Andrew Mac Posted March 13, 2018 Share Posted March 13, 2018 When creating my window and door schedule, I number them 1- through the number of windows in the project. I start on the ground floor and typically go clockwise for the number sequence. then I go first and second floors. etc, etc. What happens when I decided to add a window late in the project stage after I have already created the window schedule? An example, I am adding a new window say on the 1st floor that is between windows 113 and 114. This new ow window I want to be window number to be 114 and all the remaining window number would then need to change up one. Is there an efficient way to change these windows numbers? Quote Link to comment
nrkuhl Posted March 13, 2018 Share Posted March 13, 2018 No. I'd make your new window 113.5 or something like that. Or add a letter as suffix. I also have my office number windows as "floor.window" so 3.5 for instance. Makes it a little easier to re-number if needed. Quote Link to comment
Jonathan Pickup Posted March 13, 2018 Share Posted March 13, 2018 windoor allows you to automatically re-number all the windows. I would like the standard window to be able to do that. 1 Quote Link to comment
Itchy Posted March 14, 2018 Share Posted March 14, 2018 If I have a job with a large number of windows/or doors, I will skip a number (ie. 9, 19, 29...) that way if later in the job a window needs to be added, it just takes up one of the spare numbers closest to it. With my number sequence I used to go clockwise as well on plan, but now go anti-clockwise. That way on elevations you view the numbers left to right counting up. 1 Quote Link to comment
Tom Klaber Posted March 15, 2018 Share Posted March 15, 2018 I have a different philosophy. I will renumber objects to keep things tidy in SD - but once the drawings go out - it is more confusing to have Window 114 refer to something new than it is to have numbers visually out of sequence in the plan. Late additions just get the first available number. I use letters to refer to types - so I can not do A.B - and the 113.5 is more confusing than a number out of sequence. I think having 113, 138, 114 is the best of bad choices. THere is also a paid plugin called Smart Sequencer I think that allows you to re-number - rename objects in your file. It is not perfect as it tries to gauge which object it should number next - but all - in - all I have been happy with it. 1 Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted March 16, 2018 Vectorworks, Inc Employee Share Posted March 16, 2018 I do concur with Tom, and if there is no issues on renumbering in DD and/or CD I would still update them, the clip shows the technic I would use HTH Last_Minute_Schedule_Update.mp4 1 Quote Link to comment
anton5 Posted May 31, 2018 Share Posted May 31, 2018 (edited) For large scheme development, I would suggest that standard practice for numbering of windows (and doors too), would be to use the following format: Bldg/Block (if more than one, say: A, B, C etc) - Window/Door (W/D) - Floor (01, 02, 03 etc) - Apartment number (01, 02, 03 etc) - Window/Door Number (01, 02, 03 etc), which would give you the below example: B-W-02-05-01 or W2-05-01 for short, or even W2.05.01 / W2.5.1 this makes adding / deleting windows (or doors) much easier later on if required. just a thought for a lovely grey Thursday 😉 Kind regards anton Edited May 31, 2018 by anton5 added information Quote Link to comment
Jonathan Pickup Posted May 31, 2018 Share Posted May 31, 2018 nice strategy anton5 Quote Link to comment
markdd Posted May 31, 2018 Share Posted May 31, 2018 (edited) If you still want to automatically number or re-number your windows, doors or anything else for that matter, there is a great utility by Josh Benghiat called Savvy Sequencer that does just this and a whole lot more on any plug-in object in Vectorworks Edited May 31, 2018 by markdd Quote Link to comment
anton5 Posted May 31, 2018 Share Posted May 31, 2018 Hi Markdd, Sounds fab ! Does this sequencer work with annotating Window numbers, while still keeping them as Window types / plugin objects? kind regards anton Quote Link to comment
markdd Posted May 31, 2018 Share Posted May 31, 2018 Absolutely. The objects stay exactly the same and you can choose which fields to change, add prefixes etc. Loads of functionality. Just tried it here for windows and doors and it works a treat. Josh’s plug-ins were initially aimed at the entertainment lighting market and most still are, but this one works for all disciplines within Vectorworks. There is a demo on his website. Quote Link to comment
anton5 Posted May 31, 2018 Share Posted May 31, 2018 great, sounds good. Looking at the webpage it seems only compatible with up to VW2015 however? Quote Link to comment
markdd Posted May 31, 2018 Share Posted May 31, 2018 (edited) Worked fine for me just now. Get the demo and try it out? Edited May 31, 2018 by markdd Quote Link to comment
anton5 Posted June 4, 2018 Share Posted June 4, 2018 Hi Mark, unfortunately the trial version requires VW 2013 to be able to install it, we are on VW 2016-2018, so it won't even open up hm. I emailed the developer on his site, but no reply yet. kind regards anton Quote Link to comment
