Bruce Kieffer
    2,946
Reputation
485 Spectacular
4 Followers
Personal Information
  • Occupation
    Tinkerer
  • Homepage
    www.kieffer.us
  • Hobbies
    Woodworking, fishing, poker, napping
  • Location
    United States
Recent Profile Visitors
  1. It looks like that is the reason. Seems rather dumb though.
  2. I still can't make it work on anything but a circle.
  3. The Tool Tip says it should work, but I can only get it to work in Top/Plan view on an arc. Screen Recording 2025-12-28 at 9.53.20 AM.mov
  4. I can draw a line tangent to a circle, but not to an arc. Is there a way to do this?
  5. I think it also has to do with what might be called the wrapper "All criteria in this set" which I added to wrap the other two "Any" criteria.
  6. Trial and error and I got it. I can't say how or why though!!! I do wish that defining the criteria was more intuitive, like asking how many of these parts are on these layers.
  7. I need my worksheet to correctly display the parts for sconces I plan to build. This criteria setup should work, but I have something wrong. I want to display the sconce parts on the East Wall layer and the West Wall layer, but not the Sconces Parts layer. This setup does not exclude the sconce parts on the Sconce Parts Layer. The total count should be 30, not 36. What do I need to do to fix that?
  8. The parent class of these objects is "None". Their parts have different classes. They are not visible until I select all or use a selection marquee where they are inside. They are not selectable if I turn off the none class, but that affects some visible objects I need to show. Why are they selectable if they are not visible?
  9. I know to check for that, and I did. I set the number format to decimal and like 30 points out. Then I removed the summarize of the worksheet. Both widths of prat C showed as 10. I think the problem was something else. It's fixed now.
  10. I rebuilt the side piece and that fixed it. It makes no sense why it would not worked flipped before. Vectorworks can be SO frustrating at times.
  11. I have a symbol of a mantle I am building. The sides are tapered but they are mirrored images of each other. I duplicated a side, then flipped it horizontal. When the side is not flipped, my cut list worksheet shows it's summarized by Part ID width correctly, but when it is flipped or mirrored the worksheet shows the summarized by Part ID width as ---. What's the problem Vectorworks!
  12. Please tell us the solution that @shorter had? I don't see that in this thread.
  13. Does anyone have a storm door drawing to share? I need one for a 36 x 80 Andersen 4000 storm door. Anything close I can modify. I did contact Andersen and they said they don't share their storm door drawings. That seems strange since they share all their window and door drawings.
  14. So obviously there is no interactive setting to do this. That is sad since that is where we can go to modify the colors for many settings. Wish list here I come. @Pat Stanford, I'll see what I can do about getting your daughters that pony they want.
