TMachOHeaderIterator(CSCppMachTaskContainer const&, dyld_process_info_base const*, char*, char*, unsigned long, unsigned int, TMachOHeaderIteratorHelper<SizeAndEndianness<Pointer64, LittleEndian> >&) + 253 (CoreSymbolication + 387789) [0x7fff49547acd] 6 1 CSCppExceptionSafeThread::CSCppExceptionSafeThread(void () block_pointer) + 209 (CoreSymbolication + 8223) [0x7fff494eb01f] 6 1 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 6 *1 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 6 2 CSCppMachTask::symbol_owners(unsigned int) + 214 (CoreSymbolication + 386614) [0x7fff49547636] 7-8 2 CSCppTaskMemory::~CSCppTaskMemory() + 122 (CoreSymbolication + 7748) [0x7fff494eae44] 7-8 2 _kernelrpc_mach_vm_deallocate_trap + 10 (libsystem_kernel.dylib + 4430) [0x7fff60fd014e] 7-8 *2 hndl_mach_scall64 + 22 (kernel + 1421750) [0xffffff800035b1b6] 7-8 *2 mach_call_munger64 + 599 (kernel + 2885703) [0xffffff80004c0847] 7-8 *2 _kernelrpc_mach_vm_deallocate_trap + 126 (kernel + 1705278) [0xffffff80003a053e] 7-8 *2 vm_map_remove + 117 (kernel + 2414261) [0xffffff800044d6b5] 7-8 *2 ??? (kernel + 2382379) [0xffffff8000445a2b] 7-8 *2 vm_map_submap_pmap_clean + 376 (kernel + 2388040) [0xffffff8000447048] 7-8 *2 pmap_remove_options + 182 (kernel + 2868118) [0xffffff80004bc396] 7-8 *1 pmap_remove_range_options + 614 (kernel + 2864870) [0xffffff80004bb6e6] 7 *1 pmap_flush_tlbs + 833 (kernel + 2837873) [0xffffff80004b4d71] 7 *1 pmap_tlbi_range + 116 (kernel + 2880644) [0xffffff80004bf484] (running) 7 *1 pmap_remove_range_options + 155 (kernel + 2864411) [0xffffff80004bb51b] (running) 8 Thread 0xa9effd DispatchQueue 39 2 samples (1-2) priority 4 (base 4) cpu time <0.001s (4.3M cycles, 2.9M instructions, 1.46c/i) <thread QoS background (requested background, ipc override background), process sudden termination dirty, thread darwinbg, IO tier 2> 2 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 1-2 2 _pthread_wqthread + 421 (libsystem_pthread.dylib + 9745) [0x7fff6108e611] 1-2 2 _dispatch_workloop_worker_thread + 598 (libdispatch.dylib + 75501) [0x7fff60e5d6ed] 1-2 2 _dispatch_lane_invoke + 385 (libdispatch.dylib + 41878) [0x7fff60e55396] 1-2 2 _dispatch_lane_serial_drain + 602 (libdispatch.dylib + 39136) [0x7fff60e548e0] 1-2 2 _dispatch_client_callout + 8 (libdispatch.dylib + 13885) [0x7fff60e4e63d] 1-2 2 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 9720) [0x7fff60e4d5f8] 1-2 2 ??? (spindump + 182337) [0x108390841] 1-2 2 ??? (spindump + 183122) [0x108390b52] 1-2 2 _CFBundleCreateWithExecutableURLIfLooksLikeBundle + 94 (CoreFoundation + 601345) [0x7fff34f5ed01] 1-2 1 _CFBundleCreate + 217 (CoreFoundation + 1039646) [0x7fff34fc9d1e] 1 1 _CFBundleGetBundleVersionForURL + 330 (CoreFoundation + 151183) [0x7fff34ef0e8f] 1 1 _CFIterateDirectory + 145 (CoreFoundation + 152235) [0x7fff34ef12ab] 1 1 readdir$INODE64 + 35 (libsystem_c.dylib + 177177) [0x7fff60f10419] 1 1 __getdirentries64 + 10 (libsystem_kernel.dylib + 12062) [0x7fff60fd1f1e] 1 *1 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1 *1 unix_syscall64 + 904 (kernel + 8095112) [0xffffff80009b8588] 1 *1 throttle_lowpri_io + 1297 (kernel + 4439809) [0xffffff800063bf01] 1 *1 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1 *1 ??? (kernel + 1882937) [0xffffff80003cbb39] 1 *1 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1 1 _CFBundleCreate + 811 (CoreFoundation + 1040240) [0x7fff34fc9f70] 2 1 CFBundleGetInfoDictionary + 138 (CoreFoundation + 153859) [0x7fff34ef1903] 2 1 _CFBundleCopyInfoDictionaryInDirectoryWithVersion + 702 (CoreFoundation + 155471) [0x7fff34ef1f4f] 2 1 CFURLCreateDataAndPropertiesFromResource + 526 (CoreFoundation + 392583) [0x7fff34f2bd87] 2 1 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 2 *1 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 2 *1 unix_syscall64 + 904 (kernel + 8095112) [0xffffff80009b8588] 2 *1 throttle_lowpri_io + 1297 (kernel + 4439809) [0xffffff800063bf01] 2 *1 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 2 *1 ??? (kernel + 1882937) [0xffffff80003cbb39] 2 *1 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 2 Thread 0xaa0c4e 1 sample (2) priority 31 (base 31) cpu time <0.001s (58.1K cycles, 16.3K instructions, 3.57c/i) <Thread not seen for 1 sample, thread QoS default (requested default), process sudden termination dirty, IO tier 0> 1 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 2 1 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 2 1 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 2 1 thread_init_trampoline(CSCppExceptionSafeThread*) + 9 (CoreSymbolication + 8658) [0x7fff494eb1d2] 2 1 CSCppExceptionSafeThread::sacrificial_thread_init() + 80 (CoreSymbolication + 8752) [0x7fff494eb230] 2 1 invocation function for block in TMachOHeaderIterator<SizeAndEndianness<Pointer64, LittleEndian> >::TMachOHeaderIterator(CSCppMachTaskContainer const&, dyld_process_info_base const*, char*, char*, unsigned long, unsigned int, TMachOHeaderIteratorHelper<SizeAndEndianness<Pointer64, LittleEndian> >&) + 90 (CoreSymbolication + 388316) [0x7fff49547cdc] 2 1 _dyld_process_info_for_each_image + 44 (libdyld.dylib + 102783) [0x7fff60e9e17f] 2 1 invocation function for block in TMachOHeaderIterator<SizeAndEndianness<Pointer64, LittleEndian> >::iterate() + 341 (CoreSymbolication + 388663) [0x7fff49547e37] 2 1 SymbolOwnerIterator<SizeAndEndianness<Pointer64, LittleEndian> >::process_header(TExtendedMachOHeader<SizeAndEndianness<Pointer64, LittleEndian> >&) + 35 (CoreSymbolication + 9373) [0x7fff494eb49d] 2 1 TExtendedMachOHeader<SizeAndEndianness<Pointer64, LittleEndian> >::symbol_owner() const + 65 (CoreSymbolication + 6929) [0x7fff494eab11] 2 1 unsigned int CSCppFlagsForHeader<SizeAndEndianness<Pointer64, LittleEndian> >(TExtendedMachOHeader<SizeAndEndianness<Pointer64, LittleEndian> > const&) + 217 (CoreSymbolication + 7353) [0x7fff494eacb9] 2 1 TMachOHeader<SizeAndEndianness<Pointer64, LittleEndian> >::uses_cplusplus() const + 93 (CoreSymbolication + 165071) [0x7fff495114cf] 2 1 _platform_strstr + 42 (libsystem_platform.dylib + 8898) [0x7fff610842c2] (running) 2 Thread 0xaa0d52 1 sample (6) priority 31 (base 31) cpu time <0.001s (29.9K cycles, 12.1K instructions, 2.48c/i) <Thread not seen for 5 samples, thread QoS default (requested default), process sudden termination dirty, IO tier 0> 1 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 6 1 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 6 1 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 6 1 thread_init_trampoline(CSCppExceptionSafeThread*) + 9 (CoreSymbolication + 8658) [0x7fff494eb1d2] 6 1 CSCppExceptionSafeThread::sacrificial_thread_init() + 80 (CoreSymbolication + 8752) [0x7fff494eb230] 6 1 invocation function for block in TMachOHeaderIterator<SizeAndEndianness<Pointer64, LittleEndian> >::TMachOHeaderIterator(CSCppMachTaskContainer const&, dyld_process_info_base const*, char*, char*, unsigned long, unsigned int, TMachOHeaderIteratorHelper<SizeAndEndianness<Pointer64, LittleEndian> >&) + 90 (CoreSymbolication + 388316) [0x7fff49547cdc] 6 1 _dyld_process_info_for_each_image + 44 (libdyld.dylib + 102783) [0x7fff60e9e17f] 6 1 invocation function for block in TMachOHeaderIterator<SizeAndEndianness<Pointer64, LittleEndian> >::iterate() + 221 (CoreSymbolication + 388543) [0x7fff49547dbf] 6 1 snprintf + 156 (libsystem_c.dylib + 268933) [0x7fff60f26a85] 6 1 vsnprintf_l + 41 (libsystem_c.dylib + 330592) [0x7fff60f35b60] 6 1 _vsnprintf + 410 (libsystem_c.dylib + 330499) [0x7fff60f35b03] 6 1 __v2printf + 475 (libsystem_c.dylib + 438723) [0x7fff60f501c3] 6 1 __vfprintf + 14137 (libsystem_c.dylib + 288311) [0x7fff60f2b637] 6 1 __sfvwrite + 366 (libsystem_c.dylib + 250158) [0x7fff60f2212e] 6 1 _platform_memmove$VARIANT$Haswell + 240 (libsystem_platform.dylib + 7600) [0x7fff61083db0] (running) 6 Binary Images: 0x108364000 - 0x1083aafff spindump (267.3) <B90F40C3-A3BD-316A-B962-FC6C678400F3> /usr/sbin/spindump 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff494e9000 - 0x7fff4956dfff com.apple.CoreSymbolication 10.2 (64490.25.1) <28B2FF2D-3FDE-3A20-B343-341E5BD4E22F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x7fff58996000 - 0x7fff58a38fff com.apple.SampleAnalysis 1.0 (218.3.1) <43A67245-2358-3A09-9EBA-DB6CE125113C> /System/Library/PrivateFrameworks/SampleAnalysis.framework/Versions/A/SampleAnalysis 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60ee5000 - 0x7fff60f6cfff libsystem_c.dylib (1272.250.3) <6016EDA1-440B-34D7-A232-686CD7FBEE90> /usr/lib/system/libsystem_c.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff61082000 - 0x7fff6108bfff libsystem_platform.dylib (177.270.1) <9D1FE5E4-EB7D-3B3F-A8D1-A96D9CF1348C> /usr/lib/system/libsystem_platform.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: spindump_agent [358] UUID: 6D248CDC-BEB9-3AC5-9949-4FED5C5A8EF0 Path: /usr/libexec/spindump_agent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 1852 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: 0.016s (69.2M cycles, 34.4M instructions, 2.01c/i) Note: 2 idle work queue threads omitted Thread 0xcc7 DispatchQueue 11 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from spindump [326], IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10a479000 - 0x10a47dfff spindump_agent <6D248CDC-BEB9-3AC5-9949-4FED5C5A8EF0> /usr/libexec/spindump_agent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Spotlight [328] UUID: EAF5AD83-69C3-3BAD-8BB9-3AE9AD51F752 Path: /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 29.27 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0x9bb DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x9e5 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 ??? (Spotlight + 147207) [0x10d1d3f07] 1-11 11 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 970970) [0x7fff372410da] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xab7 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d1b0000 - 0x10d1fdfff com.apple.Spotlight 1.0 (1191.59) <EAF5AD83-69C3-3BAD-8BB9-3AE9AD51F752> /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SSMenuAgent [367] UUID: 975C0861-39EE-372F-B66A-C547F8D39020 Path: /System/Library/CoreServices/RemoteManagement/SSMenuAgent.app/Contents/MacOS/SSMenuAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 5032 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 2 idle work queue threads omitted Thread 0xd1e DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xd25 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 37 (base 37) <thread QoS user initiated (requested user interactive), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1040dc000 - 0x1040e5fff SSMenuAgent <975C0861-39EE-372F-B66A-C547F8D39020> /System/Library/CoreServices/RemoteManagement/SSMenuAgent.app/Contents/MacOS/SSMenuAgent 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: StandaloneUpdaterDaemon [89] UUID: A9E8A2F7-8F22-3677-AB0A-49920389ACB0 Path: /Applications/OneDrive.app/Contents/StandaloneUpdaterDaemon.xpc/Contents/MacOS/StandaloneUpdaterDaemon Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 7948 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x457 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10a065000 - 0x10a078fff com.microsoft.OneDriveStandaloneUpdaterDaemon 22.176.0821 (22176.0821.0003) <A9E8A2F7-8F22-3677-AB0A-49920389ACB0> /Applications/OneDrive.app/Contents/StandaloneUpdaterDaemon.xpc/Contents/MacOS/StandaloneUpdaterDaemon 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: storagekitd [80004] UUID: D0BF12B1-7802-373F-BD37-5FD3E18A2149 Path: /System/Library/PrivateFrameworks/StorageKit.framework/Versions/A/Resources/storagekitd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 3704 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (608.3K cycles, 136.6K instructions, 4.45c/i) Note: 3 idle work queue threads omitted Thread 0x508e11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0x508e15 Thread name "Storage Kit Work Thread" 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (80.4K cycles, 16.6K instructions, 4.84c/i) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 ??? (storagekitd + 207716) [0x10775ab64] 1-11 11 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 970970) [0x7fff372410da] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x508e16 Thread name "Storage Kit Disk Eject Thread" 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (125.8K cycles, 29.7K instructions, 4.24c/i) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 ??? (storagekitd + 208094) [0x10775acde] 1-11 11 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 970970) [0x7fff372410da] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x508e17 Thread name "Storage Kit Notifications Thread" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__block_start__ + 49 (Foundation + 2263736) [0x7fff3737cab8] 1-11 11 ??? (storagekitd + 207260) [0x10775a99c] 1-11 11 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 970970) [0x7fff372410da] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x107728000 - 0x1077affff storagekitd (480.26) <D0BF12B1-7802-373F-BD37-5FD3E18A2149> /System/Library/PrivateFrameworks/StorageKit.framework/Versions/A/Resources/storagekitd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: storeaccountd [334] UUID: 7D23B695-A403-3900-8290-2D2A814DF3BB Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 4256 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x9f2 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (storeaccountd + 7750) [0x106862e46] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x106861000 - 0x106867fff storeaccountd (708.6) <7D23B695-A403-3900-8290-2D2A814DF3BB> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: storeassetd [896] UUID: 9E2792D5-DEF3-32BD-BC2D-9FC50F094429 Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 9348 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (123.5K cycles, 28.9K instructions, 4.27c/i) Note: 1 idle work queue thread omitted Thread 0xa20a 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x47a3a2 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10aa3f000 - 0x10ab2cfff storeassetd <9E2792D5-DEF3-32BD-BC2D-9FC50F094429> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeassetd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: storedownloadd [799] UUID: BDE4E78A-D589-3D8C-B31F-8CA2778982A5 Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 3728 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3f5f 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1047a8000 - 0x10492dfff storedownloadd <BDE4E78A-D589-3D8C-B31F-8CA2778982A5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: storeuid [1256] UUID: 2C62924F-D835-3BC5-B2AD-7A54D54350F7 Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeuid.app/Contents/MacOS/storeuid Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 9364 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (52.3K cycles, 19.2K instructions, 2.72c/i) Note: 2 idle work queue threads omitted Thread 0x1bca1 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (storeuid + 48134) [0x100c87c06] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x1bcfb Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100c7c000 - 0x100c9bfff com.apple.storeuid 1.0 (708.6) <2C62924F-D835-3BC5-B2AD-7A54D54350F7> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeuid.app/Contents/MacOS/storeuid 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: studentd [15577] UUID: E28A485E-D024-3E9A-ADD3-DC5BF0C0F13E Path: /usr/libexec/studentd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 12.95 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (107.9K cycles, 23.7K instructions, 4.55c/i) Note: 2 idle work queue threads omitted Thread 0x16a458 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (studentd + 102806) [0x108dfb196] 1-11 11 ??? (studentd + 319548) [0x108e3003c] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108de2000 - 0x108e7efff studentd (55.2) <E28A485E-D024-3E9A-ADD3-DC5BF0C0F13E> /usr/libexec/studentd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SubmitDiagInfo [327] UUID: 26D2AD0C-38D2-38DD-97B4-AC101A8F529F Path: /System/Library/CoreServices/SubmitDiagInfo Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 8612 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (135.9K cycles, 39.0K instructions, 3.48c/i) Note: 1 idle work queue thread omitted Thread 0x997 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xea3c7 Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 3> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10482c000 - 0x104851fff SubmitDiagInfo <26D2AD0C-38D2-38DD-97B4-AC101A8F529F> /System/Library/CoreServices/SubmitDiagInfo 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: suggestd [482] UUID: A7C39782-96D4-33E1-B9E6-6B140A186098 Path: /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 30.43 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x13d4 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (suggestd + 14464) [0x10f308880] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f305000 - 0x10f30cfff suggestd (680.125) <A7C39782-96D4-33E1-B9E6-6B140A186098> /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: suhelperd [446] UUID: 027D9556-C550-3BE4-8B44-1A121C3CBBB1 Path: /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd Architecture: x86_64 Footprint: 1548 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xfbd 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102d8b000 - 0x102db7fff suhelperd (1173.10) <027D9556-C550-3BE4-8B44-1A121C3CBBB1> /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: swcd [403] UUID: 98E02708-DF39-31ED-AEEF-FC8065B17375 Path: /usr/libexec/swcd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 6764 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe2b 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e53a000 - 0x10e54dfff swcd <98E02708-DF39-31ED-AEEF-FC8065B17375> /usr/libexec/swcd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: symptomsd [169] UUID: 05CA74DB-DC6C-3B75-B277-536631F1D0BD Path: /usr/libexec/symptomsd Architecture: x86_64 Parent: launchd [1] UID: 24 Sudden Term: Tracked (allows idle exit) Footprint: 6848 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (100.9K cycles, 22.8K instructions, 4.43c/i) Note: 2 idle work queue threads omitted Thread 0x39b DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (symptomsd + 6021) [0x102473785] 1-11 11 CFRunLoopRun + 40 (CoreFoundation + 239858) [0x7fff34f068f2] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x102472000 - 0x102473fff symptomsd (820.267.2) <05CA74DB-DC6C-3B75-B277-536631F1D0BD> /usr/libexec/symptomsd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: sysdiagnose [796] UUID: C16D5660-6AAA-3858-AA6F-B071CC214964 Path: /usr/bin/sysdiagnose Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1568 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3f73 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0 and passive> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x103e1b000 - 0x103e88fff sysdiagnose <C16D5660-6AAA-3858-AA6F-B071CC214964> /usr/bin/sysdiagnose 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: syslogd [49] UUID: 2D6462A4-A41A-3850-B90A-57EAC87E1E2C Path: /usr/sbin/syslogd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 1208 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 3 idle work queue threads omitted Thread 0x303 DispatchQueue 10 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2 and passive> 11 start_wqthread + 13 (libsystem_pthread.dylib + 9213) [0x7fff6108e3fd] 1-11 11 _pthread_wqthread + 583 (libsystem_pthread.dylib + 9907) [0x7fff6108e6b3] 1-11 11 _dispatch_worker_thread2 + 90 (libdispatch.dylib + 72518) [0x7fff60e5cb46] 1-11 11 _dispatch_root_queue_drain + 657 (libdispatch.dylib + 70921) [0x7fff60e5c509] 1-11 11 _dispatch_client_callout + 8 (libdispatch.dylib + 13885) [0x7fff60e4e63d] 1-11 11 _dispatch_call_block_and_release + 12 (libdispatch.dylib + 9720) [0x7fff60e4d5f8] 1-11 11 ??? (syslogd + 35863) [0x10261ec17] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x302 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2 and passive> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x102616000 - 0x10262efff syslogd (356.200.4) <2D6462A4-A41A-3850-B90A-57EAC87E1E2C> /usr/sbin/syslogd 0x7fff60e4b000 - 0x7fff60e84fff libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: sysmond [492] UUID: 435FA172-E93D-3351-BD88-FDDCE3035F35 Path: /usr/libexec/sysmond Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1392 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1508 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10708f000 - 0x107094fff sysmond <435FA172-E93D-3351-BD88-FDDCE3035F35> /usr/libexec/sysmond 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: syspolicyd [188] UUID: 11F28D0C-0DAE-39E5-BDB7-CCC5E6E7D6D1 Path: /usr/libexec/syspolicyd Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 60.27 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (77.1K cycles, 23.7K instructions, 3.26c/i) Note: 1 idle work queue thread omitted Thread 0x3f0 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x144a Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x100f6f000 - 0x100fa8fff syspolicyd (45.270.2) <11F28D0C-0DAE-39E5-BDB7-CCC5E6E7D6D1> /usr/libexec/syspolicyd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: System Preferences [55397] [unique pid 154982] UUID: E8137A1A-4391-3DA9-B47C-E1F008D165B4 Path: /Applications/System Preferences.app/Contents/MacOS/System Preferences Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 37.70 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (74.4K cycles, 27.0K instructions, 2.76c/i) Note: 2 idle work queue threads omitted Thread 0x928af4 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (System Preferences + 7387) [0x108937cdb] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x928ba1 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 4 (base 4) <thread QoS user interactive (requested user interactive), process sudden termination clean, process suppressed, timers tier 5 (throttled), IO tier 2> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x108936000 - 0x108962fff com.apple.systempreferences 14.0 (14.0) <E8137A1A-4391-3DA9-B47C-E1F008D165B4> /Applications/System Preferences.app/Contents/MacOS/System Preferences 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: system_installd [797] UUID: 0826F357-0E61-3A7E-BA3E-EFF5C969548E Path: /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/system_installd Architecture: x86_64 Footprint: 1656 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3f57 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104e26000 - 0x104e27fff system_installd <0826F357-0E61-3A7E-BA3E-EFF5C969548E> /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/system_installd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: systemsoundserverd [360] UUID: EEF160CF-6A32-3928-95FF-30BC97507077 Path: /usr/sbin/systemsoundserverd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 5528 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xcd2 DispatchQueue 11 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10baaa000 - 0x10bacbfff systemsoundserverd <EEF160CF-6A32-3928-95FF-30BC97507077> /usr/sbin/systemsoundserverd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: systemstats [61] UUID: 40E59F12-7885-33A9-913A-6EA5B24AC9AC Path: /usr/sbin/systemstats Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 5216 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x25c DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (systemstats + 67462) [0x103386786] 1-11 11 ??? (systemstats + 106222) [0x10338feee] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x103376000 - 0x103491fff systemstats (403.270.1) <40E59F12-7885-33A9-913A-6EA5B24AC9AC> /usr/sbin/systemstats 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: systemstats [494] UUID: 40E59F12-7885-33A9-913A-6EA5B24AC9AC Path: /usr/sbin/systemstats Architecture: x86_64 Parent: systemstats [61] Responsible: systemstats [61] UID: 0 Footprint: 1900 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x1511 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x106b10000 - 0x106c2bfff systemstats (403.270.1) <40E59F12-7885-33A9-913A-6EA5B24AC9AC> /usr/sbin/systemstats 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: SystemUIServer [275] UUID: 6374DF57-07C6-3829-B34F-32C4E6DFB2F6 Path: /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 38.02 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (180.8K cycles, 38.1K instructions, 4.74c/i) Note: 3 idle work queue threads omitted Thread 0x7d3 DispatchQueue 1 11 samples (1-11) priority 47 (base 47) <process frontmost, thread QoS user interactive (requested user interactive), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (SystemUIServer + 20726) [0x10b3ae0f6] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x820 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 47 (base 47) <process frontmost, thread QoS user interactive (requested user interactive), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x35d5c9 11 samples (1-11) priority 31 (base 31) <process frontmost, thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b3a9000 - 0x10b3f6fff com.apple.systemuiserver 1.7 (480.2) <6374DF57-07C6-3829-B34F-32C4E6DFB2F6> /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: talagent [273] UUID: AC83CDD6-0CD6-33AC-9489-A5D783A69AB9 Path: /System/Library/CoreServices/talagent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 7700 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (86.7K cycles, 27.6K instructions, 3.15c/i) Note: 2 idle work queue threads omitted Thread 0x7ce DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (talagent + 7606) [0x1084d1db6] 1-11 11 ??? (talagent + 34693) [0x1084d8785] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1084d0000 - 0x1084f5fff talagent (310.10) <AC83CDD6-0CD6-33AC-9489-A5D783A69AB9> /System/Library/CoreServices/talagent 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: taskgated [431] UUID: 02655434-567B-3B18-B53D-17D2B798E5FF Path: /usr/libexec/taskgated Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 2480 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Thread 0xec4 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib + 4646) [0x7fff60fd0226] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101f94000 - 0x101f9efff taskgated (55172.200.4) <02655434-567B-3B18-B53D-17D2B798E5FF> /usr/libexec/taskgated 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: tccd [227] UUID: FEE5D334-8A85-3EE1-A4CB-D344111DEE8B Path: /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 26.28 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x649 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10324d000 - 0x10328efff tccd <FEE5D334-8A85-3EE1-A4CB-D344111DEE8B> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: tccd [284] UUID: FEE5D334-8A85-3EE1-A4CB-D344111DEE8B Path: /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 19.99 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x81e 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x106e05000 - 0x106e46fff tccd <FEE5D334-8A85-3EE1-A4CB-D344111DEE8B> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/Resources/tccd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Teams [836] UUID: 4C4C4415-5555-3144-A1F3-DA599D02CD4E Path: /Applications/Microsoft Teams.app/Contents/MacOS/Teams Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 185.38 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (493.4K cycles, 94.9K instructions, 5.20c/i) Note: 2 idle work queue threads omitted Thread 0x60d6 DispatchQueue 1 Thread name "CrBrowserMain" 11 samples (1-11) priority 46 (base 46) cpu time <0.001s (238.6K cycles, 33.7K instructions, 7.09c/i) <thread QoS user interactive (requested user interactive), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (Teams + 3339) [0x10bd42d0b] 1-11 11 ElectronMain + 146 (Electron Framework + 108402) [0x10ee8e772] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10351625 (Electron Framework + 17761097) [0x10ff64349] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10349323 (Electron Framework + 17758795) [0x10ff63a4b] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10355003 (Electron Framework + 17764475) [0x10ff6507b] 1-11 11 cdef_copy_rect8_16bit_to_16bit_sse4_1 + 10356387 (Electron Framework + 17765859) [0x10ff655e3] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 5758618 (Electron Framework + 37215642) [0x1111f1d9a] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 5775650 (Electron Framework + 37232674) [0x1111f6022] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 5768901 (Electron Framework + 37225925) [0x1111f45c5] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1120565d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x11208c6ba] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 146 (Electron Framework + 52791730) [0x1120cc9b2] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 6182 (Electron Framework + 52797766) [0x1120ce146] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x611e Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x1120c6f48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x1120a901d] 1-11 11 _TIFFSwab64BitData + 5241469 (Electron Framework + 52567213) [0x112095cad] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x1120a8e88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1120565d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x11208c6ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6120 Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x1120c6f48] 1-11 11 _TIFFSwab64BitData + 5293085 (Electron Framework + 52618829) [0x1120a264d] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x1120a2c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x1120d472c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6122 Thread name "Chrome_IOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x1120c6f48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x1120a901d] 1-11 11 v8::internal::SetupIsolateDelegate::SetupHeap(v8::internal::Heap*) + 5780479 (Electron Framework + 37237503) [0x1111f72ff] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x1120a8e88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1120565d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x11208c6ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6123 Thread name "MemoryInfra" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x1120c6f48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x1120a901d] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x1120a8e88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1120565d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x11208c6ba] 1-11 11 _TIFFSwab64BitData + 4840091 (Electron Framework + 52165835) [0x112033ccb] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 31902 (Electron Framework + 52823486) [0x1120d45be] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x1120d472c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6125 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 kevent + 10 (libsystem_kernel.dylib + 30602) [0x7fff60fd678a] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6126 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 node::CommonEnvironmentSetup::context() const + 177479 (Electron Framework + 115989639) [0x115d11c87] 1-11 11 node::CommonEnvironmentSetup::context() const + 187650 (Electron Framework + 115999810) [0x115d14442] 1-11 11 uv_cond_wait + 9 (Electron Framework + 83945) [0x10ee887e9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6127 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 node::CommonEnvironmentSetup::context() const + 177479 (Electron Framework + 115989639) [0x115d11c87] 1-11 11 node::CommonEnvironmentSetup::context() const + 187650 (Electron Framework + 115999810) [0x115d14442] 1-11 11 uv_cond_wait + 9 (Electron Framework + 83945) [0x10ee887e9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6128 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 node::CommonEnvironmentSetup::context() const + 177479 (Electron Framework + 115989639) [0x115d11c87] 1-11 11 node::CommonEnvironmentSetup::context() const + 187650 (Electron Framework + 115999810) [0x115d14442] 1-11 11 uv_cond_wait + 9 (Electron Framework + 83945) [0x10ee887e9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6132 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x616c 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 uv_cancel + 505 (Electron Framework + 17033) [0x10ee78289] 1-11 11 uv_cond_wait + 9 (Electron Framework + 83945) [0x10ee887e9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x616d 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 uv_cancel + 505 (Electron Framework + 17033) [0x10ee78289] 1-11 11 uv_cond_wait + 9 (Electron Framework + 83945) [0x10ee887e9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x616e 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 uv_cancel + 505 (Electron Framework + 17033) [0x10ee78289] 1-11 11 uv_cond_wait + 9 (Electron Framework + 83945) [0x10ee887e9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x616f 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 uv_cancel + 505 (Electron Framework + 17033) [0x10ee78289] 1-11 11 uv_cond_wait + 9 (Electron Framework + 83945) [0x10ee887e9] 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x618e 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x618f Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6190 Thread name "CrShutdownDetector" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 read + 10 (libsystem_kernel.dylib + 12014) [0x7fff60fd1eee] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 read_nocancel + 114 (kernel + 7269506) [0xffffff80008eec82] 1-11 *11 ??? (kernel + 7270151) [0xffffff80008eef07] 1-11 *11 ??? (kernel + 7294931) [0xffffff80008f4fd3] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Thread 0x6191 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6194 Thread name "ThreadPoolSingleThreadForegroundBlocking0" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x1120c6f48] 1-11 11 _TIFFSwab64BitData + 5293325 (Electron Framework + 52619069) [0x1120a273d] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x1120a2c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x1120d472c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6196 Thread name "CompositorTileWorker1" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 __psynch_cvwait + 10 (libsystem_kernel.dylib + 18534) [0x7fff60fd3866] 1-11 *11 psynch_cvcontinue + 0 (pthread + 19324) [0xffffff7f82d96b7c] 1-11 Thread 0x6197 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 ElectronMain + 1482632 (Electron Framework + 1590888) [0x10eff8668] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0x61c0 Thread name "NetworkConfigWatcher" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6208 Thread name "CacheThread_BlockFile" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x1120c6f48] 1-11 11 _TIFFSwab64BitData + 5320173 (Electron Framework + 52645917) [0x1120a901d] 1-11 11 _TIFFSwab64BitData + 5319768 (Electron Framework + 52645512) [0x1120a8e88] 1-11 11 _TIFFSwab64BitData + 4981665 (Electron Framework + 52307409) [0x1120565d1] 1-11 11 _TIFFSwab64BitData + 5203082 (Electron Framework + 52528826) [0x11208c6ba] 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0x6221 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6251 Thread name "ThreadPoolSingleThreadSharedBackgroundBlocking1" 11 samples (1-11) priority 0 (base 0) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x62fd Thread name "com.apple.NSURLConnectionLoader" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __NSThread__start__ + 1194 (Foundation + 76194) [0x7fff371669a2] 1-11 11 -[__CoreSchedulingSetRunnable runForever] + 210 (CFNetwork + 314940) [0x7fff33deae3c] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x6384 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x6389 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Thread 0x4b1ee Thread name "PowerSaveBlocker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa95214 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _TIFFSwab64BitData + 5442840 (Electron Framework + 52768584) [0x1120c6f48] 1-11 11 _TIFFSwab64BitData + 5293229 (Electron Framework + 52618973) [0x1120a26dd] 1-11 11 _TIFFSwab64BitData + 5294669 (Electron Framework + 52620413) [0x1120a2c7d] 1-11 11 base::mac::CxxPersonalityRoutine(int, _Unwind_Action, unsigned long long, _Unwind_Exception*, _Unwind_Context*) + 32268 (Electron Framework + 52823852) [0x1120d472c] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10bd42000 - 0x10bd7efff com.microsoft.teams 1.00.533356 (533356) <4C4C4415-5555-3144-A1F3-DA599D02CD4E> /Applications/Microsoft Teams.app/Contents/MacOS/Teams 0x10ee74000 - 0x1171bcfff com.github.Electron.framework (16.2.8) <4C4C4462-5555-3144-A1AC-15EC19C8E608> /Applications/Microsoft Teams.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff33d9e000 - 0x7fff34140fff com.apple.CFNetwork 978.6 (978.6) <F6AC3859-B6F9-3212-A357-54AA096DAA9E> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff7f82d92000 - 0xffffff7f82d99fff com.apple.kec.pthread 1.0 (1) <6C7628FE-2621-3C19-B248-D4DA0D722123> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: thermald [208] UUID: 2F1F4E65-A97E-3B28-81A2-1056B71DA4D9 Path: /usr/libexec/thermald Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 944 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x5e6 11 samples (1-11) priority 63 (base 63) <process sudden termination dirty, IO tier 0> 11 <truncated backtrace> 1-11 11 __ioctl + 10 (libsystem_kernel.dylib + 6998) [0x7fff60fd0b56] 1-11 *11 hndl_unix_scall64 + 22 (kernel + 1421718) [0xffffff800035b196] 1-11 *11 unix_syscall64 + 637 (kernel + 8094845) [0xffffff80009b847d] 1-11 *11 ioctl + 1321 (kernel + 7275353) [0xffffff80008f0359] 1-11 *11 fo_ioctl + 123 (kernel + 6921307) [0xffffff8000899c5b] 1-11 *11 ??? (kernel + 4321300) [0xffffff800061f014] 1-11 *11 VNOP_IOCTL + 191 (kernel + 4379663) [0xffffff800062d40f] 1-11 *11 spec_ioctl + 179 (kernel + 4426899) [0xffffff8000638c93] 1-11 *11 xcpm_cpu_control + 1045 (kernel + 3118213) [0xffffff80004f9485] 1-11 *11 ??? (kernel + 7168269) [0xffffff80008d610d] 1-11 *11 lck_mtx_sleep + 128 (kernel + 1824992) [0xffffff80003bd8e0] 1-11 *11 thread_block_reason + 175 (kernel + 1876447) [0xffffff80003ca1df] 1-11 *11 ??? (kernel + 1882937) [0xffffff80003cbb39] 1-11 *11 machine_switch_context + 195 (kernel + 2972195) [0xffffff80004d5a23] 1-11 Binary Images: 0x10ba9a000 - 0x10baa4fff thermald (79.250.2) <2F1F4E65-A97E-3B28-81A2-1056B71DA4D9> /usr/libexec/thermald 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: timed [88] UUID: A6C8278F-3FE9-30DE-8E91-AA763F33AAAA Path: /usr/libexec/timed Architecture: x86_64 Parent: launchd [1] UID: 266 Footprint: 1984 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x358 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (timed + 10137) [0x10b253799] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10b251000 - 0x10b28bfff timed (258.4) <A6C8278F-3FE9-30DE-8E91-AA763F33AAAA> /usr/libexec/timed 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: trustd [158] UUID: 4E7CAE45-E260-3A20-8933-CB927C5CC53E Path: /usr/libexec/trustd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 14.52 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3a5 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1070f4000 - 0x10714afff trustd <4E7CAE45-E260-3A20-8933-CB927C5CC53E> /usr/libexec/trustd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: trustd [277] UUID: 4E7CAE45-E260-3A20-8933-CB927C5CC53E Path: /usr/libexec/trustd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 17.25 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7e9 DispatchQueue 11 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x10c907000 - 0x10c95dfff trustd <4E7CAE45-E260-3A20-8933-CB927C5CC53E> /usr/libexec/trustd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: trustd [532] UUID: 4E7CAE45-E260-3A20-8933-CB927C5CC53E Path: /usr/libexec/trustd Architecture: x86_64 Parent: launchd [1] UID: 89 Sudden Term: Tracked (allows idle exit) Footprint: 5292 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x16fa 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1085dd000 - 0x108633fff trustd <4E7CAE45-E260-3A20-8933-CB927C5CC53E> /usr/libexec/trustd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: trustd [954] UUID: 4E7CAE45-E260-3A20-8933-CB927C5CC53E Path: /usr/libexec/trustd Architecture: x86_64 Parent: launchd [1] UID: 501 Sudden Term: Tracked (allows idle exit) Footprint: 5508 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xb43f 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x1062df000 - 0x106335fff trustd <4E7CAE45-E260-3A20-8933-CB927C5CC53E> /usr/libexec/trustd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: tzd [91093] UUID: C24C34A2-4D32-3CBF-B412-21827D23002E Path: /usr/libexec/tzd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 1628 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x54ea89 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10c8f4000 - 0x10c910fff tzd <C24C34A2-4D32-3CBF-B412-21827D23002E> /usr/libexec/tzd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: uninstalld [53] UUID: 9D4ACF21-06B4-35C3-B6EC-E2FC30F9ACDA Path: /System/Library/PrivateFrameworks/Uninstall.framework/Versions/A/Resources/uninstalld Architecture: x86_64 Parent: launchd [1] UID: 0 Footprint: 876 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x252 DispatchQueue 1 11 samples (1-11) priority 20 (base 20) <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 3> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (uninstalld + 8579) [0x10f19b183] 1-11 11 -[NSRunLoop(NSRunLoop) runUntilDate:] + 114 (Foundation + 970970) [0x7fff372410da] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10f199000 - 0x10f1a1fff uninstalld (230) <9D4ACF21-06B4-35C3-B6EC-E2FC30F9ACDA> /System/Library/PrivateFrameworks/Uninstall.framework/Versions/A/Resources/uninstalld 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: universalAccessAuthWarn [4075] UUID: D209302A-6DB8-3C7A-8C95-618E398CB735 Path: /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/Resources/universalAccessAuthWarn.app/Contents/MacOS/universalAccessAuthWarn Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 5200 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (85.0K cycles, 27.4K instructions, 3.11c/i) Note: 2 idle work queue threads omitted Thread 0x4c29d DispatchQueue 1 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 NSApplicationMain + 777 (AppKit + 12736) [0x7fff324e51c0] 1-11 11 -[NSApplication run] + 699 (AppKit + 81044) [0x7fff324f5c94] 1-11 11 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361 (AppKit + 105335) [0x7fff324fbb77] 1-11 11 _DPSNextEvent + 1135 (AppKit + 110217) [0x7fff324fce89] 1-11 11 _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 44150) [0x7fff34164c76] 1-11 11 ReceiveNextEventCommon + 603 (HIToolbox + 44773) [0x7fff34164ee5] 1-11 11 RunCurrentEventLoopInMode + 292 (HIToolbox + 45483) [0x7fff341651ab] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x4c2b2 Thread name "com.apple.NSEventThread" 11 samples (1-11) priority 46 (base 46) <thread QoS user interactive (requested user interactive), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 _NSEventThread + 175 (AppKit + 142254) [0x7fff32504bae] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1050b3000 - 0x1050b8fff universalAccessAuthWarn <D209302A-6DB8-3C7A-8C95-618E398CB735> /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/Resources/universalAccessAuthWarn.app/Contents/MacOS/universalAccessAuthWarn 0x7fff324e2000 - 0x7fff33297fff com.apple.AppKit 6.9 (1671.60.112) <4AFB032C-2786-3AD7-8EDA-576956992A9C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3415a000 - 0x7fff34451fff com.apple.HIToolbox 2.1.1 (918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: UsageTrackingAgent [10118] UUID: 050994C7-78F2-3CF9-95D2-BC3A02178765 Path: /System/Library/PrivateFrameworks/UsageTracking.framework/Versions/A/UsageTrackingAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2492 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe6e30 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x101937000 - 0x10194dfff UsageTrackingAgent <050994C7-78F2-3CF9-95D2-BC3A02178765> /System/Library/PrivateFrameworks/UsageTracking.framework/Versions/A/UsageTrackingAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: USBAgent [8247] UUID: 3066AF57-2DA5-3589-8FF4-72F105B53F27 Path: /usr/libexec/USBAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 2544 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xe531e 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x109663000 - 0x109666fff USBAgent <3066AF57-2DA5-3589-8FF4-72F105B53F27> /usr/libexec/USBAgent 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: usbd [207] UUID: 61ED6DFA-5543-31A9-B513-482D319107A0 Path: /usr/libexec/usbd Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2740 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x5e4 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x1023c3000 - 0x1023c9fff usbd <61ED6DFA-5543-31A9-B513-482D319107A0> /usr/libexec/usbd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: usbmuxd [91] UUID: 6EC40937-7879-3807-AAB1-1B1A2F8A586B Path: /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd Architecture: x86_64 Parent: launchd [1] UID: 213 Sudden Term: Tracked Footprint: 1432 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x3f9 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x402 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x106b01000 - 0x106b1bfff usbmuxd (423.258.2) <6EC40937-7879-3807-AAB1-1B1A2F8A586B> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: useractivityd [320] UUID: ED13738E-F23B-3CB7-9644-F74C8FB64522 Path: /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 15.83 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (83.9K cycles, 25.6K instructions, 3.28c/i) Note: 4 idle work queue threads omitted Thread 0x94d DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from pboard [282], IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (useractivityd + 80035) [0x10e1eb8a3] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10e1d8000 - 0x10e2a9fff useractivityd (232) <ED13738E-F23B-3CB7-9644-F74C8FB64522> /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: UserEventAgent [50] UUID: 16AF8DDC-A810-302C-87E3-2E74248E651C Path: /usr/libexec/UserEventAgent Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked Footprint: 5416 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x24f DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (UserEventAgent + 5959) [0x101b8b747] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x3dd 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x3de Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x101b8a000 - 0x101b8cfff UserEventAgent (227.250.1) <16AF8DDC-A810-302C-87E3-2E74248E651C> /usr/libexec/UserEventAgent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: UserEventAgent [268] UUID: 16AF8DDC-A810-302C-87E3-2E74248E651C Path: /usr/libexec/UserEventAgent Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked Footprint: 17.68 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7c0 DispatchQueue 1 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ??? (UserEventAgent + 5959) [0x106f41747] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x8b2 Thread name "com.apple.CFSocket.private" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 __select + 10 (libsystem_kernel.dylib + 34326) [0x7fff60fd7616] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Binary Images: 0x106f40000 - 0x106f42fff UserEventAgent (227.250.1) <16AF8DDC-A810-302C-87E3-2E74248E651C> /usr/libexec/UserEventAgent 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: usernoted [311] UUID: 1422ABC3-85FE-31D8-80E1-BAE91FDBAC08 Path: /usr/sbin/usernoted Architecture: x86_64 Parent: launchd [1] UID: 504 Footprint: 15.06 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x920 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10faa6000 - 0x10fc18fff usernoted (747.8) <1422ABC3-85FE-31D8-80E1-BAE91FDBAC08> /usr/sbin/usernoted 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: vcxpc [857] UUID: D0003C84-2620-30A9-81FC-EF387BAABDDD Path: /Applications/Microsoft Teams.app/Contents/Resources/app.asar.unpacked/node_modules/slimcore/bin/vcxpc.xpc/Contents/MacOS/vcxpc Architecture: x86_64 Parent: launchd [1] Responsible: Teams [836] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 2872 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x64df 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0x64f6 11 samples (1-11) priority 4 (base 4) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 <truncated backtrace> 1-11 11 semaphore_wait_trap + 10 (libsystem_kernel.dylib + 4694) [0x7fff60fd0256] 1-11 *11 semaphore_wait_continue + 0 (kernel + 1930816) [0xffffff80003d7640] 1-11 Binary Images: 0x101449000 - 0x101478fff vcxpc <D0003C84-2620-30A9-81FC-EF387BAABDDD> /Applications/Microsoft Teams.app/Contents/Resources/app.asar.unpacked/node_modules/slimcore/bin/vcxpc.xpc/Contents/MacOS/vcxpc 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: VDCAssistant [210] UUID: 0A223985-91C4-36A9-887D-34071172C3C6 Path: /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/Resources/VDC.plugin/Contents/Resources/VDCAssistant Architecture: x86_64 Parent: launchd [1] UID: 262 Sudden Term: Tracked Footprint: 4352 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0x7ab 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested default), process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 20770) [0x7fff60fd4122] 1-11 *11 ??? (kernel + 7168864) [0xffffff80008d6360] 1-11 Thread 0xa22230 11 samples (1-11) priority 97 (base 97) <process sudden termination clean, IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10d8a6000 - 0x10d959fff VDCAssistant <0A223985-91C4-36A9-887D-34071172C3C6> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/Resources/VDC.plugin/Contents/Resources/VDCAssistant 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: Vectorworks Web Helper (GPU) [62928] [unique pid 162511] UUID: C69F291A-B8A0-3413-82D7-F8CA05D603A1 Path: /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/Frameworks/Vectorworks Web Helper (GPU).app/Contents/MacOS/Vectorworks Web Helper (GPU) Architecture: x86_64 Parent: Vectorworks [62926] [unique pid 162509] Responsible: Vectorworks [62926] [unique pid 162509] UID: 504 Footprint: 20.78 MB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) Note: 1 idle work queue thread omitted Thread 0xa4b9f6 Thread name "CrGpuMain" 11 samples (1-11) priority 31 (base 31) <thread QoS default (requested user interactive), IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4ba17 Thread name "GpuWatchdog" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 cef_time_delta + 2801911 (Chromium Embedded Framework + 46868023) [0x107cb2637] 1-11 11 cef_time_delta + 2583588 (Chromium Embedded Framework + 46649700) [0x107c7d164] 1-11 11 cef_time_delta + 2301299 (Chromium Embedded Framework + 46367411) [0x107c382b3] 1-11 11 cef_time_delta + 2475091 (Chromium Embedded Framework + 46541203) [0x107c62993] 1-11 11 cef_time_delta + 2169878 (Chromium Embedded Framework + 46235990) [0x107c18156] 1-11 11 cef_time_delta + 2862147 (Chromium Embedded Framework + 46928259) [0x107cc1183] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4ba18 Thread name "ThreadPoolServiceThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa4ba19 Thread name "ThreadPoolForegroundWorker" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 cef_time_delta + 2801911 (Chromium Embedded Framework + 46868023) [0x107cb2637] 1-11 11 cef_time_delta + 2548637 (Chromium Embedded Framework + 46614749) [0x107c748dd] 1-11 11 cef_time_delta + 2549645 (Chromium Embedded Framework + 46615757) [0x107c74ccd] 1-11 11 cef_time_delta + 2547256 (Chromium Embedded Framework + 46613368) [0x107c74378] 1-11 11 cef_time_delta + 2862147 (Chromium Embedded Framework + 46928259) [0x107cc1183] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4ba1a Thread name "ThreadPoolBackgroundWorker" 11 samples (1-11) priority 4 (base 4) <IO tier 0> 11 thread_start + 13 (libsystem_pthread.dylib + 9229) [0x7fff6108e40d] 1-11 11 _pthread_start + 66 (libsystem_pthread.dylib + 25161) [0x7fff61092249] 1-11 11 _pthread_body + 126 (libsystem_pthread.dylib + 13035) [0x7fff6108f2eb] 1-11 11 cef_time_delta + 2801911 (Chromium Embedded Framework + 46868023) [0x107cb2637] 1-11 11 cef_time_delta + 2548493 (Chromium Embedded Framework + 46614605) [0x107c7484d] 1-11 11 cef_time_delta + 2549645 (Chromium Embedded Framework + 46615757) [0x107c74ccd] 1-11 11 cef_time_delta + 2547256 (Chromium Embedded Framework + 46613368) [0x107c74378] 1-11 11 cef_time_delta + 2862147 (Chromium Embedded Framework + 46928259) [0x107cc1183] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Thread 0xa4ba1b Thread name "Chrome_ChildIOThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 kevent64 + 10 (libsystem_kernel.dylib + 37026) [0x7fff60fd80a2] 1-11 *11 ??? (kernel + 6978560) [0xffffff80008a7c00] 1-11 Thread 0xa4ba1c Thread name "VizCompositorThread" 11 samples (1-11) priority 31 (base 31) <IO tier 0> 11 <truncated backtrace> 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x104d85000 - 0x104e6cfff net.nemetschek.vectorworks.Vectorworks_Web_Helper__GPU_ (1.0) <C69F291A-B8A0-3413-82D7-F8CA05D603A1> /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/Frameworks/Vectorworks Web Helper (GPU).app/Contents/MacOS/Vectorworks Web Helper (GPU) 0x105000000 - 0x10d1adfff org.chromium.ContentShell.framework 84.3.3.0 (3.0) <33CBB18A-CD37-38C4-94FB-B9E1EDFF8658> /Applications/Vectorworks 2021/Vectorworks 2021.app/Contents/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff6108c000 - 0x7fff61096fff libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ViewBridgeAuxiliary [286] UUID: 281B940F-091F-3C0E-88CF-F95DEB557B5A Path: /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary Architecture: x86_64 Parent: launchd [1] UID: 504 Sudden Term: Tracked (allows idle exit) Footprint: 5028 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (486.6K cycles, 141.1K instructions, 3.45c/i) Note: 1 idle work queue thread omitted Thread 0x823 DispatchQueue 1 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (486.6K cycles, 141.1K instructions, 3.45c/i) <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ViewBridgeAuxiliaryMain + 4103 (ViewBridge + 10485) [0x7fff5c9ef8f5] 1-11 11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x10dd0a000 - 0x10dd0afff ViewBridgeAuxiliary <281B940F-091F-3C0E-88CF-F95DEB557B5A> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <9FA71865-7713-3F53-91E7-5DCEBCF4F83D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff5c9ed000 - 0x7fff5cac6fff com.apple.ViewBridge 407 (407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff60e85000 - 0x7fff60eb1fff libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib 0x7fff60fcf000 - 0x7fff60ff7fff libsystem_kernel.dylib (4903.278.70) <35EE704F-F9B6-3531-B312-E45CFA2A8743> /usr/lib/system/libsystem_kernel.dylib 0x7fff610c3000 - 0x7fff610f2fff libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib *0xffffff8000200000 - 0xffffff8000bfffff kernel (4903.278.70) <041B6A6D-CD16-36FA-88B9-E32FF46EF89F> /System/Library/Kernels/kernel Process: ViewBridgeAuxiliary [383] UUID: 281B940F-091F-3C0E-88CF-F95DEB557B5A Path: /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary Architecture: x86_64 Parent: launchd [1] UID: 0 Sudden Term: Tracked (allows idle exit) Footprint: 2304 KB Start time: 2022-12-30 22:13:30 -0800 End time: 2022-12-30 22:13:31 -0800 Num samples: 11 (1-11) CPU Time: <0.001s (483.1K cycles, 136.1K instructions, 3.55c/i) Note: 1 idle work queue thread omitted Thread 0xd5d DispatchQueue 1 11 samples (1-11) priority 4 (base 4) cpu time <0.001s (483.1K cycles, 136.1K instructions, 3.55c/i) <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2> 11 start + 1 (libdyld.dylib + 91093) [0x7fff60e9b3d5] 1-11 11 ViewBridgeAuxiliaryMain + 4103 (ViewBridge + 10485) [0x7fff5c9ef8f5] 1-11 11 -[NSXPCSharedListener resume] + 16 (ViewBridge + 13808) [0x7fff5c9f05f0] 1-11 11 xpc_main + 433 (libxpc.dylib + 68445) [0x7fff610d3b5d] 1-11 11 _xpc_objc_main + 552 (libxpc.dylib + 69723) [0x7fff610d405b] 1-11 11 -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 117396) [0x7fff37170a94] 1-11 11 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 280 (Foundation + 117695) [0x7fff37170bbf] 1-11 11 CFRunLoopRunSpecific + 455 (CoreFoundation + 240350) [0x7fff34f06ade] 1-11 11 __CFRunLoopRun + 1612 (CoreFoundation + 242556) [0x7fff34f0737c] 1-11 11 __CFRunLoopServiceMachPort + 328 (CoreFoundation + 245262) [0x7fff34f07e0e] 1-11 11 mach_msg_trap + 10 (libsystem_kernel.dylib + 4634) [0x7fff60fd021a] 1-11 *11 ipc_mqueue_receive_continue + 0 (kernel + 1647440) [0xffffff8000392350] 1-11 Binary Images: 0x109bb2000 - 0x109bb2fff ViewBridgeAuxiliary <281B940F-091F-3C0E-88CF-F95DEB557B5A> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary 0x7fff34ecc000 - 0x7fff35312fff com.apple.CoreFoundation 6.9 (1575.405) <04F56DFB-C410-31B8-8AE9-7D2024DB6E22> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff37154000 - 0x7fff37502fff com.apple.Foundation 6.9 (1575.405) <
