Hello Community! Our community board will be offline for maintenance as we perform an upgrade from June 8th at 8:30 am ET until June 9th. We appreciate your patience and understanding during this time.
TLeatherman
    18
Reputation
2 Neutral
Personal Information
  • Occupation
    AV System Design Engineer
  • Location
    United States
Recent Profile Visitors
1,623 profile views
  1. This is incredibly helpful Pat! Thank you so much for the time and attention to this. This is a huge help! It's working great now!
  2. Thanks for the reply! Yes, here's an example file. There's quite a few other areas this would help us out in with tagging objects with height, we use the 5'-0" format for our drawings so the decimal feet feels messy/hard to follow. Thanks again, TV Data Tag Test.vwx
  3. Hey all, Wondering if this is possible/if someone could help me understand how to get a Z height for an object in the format of ex. 3'-6" in a data tag. I've tried quite a few things and I feel like I'm going in circles. Screenshots of what I've tried below. I've successfully gotten decimal feet to work, but I haven't been able to change to a feet-inches format. I tried looking at forums, and I assume this is similar to a worksheet conversion, but couldn't seem to find any examples. Thanks for any help in advance!
  4. Hey All, Wondering if you could help me understand the "Create Devices from Worksheet" command in VWX 2024? It seems like a really powerful tool that would save us a lot of time if we get it setup. On initial tests it's working great on the first time the command is used, but it's not always recognizing that devices have already been created. Wondering what Vectorworks is checking when it checks if there is already a device present? With a pretty large library of devices we've built would love to know a common thread or way to troubleshoot it? Also, bonus if there's any way to number things starting at 101 instead of 1. In the worksheet I put "DPB-101" in the device field, and got back DPB-1 through DPB-10 populated. Happy to DM a file if it's helpful. Thanks so much, Travis
  5. I was just about to ask this same question. Maybe the 2024 Help article is misleading? There doesn't seem to be a way to update the worksheet and the information change the Rack since it's not populated as a database? Rack Elevation Worksheet Update Test.vwx
  6. Wow, this is incredible. Thank you so so much for the detailed response and help! I was able to toggle it off after running the script, thanks so much! For future reference, I think I'm tracking for the most part on hybrid symbols/annotation layers still using screen plane. Are there any symbols or objects that when brought in from a workgroup or older file that will force the "2D Legacy Features" back on (or otherwise not appear correctly when brought in)? From your explanation above my assumption is that on a design layer, with "2D Legacy Features" off any symbol, group, etc. would default to Layer Plane correct?
  7. I'm starting the process of migrating to VWX 2024. We have a couple templates that have been around for a few years, and we had previously used Unified View and what is now called "Legacy 2D features". When I start a brand new file it defaults to having "Enable legacy 2D features" to Off in the Document preferences. When I open our template in 24 and try to disable it, it gives this dialog (below) saying the drawing contains screen plane objects. When I go to Tools>Custom Selection>Select "Plane is Screen Plane", I get a whopping 82,921 objects that meet the criteria, but when I hit OK, it only selected 10 objects. Our templates include a lot of custom symbols we've built over the years that we still use regularly. I would love for the words "Unified View" to not be in our vocabulary anymore but I'm a bit at a loss of how to make that happen. I recognize there could definitely be some TLC and cleanup of the template, but going through every symbol, punching into every group, and trying to find every screen object sounds painstaking. Is there something I'm missing or a way to migrate this well? I'm open to starting a new file if it doesn't recognize screen plane objects when dragged in or something? Thanks so much for the help, Travis
  8. Just DM'd you the file. Thank you Nikolay!
  9. Hey all, After drawing arrow circuits, the circuit will pop out and add 2 Control Points that we have to move towards the device and then move the label in as well. There seems to be no rhyme or reason as when this happens or what circuits it happens on, seemingly random as far as we can tell. Has anyone else experienced this? We have 5 users that have all had this happen when we all installed SP5, and it's happened in multiple files. It's pretty frustrating when we're about to publish and have to go back and scrub through, the drawings to catch all of these. Vectorworks 2023 SP5 Thanks for the help!
  10. Hello, I'm trying to show page number and practical label (user1 & user2 fields) of a destination ConnectCAD device in circuit graphics. Is this possible? Is there syntax I'm missing? Thanks so much for the help!
  11. Hi there, I know this isn't probably the typical workflow, but this is something we've experienced since ConnectCAD 2019. Is there any way around sockets pasting in place way off from where they were copied from on the schematic layer? From my limited knowledge I would assume it's to do with how planes work, but would love any explanation and workaround if someone else knows. Pictures below to explain it a bit better. This is the best case example, usually they're pasting way off which is time consuming to 'Fit to Objects' and drag it back to the device. Thanks a lot!
  12. First off, love the new functionality of "Navigate to Other End of Circuit" in the OIP for arrow connections in 2021. I'm guessing I know the answer, I didn't see it in the plug-in manager, but I was just curious if there's a way get a keyboard shortcut for that "Navigate to other end of Circuit" Function? Thanks a lot for the help.
  13. Thanks a lot for the response Nikolay. So after your response I tried opening up the 'Test 2020' file in 2021 and I still get the extra socket information. I tried clearing preferences and reinstalling 2021 to see if that may have been a factor and it still opens up the file with the extra sockets in 2021. I also didn't experience the changing layer reset as you described. When I changed layers on the design or device layers neither reset the sockets. However, after the reinstall - whether it was the newest service pack or the fresh install, the sockets are selectable and are able to be deleted in the 3D device layer. After deleting and re-saving the symbol all seems to work well. Still strange, but I'm just thankful to have a workaround. Thanks a lot, Travis
