Hello Community!
This Saturday, April 11, from 9am – 1pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
  • 1
mbft
VW 2018 sp3 : slow, hanging, crash
Hello again,
anybody having problems with sp3 2018 ? In many different files - size, complexity, etc - I am having problems with VW being extremely slow to change layer, change classes, edit geometry, render, basically everything - the last one I was editing a polygon. Sometimes everything is fine but I often find myself staring at the spinning beach ball of death and then having to force quit.
19 answers to this question
I’ve not seen the issues you’re describing per se, however...
- Are you able to update your Mac OS to 10.12.6?
- Have you restarted Vectorworks and your computer?
- Is the Navigation Graphics setting (in Vectorworks Preferences > Display) set to Good Performance &  Compatibility?
Integrated graphics cards such as the Intel Iris Pro aren’t typically recommended, so that may be part of the problem, but see if the tips above help.
I've noticed much of the same.  Beach balls, sudden - as in instant - crashes when doing flyovers, slow overall
@Tim Olson Since you’re seeing the same performance, and you have dual graphics cards, have you ensured that your computer is being forced to use the NVIDIA card (in System Preferences > Energy Saver)? You and I have essentially the same computers, though I’m running Mac OS 10.12.6, and I’m not seeing the slowdowns that you are.
Hi Neil, I have the automatic graphics switched off and only use the dedicated card.  I noticed a big difference as soon as I installed sp3
the only difference here seems to be high sierra
19 hours ago, Kazemester said:
Process:               Vectorworks [32088]
Path:                  /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/Vectorworks
Identifier:            net.nemetschek.vectorworks
Version:               23.0.3 [418943] (23.0.3)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Vectorworks [32088]
User ID:               502
Date/Time:             2018-04-01 20:20:45.413 +0200
OS Version:            Mac OS X 10.13.3 (17D102)
Report Version:        12
Anonymous UUID:        8B83ED14-46B1-FDC6-DE3E-87A1E92F81D4
Time Awake Since Boot: 380000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x00000000000000c8
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [0]
VM Regions Near 0xc8:
    __TEXT                 00000001013b2000-0000000104ac1000 [ 55.1M] r-x/rwx SM=COW  /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/Vectorworks
Application Specific Signatures:
{"sn":"EDXUSZ-XXXXXX-XXXXXX-G02TGN", "ts":"49dbb88037", "platform":"MAC", "os_ver":"10.13.3", "vw_ver":"2018 SP3 [23.0.3(418943)] (64-Bit app)", "error_reporting_mode":1}
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc1125b VGM::IndexRanges::Empty() + 7
1   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc7c906 VGM::RenderEngine::RenderPointBatches_Forward(bool) + 1480
2   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc7a88e VGM::RenderEngine::Render(VGM::ERenderMode) + 1200
3   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc2b5ce VGM::GeometryEngine::PointRender(std::__1::vector<VGM::Camera, std::__1::allocator<VGM::Camera> >&, VGM::StackingOrderDepthBaseArgs&) + 242
4   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc2d85f VGM::GeometryEngine::RenderScene(VGM::DisplayMode, bool) + 1133
5   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc4282e VGM::GraphicsEngine::RenderScene(glm::detail::tvec4<int> const&, unsigned int, unsigned int, unsigned int, VGM::FrameQuality const&, VGM::DisplayMode, void*) + 624
6   net.nemetschek.vectorworks        0x000000010391e284 0x1013b2000 + 39240324
7   net.nemetschek.vectorworks        0x0000000102ec3cd5 0x1013b2000 + 28384469
8   net.nemetschek.vectorworks        0x0000000102ecb8e9 0x1013b2000 + 28416233
9   net.nemetschek.vectorworks        0x0000000102eccc00 0x1013b2000 + 28421120
10  net.nemetschek.vectorworks        0x0000000102ec13ee 0x1013b2000 + 28373998
11  net.nemetschek.vectorworks        0x0000000102ec702c 0x1013b2000 + 28397612
12  net.nemetschek.vectorworks        0x0000000102eca9c6 0x1013b2000 + 28412358
13  net.nemetschek.vectorworks        0x0000000102ec8af6 0x1013b2000 + 28404470
14  net.nemetschek.vectorworks        0x0000000102ec101f 0x1013b2000 + 28373023
15  net.nemetschek.vectorworks        0x0000000102ec0fef 0x1013b2000 + 28372975
16  net.nemetschek.vectorworks        0x0000000102aae597 0x1013b2000 + 24102295
17  net.nemetschek.vectorworks        0x0000000102933d2c 0x1013b2000 + 22551852
18  net.nemetschek.vectorworks        0x00000001026b45a3 0x1013b2000 + 19932579
19  net.nemetschek.vectorworks        0x000000010157fe5d 0x1013b2000 + 1891933
20  com.apple.AppKit                  0x00007fff44664422 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 1961
21  com.apple.AppKit                  0x00007fff4466385c -[NSWindow(NSEventRouting) sendEvent:] + 497
22  net.nemetschek.vectorworks        0x00000001015b521c 0x1013b2000 + 2109980
23  com.apple.AppKit                  0x00007fff444c4617 -[NSApplication(NSEvent) sendEvent:] + 307
24  net.nemetschek.vectorworks        0x00000001016ad182 0x1013b2000 + 3125634
25  net.nemetschek.vectorworks        0x00000001016ad02d 0x1013b2000 + 3125293
26  com.apple.AppKit                  0x00007fff43d25d9d -[NSApplication run] + 812
27  com.apple.AppKit                  0x00007fff43cf4f1a NSApplicationMain + 804
28  libdyld.dylib                     0x00007fff6e061115 start + 1
Thread 1:
0   libsystem_kernel.dylib            0x00007fff6e1b0f0a __recvfrom + 10
1   net.nemetschek.vectorworks        0x0000000101f6bf82 0x1013b2000 + 12296066
2   net.nemetschek.vectorworks        0x0000000101f51bff 0x1013b2000 + 12188671
3   net.nemetschek.vectorworks        0x0000000101f51e4e 0x1013b2000 + 12189262
4   net.nemetschek.vectorworks        0x0000000101f52769 0x1013b2000 + 12191593
5   net.nemetschek.vectorworks        0x0000000101f576c0 0x1013b2000 + 12211904
6   libsystem_pthread.dylib           0x00007fff6e2ec6c1 _pthread_body + 340
7   libsystem_pthread.dylib           0x00007fff6e2ec56d _pthread_start + 377
8   libsystem_pthread.dylib           0x00007fff6e2ebc5d thread_start + 13
Thread 2:: CVDisplayLink
0   libsystem_kernel.dylib            0x00007fff6e1b0cee __psynch_cvwait + 10
1   libsystem_pthread.dylib           0x00007fff6e2ed662 _pthread_cond_wait + 732
2   com.apple.CoreVideo               0x00007fff482fb9b8 CVDisplayLink::runIOThread() + 660
3   libsystem_pthread.dylib           0x00007fff6e2ec6c1 _pthread_body + 340
4   libsystem_pthread.dylib           0x00007fff6e2ec56d _pthread_start + 377
5   libsystem_pthread.dylib           0x00007fff6e2ebc5d thread_start + 13
Thread 3:
0   libsystem_kernel.dylib            0x00007fff6e1a77fe semaphore_wait_trap + 10
1   libdispatch.dylib                 0x00007fff6e03782e _dispatch_sema4_wait + 16
2   libdispatch.dylib                 0x00007fff6e02f911 _dispatch_semaphore_wait_slow + 101
3   net.nemetschek.vectorworks        0x0000000101f57185 0x1013b2000 + 12210565
4   net.nemetschek.vectorworks        0x0000000101f57953 0x1013b2000 + 12212563
5   net.nemetschek.vectorworks        0x0000000101f4d6bb 0x1013b2000 + 12170939
6   net.nemetschek.vectorworks        0x0000000101f4cffe 0x1013b2000 + 12169214
7   net.nemetschek.vectorworks        0x0000000101f576c0 0x1013b2000 + 12211904
8   libsystem_pthread.dylib           0x00007fff6e2ec6c1 _pthread_body + 340
9   libsystem_pthread.dylib           0x00007fff6e2ec56d _pthread_start + 377
10  libsystem_pthread.dylib           0x00007fff6e2ebc5d thread_start + 13
Thread 4:
0   libsystem_kernel.dylib            0x00007fff6e1b105a __semwait_signal + 10
1   libsystem_c.dylib                 0x00007fff6e12c75c nanosleep + 199
2   libsystem_c.dylib                 0x00007fff6e12c650 usleep + 53
3   net.nemetschek.vectorworks.Renderworks    0x0000000116256e7a melange::IpKillThread::Main() + 58
4   net.nemetschek.vectorworks.Renderworks    0x0000000116230888 melange::BaseThread::Action() + 88
5   net.nemetschek.vectorworks.Renderworks    0x0000000116230769 0x1160be000 + 1517417
Thread 5:
2   libpskernel.dylib                 0x000000010ac104f2 create_wrapper + 578
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
2   libc++.1.dylib                    0x00007fff6c096cb0 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
3   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc238cb 0x12db9f000 + 542923
4   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc234cf ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::WorkerThread() + 305
5   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc23a65 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >*> >(void*) + 62
Thread 14:: com.apple.NSEventThread
0   libsystem_kernel.dylib            0x00007fff6e1a77c2 mach_msg_trap + 10
1   libsystem_kernel.dylib            0x00007fff6e1a6cdc mach_msg + 60
2   com.apple.CoreFoundation          0x00007fff4674f575 __CFRunLoopServiceMachPort + 341
3   com.apple.CoreFoundation          0x00007fff4674e8c7 __CFRunLoopRun + 1783
4   com.apple.CoreFoundation          0x00007fff4674df43 CFRunLoopRunSpecific + 483
5   com.apple.AppKit                  0x00007fff43e6e3c8 _NSEventThread + 184
Thread 15:: QThread
0   libsystem_kernel.dylib            0x00007fff6e1b0fca __select + 10
1   QtCore                            0x00000001ea5eedb3 qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*) + 547
2   QtCore                            0x00000001ea5efcf8 QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timespec*) + 680
3   QtCore                            0x00000001ea5f0d9b QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 251
4   QtCore                            0x00000001ea5989ad QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 381
5   QtCore                            0x00000001ea39007e QThread::exec() + 126
6   QtCore                            0x00000001ea3943f2 QThreadPrivate::start(void*) + 338
7   libsystem_pthread.dylib           0x00007fff6e2ec6c1 _pthread_body + 340
8   libsystem_pthread.dylib           0x00007fff6e2ec56d _pthread_start + 377
9   libsystem_pthread.dylib           0x00007fff6e2ebc5d thread_start + 13
Thread 16:
4   net.nemetschek.vectorworks        0x0000000101f5a20e 0x1013b2000 + 12222990
5   net.nemetschek.vectorworks        0x0000000101f59a96 0x1013b2000 + 12221078
6   net.nemetschek.vectorworks        0x0000000101f576c0 0x1013b2000 + 12211904
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
3   net.nemetschek.vectorworks        0x00000001039402ab ThreadGroup<DrawingUnit*>::WorkerThread() + 123
4   net.nemetschek.vectorworks        0x00000001039408d1 void* std::__1::__thread_proxy<std::__1::tuple<void (ThreadGroup<DrawingUnit*>::*)(), ThreadGroup<DrawingUnit*>*> >(void*) + 113
5   libsystem_pthread.dylib           0x00007fff6e2ec6c1 _pthread_body + 340
6   libsystem_pthread.dylib           0x00007fff6e2ec56d _pthread_start + 377
7   libsystem_pthread.dylib           0x00007fff6e2ebc5d thread_start + 13
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
0   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc21bbd VGM::VisitMesh(VGM::VisitMeshArgs&) + 2306
1   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc222ab 0x12db9f000 + 537259
2   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc20b0a VGM::FramerateMgr::ManageFramerate(std::__1::shared_ptr<VGM::FramerateJob>&) + 634
3   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc2341c ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::WorkerThread() + 126
4   net.nemetschek.vectorworks.VWGraphicsModule    0x000000012dc23a65 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >::*)(), ThreadGroup<std::__1::shared_ptr<VGM::FramerateJob> >*> >(void*) + 62
Thread 35:
Thread 36:
0   libsystem_pthread.dylib           0x00007fff6e2ebc40 start_wqthread + 0
1   ???                               0x0000700000000001 0 + 123145302310913
Thread 37:
0   libsystem_kernel.dylib            0x00007fff6e1b1562 __workq_kernreturn + 10
1   libsystem_pthread.dylib           0x00007fff6e2ec26f _pthread_wqthread + 1552
2   libsystem_pthread.dylib           0x00007fff6e2ebc4d start_wqthread + 13
Thread 38:
1   ???                               0x0000000000000001 0 + 1
Thread 39:
1   ???                               0x0000000000000010 0 + 16
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
1   ???                               0x00007fffa6f7b480 headPagePairs + 48
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x000000012dcfb32c  rcx: 0x0000000000000001  rdx: 0x0000000000000784
  rdi: 0x0000604001408048  rsi: 0x000000012dcf83a6  rbp: 0x00007ffeee84abc0  rsp: 0x00007ffeee84abc0
   r8: 0x000000012dcfcc71   r9: 0x00007fb1bac16fb0  r10: 0x0000000000000000  r11: 0x0000000000000001
  r12: 0x00007fb1b606b938  r13: 0x00007fb1c2192200  r14: 0x000000012dcfb652  r15: 0x00007fb1c21922b8
  rip: 0x000000012dc1125b  rfl: 0x0000000000010202  cr2: 0x00000000000000c8
Logical CPU:     0
Error Code:      0x00000004
Trap Number:     14
Binary Images:
       0x1013b2000 -        0x104ac0c97 +net.nemetschek.vectorworks (23.0.3 [418943] - 23.0.3) <E78D4930-4EB4-3FD5-AAFB-080C38461E59> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/Vectorworks
       0x105546000 -        0x105a38fff +libdcu2d65.dylib (0) <5961C038-836F-3D2B-A0D6-A8D7BB3B701A> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libdcu2d65.dylib
       0x105cd6000 -        0x105cd8fff +libboost_system.dylib (0) <FD3A0297-3214-3F2C-95BE-FAAC54953B5E> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libboost_system.dylib
       0x105ce6000 -        0x105d0bff7 +libosdCPU.2.5.0.dylib (0) <D1EBC34A-EFA2-3362-A101-5EC18DE33AF7> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libosdCPU.2.5.0.dylib
       0x105d2c000 -        0x105f3dfef +org.python.python (3.5.2, [c] 2001-2016 Python Software Foundation. - 3.5.2) <E72CC169-DB75-78E3-129F-F74F5A5058F8> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/Python.framework/Versions/3.5/Python
       0x106081000 -        0x106087ffb +net.nemetschek.VWMM (1.0 - 1) <CCD25092-D8D0-3301-94D9-1DBA1227E38B> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/VWMM.framework/Versions/A/VWMM
       0x106094000 -        0x10778dfff +libPDFNetC.dylib (6.5) <8242FC4C-361D-CF28-9E08-7F7C9201156B> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libPDFNetC.dylib
       0x107d36000 -        0x107d3bff7 +libpsassemblyrep.dylib (0) <08BEDFB2-C7EE-3F06-80AA-170FA486D24D> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsassemblyrep.dylib
       0x107d4c000 -        0x107e35fff +libpsgeneric.dylib (0) <FAF8F195-D749-3A51-BC66-2F3114F71CE9> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsgeneric.dylib
       0x107ea4000 -        0x107ec3ff7 +libpsiges.dylib (0) <0D544614-7178-366A-BD1F-8381C3868205> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsiges.dylib
       0x107eed000 -        0x107f13ff7 +libpsinterop.dylib (0) <6DB65E9F-E500-3D04-A189-0473329FC165> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsinterop.dylib
       0x107f53000 -        0x107f56fff +libpspropertiesbase.dylib (0) <DCFBB48F-983F-389C-9313-CD383B66920D> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpspropertiesbase.dylib
       0x107f62000 -        0x108000fff +libpsxlatorbase.dylib (0) <669E0E16-1F27-315E-8746-8F101B5805E3> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsxlatorbase.dylib
       0x108068000 -        0x10806cff7 +libpspropertiesbrepimporter.dylib (0) <2EDB7C06-14BA-3076-94CD-94021F5FD328> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpspropertiesbrepimporter.dylib
       0x108077000 -        0x108199ff7 +libpsxcore.dylib (0) <EA2395CA-CBB0-30D3-96C8-7A9C6834C01C> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsxcore.dylib
       0x108218000 -        0x1083c0fff +libpsxiges.dylib (0) <85B64C62-1ED7-356F-92BB-62D7BC1867F9> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsxiges.dylib
       0x108472000 -        0x108494ff7 +libpsxmil.dylib (0) <1C447EBD-15CA-3762-8750-A7EC3E0EC4B5> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpsxmil.dylib
       0x1084b7000 -        0x10b327ff7 +libpskernel.dylib (0) <DA1B8C12-3E7B-31C6-803D-82F161922290> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libpskernel.dylib
       0x10b5ca000 -        0x10b5cdff7 +libmessagehandler.dylib (0) <FC4D5F00-F6DE-3675-9E61-E59188FD3F81> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libmessagehandler.dylib
       0x10b5d8000 -        0x10b610fff +libHSIMac.dylib (0) <6D170DB2-9A66-30AD-9F23-2E7B4950C8F9> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/MacOS/libHSIMac.dylib
       0x10e5a7000 -        0x10e5f4ff7 +net.nemetschek.vectorworks.VWLibrary (1.0) <C84BFF90-5D11-3FC6-95BB-80DBE290EDD6> /Applications/Vectorworks 2018/*/VWLibrary
       0x10e688000 -        0x10e696fff +libboost_filesystem.dylib (0) <90F19FCF-752F-37D5-B04A-4898920178C5> /Applications/Vectorworks 2018/*/libboost_filesystem.dylib
       0x10e6a1000 -        0x10e6a3ff3 +libboost_system-mt.dylib (0) <28E41007-7056-3375-A009-BB8E0FC78AF1> /Applications/Vectorworks 2018/*/libboost_system-mt.dylib
       0x10e6a7000 -        0x10e6b5fff +libboost_filesystem-mt.dylib (0) <2DDA5D7A-2A09-33BB-B0BF-F63477DCF8BC> /Applications/Vectorworks 2018/*/libboost_filesystem-mt.dylib
       0x10e6c0000 -        0x10e6c2ff3 +libboost_system.dylib (0) <50023B1D-95F2-3C02-877F-5C7B5E6CAD4E> /Applications/Vectorworks 2018/*/libboost_system.dylib
       0x10e919000 -        0x10e966fff +net.nemetschek.vectorworks.AlignLayerViews (1.0) <267127E8-A1C2-3816-BEF1-250E29B6C726> /Applications/Vectorworks 2018/*/AlignLayerViews
       0x10eb4e000 -        0x10ebc3ff7 +net.nemetschek.vectorworks.CheckSpelling (1.0) <EFF5E969-B805-32E3-B5B9-148A7CFF477F> /Applications/Vectorworks 2018/*/CheckSpelling
       0x10ec22000 -        0x10ece5ffb  com.apple.AMDRadeonX4000GLDriver (1.60.26 - 1.6.0) <0066C672-7627-310C-8DBD-1D23BB746AE4> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
       0x10ed35000 -        0x10ee6afff  com.apple.AMDMTLBronzeDriver (1.60.26 - 1.6.0) <7C3FAF5B-05D0-3AE7-B3DB-8D50D98E3072> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
       0x10f0b9000 -        0x10f10398f  dyld (519.2.2) <6695F30B-4E88-3C0B-9867-7D738C44A3E6> /usr/lib/dyld
       0x110d5d000 -        0x110daafff +net.nemetschek.vectorworks.TesterModule (1.0) <A68B4FCC-E0D6-3EF0-9FF3-4157492916FA> /Applications/Vectorworks 2018/*/CheckForUpdates
       0x110dcb000 -        0x111082ff7 +de.computerworks.vectorworks.CWLibraryUniversal1 (D23.0.3 R1  - 1.0) <5F689514-206C-3901-9739-965EB2BA89CB> /Applications/Vectorworks 2018/*/CWLibraryUniversal1
       0x111377000 -        0x111618fff +net.nemetschek.vectorworks.DebugModule (1.0) <917B0591-CAC4-3418-B85D-B35EACA1C3F2> /Applications/Vectorworks 2018/*/DebugModule
       0x11172c000 -        0x1118c8ff7 +net.nemetschek.vectorworks.Marionette (1.0) <72853949-9EFE-3EA6-ADE0-2A0CA82282E9> /Applications/Vectorworks 2018/*/Marionette
       0x111982000 -        0x1119d2fff +net.nemetschek.vectorworks.TesterModule (1.0) <2CC15F09-8412-3C3E-B579-D6FCF0111D7C> /Applications/Vectorworks 2018/*/OnlineResources
       0x1119f7000 -        0x111b2cff7 +net.nemetschek.vectorworks.SpotlightVision (1.0) <BA175F15-26BE-3B2F-B5C4-A18499197010> /Applications/Vectorworks 2018/*/SpotlightVision
       0x111bba000 -        0x1120c9ff7 +org.qt-project.QtCore (5.5 - 5.5.1) <D07C940F-8EB1-3F47-942F-6A00BCBCCD06> /Library/Frameworks/QtCore.framework/Versions/5/QtCore
       0x1121bc000 -        0x1121f3fff +org.qt-project.QtXml (5.5 - 5.5.1) <6B22AC36-E02D-3902-98E6-8678065F9E4C> /Library/Frameworks/QtXml.framework/Versions/5/QtXml
       0x11220a000 -        0x112259ff3 +libsVisionPlugin.dylib (0) <A71BAFCF-617C-3370-A61F-50FD16741E99> /Applications/Vectorworks 2018/*/libsVisionPlugin.dylib
       0x112276000 -        0x1122b4fff +org.qt-project.QtOpenGL (5.5 - 5.5.1) <4BE1F8E5-6B6E-3988-A746-440D80603FB7> /Library/Frameworks/QtOpenGL.framework/Versions/5/QtOpenGL
       0x1122dc000 -        0x1127f1ff7 +org.qt-project.QtWidgets (5.5 - 5.5.1) <1AF6065B-6055-3DC7-B92D-AA106307735B> /Library/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
       0x1129ae000 -        0x112e42fff +org.qt-project.QtGui (5.5 - 5.5.1) <64584329-006F-386F-B498-C7D0E5FC241E> /Library/Frameworks/QtGui.framework/Versions/5/QtGui
       0x112f7f000 -        0x113027fff +libqcocoa.dylib (0) <56ADBA40-C8E0-38A5-8C62-B485E4784B5D> /Library/Frameworks/QtPlugins/plugins/platforms/libqcocoa.dylib
       0x113084000 -        0x1130ebfff +org.qt-project.QtDBus (5.5 - 5.5.1) <245EE4C3-2FE2-3C91-92A3-F2E781973C9A> /Library/Frameworks/QtDBus.framework/Versions/5/QtDBus
       0x113116000 -        0x11314bfff +org.qt-project.QtPrintSupport (5.5 - 5.5.1) <9F5C686D-7C6D-327D-8D1A-DEF6977D4004> /Library/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
       0x114b41000 -        0x114bb6ff7 +net.nemetschek.vectorworks.VCSClient (1.0) <F8B30AD5-A653-3C64-A1AF-7235C2AE959A> /Applications/Vectorworks 2018/*/VCSClient
       0x114bf0000 -        0x114c4bfff +net.nemetschek.vectorworks.VectorScriptEditor (1.0) <050D7AD1-5524-3396-B7D1-3AF888096A45> /Applications/Vectorworks 2018/*/VectorScriptEditor
       0x114c6e000 -        0x114d97ff7 +com.sun.Scintilla (1.0) <57E3650E-5878-3AF1-84E9-4BA05D528C03> /Applications/Vectorworks 2018/*/Scintilla.framework/Versions/A/Scintilla
       0x114df3000 -        0x1154c6fef +net.nemetschek.vectorworks.Support (1.0) <47B57DAA-B6F2-3886-AC0E-AFCC484E05A3> /Applications/Vectorworks 2018/*/Support
       0x1157ab000 -        0x1157adff3  com.apple.textencoding.unicode (4.0 - 4.0) <B2304E3E-5ECA-30E0-8387-AFB1AE0B659D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
       0x11583c000 -        0x1158fffff +net.nemetschek.vectorworks. (1.0) <FB729825-0643-3998-B8F0-B699F6977CF3> /Applications/Vectorworks 2018/*/VS Shared Library
       0x115e0f000 -        0x11602aeff +net.nemetschek.vectorworks. (1.0) <0114E86E-FF6C-3B9E-B42A-8EBCC3E1D5D4> /Applications/Vectorworks 2018/*/Plug-In Support
       0x1160be000 -        0x1162d8fff +net.nemetschek.vectorworks.Renderworks (1.0) <057E8C86-C985-3250-9C53-FA984EA75D0F> /Applications/Vectorworks 2018/*/Renderworks
       0x117040000 -        0x11717bfff +net.nemetschek.vectorworks. (1.0) <2DE6EB00-A95B-3CC3-BF46-5F7F3FCED6E5> /Applications/Vectorworks 2018/*/3DS Library
       0x11722c000 -        0x117367ff7 +net.nemetschek.vectorworks.Animation (1.0) <41FD72CB-C451-3A08-A228-934EDA151EFF> /Applications/Vectorworks 2018/*/Animation
       0x1173fe000 -        0x117714ff7 +net.nemetschek.vectorworks.ArchitecturalObjects (1.0) <7A326F61-F14C-37B5-B902-99B4D81860CC> /Applications/Vectorworks 2018/*/ArchitecturalObjects
       0x117816000 -        0x117ad1ff7 +com.deersoft.braceworxs.braceworxsvwxplg (0.13.2) <60975DA4-78C9-3E1F-9C72-72E0ECFF50D8> /Applications/Vectorworks 2018/*/BraceWorxsVwxPlg
       0x117c2d000 -        0x118016fff +net.nemetschek.vectorworks.EnergyAnalysis (1.0) <794E99DA-D38F-3BDE-AE73-D432BB7207C7> /Applications/Vectorworks 2018/*/EnergyAnalysis
       0x118214000 -        0x1183c8ff7 +net.nemetschek.vectorworks.GIS (1.0) <A0A1A37B-C7C7-36CF-BAF2-A8F4BA2BDE52> /Applications/Vectorworks 2018/*/GIS
       0x118499000 -        0x11902cfe7 +libgdal.20.dylib (0) <F84040B7-44E4-3789-8D2B-EADD6EFD32EB> /Applications/Vectorworks 2018/*/libgdal.20.dylib
       0x119486000 -        0x11973cfff +net.nemetschek.vectorworks.SpotlightModule (1.0) <05323D2D-1B84-3134-BAE1-7AA77A5D9C2B> /Applications/Vectorworks 2018/*/Spotlight
       0x119850000 -        0x119935ff7 +net.nemetschek.vectorworks.DetailCallout (1.0) <C2337180-1270-334F-8B92-04339C393491> /Applications/Vectorworks 2018/*/DetailCallout
       0x11999e000 -        0x119b82fff +net.nemetschek.vectorworks.Fundamentals (1.0) <9053FB57-A47F-3AE7-8126-BF63842798AE> /Applications/Vectorworks 2018/*/Fundamentals
       0x119c6b000 -        0x11a2ebfff +net.nemetschek.vectorworks.LandscapeModule (1.0) <091134B1-E53D-3FCD-9DCD-96D4BAA96BC0> /Applications/Vectorworks 2018/*/Landscape
       0x11a514000 -        0x11a79fff7 +net.nemetschek.vectorworks.LandscapeIrrigation (1.0) <827E0076-00AA-37E2-B6DF-8D07790DAD3C> /Applications/Vectorworks 2018/*/LandscapeIrrigation
       0x11a8ba000 -        0x11aedafff +Raum CW (D23.0.3 R1  - 1.0) <9522A138-E8AE-342F-ABBF-88ED29F5F31C> /Applications/Vectorworks 2018/*/Raum CW
       0x11b3ee000 -        0x11b556fff +net.nemetschek.vectorworks.TesterModule (1.0) <6D449E6B-66C1-35FE-BA88-4C312D984594> /Applications/Vectorworks 2018/*/StructuralMember
       0x11b5fe000 -        0x11bbb4ff7 +de.computerworks.vectorworks.Treppen (D23.0.3 R1  - 1.0) <3047387E-FA36-39AF-AB33-89CBDA85025A> /Applications/Vectorworks 2018/*/Treppen
       0x11c0a9000 -        0x11c1f8ff7 +net.nemetschek.vectorworks.VectorworksRemote (..) <33FA779D-C7D0-3E42-8940-46E91BC6EED3> /Applications/Vectorworks 2018/*/Vectorworks Remote
       0x11c648000 -        0x11c6c6fff +net.nemetschek.vectorworks.Workspaces (1.0) <BE21420C-D696-3CE5-92E4-79243353DD4A> /Applications/Vectorworks 2018/*/Workspaces
       0x120169000 -        0x1202a7ff3 +com.deersoft.GDTFExport (1.0) <6F1770BC-B1CC-3310-A9F4-04F78A6D334B> /Applications/Vectorworks 2018/*/VWGDTFExchange
       0x120364000 -        0x1203bfff7 +net.nemetschek.vectorworks.UpdateCheck (1.0) <C667B728-4F4A-3F50-A052-2CC925905887> /Applications/Vectorworks 2018/*/UpdateCheck
       0x1203e7000 -        0x123020fff +net.nemetschek.vectorworks. (1.0) <0A6C8D1D-9663-3ABB-B16F-BF0B06063C97> /Applications/Vectorworks 2018/*/DWG Library
       0x123ec6000 -        0x124527ff7 +net.nemetschek.vectorworks.IFCLibrary (1.0) <42AAFB29-7058-3F1D-B41C-828A0940C078> /Applications/Vectorworks 2018/*/IFCLibrary
       0x1246df000 -        0x124815fff +net.nemetschek.vectorworks.Export3DPDF (1.0) <49213AAA-A332-3363-BE1F-4FB4F23817FF> /Applications/Vectorworks 2018/*/Export3DPDF
       0x1248a7000 -        0x1249eefff +net.nemetschek.vectorworks.TesterModule (1.0) <8F5305F6-4A3F-3553-A0DC-0C48F6BD0142> /Applications/Vectorworks 2018/*/OBJExporter
       0x124a88000 -        0x124e44ff3 +libexiv2.26.0.0.dylib (0) <A0D2724E-5C06-34F8-A2CE-FC59EAA59046> /Applications/Vectorworks 2018/*/libexiv2.26.0.0.dylib
       0x124f91000 -        0x1250f8ff7 +net.nemetschek.vectorworks.TesterModule (1.0) <25C596BC-C66F-3938-ACDA-6E1B8EB04CC4> /Applications/Vectorworks 2018/*/ExportWebGl
       0x125af9000 -        0x125c03ff7 +net.nemetschek.vectorworks.PDFUtilityLib (1.0) <BEF5D29A-818C-3A42-B3A0-684F41CDADD1> /Applications/Vectorworks 2018/*/PDFUtilityLib
       0x125c69000 -        0x125d1bfef +com.adobe.ICUConverter (4.0 - 4.0) <6787A609-28A2-0813-16F8-4C410B9A01C2> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
       0x125d48000 -        0x125db5ff7 +com.adobe.ICUData (4.0 - 4.0) <563D24B9-1EC2-A553-E8BA-8D56FD7C3882> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
       0x125dba000 -        0x125ed3ff7 +DL100ACE (101.0.14) <A8725993-7185-33CC-B1CD-9BD0B5CB615C> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100ACE.framework/Versions/A/DL100ACE
       0x125f14000 -        0x125f6aff7 +DL100AdobeXMP (101.0.2) <86EEDA4B-CDA3-3408-BD25-FEE03534ECCC> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100AdobeXMP.framework/Versions/A/DL100AdobeXMP
       0x125f8a000 -        0x126537fff +DL100AGM (101.0.23) <91FECB89-7118-3B7A-A56B-5BD1C7E9AC31> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100AGM.framework/Versions/A/DL100AGM
       0x12679f000 -        0x1267d8fff +DL100ARE (101.0.6) <5BEC3796-0737-37E3-9242-AA1EB1F00426> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100ARE.framework/Versions/A/DL100ARE
       0x1267fc000 -        0x12681aff7 +DL100AXE8SharedExpat (101.0.4) <0F1ED7BD-2B86-3D9D-87C7-1728A0D29D22> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100AXE8SharedExpat.framework/Versions/A/DL100AXE8SharedExpat
       0x12682c000 -        0x126849fff +DL100BIB (101.0.5) <E172BAB4-C204-3681-B403-B3EE7EDF0C7C> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100BIB.framework/Versions/A/DL100BIB
       0x126862000 -        0x126885ff7 +DL100BIBUtils (101.0.5) <368DB4F3-967E-3AE3-AA3A-3D3B7ABA35BA> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100BIBUtils.framework/Versions/A/DL100BIBUtils
       0x1268a1000 -        0x126dccfff +com.datalogics.DL100CoolType (DL100CoolType 10.1.0.13 - 10.1.0.13) <B73980BE-CD1F-32EB-B3FF-279B8C5FE43A> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100CoolType.framework/Versions/A/DL100CoolType
       0x126f9c000 -        0x127023fff +DL100JP2KLib (101.0.3) <178F9E7D-F62D-38B9-BFB1-3F8436C5FDD7> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100JP2KLib.framework/Versions/A/DL100JP2KLib
       0x12703f000 -        0x127717ff7 +DL100PDFL (101.0.45) <2856B5F6-A0FE-3A50-9242-15AA84D969E8> /Applications/Vectorworks 2018/Vectorworks 2018.app/Contents/Frameworks/DL100PDFL.framework/Versions/A/DL100PDFL
       0x129c20000 -        0x129c91ff7 +net.nemetschek.vectorworks.WebServices (1.0) <60A7F6FA-D69E-3FAD-8BE7-53DA98E08E0C> /Applications/Vectorworks 2018/*/WebServices
       0x129d43000 -        0x12a9e3fff +net.nemetschek.vectorworks.PointCloud (1.0) <5F5C0435-C79B-355E-973A-0DD7D0EC5C1D> /Applications/Vectorworks 2018/*/PointCloud
       0x12b296000 -        0x12b4bdfff +libxerces-c-3.1.dylib (0) <1950D4AB-692C-3EB0-A37F-520F462A04B0> /Applications/Vectorworks 2018/*/libxerces-c-3.1.dylib
       0x12db9f000 -        0x12dd03fff +net.nemetschek.vectorworks.VWGraphicsModule (1.0) <25F74333-FD6A-30B2-B545-35F3043E21CA> /Applications/Vectorworks 2018/*/VWGraphicsModule
       0x16b192000 -        0x16b1eeff7 +net.nemetschek.vectorworks.RenderSettings (1.0) <F6B34C8D-2EB4-3B4C-9C99-3B5145C993E9> /Applications/Vectorworks 2018/*/RenderSettings
       0x170278000 -        0x17034bfff +net.nemetschek.vectorworks.SectionLine (1.0) <8E5EB638-6870-3868-8C9A-341E91FFEDEE> /Applications/Vectorworks 2018/*/SectionLine
       0x1703b2000 -        0x170428fff +net.nemetschek.vectorworks.TaperedExtrude (1.0) <85851C7D-D162-3AFE-93CB-3342365D2D5F> /Applications/Vectorworks 2018/*/TaperedExtrude
       0x170458000 -        0x17053cff7 +net.nemetschek.vectorworks. (1.0) <9967E84E-121D-3806-8E66-35335DBEEAD3> /Applications/Vectorworks 2018/*/ExtrudeAlongPath
       0x190572000 -        0x1905bfff7 +net.nemetschek.vectorworks. (1.0) <723FD760-15C8-3E3F-B265-43152E04441D> /Applications/Vectorworks 2018/*/Fit To Objects
       0x1c872c000 -        0x1c87f5ff7 +net.nemetschek.vectorworks.TesterModule (1.0) <945716BB-B988-3168-9598-BD7F00266B12> /Applications/Vectorworks 2018/*/PointTools
       0x1c8b3b000 -        0x1c8c20ff7 +net.nemetschek.vectorworks. (1.0) <9CEACA85-4A88-35B5-848B-E561E2CC3BBA> /Applications/Vectorworks 2018/*/Offset Tool
       0x1e8ff8000 -        0x1e9045fff +net.nemetschek.vectorworks.Guides (1.0) <787E9F72-D276-35C5-A706-68BDF74AACD0> /Applications/Vectorworks 2018/*/Guides
       0x1e9144000 -        0x1e9165ffb +VectorworksRemoteServer (0) <C4568963-9F07-3D1C-937B-5F628EB75A67> /Applications/Vectorworks 2018/*/VectorworksRemoteServer.framework/VectorworksRemoteServer
       0x1e95b7000 -        0x1e9799fff +net.nemetschek.vectorworks.NotesManager (1.0) <9F3B9F21-6A65-3FCF-9E05-E07CB331AC50> /Applications/Vectorworks 2018/*/NotesManager
       0x1ea1ee000 -        0x1ea2fbfff +QtNetwork (5.3.2) <F6FAE5D5-FAA7-3F63-A3DB-A0D227F1A4EB> /Applications/Vectorworks 2018/*/VectorworksRemoteServer.framework/Libraries/QtNetwork.framework/Versions/5/QtNetwork
       0x1ea361000 -        0x1ea895ff7 +QtCore (5.3.2) <94810710-91FA-308D-B210-3166F83FCA81> /Applications/Vectorworks 2018/*/VectorworksRemoteServer.framework/Libraries/QtCore.framework/Versions/5/QtCore
    0x7fff3edf1000 -     0x7fff3f13fff7  com.apple.RawCamera.bundle (8.02.0 - 1017.2.2) <C799730B-C745-3775-BCE7-C67B8BD97FDB> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff3f387000 -     0x7fff3fbb1ff7  ATIRadeonX4000SCLib.dylib (1.60.26) <35CB9BC0-C664-38A7-96FA-0F07243E68D6> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
    0x7fff4290f000 -     0x7fff42913ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <5A110DE6-3EE7-343B-95FE-9642517D1B64> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x7fff42914000 -     0x7fff42aeffff  com.apple.avfoundation (2.0 - 1530.2) <30F528A4-548F-3E18-80A8-06481788E84C> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff42af0000 -     0x7fff42baaff7  com.apple.audio.AVFAudio (1.0 - ???) <891340D8-A1F3-37B5-A183-EE5BE81F5296> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fff42cb0000 -     0x7fff42cb0fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <5AA750F5-D633-32BA-B7F3-4F651FB1761E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff42cb1000 -     0x7fff42cc7fe3  libCGInterfaces.dylib (417) <27E09D39-51B5-3297-BE33-0DB1736B833A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff42cc8000 -     0x7fff431c6fc3  com.apple.vImage (8.1 - ???) <310976EE-E12D-39D7-8F58-6EE924E08576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff431c7000 -     0x7fff43321fcb  libBLAS.dylib (1211.30.1) <0DB0D952-BCF4-3479-BA2F-785FB1A57479> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff43322000 -     0x7fff43350fef  libBNNS.dylib (37) <49EB4DBA-877C-3D41-90A2-C3D982C72A54> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff43351000 -     0x7fff43711ff7  libLAPACK.dylib (1211.30.1) <2D4E4446-6B63-350C-BD68-A1B8FBE99539> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff43712000 -     0x7fff43727ff7  libLinearAlgebra.dylib (1211.30.1) <6C68F41D-1398-3AFE-BE72-C0ECA1B24BDC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff43728000 -     0x7fff4372dff3  libQuadrature.dylib (3) <3D6BF66A-55B2-3692-BAC7-DEB0C676ED29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff4372e000 -     0x7fff4378cfff  libSparse.dylib (79.1.1) <7AD0F8A8-FD36-36FE-B83D-58648EBD0027> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff4378d000 -     0x7fff437a0fff  libSparseBLAS.dylib (1211.30.1) <42506F6F-0F38-322E-9903-C1DB66E4DA05> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff437a1000 -     0x7fff4394dfc3  libvDSP.dylib (622.20.8) <6FFCA52B-7D60-326A-ADF2-601F39A8685A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff4394e000 -     0x7fff439fefef  libvMisc.dylib (622.20.8) <54F90047-879F-3260-8604-6E453149B49E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff439ff000 -     0x7fff439fffff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <8A96A8ED-7B88-3D17-8D17-41D224E0EC90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff43a00000 -     0x7fff43a57ff7  com.apple.Accounts (113 - 113) <02AC0AF3-D620-340E-BE52-CD31119F9CD8> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff43a58000 -     0x7fff43ceefff  com.apple.AddressBook.framework (11.0 - 1808.6) <1BE4B8EF-60A4-320C-91A5-5241E2118B82> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x7fff43cef000 -     0x7fff44b4cfff  com.apple.AppKit (6.9 - 1561.20.106) <AF59A3CF-E3C3-3046-86D9-0C9145E60CE4> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff44b9e000 -     0x7fff44b9efff  com.apple.ApplicationServices (48 - 50) <7627DBD6-497B-3AB7-9B63-F0532EDF09B8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff44b9f000 -     0x7fff44c05fff  com.apple.ApplicationServices.ATS (377 - 445) <CDF5F6D7-4E7D-3D28-9FBA-1B53AD9FA8F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff44c9e000 -     0x7fff44dc0fff  libFontParser.dylib (222.1.2) <11BD5EEF-AF18-33FB-B114-DD611932E822> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff44dc1000 -     0x7fff44e0bff7  libFontRegistry.dylib (221) <A22F82C0-B4FE-3DB5-B968-79B28257DF2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff44eb0000 -     0x7fff44ee3ff7  libTrueTypeScaler.dylib (222.1.2) <33C245B4-E1AD-3C89-B735-5A5610E547C8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff44f4d000 -     0x7fff44f51ff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <42C25E85-1CF3-3DEC-A434-BE69F68F4318> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff44ff1000 -     0x7fff45043ff7  com.apple.HIServices (1.22 - 622) <2E83CD6F-ED98-3C29-BD0A-8525E38AB5DB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff45044000 -     0x7fff45052fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <71A9C815-AC55-3E36-A618-F6778F5119AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff45053000 -     0x7fff4509ffff  com.apple.print.framework.PrintCore (13 - 503) <A69E2BAD-2B66-38CC-9D3A-0A0EBC41341D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff450a0000 -     0x7fff450dafff  com.apple.QD (3.12 - 403) <38D8106A-4FFA-3FE9-9999-714CADD7EE9C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff450db000 -     0x7fff450e7fff  com.apple.speech.synthesis.framework (7.4.1 - 7.4.1) <9ABE85D9-6E4A-3CEF-AA09-F81E52730598> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff450e8000 -     0x7fff45373fff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <46EDC245-5877-3438-805C-3AA0316E3F5C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff45375000 -     0x7fff45375fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <0FC3B4FF-FFAB-3346-9A6A-C1DE033185EA> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff4568a000 -     0x7fff45a1cfff  com.apple.CFNetwork (893.13.1 - 893.13.1) <3ECC6AD0-B47D-38D2-BF26-496B34847D25> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff45a31000 -     0x7fff45a31fff  com.apple.Carbon (158 - 158) <FCD7A9FF-5E53-3B0C-8A52-691C11B2A0C5> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff45a32000 -     0x7fff45a35ffb  com.apple.CommonPanels (1.2.6 - 98) <39C8EBA3-EEB2-335B-8A88-D6C64BAA112F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff45a36000 -     0x7fff45d3bff7  com.apple.HIToolbox (2.1.1 - 910.4) <D1A799BC-146A-35E8-86FF-E36273123006> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff45d3c000 -     0x7fff45d3fffb  com.apple.help (1.3.8 - 64) <18D02016-119A-33E8-AEB0-E9466BA4AD56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff45d40000 -     0x7fff45d45fff  com.apple.ImageCapture (9.0 - 9.0) <2DE590E5-DF0E-3962-A2BE-06EBC79B3D72> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff45d46000 -     0x7fff45ddbffb  com.apple.ink.framework (10.9 - 220) <D8AECAE3-9FD2-32E3-B659-026F33650BB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff45ddc000 -     0x7fff45df6ff7  com.apple.openscripting (1.7 - 174) <66899B51-ADFD-360D-88E9-B52439F531B4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff45e17000 -     0x7fff45e18fff  com.apple.print.framework.Print (12 - 267) <E4CBAAFC-9045-38AC-9F93-8C931DDED9D8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff45e19000 -     0x7fff45e1bff7  com.apple.securityhi (9.0 - 55006) <E7668200-B4CB-3612-96B8-D57E94077787> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff45e1c000 -     0x7fff45e22fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1F10ED1F-12C7-39AC-88A0-43A1338F9316> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff45f2f000 -     0x7fff45f2ffff  com.apple.Cocoa (6.11 - 22) <1553F279-3C7B-3A48-87E6-35237F7F452E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff45f3d000 -     0x7fff45ff6ff7  com.apple.ColorSync (4.13.0 - 546) <A5E013D9-7305-3026-879E-4D1F038A430D> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff46183000 -     0x7fff46216ff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <F91FDE26-0702-3E44-8931-E2CAD8E36F5A> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff4627d000 -     0x7fff462a6ffb  com.apple.CoreBluetooth (1.0 - 1) <942F88A5-AD68-3359-90D5-6F1A3311C51A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff462a7000 -     0x7fff465fbfe7  com.apple.CoreData (120 - 849.2) <CE0AF596-64C0-34F3-AFE0-B94D18C09957> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff465fc000 -     0x7fff466c8fff  com.apple.CoreDisplay (1.0 - 81.7) <D8030B81-097E-3FA2-A85C-AE1A3B8EBCFB> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff466c9000 -     0x7fff46b69fe7  com.apple.CoreFoundation (6.9 - 1451) <7AFE9C8F-A562-3AFC-8402-117AA02F57E9> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff46b6b000 -     0x7fff47178fef  com.apple.CoreGraphics (2.0 - 1129.5) <F37BFBD2-CC21-3521-B034-9D4D36197487> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff4717a000 -     0x7fff47469fff  com.apple.CoreImage (13.0.0 - 579.2.9) <8AE143AB-6284-3B00-B56D-8C0C1826EF34> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff476f8000 -     0x7fff477d9fff  com.apple.CoreMedia (1.0 - 2270.12.1) <B62CF714-D69A-38C3-9929-B70FF4CBB216> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff477da000 -     0x7fff47828fff  com.apple.CoreMediaIO (812.0 - 4993) <CA47AF11-0EF4-33E1-9EC3-7A56661FFEE4> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fff47829000 -     0x7fff47829fff  com.apple.CoreServices (822.19 - 822.19) <44456ED2-59E4-34CB-B41B-C6A82B269949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff4782a000 -     0x7fff4789effb  com.apple.AE (735.1 - 735.1) <D0C73200-90A7-3FD1-A6EC-97055AA367E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff4789f000 -     0x7fff47b76ff7  com.apple.CoreServices.CarbonCore (1178.2 - 1178.2) <A1FE74F8-953B-371E-A8AC-E87B30FB79C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff47b77000 -     0x7fff47babff7  com.apple.DictionaryServices (1.2 - 284) <3FCEE280-8DD0-37C9-BFD4-7BA87AAFC8EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff47bac000 -     0x7fff47bb4ff3  com.apple.CoreServices.FSEvents (1239 - 1239) <7BBC5CB7-DBC8-316B-99B0-781827159A2F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff47bb5000 -     0x7fff47d6dff7  com.apple.LaunchServices (822.19 - 822.19) <2895A919-0445-3CE2-9696-40122B5A46C5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff47d6e000 -     0x7fff47e1dff7  com.apple.Metadata (10.7.0 - 1191.2.6) <FB66B298-D55D-398A-BEDB-CB7B82956AE5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff47e1e000 -     0x7fff47e7bff7  com.apple.CoreServices.OSServices (822.19 - 822.19) <34BF1FAC-A0F7-37B4-950D-46408EBA9684> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff47e7c000 -     0x7fff47eeafff  com.apple.SearchKit (1.4.0 - 1.4.0) <14053F88-2C76-35CA-9FC1-2A9BC0B63F88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff47eeb000 -     0x7fff47f0fffb  com.apple.coreservices.SharedFileList (71.4 - 71.4) <4AA6DCF5-BAF8-36FA-A8B0-EDF518EFEF14> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff481aa000 -     0x7fff482f8fff  com.apple.CoreText (352.0 - 578.12.1) <55B16B2D-F083-3B89-A5C2-52FB053331F2> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff482f9000 -     0x7fff48333ff3  com.apple.CoreVideo (1.8 - 279.2) <A8FC5325-D092-3A28-A1CF-5C94B8101F71> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff48334000 -     0x7fff483beffb  com.apple.framework.CoreWLAN (13.0 - 1339) <16DDD47C-BBFE-3D49-8BDF-3652017240FD> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff4854c000 -     0x7fff48557ff7  com.apple.DirectoryService.Framework (10.13 - 207) <79F272D7-48AE-3D1E-AC5B-3CEB5F16E7D5> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff48558000 -     0x7fff48612fff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <2094BAC4-4F37-3741-B9BD-60158A63C503> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff48639000 -     0x7fff4863efff  com.apple.DiskArbitration (2.7 - 2.7) <44836CE9-A9ED-3017-972A-7A0A3D6B472B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff487d8000 -     0x7fff487daff3  com.apple.ExceptionHandling (1.5 - 12) <47D558A6-45B1-3A1A-A619-9CA52225CB49> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
    0x7fff487ff000 -     0x7fff48bc4fff  com.apple.Foundation (6.9 - 1451) <B99F94E7-117E-39CC-A65D-B7AEA8998481> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff48c34000 -     0x7fff48c64fff  com.apple.GSS (4.0 - 2.0) <3B4B4509-B5A3-396B-9C71-80BAE84476FA> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff48d76000 -     0x7fff48e79ff3  com.apple.Bluetooth (6.0.2 - 6.0.2f2) <718565B3-6DA7-3DF9-BB51-391FFCAEAFA5> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff48ed9000 -     0x7fff48f74fff  com.apple.framework.IOKit (2.0.2 - 1445.40.1) <9CFA07B9-BA6E-31E4-AD4F-C47071A8C522> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff48f76000 -     0x7fff48f7dffb  com.apple.IOSurface (209.2.2 - 209.2.2) <6D35A601-1C47-37BE-AD31-F8EB88F67573> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff48f7e000 -     0x7fff48fd3ff3  com.apple.ImageCaptureCore (7.0 - 7.0) <CBE349D4-2C8B-31F5-B5ED-B8E978DA9245> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fff48fd4000 -     0x7fff4914bff7  com.apple.ImageIO.framework (3.3.0 - 1713) <D3CE3838-72C5-3860-B3A4-6937FD916329> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff4914c000 -     0x7fff49150ffb  libGIF.dylib (1713) <C65B2846-1B94-3BB3-BBBF-5A9E5054CE1E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff49151000 -     0x7fff49238fff  libJP2.dylib (1713) <332083DD-3D27-3DE7-9866-A36D590E511E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff49239000 -     0x7fff4925cff7  libJPEG.dylib (1713) <2D846A18-D8AF-3573-803B-BEABCBAC38D1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff49538000 -     0x7fff4955efeb  libPng.dylib (1713) <546F41CE-185C-31A0-B61C-1012AA932624> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff4955f000 -     0x7fff49561ffb  libRadiance.dylib (1713) <31787C46-4A2B-3CDF-95E9-EC1BD4794917> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff49562000 -     0x7fff495affeb  libTIFF.dylib (1713) <5319B2E1-83D2-30C7-A7BC-A0CE0B07885D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff4976b000 -     0x7fff4a326fff  com.apple.JavaScriptCore (13604 - 13604.5.6) <5541E211-3248-3B89-9AE9-D5FE413F12D1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff4a33e000 -     0x7fff4a357ff7  com.apple.Kerberos (3.0 - 1) <CAF075C0-4C24-3ACE-9AE6-77BEFDEA3622> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff4a358000 -     0x7fff4a38dfff  com.apple.LDAPFramework (2.4.28 - 194.5) <8419BDB5-12DF-3BC9-871D-7A270E080249> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff4a60f000 -     0x7fff4a616fff  com.apple.MediaAccessibility (1.0 - 114) <D72C593A-AC32-3419-AB86-6B07217EBFD5> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff4a6b9000 -     0x7fff4acd4fff  com.apple.MediaToolbox (1.0 - 2270.12.1) <40802884-1347-3CDC-AAD3-D046463A528E> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff4acd6000 -     0x7fff4ad55fff  com.apple.Metal (124.7 - 124.7) <F161C177-80B4-3674-8147-04343702CF08> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff4ad72000 -     0x7fff4ad87fff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <D4BCBA84-AD1B-33DC-99F3-16F9E5E50906> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff4ad88000 -     0x7fff4adf3fef  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <E504EC97-FAD7-36DC-B151-6F89AB911E3A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff4adf4000 -     0x7fff4ae17fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <A5B6F6FC-A19A-32C0-A999-98B6688760C7> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff4ae18000 -     0x7fff4ae98ff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <D0D8F13F-ACD4-3B61-BE54-121CCB05ECF4> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff4ae99000 -     0x7fff4ae99ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <2E8723FC-AA53-3596-B6A4-220A378B7A5A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff4bea2000 -     0x7fff4beaeffb  com.apple.NetFS (6.0 - 4.0) <81B22AE7-7094-30F2-BF41-84CA05EDB95B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff4ec96000 -     0x7fff4ec9efef  libcldcpuengine.dylib (2.8.7) <DD781325-D94E-3AD7-8D6C-817FB3068917> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff4ec9f000 -     0x7fff4ececffb  com.apple.opencl (2.8.12 - 2.8.12) <7F9BF7F0-AFB2-349A-BF9B-2DE5288380C4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff4eced000 -     0x7fff4ed09ffb  com.apple.CFOpenDirectory (10.13 - 207) <A229B355-337B-33F4-AAA8-C751BEF0B718> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff4ed0a000 -     0x7fff4ed15fff  com.apple.OpenDirectory (10.13 - 207) <D8AA4C58-149E-3504-88CD-F5B59F882C25> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff4fe94000 -     0x7fff4fe96fff  libCVMSPluginSupport.dylib (16.4.2) <A967BC8B-ABB3-393F-BF34-BD32B45831F7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff4fe97000 -     0x7fff4fe9bff7  libCoreFSCache.dylib (162.4) <B325B709-0C81-357A-B9F1-6E0027B64F9B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff4fe9c000 -     0x7fff4fea0fff  libCoreVMClient.dylib (162.4) <B129DB84-39BA-34E4-9FB7-20A020A1BB86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff4fea1000 -     0x7fff4fea9fff  libGFXShared.dylib (16.4.2) <07F1D947-F79B-3608-9080-E4DBFE13AF1D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff4feaa000 -     0x7fff4feb5fff  libGL.dylib (16.4.2) <97D6871A-BAF1-33DD-9ED7-BE7BB437F378> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff4feb6000 -     0x7fff4fef1fe7  libGLImage.dylib (16.4.2) <3E2802DF-4998-31DB-B3A2-65720DE919A5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff4fef2000 -     0x7fff5005efff  libGLProgrammability.dylib (16.4.2) <3505EF20-FA3D-321B-8C11-D9CA74656F30> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff5005f000 -     0x7fff5009dffb  libGLU.dylib (16.4.2) <ECABCFAB-E400-3667-8EE1-586C07E0E214> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff50a15000 -     0x7fff50a23ffb  com.apple.opengl (16.4.2 - 16.4.2) <C8C31EF5-8DB4-336F-A87C-5D520C7EFDC5> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff50a24000 -     0x7fff50bbbffb  GLEngine (16.4.2) <8F35484D-9C09-3D79-9825-7E73661326D4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff50bbc000 -     0x7fff50be4ffb  GLRendererFloat (16.4.2) <463BD481-6E1A-3EFC-A93B-C7E9292F76ED> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff50d9b000 -     0x7fff50ee7fff  com.apple.QTKit (7.7.3 - 3014) <CF2818E6-E215-3C24-A2AC-1B5F8AD7E398> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fff50ee8000 -     0x7fff5114dff7  com.apple.imageKit (3.0 - 1040) <5A1261EA-76C5-386C-9F46-06EE804E2234> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fff5114e000 -     0x7fff5123aff3  com.apple.PDFKit (1.0 - 677.4) <265C1FB2-4E62-3498-A86B-02C0F790F1ED> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fff5123b000 -     0x7fff5174dff7  com.apple.QuartzComposer (5.1 - 364) <D99600D5-C066-3D49-8641-369A69300D16> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fff5174e000 -     0x7fff51771fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <8CBE10F3-828F-373C-B92A-A5289CBCF77A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fff51772000 -     0x7fff51869ff7  com.apple.QuickLookUIFramework (5.0 - 743.7) <B0352E2A-C582-3C86-A2ED-A30D4A3B785D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fff5186a000 -     0x7fff5186afff  com.apple.quartzframework (1.5 - 21) <3F3BE91F-A032-3E92-ACEA-E2DFEC999E93> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fff5186b000 -     0x7fff51ab3fff  com.apple.QuartzCore (1.11 - 584.8.102) <4479AF33-E6EA-3037-A2C1-3C6F12B1260A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff51ab4000 -     0x7fff51b0bff7  com.apple.QuickLookFramework (5.0 - 743.7) <0CB6717C-CCE2-3591-A31E-A8EF01DD4FC8> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff51cd0000 -     0x7fff51ce6fff  com.apple.SafariServices.framework (13604 - 13604.5.6) <D71DE52A-9B30-381B-82CA-57473E7A0E7E> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fff522ec000 -     0x7fff52603ff7  com.apple.security (7.0 - 58286.41.2) <EB297497-884A-362F-B566-73A14A2F25FE> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff52604000 -     0x7fff5268eff7  com.apple.securityfoundation (6.0 - 55185.30.4) <65144003-B9E2-3DE3-8923-F2BAA68BBF4E> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff5268f000 -     0x7fff526bfff3  com.apple.securityinterface (10.0 - 55109.30.2) <8BFD22AB-32C9-3AD1-9CB4-39EA2D18E865> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fff526c0000 -     0x7fff526c3ffb  com.apple.xpc.ServiceManagement (1.0 - 1) <B11C3C64-6FE7-3A78-B583-D790B7CCE95A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff52a68000 -     0x7fff52ad8ff3  com.apple.SystemConfiguration (1.17 - 1.17) <3C6B2BB9-43AB-39AD-8027-38E30A8A4186> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff52c8d000 -     0x7fff53006ff7  com.apple.VideoToolbox (1.0 - 2270.12.1) <77848D39-10DA-3AA3-88F4-2898F42FCA5A> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff532ae000 -     0x7fff537c6fe7  libwebrtc.dylib (7604.5.6) <7C956A2C-8F14-310F-AE27-CCDA9F64AAE5> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
    0x7fff537c7000 -     0x7fff54caeff7  com.apple.WebCore (13604 - 13604.5.6) <558072BF-6134-3C19-B32E-4889C5C06C5C> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
    0x7fff54caf000 -     0x7fff54ea2ff3  com.apple.WebKitLegacy (13604 - 13604.5.6) <E0177202-32F5-3D0F-9F80-85F41AFF049E> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
    0x7fff54ea3000 -     0x7fff5529bff7  com.apple.WebKit (13604 - 13604.5.6) <5AB44A86-7C8C-3F24-A76B-80618F164763> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x7fff5570b000 -     0x7fff55797ff7  com.apple.APFS (1.0 - 1) <9D67579C-7FB4-3AD9-AB4F-9174A552EB37> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff563aa000 -     0x7fff563d2fff  com.apple.framework.Apple80211 (13.0 - 1345) <D1B8340A-41FB-35C3-88F0-3DDD9A2A1999> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff563d4000 -     0x7fff563e3ff7  com.apple.AppleFSCompression (96.30.2 - 1.0) <CFA90544-68EB-3CCE-A8F7-1B03974F3B85> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff5651f000 -     0x7fff56567ff3  com.apple.AppleJPEG (1.0 - 1) <8BBD5180-5BF9-33DB-8B91-974B1D0AECFB> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff5657a000 -     0x7fff56598ff3  com.apple.aps.framework (4.0 - 4.0) <932274E4-DCD5-30D5-9AC7-58CEF4571EB3> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff56599000 -     0x7fff565a1ff3  com.apple.AppleSRP (5.0 - 1) <4CEC34CF-63E3-3023-B61B-F8D133698534> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff565a2000 -     0x7fff565cafff  com.apple.applesauce (1.0 - ???) <32FF4851-2F68-35BA-835F-91856A20C323> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff56693000 -     0x7fff56696ff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <A6795AC1-D528-3A2F-9C43-14EBFC57B7D6> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff56697000 -     0x7fff566e7ff7  com.apple.AppleVAFramework (5.0.39 - 5.0.39) <4B830521-2A54-3116-8103-127E631FEDC8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff56db6000 -     0x7fff56dbdff7  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <47B6301F-D908-3811-BB9E-DA16D9B29A34> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff56dbe000 -     0x7fff56e45ff7  com.apple.backup.framework (1.9.2 - 1.9.2) <40C6CFA8-4013-3AFB-97CE-8A09388FA343> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff56ebb000 -     0x7fff56ef7fff  com.apple.bom (14.0 - 194.2) <ED2FFB9D-4DA4-322B-89C0-102D790649CD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff57515000 -     0x7fff57542fff  com.apple.CalendarAgentLink (8.0 - 250) <55B60B04-2EAA-3F22-88EF-1602129D5294> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
    0x7fff57c09000 -     0x7fff57c58ff3  com.apple.ChunkingLibrary (188 - 188) <84E024A0-5F95-3A30-A60B-102343AE46B7> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff57c5f000 -     0x7fff57cefff7  com.apple.CloudDocs (1.0 - 572.2) <7549FED5-7C41-3E3E-ABB4-34DCB312F8A2> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff587d5000 -     0x7fff587deff3  com.apple.CommonAuth (4.0 - 2.0) <11B2D184-36B8-3624-B1AD-7B6037D76160> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff587f3000 -     0x7fff58808ff7  com.apple.commonutilities (8.0 - 900) <518FBC2C-0AF3-39DF-B454-526311796A49> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
    0x7fff5898c000 -     0x7fff589ecfff  com.apple.AddressBook.ContactsFoundation (8.0 - ???) <9B39DF3E-5B7F-3467-AC17-23258F76A376> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
    0x7fff589ed000 -     0x7fff58a0ffff  com.apple.contacts.ContactsPersistence (1.0 - 2330.3) <EE8079D4-E1E2-3EFF-A7E1-E97BD81F6C6F> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
    0x7fff58a6f000 -     0x7fff58e4ffff  com.apple.CoreAUC (249.0.0 - 249.0.0) <7F406271-A215-3C75-BDAA-B9611BA2822E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff58e50000 -     0x7fff58e80ff7  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <D0879D8F-488A-3D46-BC50-AD7B0642C0E8> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff5907b000 -     0x7fff59084ff7  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <0A87A91C-A2CF-3BB1-9038-7F610111BC30> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff591eb000 -     0x7fff591fbff7  com.apple.CoreEmoji (1.0 - 69.3) <A4357F5C-0C38-3A61-B456-D7321EB2CEE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff59ab6000 -     0x7fff59accff7  com.apple.CoreMediaAuthoring (2.2 - 956) <A5003E93-68B3-3A0E-8252-454CC4CFEC4D> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x7fff59c0e000 -     0x7fff59c6bff7  com.apple.CoreNLP (1.0 - 130.4.1) <1F329E38-E7D0-3455-981B-48F434C9E8CC> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fff59df4000 -     0x7fff59df9ff7  com.apple.CoreOptimization (1.0 - 1) <785B622B-8F7D-3B4D-83AF-EB98CB79FFF6> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
    0x7fff59dfa000 -     0x7fff59e9fff7  com.apple.CorePDF (4.0 - 414) <2F0447DB-826B-3CEC-A98C-B8A8DDEA1B26> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fff59f3f000 -     0x7fff59f47ff7  com.apple.CorePhoneNumbers (1.0 - 1) <B782FEA6-ACAD-34C6-811F-635F319C3B71> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff59f48000 -     0x7fff59fa4fff  com.apple.CorePrediction (1.0 - 1) <B1E687BA-4E62-321B-8C87-D37C540A5A68> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
    0x7fff5a0d1000 -     0x7fff5a102ff3  com.apple.CoreServicesInternal (309.1 - 309.1) <EB09CAFC-AE9B-3257-BE45-5471D9F64AAD> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff5a451000 -     0x7fff5a4e2fff  com.apple.CoreSymbolication (63075) <2458D96C-1C31-34F8-93F0-73DB0042CB30> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff5a565000 -     0x7fff5a699fff  com.apple.coreui (2.1 - 492.2) <FE0B32BC-958D-3445-866E-A3905626396D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff5a69a000 -     0x7fff5a7a5fff  com.apple.CoreUtils (5.3 - 530.60) <D74B16CC-E2C5-3D8A-B9F4-6D1DB23092B1> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff5a7fa000 -     0x7fff5a85efff  com.apple.framework.CoreWiFi (13.0 - 1339) <7EBA8BA5-C650-3067-A805-8DD08FC816FD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff5a85f000 -     0x7fff5a86eff7  com.apple.CrashReporterSupport (10.13 - 1) <6B5B2B78-15D2-363F-BE34-8F9226E79E24> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff5a8eb000 -     0x7fff5a8faff7  com.apple.framework.DFRFoundation (1.0 - 191.1) <87B83349-C317-3E07-894C-5BC5C20AE08B> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff5a8fd000 -     0x7fff5a901ffb  com.apple.DSExternalDisplay (3.1 - 380) <BEC07C7C-F3AC-3CF3-B13E-3EBFD6224C0D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff5a946000 -     0x7fff5a986ffb  com.apple.datadetectors (5.0 - 376) <612C677D-BB71-35D2-BBF3-EA9EC51ADF12> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
    0x7fff5a987000 -     0x7fff5a9fdfff  com.apple.datadetectorscore (7.0 - 590.3) <792593BC-21C7-3E0C-929E-067CD725FCBD> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff5aa4b000 -     0x7fff5aa8bff7  com.apple.DebugSymbols (141 - 141) <99562E28-0E56-3F6F-93A1-EF997A5E1F87> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff5aa8c000 -     0x7fff5abbbfff  com.apple.desktopservices (1.12.2 - 1.12.2) <8E068AF7-FB72-38E2-948E-6C13F359C69D> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff5ac1b000 -     0x7fff5ac1cff7  com.apple.diagnosticlogcollection (10.0 - 1000) <DFD57FDB-CB78-3FB0-B49B-4586F9E0DFC1> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
    0x7fff5acae000 -     0x7fff5ad80ff7  com.apple.DiskImagesFramework (480.30.2 - 480.30.2) <4A7D01B5-0A30-3425-AC35-D349EC10454F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff5ad81000 -     0x7fff5adf8ff7  com.apple.DiskManagement (11.2 - 1339) <0B17E79A-0BF6-3FD8-8AD0-A8498545030F> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
    0x7fff5adf9000 -     0x7fff5ae04ff7  com.apple.DisplayServicesFW (3.1 - 380) <FB1FBB24-7FD5-3B57-8D3C-39F953F8A9BB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fff5ae8c000 -     0x7fff5ae8eff7  com.apple.EFILogin (2.0 - 2) <5B6E5A73-C2B2-3188-ADE9-C29CE29BB225> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff5b5da000 -     0x7fff5b5f2fff  com.apple.Engram (1.0 - 1) <93DC8AE3-B3F7-326E-93DB-C85A2BFD3C3F> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
    0x7fff5b930000 -     0x7fff5bd5efff  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <80C97AD7-D5C2-311A-B268-4AA60CAD6CED> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff5bd91000 -     0x7fff5be1aff7  com.apple.FileProvider (124.1 - 124.1) <5BF434E7-7675-3877-B761-0281418BC633> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider
    0x7fff5d9c6000 -     0x7fff5d9c6fff  libmetal_timestamp.dylib (802.3.14) <567B1E2F-A6C4-3350-A72E-AF0E0C4A7788> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3802/Libraries/libmetal_timestamp.dylib
    0x7fff5f026000 -     0x7fff5f031ff7  libGPUSupportMercury.dylib (16.4.2) <F5BA5D7A-FD23-3416-B9B3-7EABFD4279D5> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fff5f3ce000 -     0x7fff5f3f3ff3  com.apple.GenerationalStorage (2.0 - 285) <07E7BC5F-8EF2-34FC-9EEC-B4E61EAAFA9A> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff5fd72000 -     0x7fff5fd81fff  com.apple.GraphVisualizer (1.0 - 5) <0A93C5DE-0D28-312E-8764-6B0FB805ED91> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff5fdf9000 -     0x7fff5fe6dfff  com.apple.Heimdal (4.0 - 2.0) <ACC132E5-97F1-3B36-AD7B-4E6CC077E691> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff5fe6e000 -     0x7fff5fe9bfff  com.apple.HelpData (2.3 - 158) <4508839C-39FC-31FD-9AB8-A7ADA9284F5C> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fff5ff07000 -     0x7fff60019ff3  com.apple.ids (10.0 - 1000) <F85463DF-6D86-33C6-B740-498B29D7ECC6> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
    0x7fff6001a000 -     0x7fff600f8fff  com.apple.idsfoundation (10.0 - 1000) <BE207DF9-8609-3A80-9132-87FEB8E817B6> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
    0x7fff605ff000 -     0x7fff60665ff3  com.apple.imfoundation (10.0 - 1000) <32799DD1-91A2-3093-8D8C-4F4988560FC2> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
    0x7fff60715000 -     0x7fff6071efff  com.apple.IOAccelMemoryInfo (1.0 - 1) <E062BBA9-0857-384E-978B-4C6346825E51> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
    0x7fff6071f000 -     0x7fff60726ffb  com.apple.IOAccelerator (376.6 - 376.6) <A47129CC-F386-3C31-AD66-C19A70615A50> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff6072a000 -     0x7fff60741fff  com.apple.IOPresentment (1.0 - 32.1) <B95F06EA-9D5D-311D-9912-978AE42ECFCE> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff60b0b000 -     0x7fff60b30fff  com.apple.IconServices (97.4 - 97.4) <C84A6CA5-8C50-3288-8572-CC3DABF5BBCE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff60c3a000 -     0x7fff60c3dff3  com.apple.InternationalSupport (1.0 - 1) <5AB382FD-BF81-36A1-9565-61F1FD398ECA> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
    0x7fff60cab000 -     0x7fff60cbbffb  com.apple.IntlPreferences (2.0 - 227) <0FF7209B-0E4D-3411-B325-03938B7C0938> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
    0x7fff60dc5000 -     0x7fff60ebafff  com.apple.LanguageModeling (1.0 - 159.3.1) <9B08E18E-69B4-3413-A03A-EF5AE4BE6277> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff60ebb000 -     0x7fff60efdff7  com.apple.Lexicon-framework (1.0 - 33.2) <5CC5E8EE-62A1-3EA5-B300-A39ABD0CF12D> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff60f01000 -     0x7fff60f08ff7  com.apple.LinguisticData (1.0 - 238.3) <228AF7CA-649A-3E24-BBC7-8A24B39B3FC4> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff60fef000 -     0x7fff60ff4fff  com.apple.LoginUICore (4.0 - 4.0) <33D9089B-ECDB-361D-973A-1FDDACC5BFDF> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
    0x7fff61040000 -     0x7fff6105dff3  com.apple.LookupFramework (1.2 - 239) <ACECB15D-1C21-3D3D-A4C5-F9736090E741> /System/Library/PrivateFrameworks/Lookup.framework/Versions/A/Lookup
    0x7fff6172c000 -     0x7fff6172ffff  com.apple.Mangrove (1.0 - 1) <13832222-8A6B-3790-8914-BE874B5ED4DD> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fff617b8000 -     0x7fff617baff7  com.apple.marco (10.0 - 1000) <86E99D5C-D56D-3874-B465-833A9B40DE88> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
    0x7fff61848000 -     0x7fff6187bff7  com.apple.MediaKit (16 - 871) <47A5B872-4139-315D-A047-581F9C485D15> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff61b6a000 -     0x7fff61bd3ff7  com.apple.gpusw.MetalTools (1.0 - 1) <F77943BC-0466-3700-BEDF-CDD13125D36A> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff61bdb000 -     0x7fff61bf0ff3  com.apple.MobileAssets (1.0 - 437.40.1) <589D6786-0C0F-3CDB-8093-3834402CE083> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
    0x7fff61d48000 -     0x7fff61d60ff3  com.apple.MobileKeyBag (2.0 - 1.0) <4C70F92C-BB58-393E-B613-EAB16790CCED> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff61dec000 -     0x7fff61e14fff  com.apple.MultitouchSupport.framework (1204.13 - 1204.13) <6C5D778D-4AB7-39A4-989B-2E8D2D57B3A0> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff62079000 -     0x7fff62084fff  com.apple.NetAuth (6.2 - 6.2) <5C6F492A-28EF-3A0E-B573-6F3D60CFF0C7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff62091000 -     0x7fff6215eff7  com.apple.Network (1.0 - 1) <0221BFB3-3174-3D87-B6F2-4557367B770B> /System/Library/PrivateFrameworks/Network.framework/Versions/A/Network
    0x7fff63886000 -     0x7fff638c6ffb  com.apple.PerformanceAnalysis (1.183.1 - 183.1) <2BE359F2-DCE6-3E33-BA99-964507A3F540> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff6393e000 -     0x7fff6393eff7  com.apple.PhoneNumbers (1.0 - 1) <F8D10107-164F-39BE-8A3D-638E90678DDD> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fff6564e000 -     0x7fff656a1fff  com.apple.ProtectedCloudStorage (1.0 - 1) <BA92C805-2AAD-3C71-A8EC-C2A4DAFD5E7C> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff656a2000 -     0x7fff656c0fff  com.apple.ProtocolBuffer (1 - 259) <D047A3FE-C7A8-3CAA-9891-6232BA88C247> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff6582d000 -     0x7fff65842ff3  com.apple.QuickLookThumbnailing (1.0 - 1) <0771325B-BBAD-3865-B2A3-BE7089641C52> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
    0x7fff65891000 -     0x7fff6589cfff  com.apple.xpc.RemoteServiceDiscovery (1.0 - 1205.30.29) <E2AEA0D7-23E6-3198-96EF-2F1F8ACD98B4> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
    0x7fff6589d000 -     0x7fff658c0ffb  com.apple.RemoteViewServices (2.0 - 125) <AEDBCE8C-88B7-315A-9F81-3E068F0D3EDC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff658c1000 -     0x7fff658d2ffb  com.apple.xpc.RemoteXPC (1.0 - 1205.30.29) <1FD53EC6-A9E9-3AEC-86A7-C52729D1A135> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
    0x7fff671dd000 -     0x7fff672eefff  com.apple.Sharing (972.14 - 972.14) <964AEC2D-8A2A-33BE-9334-98A7CBE7CC51> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff672ef000 -     0x7fff6730eff3  com.apple.shortcut (2.16 - 98) <B8A517F6-B872-3A71-B096-709A0CC6656F> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fff67318000 -     0x7fff67319fff  com.apple.performance.SignpostNotification (1.0 - 1) <D4C967BA-92C6-3BAB-AFB5-59F98B35F921> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
    0x7fff68016000 -     0x7fff682b0fff  com.apple.SkyLight (1.600.0 - 312.23.4) <455CE6F6-CD58-3E08-8300-CA8BDD3377FC> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff68a61000 -     0x7fff68a6eff7  com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <AC026FB9-78F8-31F9-BB80-619D5378DB70> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff68b21000 -     0x7fff68d5cfff  com.apple.spotlight.index (10.7.0 - 1191.2.6) <236BC19C-F361-344B-91DE-1B40C6E31878> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
    0x7fff68f07000 -     0x7fff68f2eff7  com.apple.StreamingZip (1.0 - 1) <F06F4CDC-138C-3991-A987-7C7332BE4508> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
    0x7fff69600000 -     0x7fff69684fe7  com.apple.Symbolication (9.0 - 63079.1) <177BC9CA-E6AE-3B40-806F-0080C0CDFF29> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff69695000 -     0x7fff6969cfff  com.apple.SymptomDiagnosticReporter (1.0 - 820.30.7) <0188BA8D-0C88-3413-A199-666C7FBE4DF1> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
    0x7fff69946000 -     0x7fff69972fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <6AE03DE8-E5C1-38E5-B788-0A763CAACDC2> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
    0x7fff69b76000 -     0x7fff69b7dff3  com.apple.TCC (1.0 - 1) <C807D3F0-FE20-3FC0-8D61-306477ABEBC4> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff69d8a000 -     0x7fff69e47ff7  com.apple.TextureIO (3.7 - 3.7) <C98BFACA-7807-3DCA-945D-58EBA2B723C8> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff69e98000 -     0x7fff69eb3ffb  com.apple.ToneKit (1.0 - 1) <A0242052-983B-3726-B5BD-D2E672CEFE2F> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
    0x7fff69eb4000 -     0x7fff69edbfff  com.apple.ToneLibrary (1.0 - 1) <7EEABD7F-D0CB-327E-A772-ACF406B9C8F2> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
    0x7fff69eeb000 -     0x7fff69eecfff  com.apple.TrustEvaluationAgent (2.0 - 31) <39F533B2-211E-3635-AF47-23F27749FF4A> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff69ef2000 -     0x7fff6a0a1ff3  com.apple.UIFoundation (1.0 - 546.1.1) <D2DB451C-56CD-3249-B8EE-AF21DBDCFBF8> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff6ad6a000 -     0x7fff6ae39ff7  com.apple.ViewBridge (343.2 - 343.2) <B23D10F2-A5E8-30EF-964A-6E968F4017A1> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff6b7e4000 -     0x7fff6b7e6ffb  com.apple.loginsupport (1.0 - 1) <5E2C4AA7-066D-3FDB-B0E1-4CDAF287392C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff6b7e7000 -     0x7fff6b7fcfff  com.apple.login (3.0 - 3.0) <140118A7-8FB9-35C5-92FA-BD79C9C32309> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
    0x7fff6b827000 -     0x7fff6b854fff  com.apple.contacts.vCard (1.0 - 2330.3) <0417A3AE-7A95-37DB-895B-33EAAC7A1422> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
    0x7fff6b94a000 -     0x7fff6b97dfff  libclosured.dylib (519.2.2) <48051216-5647-3643-B979-B77D0FD20011> /usr/lib/closure/libclosured.dylib
    0x7fff6ba1d000 -     0x7fff6ba56ff7  libCRFSuite.dylib (41) <AB2DA745-F22C-30CF-81D4-35DD716463B8> /usr/lib/libCRFSuite.dylib
    0x7fff6ba57000 -     0x7fff6ba62fff  libChineseTokenizer.dylib (28) <D30A7DB6-058F-3286-9583-60C9EEB77A6E> /usr/lib/libChineseTokenizer.dylib
    0x7fff6ba63000 -     0x7fff6baf0ff7  libCoreStorage.dylib (546) <B495D87B-FE21-3C14-9017-F02D9CA226D5> /usr/lib/libCoreStorage.dylib
    0x7fff6baf4000 -     0x7fff6baf5ff3  libDiagnosticMessagesClient.dylib (104) <9712E980-76EE-3A89-AEA6-DF4BAF5C0574> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff6bb2c000 -     0x7fff6bcf6ff3  libFosl_dynamic.dylib (17.7) <B2476843-7FA7-3E62-B79F-2B15FE557E63> /usr/lib/libFosl_dynamic.dylib
    0x7fff6bd2e000 -     0x7fff6bd2efff  libOpenScriptingUtil.dylib (174) <203D2C39-61BB-3713-A502-2D17B04A42AC> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff6be57000 -     0x7fff6be5bffb  libScreenReader.dylib (562.13) <21638ECC-87BF-3CC5-B2D8-6F7883F5FDCA> /usr/lib/libScreenReader.dylib
    0x7fff6be5c000 -     0x7fff6be5dff3  libSystem.B.dylib (1252) <47329E26-DC23-3EBA-9461-37755368327D> /usr/lib/libSystem.B.dylib
    0x7fff6bedc000 -     0x7fff6beddfff  libThaiTokenizer.dylib (2.2) <04AC7CD4-BD9A-3B1D-8CEB-9E2030B6B667> /usr/lib/libThaiTokenizer.dylib
    0x7fff6bef0000 -     0x7fff6bef0fff  libapple_crypto.dylib (109.40.1) <32252490-B1E9-363F-AEED-3EC97D919348> /usr/lib/libapple_crypto.dylib
    0x7fff6bef1000 -     0x7fff6bf07ff7  libapple_nghttp2.dylib (1.24) <01402BC4-4822-3676-9C80-50D83F816424> /usr/lib/libapple_nghttp2.dylib
    0x7fff6bf08000 -     0x7fff6bf32ff3  libarchive.2.dylib (54) <8FC28DD8-E315-3C3E-95FE-D1D2CBE49888> /usr/lib/libarchive.2.dylib
    0x7fff6bf33000 -     0x7fff6bfb4fdf  libate.dylib (1.13.1) <178ACDAD-DE7E-346C-A613-1CBF7929AC07> /usr/lib/libate.dylib
    0x7fff6bfb8000 -     0x7fff6bfb8ff3  libauto.dylib (187) <A05C7900-F8C7-3E75-8D3F-909B40C19717> /usr/lib/libauto.dylib
    0x7fff6bfb9000 -     0x7fff6c070fff  libboringssl.dylib (109.40.1) <75F5F125-B919-3318-BD12-29CB5E868475> /usr/lib/libboringssl.dylib
    0x7fff6c071000 -     0x7fff6c081ff3  libbsm.0.dylib (39) <770B341F-3BB7-3123-B53C-F2D58868A963> /usr/lib/libbsm.0.dylib
    0x7fff6c082000 -     0x7fff6c08fffb  libbz2.1.0.dylib (38) <0A5086BB-4724-3C14-979D-5AD4F26B5B45> /usr/lib/libbz2.1.0.dylib
    0x7fff6c090000 -     0x7fff6c0e6fff  libc++.1.dylib (400.9) <FCF5E1F6-2B04-3545-8004-F3AB32FED172> /usr/lib/libc++.1.dylib
    0x7fff6c0e7000 -     0x7fff6c10bff7  libc++abi.dylib (400.7) <217656D5-BC40-37FF-B322-91CB2AAD4F34> /usr/lib/libc++abi.dylib
    0x7fff6c10d000 -     0x7fff6c11dfff  libcmph.dylib (6) <A5509EE8-7E00-3224-8814-015B077A3CF5> /usr/lib/libcmph.dylib
    0x7fff6c11e000 -     0x7fff6c134fff  libcompression.dylib (47) <E64D4416-DFBF-314B-BBB9-BED23C3A251C> /usr/lib/libcompression.dylib
    0x7fff6c3e1000 -     0x7fff6c3f9ff7  libcoretls.dylib (155) <DFE2454F-2FE3-3B2B-A22B-422947C34C69> /usr/lib/libcoretls.dylib
    0x7fff6c3fa000 -     0x7fff6c3fbffb  libcoretls_cfhelpers.dylib (155) <D3F4B882-40C1-3CD4-927B-0E0ED6031D0B> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff6c594000 -     0x7fff6c724fff  libcrypto.35.dylib (22) <067CFC21-249D-392D-ADE1-785100BF0F83> /usr/lib/libcrypto.35.dylib
    0x7fff6c8bf000 -     0x7fff6c8caff7  libcsfde.dylib (546) <B6F6340A-F874-38BD-A7BB-FFADEBA54789> /usr/lib/libcsfde.dylib
    0x7fff6c8cb000 -     0x7fff6c921ff3  libcups.2.dylib (462.1) <B78448A0-9C97-3D4A-823E-EBE37B2B7CA6> /usr/lib/libcups.2.dylib
    0x7fff6c94c000 -     0x7fff6c9a0ffb  libcurl.4.dylib (105.40.1) <17EC22AC-0CE7-3FA7-AD55-B636806F46F8> /usr/lib/libcurl.4.dylib
    0x7fff6c9a3000 -     0x7fff6c9aaff3  libdscsym.dylib (183.1) <2DE012BF-CE9A-3BDF-9A2D-55D66B51AA35> /usr/lib/libdscsym.dylib
    0x7fff6ca5f000 -     0x7fff6ca5ffff  libenergytrace.dylib (16) <A92AB8B8-B986-3CE6-980D-D55090FEF387> /usr/lib/libenergytrace.dylib
    0x7fff6ca60000 -     0x7fff6ca79ffb  libexpat.1.dylib (16.1.1) <5E1796FA-4041-3187-B5C2-8E6B03D1D72A> /usr/lib/libexpat.1.dylib
    0x7fff6ca91000 -     0x7fff6ca95ff7  libgermantok.dylib (17) <379C5DC6-BEDB-378D-B09C-A63D297EAA6D> /usr/lib/libgermantok.dylib
    0x7fff6ca96000 -     0x7fff6ca9bff3  libheimdal-asn1.dylib (520.30.1) <14DC1451-6E22-3A48-80CB-5D33DC0F8C3B> /usr/lib/libheimdal-asn1.dylib
    0x7fff6cac7000 -     0x7fff6cbb8ff7  libiconv.2.dylib (51) <0772997F-4109-38A1-91ED-0F3F16AE99E5> /usr/lib/libiconv.2.dylib
    0x7fff6cbb9000 -     0x7fff6cde0ffb  libicucore.A.dylib (59152.0.1) <E628882C-6F83-3DCD-B62A-2FE6F77EF6F7> /usr/lib/libicucore.A.dylib
    0x7fff6cde1000 -     0x7fff6ce16ffb  libiodbc.2.1.18.dylib (42.5) <053A2EDF-A24C-3F8D-AB83-1C1F4711CE94> /usr/lib/libiodbc.2.1.18.dylib
    0x7fff6ce2d000 -     0x7fff6ce2efff  liblangid.dylib (128) <39C39393-0D05-301D-93B2-F224FC4949AA> /usr/lib/liblangid.dylib
    0x7fff6ce2f000 -     0x7fff6ce48ffb  liblzma.5.dylib (10) <3D419A50-961F-37D2-8A01-3DC7AB7B8D18> /usr/lib/liblzma.5.dylib
    0x7fff6ce49000 -     0x7fff6ce5fff7  libmarisa.dylib (9) <D6D2D55D-1D2E-3442-B152-B18803C0ABB4> /usr/lib/libmarisa.dylib
    0x7fff6ce60000 -     0x7fff6cf0ffff  libmecab.1.0.0.dylib (779.7.6) <4FFE8518-473B-378D-997B-9DB55AB66ADA> /usr/lib/libmecab.1.0.0.dylib
    0x7fff6cf10000 -     0x7fff6d138ff7  libmecabra.dylib (779.7.6) <7E255F87-BBB4-3AE5-BC82-6DEE70566D05> /usr/lib/libmecabra.dylib
    0x7fff6d310000 -     0x7fff6d3e7ffb  libnetwork.dylib (1229.30.11) <4E7A6EBA-B3DD-3001-9C97-CB423922B78C> /usr/lib/libnetwork.dylib
    0x7fff6d45d000 -     0x7fff6d84b7e7  libobjc.A.dylib (723) <93A92316-DE1E-378C-8891-99720B50D075> /usr/lib/libobjc.A.dylib
    0x7fff6d84c000 -     0x7fff6d84dff7  libodfde.dylib (24) <1BBC519E-EF89-38F3-B226-70F086670D0F> /usr/lib/libodfde.dylib
    0x7fff6d85e000 -     0x7fff6d862fff  libpam.2.dylib (22) <7B4D2CE2-1438-387A-9802-5CEEFBF26F86> /usr/lib/libpam.2.dylib
    0x7fff6d865000 -     0x7fff6d899fff  libpcap.A.dylib (79.20.1) <FA13918B-A247-3181-B256-9B852C7BA316> /usr/lib/libpcap.A.dylib
    0x7fff6d918000 -     0x7fff6d934ffb  libresolv.9.dylib (65) <E8F3415B-4472-3202-8901-41FD87981DB2> /usr/lib/libresolv.9.dylib
    0x7fff6d96f000 -     0x7fff6d981fff  libsasl2.2.dylib (211) <D9E281A2-D7BA-32CD-8B96-54972B1D9E66> /usr/lib/libsasl2.2.dylib
    0x7fff6d982000 -     0x7fff6d983ff7  libspindump.dylib (248) <12E8B8BA-072F-39AE-8BC9-7D5840DA80EB> /usr/lib/libspindump.dylib
    0x7fff6d984000 -     0x7fff6db17fe7  libsqlite3.dylib (274.5) <A1DEB5AB-8FE8-332E-A7E5-F493F2223FE3> /usr/lib/libsqlite3.dylib
    0x7fff6db73000 -     0x7fff6dbc6ffb  libssl.35.dylib (22) <4D77B502-E065-3794-90E7-39E83F9683F6> /usr/lib/libssl.35.dylib
    0x7fff6dc19000 -     0x7fff6dc67fff  libstdc++.6.0.9.dylib (104.1) <92CC5BBD-2FB2-3864-BF6B-B4B1BFF4C1EE> /usr/lib/libstdc++.6.0.9.dylib
    0x7fff6dc9b000 -     0x7fff6dcd0fff  libtidy.A.dylib (15.18.1) <3E33A53A-53AB-3FD5-BBAB-DFA6A3A90132> /usr/lib/libtidy.A.dylib
    0x7fff6dce8000 -     0x7fff6dd21fff  libusrtcp.dylib (1229.30.11) <537F14D0-84DF-349F-8EA0-52BB7A241E60> /usr/lib/libusrtcp.dylib
    0x7fff6dd22000 -     0x7fff6dd25ffb  libutil.dylib (51.20.1) <216D18E5-0BAF-3EAF-A38E-F6AC37CBABD9> /usr/lib/libutil.dylib
    0x7fff6dd26000 -     0x7fff6dd33fff  libxar.1.dylib (400) <0316128D-3B47-3052-995D-97B4FE5491DC> /usr/lib/libxar.1.dylib
    0x7fff6dd37000 -     0x7fff6de1efff  libxml2.2.dylib (31.7) <49544596-BCF8-3765-8DC5-DB1A9A90EF92> /usr/lib/libxml2.2.dylib
    0x7fff6de1f000 -     0x7fff6de47fff  libxslt.1.dylib (15.10) <66682AF6-C2D5-374C-901F-25A3E72814DC> /usr/lib/libxslt.1.dylib
    0x7fff6de48000 -     0x7fff6de5affb  libz.1.dylib (70) <48C67CFC-940D-3857-8DAD-857774605352> /usr/lib/libz.1.dylib
    0x7fff6def8000 -     0x7fff6defcff7  libcache.dylib (80) <354F3B7D-404E-3398-9EBF-65CA2CE65211> /usr/lib/system/libcache.dylib
    0x7fff6defd000 -     0x7fff6df07ff3  libcommonCrypto.dylib (60118.30.2) <674286D3-7744-36A3-9AAA-49DFCD97A986> /usr/lib/system/libcommonCrypto.dylib
    0x7fff6df08000 -     0x7fff6df0ffff  libcompiler_rt.dylib (62) <4487CFBA-A5D7-3282-9E6B-94CAD7BE507E> /usr/lib/system/libcompiler_rt.dylib
    0x7fff6df10000 -     0x7fff6df18ffb  libcopyfile.dylib (146.30.2) <2C7C67D7-562B-3FFA-973D-BACF4C10E1EC> /usr/lib/system/libcopyfile.dylib
    0x7fff6df19000 -     0x7fff6df9efff  libcorecrypto.dylib (562.30.10) <8A53EFE1-AFCA-3676-BEE1-FA5ED9F0E222> /usr/lib/system/libcorecrypto.dylib
    0x7fff6e026000 -     0x7fff6e05fff7  libdispatch.dylib (913.30.4) <7D0E3183-282B-3FEE-A734-2C0ADC092084> /usr/lib/system/libdispatch.dylib
    0x7fff6e060000 -     0x7fff6e07dff7  libdyld.dylib (519.2.2) <C50D02BC-A333-3313-B787-02F255A6783F> /usr/lib/system/libdyld.dylib
    0x7fff6e07e000 -     0x7fff6e07effb  libkeymgr.dylib (28) <6D84A96F-C65B-38EC-BDB5-21FD2C97E7B2> /usr/lib/system/libkeymgr.dylib
    0x7fff6e07f000 -     0x7fff6e08bff3  libkxld.dylib (4570.41.2) <661F47FA-F6FC-3FB1-8023-9DFE108AEEF7> /usr/lib/system/libkxld.dylib
    0x7fff6e08c000 -     0x7fff6e08cff7  liblaunch.dylib (1205.30.29) <E66F58ED-C15E-3DFB-BC22-A861E13918C6> /usr/lib/system/liblaunch.dylib
    0x7fff6e08d000 -     0x7fff6e091ffb  libmacho.dylib (900.0.1) <756F2553-07B6-3B42-ACEA-2F0F1A5E8D0F> /usr/lib/system/libmacho.dylib
    0x7fff6e092000 -     0x7fff6e094ff3  libquarantine.dylib (86) <6AC8773F-3817-3D82-99C2-01BABB9C3CBB> /usr/lib/system/libquarantine.dylib
    0x7fff6e095000 -     0x7fff6e096ff3  libremovefile.dylib (45) <912FA211-DD8C-3C92-8424-21B89F8B10FD> /usr/lib/system/libremovefile.dylib
    0x7fff6e097000 -     0x7fff6e0aefff  libsystem_asl.dylib (356.1.1) <94972913-9DF0-3C78-847C-43E58919E3DA> /usr/lib/system/libsystem_asl.dylib
    0x7fff6e0af000 -     0x7fff6e0affff  libsystem_blocks.dylib (67) <F2493BB5-B1C6-3C4D-9F1F-1B402E0F1DB7> /usr/lib/system/libsystem_blocks.dylib
    0x7fff6e0b0000 -     0x7fff6e139ff7  libsystem_c.dylib (1244.30.3) <E0136C71-0648-36F0-9F84-82EA2748A8D7> /usr/lib/system/libsystem_c.dylib
    0x7fff6e13a000 -     0x7fff6e13dffb  libsystem_configuration.dylib (963.30.1) <0F8D0B76-4F7D-34EC-AB6C-50F9465809DA> /usr/lib/system/libsystem_configuration.dylib
    0x7fff6e13e000 -     0x7fff6e141ffb  libsystem_coreservices.dylib (51) <21A488D0-2D07-344E-8631-CC8B2A246F35> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff6e142000 -     0x7fff6e143fff  libsystem_darwin.dylib (1244.30.3) <2F750CB1-BC26-3FA3-AE59-553EE30D451B> /usr/lib/system/libsystem_darwin.dylib
    0x7fff6e144000 -     0x7fff6e14aff7  libsystem_dnssd.dylib (878.30.4) <EB9BB165-45A4-367C-B33A-688D4F383A95> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff6e14b000 -     0x7fff6e194ff7  libsystem_info.dylib (517.30.1) <7D79E167-4B5C-3833-81EE-3AF3FB53616D> /usr/lib/system/libsystem_info.dylib
    0x7fff6e195000 -     0x7fff6e1baff7  libsystem_kernel.dylib (4570.41.2) <5155A4C3-825B-3178-AC51-0D2D2F2A6618> /usr/lib/system/libsystem_kernel.dylib
    0x7fff6e1bb000 -     0x7fff6e206fcb  libsystem_m.dylib (3146) <ABB1B85F-9FFE-31B8-AD4F-E39A30794A93> /usr/lib/system/libsystem_m.dylib
    0x7fff6e207000 -     0x7fff6e226fff  libsystem_malloc.dylib (140.40.1) <36B22C99-D772-3039-9A4C-AA31389965E1> /usr/lib/system/libsystem_malloc.dylib
    0x7fff6e227000 -     0x7fff6e2cbff3  libsystem_network.dylib (1229.30.11) <40BAD301-8744-3AD8-A688-E7925C587B00> /usr/lib/system/libsystem_network.dylib
    0x7fff6e2cc000 -     0x7fff6e2d6ffb  libsystem_networkextension.dylib (767.40.1) <CEDC330D-28F0-3902-BEB0-10B92ACEC69F> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff6e2d7000 -     0x7fff6e2e0ff3  libsystem_notify.dylib (172) <98EA3D62-7C86-30DE-8261-D020D2F1EFF3> /usr/lib/system/libsystem_notify.dylib
    0x7fff6e2e1000 -     0x7fff6e2e8ff7  libsystem_platform.dylib (161.20.1) <C049250F-8C35-314D-810F-4E28AEAED983> /usr/lib/system/libsystem_platform.dylib
    0x7fff6e2e9000 -     0x7fff6e2f4fff  libsystem_pthread.dylib (301.30.1) <ABA848E1-6978-3B42-A3A7-608B2C36FA93> /usr/lib/system/libsystem_pthread.dylib
    0x7fff6e2f5000 -     0x7fff6e2f8ff3  libsystem_sandbox.dylib (765.40.2) <922D3D15-AB4C-3F1A-A94F-39214AF1ADB3> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff6e2f9000 -     0x7fff6e2faff3  libsystem_secinit.dylib (30) <F06ADB8F-9E94-34A7-B3C9-2C22FDD14BAD> /usr/lib/system/libsystem_secinit.dylib
    0x7fff6e2fb000 -     0x7fff6e302ff7  libsystem_symptoms.dylib (820.30.7) <DC3586C2-AA56-3419-88D3-FC0DBF08E3C0> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff6e303000 -     0x7fff6e316ff7  libsystem_trace.dylib (829.30.14) <69EBF017-D40F-30D7-9B0B-BFC862D761A5> /usr/lib/system/libsystem_trace.dylib
    0x7fff6e318000 -     0x7fff6e31dff7  libunwind.dylib (35.3) <6D4FCD49-D2A9-3233-95C7-A7635CE265F2> /usr/lib/system/libunwind.dylib
    0x7fff6e31e000 -     0x7fff6e34aff7  libxpc.dylib (1205.30.29) <F7E5F1BC-614B-39CB-B6CE-92A9C7B7EC0B> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 58871
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 109942451
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=866.3M resident=0K(0%) swapped_out_or_unallocated=866.3M(100%)
Writable regions: Total=6.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=6.7G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework              1280K        9
Activity Tracing                   256K        2
CG backing stores                123.2M       11
CG image                          1712K      244
CoreAnimation                     52.5M      111
CoreGraphics                         8K        2
CoreImage                          256K       31
CoreUI image data                 5784K       41
CoreUI image file                  292K        5
Foundation                          24K        3
IOKit                             7940K        2
Image IO                          2728K      200
Kernel Alloc Once                    8K        2
MALLOC                             6.0G     3322
MALLOC guard page                   64K       14
MALLOC_LARGE (reserved)           2816K        2         reserved VM address space (unallocated)
Memory Tag 242                      12K        2
OpenGL GLSL                        256K        4
STACK GUARD                       56.2M       46
Stack                             32.3M      294
VM_ALLOCATE                      518.1M      286
__DATA                            62.0M      498
__FONT_DATA                          4K        2
__GLSLBUILTINS                    2588K        2
__LINKEDIT                       277.8M      109
__TEXT                           588.5M      441
__UNICODE                          560K        2
mapped file                       88.6M       36
shared memory                      716K       13
TOTAL                              7.7G     5707
TOTAL, minus reserved VM space     7.7G     5707
Model: iMac17,1, BootROM IM171.0147.B00, 4 processors, Intel Core i7, 4 GHz, 24 GB, SMC 2.33f10
Graphics: AMD Radeon R9 M390, AMD Radeon R9 M390, PCIe, 2 GB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1867 MHz, 0x198, 0x4B48583138363643313153334C2F38472020
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1867 MHz, 0x198, 0x4B48583138363643313153334C2F38472020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x802C, 0x384B54463531323634485A2D314739453220
Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1867 MHz, 0x802C, 0x384B54463531323634485A2D314739453220
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.77.37.5.1a3)
Bluetooth: Version 6.0.2f2, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD ST1000DM003, 1 TB
USB Device: USB 3.0 Bus
USB Device: iPad
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: Keyboard Hub
USB Device: DeathTaker Gaming Mouse
USB Device: Apple Keyboard
Thunderbolt Bus: iMac, Apple Inc., 28.1
For anyone noticing a sudden negative performance impact (this goes for any SP update from us, not only this one) you should close Vectorworks down entirely, back up your preferences as described below, and then reset them to their defaults:
Restart your machine, relaunch Vectorworks and then try working in the same file to see if the same issues remain or if the behavior has changed.
So, I just tried this.   And so far it's working.   I gotta be honest though,  I am just about sick of resetting my preferences.    There has to be a better solution.   I've lost count of how many times I've had to do that with 2018.
Edited by Wesley Burrows
preference reset is basically a sledgehammer fix. The main reason it's used is because of how frequently it works and how relatively simple it is to explain. The majority of the issues it fixes WILL have some very specific cause buried deep within the preferences or user folder contents, but we often can't track it down or replicate it, so we go with the fix that works the majority of the time for the majority of the people. It's mostly the workaround while engineering finds the actual source of the problem and fixes it properly.
I miss those good old days when a new VectorWorks release was actually released after it was tested and optimized even if it took more than a year. It's sad that the "dev team" focuses on the "new content" instead of fixing the old ones and implement stuff that is actually needed. (Freeform bendable walls, window and door centerline data...etc.)
I think you and many others be pleased with some news coming up this year.
  • Love 1
Hello all. Think I figured out a few things that deflated the sbbod.
I removed old favorites from the resource browser which helped significantly.
Also in section viewport I realized that the 3D geometry thing was set to very high. I bumped that down to medium and have not had any problems since.
PS : any word about the DIN structural members?
a bientôt
marc
PSA: Some antivirus software seems to have been responsible for major speed issues with Vectorworks 2018 where the program gets progressively more laggy as the hours pass. Here's what I've encountered helping one of our customers with this problem:
Vectorworks 2018 SP2 had been slowing down after 2 - 3 hours of work and some crashes too. I determined our customer installed a new/different antivirus program (Malwarebytes) just before they upgraded from 2017 to 2018, so I asked that they turn it off temporarily or 'whitelist' Vectorworks 2018. Their IT people told Malwarebytes to ignore the Vectorworks 2018 program folder, after which their speed issues have disappeared and no reported crashes either.
I have one other user with the same 'slowdown over 2 - 3 hours' symptom who also adopted a new antivirus program at the same time they upgraded to 2018. They are using Webroot and are going to test if turning it off helps them too. I'll endeavour to update this thread if this fixes the issue for them as well.
EDIT: Both cases above are Windows users. Windows 10 and Windows 7 respectively.
@JimW Do you have any comments on this matter? I'd like to know whether software vendors are expected to contact antivirus manufacturers to get their programs 'whitelisted?' Or is it expected that their software just wouldn't cause interference at all, except in unusual circumstances?
Edited by Jeremy Best
Added platforms involved and directed a specific question to JimW.
I don’t have any antivirus on my mac and VW slows down significantly after a couple hours of work. It seems to be a memory related “problem”, as i see VW doesn’t really cleans memory efficiently and keeps eating ram until it dies.
When we identify a package that interferes with us, we do so. Depending on the developer, sometimes they are easy to work with and the issue is resolved, sometimes the only solution is to remove the offending security app.
Overall, antivirus and other security minded software can often cause problems with both professional applications as well as video games. I see constant reports of this in my professional and personal circles.
Hey @JimW, how hard would it be to write an Applescript or an Automator workflow or a [equivalent type thing] to be run in Terminal that would do the necessary steps?
In the past I've encountered barriers with privileges when sending Automator workflows to other users hence why maybe a Terminal script might be more appropriate... Your thoughts on this matter?
For Windows perhaps Powershell is appropriate, although I did find an adaptation of Apple's Automator for Mac and Windows that might be useful: https://app.jbbres.com/actions/
This would be pretty handy for us in Tech Support too.
So, I have tried doing this a few times, the results ended up working on my machine (I keep one around to reset my own preferences to default from time to time) but when I took the utility to other machines with different OS versions, it did not always work as expected, in some cases appearing to work, but then actually doing nothing as well as permissions issues like you describe. This led to users getting frustrated so I abandoned the experiment.
However, these days resetting JUST the user folder resolves most issues that aren't related to licensing, so with the long list of variously named plist files/registry keys out of the way, this might be worth another try, I'll look into it.
