145 -
BCF Manager web pallete does not open
Kazemester replied to Kazemester's question in Troubleshooting
Sorry...restart did it's thing. Good day! -
Hi, when i want to open the BCF Manager window VW does not do anything. Im on the latest sp VXW2025, running on Mac. Does this happen to anyone else or am i doing something wrong? Thanks
This topic has been revived more than zombies in a post apocalyptic movie! :D
I deleted the plist and reentered my serial number. Now it works...weird.
That is what i did and NOPE. It does not appear. That is why i asked.
Hi, where did the "convert to group" dialog box go? I try to convert a group with a lot of symbols in it (dwg import - trying to rescale), but the dialog box disappeared when it asked me what i want to convert. How can i turn it on? Thanks
Mouse disappears and going out of window in walkthrough
It does not matter for me...it activates my hot corners in game mode whatever i do. 🤷 -
Hi, whenever i try to export a PDF/A-1b format the resolution seems to be fixed. It does not matter how i set the export from sheet layer (i set the sheet layer resolution as well as in the export menü) it always exports pdf to a weird resolution (i guess 72dpi). Is that a bug or how can i resolve this? Thanks (See my settings attached and how the export resolution turns out.)
Thanks for the tip, record indeed did its job.
Hi, I've been trying to list my space perimeters but when i draw a space manually the dimension of the drawn space is messed up. When i draw a space with auto-bound it shows the perimeter data correctly. Am i doing something wrong? How can i list my manually placed spaces perimeter correctly? Or does it go with a different name? Thanks
Turn off auto-scroll at edge of window?
Kazemester replied to Thomas H Donalek AIA's question in Troubleshooting
I wish it was working as it did years ago. The cursor moves out of the screen all the time though when in walkthrough mode...and activates my hot corners all the time. Auto scroll switch should be an extra feature after all these fixes... -
Thanks! Looks like the "repair" function did its job.
Hi, i just started working on my pc lately and i automatially updated to SP3. Now VW2023 stutters every 5-6 seconds. The screen and my mouse just stopps for 1-2 seconds. It is just annoying to work like that. My specs can be read on the bottom in my signature. Is that a bug because of ryzen cpu or something else? Would reinstalling solve this issue or should i just go back to sp2 somehow? Thanks
Room Finish Schedule - How to get Read out of wall areas
Kazemester replied to a topic in Architecture
@Silvano yeah...thanks. I figured that the space tool is ok for some cases, but it just can not be used as a powerful all capable BIM object. (for example calculating areas for room finishes...meh.) -
Let me quickly resurrect this topic...is there an answer? I see all the commands, but i can not see how can i list all my areas by the surfaces on the room finish schedule. Im still struggeling with that how can i exclude all windows and doors from a space so my wall areas are correctly calculated? Thanks.
